root/radiance/ray/src/rt/rtmain.c
Revision: 2.44
Committed: Mon Feb 6 22:40:21 2023 UTC (2 years, 4 months ago) by greg
Changes since 2.43: +3 -4 lines
2 static const char RCSid[] = "$Id: rtmain.c,v 2.43 2023/02/06 20:37:06 greg Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "rtprocess.h" /* getpid() */
14 #include "resolu.h"
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "pmapray.h"
21
22 extern char *progname; /* global argv[0] */
23
24 extern char *shm_boundary; /* boundary of shared memory */
25
26 /* persistent processes define */
27 #ifdef F_SETLKW
28 #define PERSIST 1 /* normal persist */
29 #define PARALLEL 2 /* parallel persist */
30 #define PCHILD 3 /* child of normal persist */
31 #endif
32
33 char *sigerr[NSIG]; /* signal error messages */
34 char *errfile = NULL; /* error output file */
35
36 int nproc = 1; /* number of processes */
37
38 extern int setrtoutput(void); /* set output values */
39
40 int inform = 'a'; /* input format */
41 int outform = 'a'; /* output format */
42 char *outvals = "v"; /* output specification */
43
44 int hresolu = 0; /* horizontal (scan) size */
45 int vresolu = 0; /* vertical resolution */
46
47 extern int castonly; /* only doing ray-casting? */
48
49 int imm_irrad = 0; /* compute immediate irradiance? */
50 int lim_dist = 0; /* limit distance? */
51
52 #ifndef MAXMODLIST
53 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
54 #endif
55
56 extern void (*addobjnotify[])(); /* object notification calls */
57 extern void tranotify(OBJECT obj);
58
59 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
60 int traincl = -1; /* include == 1, exclude == 0 */
61
62 static int loadflags = ~IO_FILES; /* what to load from octree */
63
64 static void onsig(int signo);
65 static void sigdie(int signo, char *msg);
66 static void printdefaults(void);
67
68 #ifdef PERSIST
69 #define RTRACE_FEATURES "Persist\nParallelPersist\nMultiProcessing\n" \
70 "IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \
71 "HessianAmbientCache\nAmbientAveraging\n" \
72 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
73 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n"
74 #else
75 #define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \
76 "HessianAmbientCache\nAmbientAveraging\n" \
77 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
78 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n"
79 #endif
80
81
82 int
83 main(int argc, char *argv[])
84 {
85 #define check(ol,al) if (argv[i][ol] || \
86 badarg(argc-i-1,argv+i+1,al)) \
87 goto badopt
88 #define check_bool(olen,var) switch (argv[i][olen]) { \
89 case '\0': var = !var; break; \
90 case 'y': case 'Y': case 't': case 'T': \
91 case '+': case '1': var = 1; break; \
92 case 'n': case 'N': case 'f': case 'F': \
93 case '-': case '0': var = 0; break; \
94 default: goto badopt; }
95 extern char *octname;
96 int persist = 0;
97 char *octnm = NULL;
98 char **tralp = NULL;
99 int duped1 = -1;
100 int rval;
101 int i;
102 /* global program name */
103 progname = argv[0] = fixargv0(argv[0]);
104 /* feature check only? */
105 strcat(RFeatureList, RTRACE_FEATURES);
106 if (argc > 1 && !strcmp(argv[1], "-features"))
107 return feature_status(argc-2, argv+2);
108 /* add trace notify function */
109 for (i = 0; addobjnotify[i] != NULL; i++)
110 ;
111 addobjnotify[i] = tranotify;
112 /* option city */
113 for (i = 1; i < argc; i++) {
114 /* expand arguments */
115 while ((rval = expandarg(&argc, &argv, i)) > 0)
116 ;
117 if (rval < 0) {
118 sprintf(errmsg, "cannot expand '%s'", argv[i]);
119 error(SYSTEM, errmsg);
120 }
121 if (argv[i] == NULL || argv[i][0] != '-')
122 break; /* break from options */
123 if (!strcmp(argv[i], "-version")) {
124 puts(VersionID);
125 quit(0);
126 }
127 if (!strcmp(argv[i], "-defaults") ||
128 !strcmp(argv[i], "-help")) {
129 printdefaults();
130 quit(0);
131 }
132 rval = getrenderopt(argc-i, argv+i);
133 if (rval >= 0) {
134 i += rval;
135 continue;
136 }
137 switch (argv[i][1]) {
138 case 'n': /* number of cores */
139 check(2,"i");
140 nproc = atoi(argv[++i]);
141 if (nproc <= 0)
142 error(USER, "bad number of processes");
143 break;
144 case 'x': /* x resolution */
145 check(2,"i");
146 hresolu = atoi(argv[++i]);
147 break;
148 case 'y': /* y resolution */
149 check(2,"i");
150 vresolu = atoi(argv[++i]);
151 break;
152 case 'w': /* warnings */
153 rval = erract[WARNING].pf != NULL;
154 check_bool(2,rval);
155 if (rval) erract[WARNING].pf = wputs;
156 else erract[WARNING].pf = NULL;
157 break;
158 case 'e': /* error file */
159 check(2,"s");
160 errfile = argv[++i];
161 break;
162 case 'l': /* limit distance */
163 if (argv[i][2] != 'd')
164 goto badopt;
165 check_bool(3,lim_dist);
166 break;
167 case 'I': /* immed. irradiance */
168 check_bool(2,imm_irrad);
169 break;
170 case 'f': /* format i/o */
171 switch (argv[i][2]) {
172 case 'a': /* ascii */
173 case 'f': /* float */
174 case 'd': /* double */
175 inform = argv[i][2];
176 break;
177 default:
178 goto badopt;
179 }
180 switch (argv[i][3]) {
181 case '\0':
182 outform = inform;
183 break;
184 case 'a': /* ascii */
185 case 'f': /* float */
186 case 'd': /* double */
187 case 'c': /* color */
188 check(4,"");
189 outform = argv[i][3];
190 break;
191 default:
192 goto badopt;
193 }
194 break;
195 case 'o': /* output */
196 outvals = argv[i]+2;
197 break;
198 case 'h': /* header output */
199 rval = loadflags & IO_INFO;
200 check_bool(2,rval);
201 loadflags = rval ? loadflags | IO_INFO :
202 loadflags & ~IO_INFO;
203 break;
204 case 't': /* trace */
205 switch (argv[i][2]) {
206 case 'i': /* include */
207 case 'I':
208 check(3,"s");
209 if (traincl != 1) {
210 traincl = 1;
211 tralp = tralist;
212 }
213 if (argv[i][2] == 'I') { /* file */
214 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
215 getpath(argv[++i],getrlibpath(),R_OK));
216 if (rval < 0) {
217 sprintf(errmsg,
218 "cannot open trace include file \"%s\"",
219 argv[i]);
220 error(SYSTEM, errmsg);
221 }
222 tralp += rval;
223 } else {
224 *tralp++ = argv[++i];
225 *tralp = NULL;
226 }
227 break;
228 case 'e': /* exclude */
229 case 'E':
230 check(3,"s");
231 if (traincl != 0) {
232 traincl = 0;
233 tralp = tralist;
234 }
235 if (argv[i][2] == 'E') { /* file */
236 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
237 getpath(argv[++i],getrlibpath(),R_OK));
238 if (rval < 0) {
239 sprintf(errmsg,
240 "cannot open trace exclude file \"%s\"",
241 argv[i]);
242 error(SYSTEM, errmsg);
243 }
244 tralp += rval;
245 } else {
246 *tralp++ = argv[++i];
247 *tralp = NULL;
248 }
249 break;
250 default:
251 goto badopt;
252 }
253 break;
254 #ifdef PERSIST
255 case 'P': /* persist file */
256 if (argv[i][2] == 'P') {
257 check(3,"s");
258 persist = PARALLEL;
259 } else {
260 check(2,"s");
261 persist = PERSIST;
262 }
263 persistfile(argv[++i]);
264 break;
265 #endif
266 default:
267 goto badopt;
268 }
269 }
270 if (nproc > 1 && persist)
271 error(USER, "multiprocessing incompatible with persist file");
272 /* initialize object types */
273 initotypes();
274 /* initialize urand */
275 if (rand_samp) {
276 srandom((long)time(0));
277 initurand(0);
278 } else {
279 srandom(0L);
280 initurand(2048);
281 }
282 /* set up signal handling */
283 sigdie(SIGINT, "Interrupt");
284 #ifdef SIGHUP
285 sigdie(SIGHUP, "Hangup");
286 #endif
287 sigdie(SIGTERM, "Terminate");
288 #ifdef SIGPIPE
289 sigdie(SIGPIPE, "Broken pipe");
290 #endif
291 #ifdef SIGALRM
292 sigdie(SIGALRM, "Alarm clock");
293 #endif
294 #ifdef SIGXCPU
295 sigdie(SIGXCPU, "CPU limit exceeded");
296 sigdie(SIGXFSZ, "File size exceeded");
297 #endif
298 /* open error file */
299 if (errfile != NULL) {
300 if (freopen(errfile, "a", stderr) == NULL)
301 quit(2);
302 fprintf(stderr, "**************\n*** PID %5d: ",
303 getpid());
304 printargs(argc, argv, stderr);
305 putc('\n', stderr);
306 fflush(stderr);
307 }
308 #ifdef NICE
309 nice(NICE); /* lower priority */
310 #endif
311 /* get octree */
312 if (i == argc)
313 octnm = NULL;
314 else if (i == argc-1)
315 octnm = argv[i];
316 else
317 goto badopt;
318 if (octnm == NULL)
319 error(USER, "missing octree argument");
320 /* set up output */
321 #ifdef PERSIST
322 if (persist) {
323 duped1 = dup(fileno(stdout)); /* don't lose our output */
324 openheader();
325 }
326 #endif
327 if (outform != 'a')
328 SET_FILE_BINARY(stdout);
329 rval = setrtoutput();
330 octname = savqstr(octnm);
331 readoct(octname, loadflags, &thescene, NULL);
332 nsceneobjs = nobjects;
333
334 if (loadflags & IO_INFO) { /* print header */
335 printargs(i, argv, stdout);
336 printf("SOFTWARE= %s\n", VersionID);
337 fputnow(stdout);
338 if (rval > 0) /* saved from setrtoutput() call */
339 printf("NCOMP=%d\n", rval);
340 if ((outform == 'f') | (outform == 'd'))
341 fputendian(stdout);
342 fputformat(formstr(outform), stdout);
343 putchar('\n');
344 }
345
346 if (!castonly) { /* any actual ray traversal to do? */
347
348 ray_init_pmap(); /* PMAP: set up & load photon maps */
349
350 marksources(); /* find and mark sources */
351
352 setambient(); /* initialize ambient calculation */
353 } else
354 distantsources(); /* else mark only distant sources */
355
356 fflush(stdout); /* in case we're duplicating header */
357
358 #ifdef PERSIST
359 if (persist) {
360 /* reconnect stdout */
361 dup2(duped1, fileno(stdout));
362 close(duped1);
363 if (persist == PARALLEL) { /* multiprocessing */
364 preload_objs(); /* preload scene */
365 shm_boundary = (char *)malloc(16);
366 strcpy(shm_boundary, "SHM_BOUNDARY");
367 while ((rval=fork()) == 0) { /* keep on forkin' */
368 pflock(1);
369 pfhold();
370 ambsync(); /* load new values */
371 }
372 if (rval < 0)
373 error(SYSTEM, "cannot fork child for persist function");
374 pfdetach(); /* parent will run then exit */
375 }
376 }
377 runagain:
378 if (persist)
379 dupheader(); /* send header to stdout */
380 #endif
381 /* trace rays */
382 rtrace(NULL, nproc);
383 /* flush ambient file */
384 ambsync();
385 #ifdef PERSIST
386 if (persist == PERSIST) { /* first run-through */
387 if ((rval=fork()) == 0) { /* child loops until killed */
388 pflock(1);
389 persist = PCHILD;
390 } else { /* original process exits */
391 if (rval < 0)
392 error(SYSTEM, "cannot fork child for persist function");
393 pfdetach(); /* parent exits */
394 }
395 }
396 if (persist == PCHILD) { /* wait for a signal then go again */
397 pfhold();
398 raynum = nrays = 0; /* reinitialize */
399 goto runagain;
400 }
401 #endif
402
403 ray_done_pmap(); /* PMAP: free photon maps */
404
405 quit(0);
406
407 badopt:
408 sprintf(errmsg, "command line error at '%s'", argv[i]);
409 error(USER, errmsg);
410 return 1; /* pro forma return */
411
412 #undef check
413 #undef check_bool
414 }
415
416
417 void
418 wputs( /* warning output function */
419 const char *s
420 )
421 {
422 int lasterrno = errno;
423 eputs(s);
424 errno = lasterrno;
425 }
426
427
428 void
429 eputs( /* put string to stderr */
430 const char *s
431 )
432 {
433 static int midline = 0;
434
435 if (!*s)
436 return;
437 if (!midline++) {
438 fputs(progname, stderr);
439 fputs(": ", stderr);
440 }
441 fputs(s, stderr);
442 if (s[strlen(s)-1] == '\n') {
443 fflush(stderr);
444 midline = 0;
445 }
446 }
447
448
449 static void
450 onsig( /* fatal signal */
451 int signo
452 )
453 {
454 static int gotsig = 0;
455
456 if (gotsig++) /* two signals and we're gone! */
457 _exit(signo);
458
459 #ifdef SIGALRM
460 alarm(15); /* allow 15 seconds to clean up */
461 signal(SIGALRM, SIG_DFL); /* make certain we do die */
462 #endif
463 eputs("signal - ");
464 eputs(sigerr[signo]);
465 eputs("\n");
466 quit(3);
467 }
468
469
470 static void
471 sigdie( /* set fatal signal */
472 int signo,
473 char *msg
474 )
475 {
476 if (signal(signo, onsig) == SIG_IGN)
477 signal(signo, SIG_IGN);
478 sigerr[signo] = msg;
479 }
480
481
482 static void
483 printdefaults(void) /* print default values to stdout */
484 {
485 char *cp;
486
487 if (imm_irrad)
488 printf("-I+\t\t\t\t# immediate irradiance on\n");
489 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
490 printf("-x %-9d\t\t\t# %s\n", hresolu,
491 vresolu && hresolu ? "x resolution" : "flush interval");
492 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
493 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
494 "-ld-\t\t\t\t# limit distance off\n");
495 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
496 loadflags & IO_INFO ? "output" : "no");
497 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
498 inform, outform, formstr(inform), formstr(outform));
499 printf("-o%-9s\t\t\t# output", outvals);
500 for (cp = outvals; *cp; cp++)
501 switch (*cp) {
502 case 't': case 'T': printf(" trace"); break;
503 case 'o': printf(" origin"); break;
504 case 'd': printf(" direction"); break;
505 case 'r': printf(" reflect_contrib"); break;
506 case 'R': printf(" reflect_length"); break;
507 case 'x': printf(" unreflect_contrib"); break;
508 case 'X': printf(" unreflect_length"); break;
509 case 'v': printf(" value"); break;
510 case 'V': printf(" contribution"); break;
511 case 'l': printf(" length"); break;
512 case 'L': printf(" first_length"); break;
513 case 'p': printf(" point"); break;
514 case 'n': printf(" normal"); break;
515 case 'N': printf(" unperturbed_normal"); break;
516 case 's': printf(" surface"); break;
517 case 'w': printf(" weight"); break;
518 case 'W': printf(" coefficient"); break;
519 case 'm': printf(" modifier"); break;
520 case 'M': printf(" material"); break;
521 case '~': printf(" tilde"); break;
522 }
523 putchar('\n');
524 printf(erract[WARNING].pf != NULL ?
525 "-w+\t\t\t\t# warning messages on\n" :
526 "-w-\t\t\t\t# warning messages off\n");
527 print_rdefaults();
528 }
