root/radiance/ray/src/rt/rpmain.c
Revision: 2.38
Committed: Tue Apr 22 17:12:25 2025 UTC (2 weeks, 1 day ago) by greg
Changes since 2.37: +4 -1 lines
2 static const char RCSid[] = "$Id: rpmain.c,v 2.37 2025/01/18 03:49:00 greg Exp $";
5 * rpmain.c - main for rpict batch rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "ray.h"
16 #include "func.h"
17 #include "source.h"
18 #include "ambient.h"
19 #include "random.h"
20 #include "paths.h"
21 #include "view.h"
22 #include "pmapray.h"
23
24 /* persistent processes define */
25 #ifdef F_SETLKW
26 #define PERSIST 1 /* normal persist */
27 #define PARALLEL 2 /* parallel persist */
28 #define PCHILD 3 /* child of normal persist */
29 #endif
30
31 char *progname; /* argv[0] */
32 char *octname; /* octree name */
33 char *sigerr[NSIG]; /* signal error messages */
34 char *errfile = NULL; /* error output file */
35
36 extern time_t time();
37 extern time_t tstart; /* start time */
38
39 extern int ralrm; /* seconds between reports */
40
41 extern VIEW ourview; /* viewing parameters */
42
43 extern int hresolu; /* horizontal resolution */
44 extern int vresolu; /* vertical resolution */
45 extern double pixaspect; /* pixel aspect ratio */
46
47 extern int psample; /* pixel sample size */
48 extern double maxdiff; /* max. sample difference */
49 extern double dstrpix; /* square pixel distribution */
50
51 extern double mblur; /* motion blur parameter */
52
53 extern double dblur; /* depth-of-field blur parameter */
54
55 RGBPRIMP out_prims = stdprims; /* output color primitives */
56 static RGBPRIMS our_prims; /* private output color primitives */
57
58 static void onsig(int signo);
59 static void sigdie(int signo, char *msg);
60 static void printdefaults(void);
61 /* rpict additional features */
62 #ifdef PERSIST
63 #define RPICT_FEATURES "Persist\nParallelPersist\n" \
64 "ParticipatingMedia=Mist\n" \
65 "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
66 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
67 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
68 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
69 "AdaptiveShadowTesting\nOutputs=v,l\n" \
70 "OutputCS=RGB,XYZ,prims\n"
71 #else
72 #define RPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
73 "ParticipatingMedia=Mist\n" \
74 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
75 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
76 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
77 "AdaptiveShadowTesting\nOutputs=v,l\n" \
78 "OutputCS=RGB,XYZ,prims\n"
79 #endif
80
81
82 int
83 main(int argc, char *argv[])
84 {
85 #define check(ol,al) if (argv[i][ol] || \
86 badarg(argc-i-1,argv+i+1,al)) \
87 goto badopt
88 #define check_bool(olen,var) switch (argv[i][olen]) { \
89 case '\0': var = !var; break; \
90 case 'y': case 'Y': case 't': case 'T': \
91 case '+': case '1': var = 1; break; \
92 case 'n': case 'N': case 'f': case 'F': \
93 case '-': case '0': var = 0; break; \
94 default: goto badopt; }
95 char *err;
96 char *recover = NULL;
97 char *outfile = NULL;
98 char *zfile = NULL;
99 int loadflags = ~IO_FILES;
100 int seqstart = 0;
101 int persist = 0;
102 int duped1 = -1;
103 int rval;
104 int i;
105 /* record start time */
106 tstart = time((time_t *)NULL);
107 /* global program name */
108 progname = argv[0] = fixargv0(argv[0]);
109 /* feature check only? */
110 strcat(RFeatureList, RPICT_FEATURES);
111 if (argc > 1 && !strcmp(argv[1], "-features"))
112 return feature_status(argc-2, argv+2);
113 /* initialize calcomp routines */
114 initfunc();
115 /* option city */
116 for (i = 1; i < argc; i++) {
117 /* expand arguments */
118 while ((rval = expandarg(&argc, &argv, i)) > 0)
119 ;
120 if (rval < 0) {
121 sprintf(errmsg, "cannot expand '%s'", argv[i]);
122 error(SYSTEM, errmsg);
123 }
124 if (argv[i] == NULL || argv[i][0] != '-')
125 break; /* break from options */
126 if (!strcmp(argv[i], "-version")) {
127 puts(VersionID);
128 quit(0);
129 }
130 if (!strcmp(argv[i], "-defaults") ||
131 !strcmp(argv[i], "-help")) {
132 printdefaults();
133 quit(0);
134 }
135 rval = getrenderopt(argc-i, argv+i);
136 if (rval >= 0) {
137 i += rval;
138 continue;
139 }
140 rval = getviewopt(&ourview, argc-i, argv+i);
141 if (rval >= 0) {
142 i += rval;
143 continue;
144 }
145 /* rpict options */
146 switch (argv[i][1]) {
147 case 'v': /* view file */
148 if (argv[i][2] != 'f')
149 goto badopt;
150 check(3,"s");
151 rval = viewfile(argv[++i], &ourview, NULL);
152 if (rval < 0) {
153 sprintf(errmsg,
154 "cannot open view file \"%s\"",
155 argv[i]);
156 error(SYSTEM, errmsg);
157 } else if (rval == 0) {
158 sprintf(errmsg,
159 "bad view file \"%s\"",
160 argv[i]);
161 error(USER, errmsg);
162 }
163 break;
164 case 'p': /* pixel */
165 switch (argv[i][2]) {
166 case 's': /* sample */
167 check(3,"i");
168 psample = atoi(argv[++i]);
169 break;
170 case 't': /* threshold */
171 check(3,"f");
172 maxdiff = atof(argv[++i]);
173 break;
174 case 'j': /* jitter */
175 check(3,"f");
176 dstrpix = atof(argv[++i]);
177 break;
178 case 'a': /* aspect */
179 check(3,"f");
180 pixaspect = atof(argv[++i]);
181 break;
182 case 'm': /* motion */
183 check(3,"f");
184 mblur = atof(argv[++i]);
185 break;
186 case 'd': /* aperture */
187 check(3,"f");
188 dblur = atof(argv[++i]);
189 break;
190 case 'R': /* standard RGB output */
191 if (strcmp(argv[i]+2, "RGB"))
192 goto badopt;
193 out_prims = stdprims;
194 break;
195 case 'X': /* XYZ output */
196 if (strcmp(argv[i]+2, "XYZ"))
197 goto badopt;
198 out_prims = xyzprims;
199 break;
200 case 'c': { /* chromaticities */
201 int j;
202 check(3,"ffffffff");
203 rval = 0;
204 for (j = 0; j < 8; j++) {
205 our_prims[0][j] = atof(argv[++i]);
206 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
207 }
208 if (rval) {
209 if (!colorprimsOK(our_prims))
210 error(USER, "illegal primary chromaticities");
211 out_prims = our_prims;
212 } else
213 out_prims = stdprims;
214 } break;
215 default:
216 goto badopt;
217 }
218 break;
219 case 'x': /* x resolution */
220 check(2,"i");
221 hresolu = atoi(argv[++i]);
222 break;
223 case 'y': /* y resolution */
224 check(2,"i");
225 vresolu = atoi(argv[++i]);
226 break;
227 case 'S': /* slave index */
228 check(2,"i");
229 seqstart = atoi(argv[++i]);
230 break;
231 case 'o': /* output file */
232 check(2,"s");
233 outfile = argv[++i];
234 break;
235 case 'z': /* z file */
236 check(2,"s");
237 zfile = argv[++i];
238 break;
239 case 'r': /* recover file */
240 if (argv[i][2] == 'o') { /* +output */
241 check(3,"s");
242 outfile = argv[i+1];
243 } else
244 check(2,"s");
245 recover = argv[++i];
246 break;
247 #ifdef PERSIST
248 case 'P': /* persist file */
249 if (argv[i][2] == 'P') {
250 check(3,"s");
251 persist = PARALLEL;
252 } else {
253 check(2,"s");
254 persist = PERSIST;
255 }
256 persistfile(argv[++i]);
257 break;
258 #endif
259 case 't': /* timer */
260 check(2,"i");
261 ralrm = atoi(argv[++i]);
262 break;
263 case 'w': /* warnings */
264 rval = erract[WARNING].pf != NULL;
265 check_bool(2,rval);
266 if (rval) erract[WARNING].pf = wputs;
267 else erract[WARNING].pf = NULL;
268 break;
269 case 'e': /* error file */
270 check(2,"s");
271 errfile = argv[++i];
272 break;
273 default:
274 goto badopt;
275 }
276 }
277 /* set/check spectral sampling */
278 if (setspectrsamp(CNDX, WLPART) <= 0)
279 error(USER, "unsupported spectral sampling");
280
281 err = setview(&ourview); /* set viewing parameters */
282 if (err != NULL)
283 error(USER, err);
284 /* initialize object types */
285 initotypes();
286 /* initialize urand */
287 if (rand_samp) {
288 srandom((long)time(0));
289 initurand(0);
290 } else {
291 srandom(0L);
292 initurand(2048);
293 }
294 /* set up signal handling */
295 sigdie(SIGINT, "Interrupt");
296 #ifdef SIGHUP
297 sigdie(SIGHUP, "Hangup");
298 #endif
299 sigdie(SIGTERM, "Terminate");
300 #ifdef SIGPIPE
301 sigdie(SIGPIPE, "Broken pipe");
302 #endif
303 #ifdef SIGALRM
304 sigdie(SIGALRM, "Alarm clock");
305 #endif
306 #ifdef SIGXCPU
307 sigdie(SIGXCPU, "CPU limit exceeded");
308 sigdie(SIGXFSZ, "File size exceeded");
309 #endif
310 /* open error file */
311 if (errfile != NULL) {
312 if (freopen(errfile, "a", stderr) == NULL)
313 quit(2);
314 fprintf(stderr, "**************\n*** PID %5d: ",
315 getpid());
316 printargs(argc, argv, stderr);
317 putc('\n', stderr);
318 fflush(stderr);
319 }
320 #ifdef NICE
321 nice(NICE); /* lower priority */
322 #endif
323 /* get octree */
324 if (i == argc)
325 octname = NULL;
326 else if (i == argc-1)
327 octname = argv[i];
328 else
329 goto badopt;
330 if (seqstart > 0 && octname == NULL)
331 error(USER, "missing octree argument");
332 /* set up output */
333 #ifdef PERSIST
334 if (persist) {
335 if (recover != NULL)
336 error(USER, "persist option used with recover file");
337 if (seqstart <= 0)
338 error(USER, "persist option only for sequences");
339 if (outfile == NULL)
340 duped1 = dup(fileno(stdout)); /* don't lose our output */
341 openheader();
342 } else
343 #endif
344 if (outfile != NULL)
345 openheader();
346 SET_FILE_BINARY(stdout);
347 if (octname == NULL)
348 SET_FILE_BINARY(stdin);
349 readoct(octname, loadflags, &thescene, NULL);
350 nsceneobjs = nobjects;
351
352 if (loadflags & IO_INFO) { /* print header */
353 printargs(i, argv, stdout);
354 printf("SOFTWARE= %s\n", VersionID);
355 }
356
357 ray_init_pmap(); /* PMAP: set up & load photon maps */
358
359 marksources(); /* find and mark sources */
360 setambient(); /* initialize ambient calculation */
361
362 fflush(stdout); /* in case we're duplicating header */
363
364 #ifdef PERSIST
365 if (persist) {
366 if (outfile == NULL) { /* reconnect stdout */
367 dup2(duped1, fileno(stdout));
368 close(duped1);
369 }
370 if (persist == PARALLEL) { /* multiprocessing */
371 cow_memshare(); /* preloads scene */
372 while ((rval=fork()) == 0) { /* keep on forkin' */
373 pflock(1);
374 pfhold();
375 tstart = time((time_t *)NULL);
376 ambsync(); /* load new values */
377 }
378 if (rval < 0)
379 error(SYSTEM, "cannot fork child for persist function");
380 pfdetach(); /* parent will run then exit */
381 }
382 }
383 runagain:
384 if (persist) {
385 if (outfile == NULL) /* if out to stdout */
386 dupheader(); /* send header */
387 else /* if out to file */
388 duped1 = dup(fileno(stdout)); /* hang onto pipe */
389 }
390 #endif
391 /* batch render picture(s) */
392 rpict(seqstart, outfile, zfile, recover);
393 /* flush ambient file */
394 ambsync();
395 #ifdef PERSIST
396 if (persist == PERSIST) { /* first run-through */
397 if ((rval=fork()) == 0) { /* child loops until killed */
398 pflock(1);
399 persist = PCHILD;
400 } else { /* original process exits */
401 if (rval < 0)
402 error(SYSTEM, "cannot fork child for persist function");
403 pfdetach(); /* parent exits */
404 }
405 }
406 if (persist == PCHILD) { /* wait for a signal then go again */
407 if (outfile != NULL)
408 close(duped1); /* release output handle */
409 pfhold();
410 tstart = time((time_t *)NULL); /* reinitialize */
411 raynum = nrays = 0;
412 goto runagain;
413 }
414 #endif
415
416
417 ray_done_pmap(); /* PMAP: free photon maps */
418
419 quit(0);
420
421 badopt:
422 sprintf(errmsg, "command line error at '%s'", argv[i]);
423 error(USER, errmsg);
424 return 1; /* pro forma return */
425
426 #undef check
427 #undef check_bool
428 }
429
430
431 void
432 wputs( /* warning output function */
433 const char *s
434 )
435 {
436 int lasterrno = errno;
437 if (erract[WARNING].pf == NULL)
438 return; /* called by calcomp or someone */
439 eputs(s);
440 errno = lasterrno;
441 }
442
443
444 void
445 eputs( /* put string to stderr */
446 const char *s
447 )
448 {
449 static int midline = 0;
450
451 if (!*s)
452 return;
453 if (!midline++) {
454 fputs(progname, stderr);
455 fputs(": ", stderr);
456 }
457 fputs(s, stderr);
458 if (s[strlen(s)-1] == '\n') {
459 fflush(stderr);
460 midline = 0;
461 }
462 }
463
464
465 static void
466 onsig( /* fatal signal */
467 int signo
468 )
469 {
470 static int gotsig = 0;
471
472 if (gotsig++) /* two signals and we're gone! */
473 _exit(signo);
474
475 #ifdef SIGALRM /* XXX how critical is this? */
476 alarm(15); /* allow 15 seconds to clean up */
477 signal(SIGALRM, SIG_DFL); /* make certain we do die */
478 #endif
479 eputs("signal - ");
480 eputs(sigerr[signo]);
481 eputs("\n");
482 quit(3);
483 }
484
485
486 static void
487 sigdie( /* set fatal signal */
488 int signo,
489 char *msg
490 )
491 {
492 if (signal(signo, onsig) == SIG_IGN)
493 signal(signo, SIG_IGN);
494 sigerr[signo] = msg;
495 }
496
497
498 static void
499 printdefaults(void) /* print default values to stdout */
500 {
501 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
502 ourview.type==VT_PER ? "perspective" :
503 ourview.type==VT_PAR ? "parallel" :
504 ourview.type==VT_HEM ? "hemispherical" :
505 ourview.type==VT_ANG ? "angular" :
506 ourview.type==VT_CYL ? "cylindrical" :
507 ourview.type==VT_PLS ? "planisphere" :
508 "unknown");
509 printf("-vp %f %f %f\t# view point\n",
510 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
511 printf("-vd %f %f %f\t# view direction\n",
512 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
513 printf("-vu %f %f %f\t# view up\n",
514 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
515 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
516 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
517 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
518 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
519 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
520 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
521 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
522 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
523 if (out_prims == stdprims)
524 printf("-pRGB\t\t\t\t# standard RGB color output\n");
525 else if (out_prims == xyzprims)
526 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
527 else if (out_prims != NULL)
528 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
529 out_prims[RED][0], out_prims[RED][1],
530 out_prims[GRN][0], out_prims[GRN][1],
531 out_prims[BLU][0], out_prims[BLU][1],
532 out_prims[WHT][0], out_prims[WHT][1]);
533 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
534 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
535 printf("-pm %f\t\t\t# pixel motion\n", mblur);
536 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
537 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
538 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
539 printf("-t %-9d\t\t\t# time between reports\n", ralrm);
540 printf(erract[WARNING].pf != NULL ?
541 "-w+\t\t\t\t# warning messages on\n" :
542 "-w-\t\t\t\t# warning messages off\n");
543 print_rdefaults();
544 }
