root/radiance/ray/src/rt/rtmain.c
Revision: 2.58
Committed: Tue Apr 22 17:12:25 2025 UTC (2 weeks, 4 days ago) by greg
Changes since 2.57: +4 -1 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.58 static const char RCSid[] = "$Id: rtmain.c,v 2.57 2025/03/05 18:56:28 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * rtmain.c - main for rtrace per-ray calculation program
6     */
7
8 greg 2.2 #include "copyright.h"
9 greg 2.1
10 schorsch 2.4 #include <signal.h>
11
12     #include "platform.h"
13 schorsch 2.7 #include "rtprocess.h" /* getpid() */
14 schorsch 2.9 #include "resolu.h"
15 greg 2.1 #include "ray.h"
16 greg 2.58 #include "func.h"
17 greg 2.1 #include "source.h"
18     #include "ambient.h"
19     #include "random.h"
20     #include "paths.h"
21 greg 2.23 #include "pmapray.h"
22 greg 2.1
23 greg 2.18 extern char *progname; /* global argv[0] */
24
25 greg 2.1 /* persistent processes define */
26     #ifdef F_SETLKW
27     #define PERSIST 1 /* normal persist */
28     #define PARALLEL 2 /* parallel persist */
29     #define PCHILD 3 /* child of normal persist */
30     #endif
31
32     char *sigerr[NSIG]; /* signal error messages */
33     char *errfile = NULL; /* error output file */
34
35 greg 2.18 int nproc = 1; /* number of processes */
36
37 greg 2.31 extern int setrtoutput(void); /* set output values */
38 greg 2.32
39 greg 2.18 int inform = 'a'; /* input format */
40     int outform = 'a'; /* output format */
41     char *outvals = "v"; /* output specification */
42 greg 2.1
43 greg 2.18 int hresolu = 0; /* horizontal (scan) size */
44     int vresolu = 0; /* vertical resolution */
45 greg 2.1
46 greg 2.33 extern int castonly; /* only doing ray-casting? */
47 greg 2.32
48 greg 2.18 int imm_irrad = 0; /* compute immediate irradiance? */
49     int lim_dist = 0; /* limit distance? */
50
51     #ifndef MAXMODLIST
52     #define MAXMODLIST 1024 /* maximum modifiers we'll track */
53     #endif
54 greg 2.1
55 greg 2.18 extern void (*addobjnotify[])(); /* object notification calls */
56     extern void tranotify(OBJECT obj);
57
58     char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
59     int traincl = -1; /* include == 1, exclude == 0 */
60 greg 2.1
61 greg 2.54 double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */
62 greg 2.47 double out_scalefactor = 1; /* output calibration scale factor */
63     RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */
64     static RGBPRIMS our_prims; /* private output color primitives */
65
66 greg 2.10 static int loadflags = ~IO_FILES; /* what to load from octree */
67
68 schorsch 2.9 static void onsig(int signo);
69     static void sigdie(int signo, char *msg);
70     static void printdefaults(void);
71 greg 2.1
72 greg 2.38 #ifdef PERSIST
73 greg 2.45 #define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \
74 greg 2.38 "IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \
75 greg 2.48 "ParticipatingMedia=Mist\n" \
76 greg 2.39 "HessianAmbientCache\nAmbientAveraging\n" \
77 greg 2.40 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
78 greg 2.45 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
79 greg 2.51 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \
80     "OutputCS=RGB,XYZ,Y,S,M,prims,spec\n"
81 greg 2.38 #else
82     #define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \
83 greg 2.48 "ParticipatingMedia=Mist\n" \
84 greg 2.39 "HessianAmbientCache\nAmbientAveraging\n" \
85 greg 2.40 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
86 greg 2.45 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
87 greg 2.52 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \
88 greg 2.51 "OutputCS=RGB,XYZ,Y,S,M,prims,spec\n"
89 greg 2.38 #endif
90
91 greg 2.1
92     int
93 schorsch 2.9 main(int argc, char *argv[])
94 greg 2.1 {
95     #define check(ol,al) if (argv[i][ol] || \
96     badarg(argc-i-1,argv+i+1,al)) \
97     goto badopt
98 schorsch 2.26 #define check_bool(olen,var) switch (argv[i][olen]) { \
99 greg 2.1 case '\0': var = !var; break; \
100     case 'y': case 'Y': case 't': case 'T': \
101     case '+': case '1': var = 1; break; \
102     case 'n': case 'N': case 'f': case 'F': \
103     case '-': case '0': var = 0; break; \
104     default: goto badopt; }
105 greg 2.25 extern char *octname;
106 greg 2.1 int persist = 0;
107 greg 2.18 char *octnm = NULL;
108 greg 2.22 char **tralp = NULL;
109     int duped1 = -1;
110 greg 2.1 int rval;
111     int i;
112     /* global program name */
113     progname = argv[0] = fixargv0(argv[0]);
114 greg 2.38 /* feature check only? */
115     strcat(RFeatureList, RTRACE_FEATURES);
116 greg 2.43 if (argc > 1 && !strcmp(argv[1], "-features"))
117 greg 2.38 return feature_status(argc-2, argv+2);
118 greg 2.58 /* initialize calcomp routines */
119     initfunc();
120 greg 2.18 /* add trace notify function */
121     for (i = 0; addobjnotify[i] != NULL; i++)
122     ;
123     addobjnotify[i] = tranotify;
124 greg 2.1 /* option city */
125     for (i = 1; i < argc; i++) {
126     /* expand arguments */
127     while ((rval = expandarg(&argc, &argv, i)) > 0)
128     ;
129     if (rval < 0) {
130     sprintf(errmsg, "cannot expand '%s'", argv[i]);
131     error(SYSTEM, errmsg);
132     }
133     if (argv[i] == NULL || argv[i][0] != '-')
134     break; /* break from options */
135     if (!strcmp(argv[i], "-version")) {
136     puts(VersionID);
137     quit(0);
138     }
139     if (!strcmp(argv[i], "-defaults") ||
140     !strcmp(argv[i], "-help")) {
141     printdefaults();
142     quit(0);
143     }
144     rval = getrenderopt(argc-i, argv+i);
145     if (rval >= 0) {
146     i += rval;
147     continue;
148     }
149     switch (argv[i][1]) {
150 greg 2.18 case 'n': /* number of cores */
151     check(2,"i");
152     nproc = atoi(argv[++i]);
153     if (nproc <= 0)
154     error(USER, "bad number of processes");
155     break;
156 greg 2.1 case 'x': /* x resolution */
157     check(2,"i");
158     hresolu = atoi(argv[++i]);
159     break;
160     case 'y': /* y resolution */
161     check(2,"i");
162     vresolu = atoi(argv[++i]);
163     break;
164 greg 2.47 case 'w': /* warnings & spectral */
165 greg 2.1 rval = erract[WARNING].pf != NULL;
166 schorsch 2.26 check_bool(2,rval);
167 greg 2.1 if (rval) erract[WARNING].pf = wputs;
168     else erract[WARNING].pf = NULL;
169     break;
170     case 'e': /* error file */
171     check(2,"s");
172     errfile = argv[++i];
173     break;
174     case 'l': /* limit distance */
175     if (argv[i][2] != 'd')
176     goto badopt;
177 schorsch 2.26 check_bool(3,lim_dist);
178 greg 2.1 break;
179     case 'I': /* immed. irradiance */
180 schorsch 2.26 check_bool(2,imm_irrad);
181 greg 2.1 break;
182     case 'f': /* format i/o */
183     switch (argv[i][2]) {
184     case 'a': /* ascii */
185     case 'f': /* float */
186     case 'd': /* double */
187     inform = argv[i][2];
188     break;
189     default:
190     goto badopt;
191     }
192     switch (argv[i][3]) {
193     case '\0':
194     outform = inform;
195     break;
196     case 'a': /* ascii */
197     case 'f': /* float */
198     case 'd': /* double */
199     case 'c': /* color */
200     check(4,"");
201     outform = argv[i][3];
202     break;
203     default:
204     goto badopt;
205     }
206     break;
207     case 'o': /* output */
208     outvals = argv[i]+2;
209     break;
210     case 'h': /* header output */
211     rval = loadflags & IO_INFO;
212 schorsch 2.26 check_bool(2,rval);
213 greg 2.1 loadflags = rval ? loadflags | IO_INFO :
214     loadflags & ~IO_INFO;
215     break;
216     case 't': /* trace */
217     switch (argv[i][2]) {
218     case 'i': /* include */
219     case 'I':
220     check(3,"s");
221     if (traincl != 1) {
222     traincl = 1;
223     tralp = tralist;
224     }
225     if (argv[i][2] == 'I') { /* file */
226 greg 2.27 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
227 greg 2.3 getpath(argv[++i],getrlibpath(),R_OK));
228 greg 2.1 if (rval < 0) {
229     sprintf(errmsg,
230     "cannot open trace include file \"%s\"",
231     argv[i]);
232     error(SYSTEM, errmsg);
233     }
234     tralp += rval;
235     } else {
236     *tralp++ = argv[++i];
237     *tralp = NULL;
238     }
239     break;
240     case 'e': /* exclude */
241     case 'E':
242     check(3,"s");
243     if (traincl != 0) {
244     traincl = 0;
245     tralp = tralist;
246     }
247     if (argv[i][2] == 'E') { /* file */
248 greg 2.27 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
249 greg 2.3 getpath(argv[++i],getrlibpath(),R_OK));
250 greg 2.1 if (rval < 0) {
251     sprintf(errmsg,
252     "cannot open trace exclude file \"%s\"",
253     argv[i]);
254     error(SYSTEM, errmsg);
255     }
256     tralp += rval;
257     } else {
258     *tralp++ = argv[++i];
259     *tralp = NULL;
260     }
261     break;
262     default:
263     goto badopt;
264     }
265     break;
266 greg 2.47 case 'p': /* value output */
267     switch (argv[i][2]) {
268     case 'R': /* standard RGB output */
269     if (strcmp(argv[i]+2, "RGB"))
270     goto badopt;
271     out_prims = stdprims;
272     out_scalefactor = 1;
273     sens_curve = NULL;
274     break;
275     case 'X': /* XYZ output */
276     if (strcmp(argv[i]+2, "XYZ"))
277     goto badopt;
278     out_prims = xyzprims;
279     out_scalefactor = WHTEFFICACY;
280     sens_curve = NULL;
281     break;
282     case 'c': {
283     int j;
284     check(3,"ffffffff");
285     rval = 0;
286     for (j = 0; j < 8; j++) {
287     our_prims[0][j] = atof(argv[++i]);
288     rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
289     }
290     if (rval) {
291     if (!colorprimsOK(our_prims))
292     error(USER, "illegal primary chromaticities");
293     out_prims = our_prims;
294     } else
295     out_prims = stdprims;
296     out_scalefactor = 1;
297     sens_curve = NULL;
298     } break;
299     case 'Y': /* photopic response */
300 greg 2.50 if (argv[i][3])
301     goto badopt;
302 greg 2.47 sens_curve = scolor_photopic;
303     out_scalefactor = WHTEFFICACY;
304     break;
305     case 'S': /* scotopic response */
306 greg 2.50 if (argv[i][3])
307     goto badopt;
308 greg 2.47 sens_curve = scolor_scotopic;
309     out_scalefactor = WHTSCOTOPIC;
310     break;
311     case 'M': /* melanopic response */
312 greg 2.50 if (argv[i][3])
313     goto badopt;
314 greg 2.47 sens_curve = scolor_melanopic;
315     out_scalefactor = WHTMELANOPIC;
316     break;
317     default:
318     goto badopt;
319     }
320     break;
321     #if MAXCSAMP>3
322 greg 2.48 case 'c': /* output spectral results */
323     if (argv[i][2] != 'o')
324 greg 2.47 goto badopt;
325 greg 2.49 rval = (out_prims == NULL) & (sens_curve == NULL);
326 greg 2.48 check_bool(3,rval);
327 greg 2.49 if (rval) {
328     out_prims = NULL;
329     sens_curve = NULL;
330     } else if (out_prims == NULL)
331     out_prims = stdprims;
332 greg 2.47 break;
333     #endif
334 greg 2.1 #ifdef PERSIST
335     case 'P': /* persist file */
336     if (argv[i][2] == 'P') {
337     check(3,"s");
338     persist = PARALLEL;
339     } else {
340     check(2,"s");
341     persist = PERSIST;
342     }
343     persistfile(argv[++i]);
344     break;
345     #endif
346     default:
347     goto badopt;
348     }
349     }
350 greg 2.47 /* set/check spectral sampling */
351     rval = setspectrsamp(CNDX, WLPART);
352     if (rval < 0)
353     error(USER, "unsupported spectral sampling");
354 greg 2.57 if (sens_curve != NULL)
355     out_prims = NULL;
356     else if (out_prims != NULL) {
357 greg 2.47 if (!rval)
358     error(WARNING, "spectral range incompatible with color output");
359     } else if (NCSAMP == 3)
360     out_prims = stdprims; /* 3 samples do not a spectrum make */
361 greg 2.34 if (nproc > 1 && persist)
362     error(USER, "multiprocessing incompatible with persist file");
363 greg 2.1 /* initialize object types */
364     initotypes();
365     /* initialize urand */
366 greg 2.14 if (rand_samp) {
367     srandom((long)time(0));
368     initurand(0);
369     } else {
370     srandom(0L);
371     initurand(2048);
372     }
373 greg 2.1 /* set up signal handling */
374     sigdie(SIGINT, "Interrupt");
375 schorsch 2.5 #ifdef SIGHUP
376 greg 2.1 sigdie(SIGHUP, "Hangup");
377 schorsch 2.5 #endif
378 greg 2.1 sigdie(SIGTERM, "Terminate");
379 schorsch 2.5 #ifdef SIGPIPE
380 greg 2.1 sigdie(SIGPIPE, "Broken pipe");
381 schorsch 2.5 #endif
382     #ifdef SIGALRM
383 greg 2.1 sigdie(SIGALRM, "Alarm clock");
384 schorsch 2.5 #endif
385 greg 2.1 #ifdef SIGXCPU
386     sigdie(SIGXCPU, "CPU limit exceeded");
387     sigdie(SIGXFSZ, "File size exceeded");
388     #endif
389     /* open error file */
390     if (errfile != NULL) {
391     if (freopen(errfile, "a", stderr) == NULL)
392     quit(2);
393     fprintf(stderr, "**************\n*** PID %5d: ",
394     getpid());
395     printargs(argc, argv, stderr);
396     putc('\n', stderr);
397     fflush(stderr);
398     }
399     #ifdef NICE
400     nice(NICE); /* lower priority */
401     #endif
402     /* get octree */
403     if (i == argc)
404 greg 2.18 octnm = NULL;
405 greg 2.1 else if (i == argc-1)
406 greg 2.18 octnm = argv[i];
407 greg 2.1 else
408     goto badopt;
409 greg 2.18 if (octnm == NULL)
410 greg 2.1 error(USER, "missing octree argument");
411     /* set up output */
412     #ifdef PERSIST
413     if (persist) {
414     duped1 = dup(fileno(stdout)); /* don't lose our output */
415     openheader();
416     }
417     #endif
418     if (outform != 'a')
419 schorsch 2.4 SET_FILE_BINARY(stdout);
420 greg 2.31 rval = setrtoutput();
421 greg 2.41 octname = savqstr(octnm);
422     readoct(octname, loadflags, &thescene, NULL);
423 greg 2.1 nsceneobjs = nobjects;
424
425     if (loadflags & IO_INFO) { /* print header */
426     printargs(i, argv, stdout);
427     printf("SOFTWARE= %s\n", VersionID);
428     fputnow(stdout);
429 greg 2.31 if (rval > 0) /* saved from setrtoutput() call */
430 greg 2.47 fputncomp(rval, stdout);
431     if (NCSAMP > 3)
432     fputwlsplit(WLPART, stdout);
433     if ((out_prims != stdprims) & (out_prims != NULL))
434     fputprims(out_prims, stdout);
435 greg 2.30 if ((outform == 'f') | (outform == 'd'))
436     fputendian(stdout);
437 greg 2.1 fputformat(formstr(outform), stdout);
438 greg 2.47 fputc('\n', stdout); /* end of header */
439 greg 2.1 }
440
441 greg 2.32 if (!castonly) { /* any actual ray traversal to do? */
442
443     ray_init_pmap(); /* PMAP: set up & load photon maps */
444
445     marksources(); /* find and mark sources */
446
447     setambient(); /* initialize ambient calculation */
448 greg 2.33 } else
449     distantsources(); /* else mark only distant sources */
450 greg 2.35
451 greg 2.36 fflush(stdout); /* in case we're duplicating header */
452 greg 2.35
453 greg 2.1 #ifdef PERSIST
454     if (persist) {
455     /* reconnect stdout */
456     dup2(duped1, fileno(stdout));
457     close(duped1);
458     if (persist == PARALLEL) { /* multiprocessing */
459 greg 2.55 cow_memshare(); /* preloads scene */
460 greg 2.1 while ((rval=fork()) == 0) { /* keep on forkin' */
461     pflock(1);
462     pfhold();
463 greg 2.15 ambsync(); /* load new values */
464 greg 2.1 }
465     if (rval < 0)
466     error(SYSTEM, "cannot fork child for persist function");
467 greg 2.15 pfdetach(); /* parent will run then exit */
468 greg 2.1 }
469     }
470     runagain:
471     if (persist)
472     dupheader(); /* send header to stdout */
473     #endif
474     /* trace rays */
475 greg 2.19 rtrace(NULL, nproc);
476 greg 2.1 /* flush ambient file */
477     ambsync();
478     #ifdef PERSIST
479     if (persist == PERSIST) { /* first run-through */
480     if ((rval=fork()) == 0) { /* child loops until killed */
481     pflock(1);
482     persist = PCHILD;
483     } else { /* original process exits */
484     if (rval < 0)
485     error(SYSTEM, "cannot fork child for persist function");
486     pfdetach(); /* parent exits */
487     }
488     }
489     if (persist == PCHILD) { /* wait for a signal then go again */
490     pfhold();
491     raynum = nrays = 0; /* reinitialize */
492     goto runagain;
493     }
494     #endif
495 greg 2.23
496     ray_done_pmap(); /* PMAP: free photon maps */
497
498 greg 2.1 quit(0);
499
500     badopt:
501     sprintf(errmsg, "command line error at '%s'", argv[i]);
502     error(USER, errmsg);
503 schorsch 2.9 return 1; /* pro forma return */
504 greg 2.1
505     #undef check
506 schorsch 2.26 #undef check_bool
507 greg 2.1 }
508
509
510     void
511 schorsch 2.9 wputs( /* warning output function */
512 greg 2.44 const char *s
513 schorsch 2.9 )
514 greg 2.1 {
515     int lasterrno = errno;
516 greg 2.56 if (erract[WARNING].pf == NULL)
517     return; /* called by calcomp or someone */
518 greg 2.1 eputs(s);
519     errno = lasterrno;
520     }
521
522
523     void
524 schorsch 2.9 eputs( /* put string to stderr */
525 greg 2.44 const char *s
526 schorsch 2.9 )
527 greg 2.1 {
528     static int midline = 0;
529
530     if (!*s)
531     return;
532     if (!midline++) {
533     fputs(progname, stderr);
534     fputs(": ", stderr);
535     }
536     fputs(s, stderr);
537     if (s[strlen(s)-1] == '\n') {
538     fflush(stderr);
539     midline = 0;
540     }
541     }
542
543
544 schorsch 2.9 static void
545     onsig( /* fatal signal */
546     int signo
547     )
548 greg 2.1 {
549     static int gotsig = 0;
550
551     if (gotsig++) /* two signals and we're gone! */
552     _exit(signo);
553
554 schorsch 2.5 #ifdef SIGALRM
555 greg 2.1 alarm(15); /* allow 15 seconds to clean up */
556     signal(SIGALRM, SIG_DFL); /* make certain we do die */
557 schorsch 2.5 #endif
558 greg 2.1 eputs("signal - ");
559     eputs(sigerr[signo]);
560     eputs("\n");
561     quit(3);
562     }
563
564
565 schorsch 2.9 static void
566     sigdie( /* set fatal signal */
567     int signo,
568     char *msg
569     )
570 greg 2.1 {
571     if (signal(signo, onsig) == SIG_IGN)
572     signal(signo, SIG_IGN);
573     sigerr[signo] = msg;
574     }
575
576
577 schorsch 2.9 static void
578 schorsch 2.8 printdefaults(void) /* print default values to stdout */
579 greg 2.1 {
580 greg 2.38 char *cp;
581 greg 2.1
582 greg 2.49 printf(erract[WARNING].pf != NULL ?
583     "-w+\t\t\t\t# warning messages on\n" :
584     "-w-\t\t\t\t# warning messages off\n");
585 greg 2.1 if (imm_irrad)
586     printf("-I+\t\t\t\t# immediate irradiance on\n");
587 greg 2.18 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
588 greg 2.21 printf("-x %-9d\t\t\t# %s\n", hresolu,
589     vresolu && hresolu ? "x resolution" : "flush interval");
590 greg 2.16 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
591 greg 2.1 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
592     "-ld-\t\t\t\t# limit distance off\n");
593 greg 2.47 printf(loadflags & IO_INFO ? "-h+\t\t\t\t# output header\n" :
594     "-h-\t\t\t\t# no header\n");
595 greg 2.1 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
596     inform, outform, formstr(inform), formstr(outform));
597 greg 2.10 printf("-o%-9s\t\t\t# output", outvals);
598 greg 2.1 for (cp = outvals; *cp; cp++)
599     switch (*cp) {
600 greg 2.10 case 't': case 'T': printf(" trace"); break;
601 greg 2.1 case 'o': printf(" origin"); break;
602     case 'd': printf(" direction"); break;
603 greg 2.28 case 'r': printf(" reflect_contrib"); break;
604     case 'R': printf(" reflect_length"); break;
605     case 'x': printf(" unreflect_contrib"); break;
606     case 'X': printf(" unreflect_length"); break;
607 greg 2.1 case 'v': printf(" value"); break;
608 greg 2.13 case 'V': printf(" contribution"); break;
609 greg 2.1 case 'l': printf(" length"); break;
610     case 'L': printf(" first_length"); break;
611     case 'p': printf(" point"); break;
612     case 'n': printf(" normal"); break;
613     case 'N': printf(" unperturbed_normal"); break;
614     case 's': printf(" surface"); break;
615     case 'w': printf(" weight"); break;
616 greg 2.13 case 'W': printf(" coefficient"); break;
617 greg 2.1 case 'm': printf(" modifier"); break;
618 greg 2.10 case 'M': printf(" material"); break;
619 greg 2.37 case '~': printf(" tilde"); break;
620 greg 2.1 }
621 greg 2.47 fputc('\n', stdout);
622     if (sens_curve == scolor_photopic)
623     printf("-pY\t\t\t\t# photopic output\n");
624     else if (sens_curve == scolor_scotopic)
625     printf("-pS\t\t\t\t# scotopic output\n");
626     else if (sens_curve == scolor_melanopic)
627     printf("-pM\t\t\t\t# melanopic output\n");
628     else if (out_prims == stdprims)
629     printf("-pRGB\t\t\t\t# standard RGB color output\n");
630     else if (out_prims == xyzprims)
631     printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
632     else if (out_prims != NULL)
633     printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
634     out_prims[RED][0], out_prims[RED][1],
635     out_prims[GRN][0], out_prims[GRN][1],
636     out_prims[BLU][0], out_prims[BLU][1],
637     out_prims[WHT][0], out_prims[WHT][1]);
638 greg 2.53 if ((sens_curve == NULL) & (NCSAMP > 3))
639 greg 2.49 printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
640     "-co+\t\t\t\t# output spectral values\n");
641 greg 2.1 print_rdefaults();
642     }
