root/radiance/ray/src/rt/rtmain.c
Fri Apr 18 18:06:29 2008 UTC (17 years ago) by greg
Diff to previous 2.15
Modified rtcontrib -c option to accumulate a specified number of rays
Thu Sep 13 20:02:11 2007 UTC (17 years, 7 months ago) by greg
Changes since 2.14: +3 -2 lines
Diff to previous 2.14
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (19 years, 1 month ago) by greg
Changes since 2.13: +8 -3 lines
Diff to previous 2.13
Made -u+ option truly random
Sun Feb 5 22:22:20 2006 UTC (19 years, 3 months ago) by greg
Diff to previous 2.12
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Wed Jun 15 15:36:52 2005 UTC (19 years, 10 months ago) by greg
Thu Jun 2 04:47:27 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.10: +1 -5 lines
Wed May 25 04:44:26 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.9: +11 -5 lines
Changes since 2.8: +23 -23 lines
Tue Oct 21 19:19:28 2003 UTC (21 years, 6 months ago) by schorsch
Mon Jul 14 20:02:30 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.6: +2 -4 lines
Mon Jun 30 14:59:12 2003 UTC (21 years, 10 months ago) by schorsch
Thu Jun 26 00:58:10 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.4: +9 -1 lines
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.3: +8 -11 lines
Tue May 13 17:58:33 2003 UTC (22 years ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
