root/radiance/ray/src/rt/rpmain.c
Revision: 2.9
Committed: Tue Jan 18 00:33:16 2005 UTC (20 years, 4 months ago) by greg
Changes since 2.8: +8 -1 lines
2 static const char RCSid[] = "$Id: rpmain.c,v 2.8 2004/03/30 16:13:01 schorsch Exp $";
5 * rpmain.c - main for rpict batch rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <sys/types.h>
11 #include <signal.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "view.h"
21
22 /* persistent processes define */
23 #ifdef F_SETLKW
24 #define PERSIST 1 /* normal persist */
25 #define PARALLEL 2 /* parallel persist */
26 #define PCHILD 3 /* child of normal persist */
27 #endif
28
29 char *progname; /* argv[0] */
30 char *octname; /* octree name */
31 char *sigerr[NSIG]; /* signal error messages */
32 char *shm_boundary = NULL; /* boundary of shared memory */
33 char *errfile = NULL; /* error output file */
34
35 extern time_t time();
36 extern time_t tstart; /* start time */
37
38 extern int ralrm; /* seconds between reports */
39
40 extern VIEW ourview; /* viewing parameters */
41
42 extern int hresolu; /* horizontal resolution */
43 extern int vresolu; /* vertical resolution */
44 extern double pixaspect; /* pixel aspect ratio */
45
46 extern int psample; /* pixel sample size */
47 extern double maxdiff; /* max. sample difference */
48 extern double dstrpix; /* square pixel distribution */
49
50 extern double mblur; /* motion blur parameter */
51
52 extern double dblur; /* depth-of-field blur parameter */
53
54 static void onsig(int signo);
55 static void sigdie(int signo, char *msg);
56 static void printdefaults(void);
57
58
59 int
60 main(int argc, char *argv[])
61 {
62 #define check(ol,al) if (argv[i][ol] || \
63 badarg(argc-i-1,argv+i+1,al)) \
64 goto badopt
65 #define bool(olen,var) switch (argv[i][olen]) { \
66 case '\0': var = !var; break; \
67 case 'y': case 'Y': case 't': case 'T': \
68 case '+': case '1': var = 1; break; \
69 case 'n': case 'N': case 'f': case 'F': \
70 case '-': case '0': var = 0; break; \
71 default: goto badopt; }
72 char *err;
73 char *recover = NULL;
74 char *outfile = NULL;
75 char *zfile = NULL;
76 int loadflags = ~IO_FILES;
77 int seqstart = 0;
78 int persist = 0;
79 int duped1;
80 int rval;
81 int i;
82 /* record start time */
83 tstart = time((time_t *)NULL);
84 /* global program name */
85 progname = argv[0] = fixargv0(argv[0]);
86 /* option city */
87 for (i = 1; i < argc; i++) {
88 /* expand arguments */
89 while ((rval = expandarg(&argc, &argv, i)) > 0)
90 ;
91 if (rval < 0) {
92 sprintf(errmsg, "cannot expand '%s'", argv[i]);
93 error(SYSTEM, errmsg);
94 }
95 if (argv[i] == NULL || argv[i][0] != '-')
96 break; /* break from options */
97 if (!strcmp(argv[i], "-version")) {
98 puts(VersionID);
99 quit(0);
100 }
101 if (!strcmp(argv[i], "-defaults") ||
102 !strcmp(argv[i], "-help")) {
103 printdefaults();
104 quit(0);
105 }
106 rval = getrenderopt(argc-i, argv+i);
107 if (rval >= 0) {
108 i += rval;
109 continue;
110 }
111 rval = getviewopt(&ourview, argc-i, argv+i);
112 if (rval >= 0) {
113 i += rval;
114 continue;
115 }
116 /* rpict options */
117 switch (argv[i][1]) {
118 case 'v': /* view file */
119 if (argv[i][2] != 'f')
120 goto badopt;
121 check(3,"s");
122 rval = viewfile(argv[++i], &ourview, NULL);
123 if (rval < 0) {
124 sprintf(errmsg,
125 "cannot open view file \"%s\"",
126 argv[i]);
127 error(SYSTEM, errmsg);
128 } else if (rval == 0) {
129 sprintf(errmsg,
130 "bad view file \"%s\"",
131 argv[i]);
132 error(USER, errmsg);
133 }
134 break;
135 case 'p': /* pixel */
136 switch (argv[i][2]) {
137 case 's': /* sample */
138 check(3,"i");
139 psample = atoi(argv[++i]);
140 break;
141 case 't': /* threshold */
142 check(3,"f");
143 maxdiff = atof(argv[++i]);
144 break;
145 case 'j': /* jitter */
146 check(3,"f");
147 dstrpix = atof(argv[++i]);
148 break;
149 case 'a': /* aspect */
150 check(3,"f");
151 pixaspect = atof(argv[++i]);
152 break;
153 case 'm': /* motion */
154 check(3,"f");
155 mblur = atof(argv[++i]);
156 break;
157 case 'd': /* aperture */
158 check(3,"f");
159 dblur = atof(argv[++i]);
160 break;
161 default:
162 goto badopt;
163 }
164 break;
165 case 'x': /* x resolution */
166 check(2,"i");
167 hresolu = atoi(argv[++i]);
168 break;
169 case 'y': /* y resolution */
170 check(2,"i");
171 vresolu = atoi(argv[++i]);
172 break;
173 case 'S': /* slave index */
174 check(2,"i");
175 seqstart = atoi(argv[++i]);
176 break;
177 case 'o': /* output file */
178 check(2,"s");
179 outfile = argv[++i];
180 break;
181 case 'z': /* z file */
182 check(2,"s");
183 zfile = argv[++i];
184 break;
185 case 'r': /* recover file */
186 if (argv[i][2] == 'o') { /* +output */
187 check(3,"s");
188 outfile = argv[i+1];
189 } else
190 check(2,"s");
191 recover = argv[++i];
192 break;
193 case 't': /* timer */
194 check(2,"i");
195 ralrm = atoi(argv[++i]);
196 break;
197 #ifdef PERSIST
198 case 'P': /* persist file */
199 if (argv[i][2] == 'P') {
200 check(3,"s");
201 persist = PARALLEL;
202 } else {
203 check(2,"s");
204 persist = PERSIST;
205 }
206 persistfile(argv[++i]);
207 break;
208 #endif
209 case 'w': /* warnings */
210 rval = erract[WARNING].pf != NULL;
211 bool(2,rval);
212 if (rval) erract[WARNING].pf = wputs;
213 else erract[WARNING].pf = NULL;
214 break;
215 case 'e': /* error file */
216 check(2,"s");
217 errfile = argv[++i];
218 break;
219 default:
220 goto badopt;
221 }
222 }
223 err = setview(&ourview); /* set viewing parameters */
224 if (err != NULL)
225 error(USER, err);
226 /* initialize object types */
227 initotypes();
228 /* initialize urand */
229 initurand(2048);
230 /* set up signal handling */
231 sigdie(SIGINT, "Interrupt");
232 #ifdef SIGHUP
233 sigdie(SIGHUP, "Hangup");
234 #endif
235 sigdie(SIGTERM, "Terminate");
236 #ifdef SIGPIPE
237 sigdie(SIGPIPE, "Broken pipe");
238 #endif
239 #ifdef SIGALRM
240 sigdie(SIGALRM, "Alarm clock");
241 #endif
242 #ifdef SIGXCPU
243 sigdie(SIGXCPU, "CPU limit exceeded");
244 sigdie(SIGXFSZ, "File size exceeded");
245 #endif
246 /* open error file */
247 if (errfile != NULL) {
248 if (freopen(errfile, "a", stderr) == NULL)
249 quit(2);
250 fprintf(stderr, "**************\n*** PID %5d: ",
251 getpid());
252 printargs(argc, argv, stderr);
253 putc('\n', stderr);
254 fflush(stderr);
255 }
256 #ifdef NICE
257 nice(NICE); /* lower priority */
258 #endif
259 /* get octree */
260 if (i == argc)
261 octname = NULL;
262 else if (i == argc-1)
263 octname = argv[i];
264 else
265 goto badopt;
266 if (seqstart > 0 && octname == NULL)
267 error(USER, "missing octree argument");
268 /* set up output */
269 #ifdef PERSIST
270 if (persist) {
271 if (recover != NULL)
272 error(USER, "persist option used with recover file");
273 if (seqstart <= 0)
274 error(USER, "persist option only for sequences");
275 if (outfile == NULL)
276 duped1 = dup(fileno(stdout)); /* don't lose our output */
277 openheader();
278 } else
279 #endif
280 if (outfile != NULL)
281 openheader();
282 #ifdef _WIN32
283 SET_FILE_BINARY(stdout);
284 if (octname == NULL)
285 SET_FILE_BINARY(stdin);
286 #endif
287 readoct(octname, loadflags, &thescene, NULL);
288 nsceneobjs = nobjects;
289
290 if (loadflags & IO_INFO) { /* print header */
291 printargs(i, argv, stdout);
292 printf("SOFTWARE= %s\n", VersionID);
293 }
294
295 marksources(); /* find and mark sources */
296
297 setambient(); /* initialize ambient calculation */
298
299 #ifdef PERSIST
300 if (persist) {
301 fflush(stdout);
302 if (outfile == NULL) { /* reconnect stdout */
303 dup2(duped1, fileno(stdout));
304 close(duped1);
305 }
306 if (persist == PARALLEL) { /* multiprocessing */
307 preload_objs(); /* preload scene */
308 shm_boundary = (char *)malloc(16);
309 strcpy(shm_boundary, "SHM_BOUNDARY");
310 while ((rval=fork()) == 0) { /* keep on forkin' */
311 pflock(1);
312 pfhold();
313 tstart = time((time_t *)NULL);
314 }
315 if (rval < 0)
316 error(SYSTEM, "cannot fork child for persist function");
317 pfdetach(); /* parent exits */
318 }
319 }
320 runagain:
321 if (persist) {
322 if (outfile == NULL) /* if out to stdout */
323 dupheader(); /* send header */
324 else /* if out to file */
325 duped1 = dup(fileno(stdout)); /* hang onto pipe */
326 }
327 #endif
328 /* batch render picture(s) */
329 rpict(seqstart, outfile, zfile, recover);
330 /* flush ambient file */
331 ambsync();
332 #ifdef PERSIST
333 if (persist == PERSIST) { /* first run-through */
334 if ((rval=fork()) == 0) { /* child loops until killed */
335 pflock(1);
336 persist = PCHILD;
337 } else { /* original process exits */
338 if (rval < 0)
339 error(SYSTEM, "cannot fork child for persist function");
340 pfdetach(); /* parent exits */
341 }
342 }
343 if (persist == PCHILD) { /* wait for a signal then go again */
344 if (outfile != NULL)
345 close(duped1); /* release output handle */
346 pfhold();
347 tstart = time((time_t *)NULL); /* reinitialize */
348 raynum = nrays = 0;
349 goto runagain;
350 }
351 #endif
352 quit(0);
353
354 badopt:
355 sprintf(errmsg, "command line error at '%s'", argv[i]);
356 error(USER, errmsg);
357 return 1; /* pro forma return */
358
359 #undef check
360 #undef bool
361 }
362
363
364 void
365 wputs( /* warning output function */
366 char *s
367 )
368 {
369 int lasterrno = errno;
370 eputs(s);
371 errno = lasterrno;
372 }
373
374
375 void
376 eputs( /* put string to stderr */
377 register char *s
378 )
379 {
380 static int midline = 0;
381
382 if (!*s)
383 return;
384 if (!midline++) {
385 fputs(progname, stderr);
386 fputs(": ", stderr);
387 }
388 fputs(s, stderr);
389 if (s[strlen(s)-1] == '\n') {
390 fflush(stderr);
391 midline = 0;
392 }
393 }
394
395
396 static void
397 onsig( /* fatal signal */
398 int signo
399 )
400 {
401 static int gotsig = 0;
402
403 if (gotsig++) /* two signals and we're gone! */
404 _exit(signo);
405
406 #ifdef SIGALRM /* XXX how critical is this? */
407 alarm(15); /* allow 15 seconds to clean up */
408 signal(SIGALRM, SIG_DFL); /* make certain we do die */
409 #endif
410 eputs("signal - ");
411 eputs(sigerr[signo]);
412 eputs("\n");
413 quit(3);
414 }
415
416
417 static void
418 sigdie( /* set fatal signal */
419 int signo,
420 char *msg
421 )
422 {
423 if (signal(signo, onsig) == SIG_IGN)
424 signal(signo, SIG_IGN);
425 sigerr[signo] = msg;
426 }
427
428
429 static void
430 printdefaults(void) /* print default values to stdout */
431 {
432 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
433 ourview.type==VT_PER ? "perspective" :
434 ourview.type==VT_PAR ? "parallel" :
435 ourview.type==VT_HEM ? "hemispherical" :
436 ourview.type==VT_ANG ? "angular" :
437 ourview.type==VT_CYL ? "cylindrical" :
438 "unknown");
439 printf("-vp %f %f %f\t# view point\n",
440 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
441 printf("-vd %f %f %f\t# view direction\n",
442 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
443 printf("-vu %f %f %f\t# view up\n",
444 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
445 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
446 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
447 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
448 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
449 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
450 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
451 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
452 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
453 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
454 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
455 printf("-pm %f\t\t\t# pixel motion\n", mblur);
456 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
457 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
458 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
459 printf("-t %-9d\t\t\t# time between reports\n", ralrm);
460 printf(erract[WARNING].pf != NULL ?
461 "-w+\t\t\t\t# warning messages on\n" :
462 "-w-\t\t\t\t# warning messages off\n");
463 print_rdefaults();
464 }
