root/radiance/ray/src/rt/rpmain.c
Revision: 2.34
Committed: Wed Aug 21 20:42:20 2024 UTC (10 months, 1 week ago) by greg
Changes since 2.33: +2 -5 lines
refactor: moved memory sharing routines to preload.c with common call interface
2 static const char RCSid[] = "$Id: rpmain.c,v 2.33 2024/04/08 17:08:15 greg Exp $";
5 * rpmain.c - main for rpict batch rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "view.h"
21 #include "pmapray.h"
22
23 /* persistent processes define */
24 #ifdef F_SETLKW
25 #define PERSIST 1 /* normal persist */
26 #define PARALLEL 2 /* parallel persist */
27 #define PCHILD 3 /* child of normal persist */
28 #endif
29
30 char *progname; /* argv[0] */
31 char *octname; /* octree name */
32 char *sigerr[NSIG]; /* signal error messages */
33 char *errfile = NULL; /* error output file */
34
35 extern time_t time();
36 extern time_t tstart; /* start time */
37
38 extern int ralrm; /* seconds between reports */
39
40 extern VIEW ourview; /* viewing parameters */
41
42 extern int hresolu; /* horizontal resolution */
43 extern int vresolu; /* vertical resolution */
44 extern double pixaspect; /* pixel aspect ratio */
45
46 extern int psample; /* pixel sample size */
47 extern double maxdiff; /* max. sample difference */
48 extern double dstrpix; /* square pixel distribution */
49
50 extern double mblur; /* motion blur parameter */
51
52 extern double dblur; /* depth-of-field blur parameter */
53
54 RGBPRIMP out_prims = stdprims; /* output color primitives */
55 static RGBPRIMS our_prims; /* private output color primitives */
56
57 static void onsig(int signo);
58 static void sigdie(int signo, char *msg);
59 static void printdefaults(void);
60 /* rpict additional features */
61 #ifdef PERSIST
62 #define RPICT_FEATURES "Persist\nParallelPersist\n" \
63 "ParticipatingMedia=Mist\n" \
64 "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
65 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
66 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
67 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
68 "AdaptiveShadowTesting\nOutputs=v,l\n" \
69 "OutputCS=RGB,XYZ,prims\n"
70 #else
71 #define RPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
72 "ParticipatingMedia=Mist\n" \
73 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
74 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
75 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
76 "AdaptiveShadowTesting\nOutputs=v,l\n" \
77 "OutputCS=RGB,XYZ,prims\n"
78 #endif
79
80
81 int
82 main(int argc, char *argv[])
83 {
84 #define check(ol,al) if (argv[i][ol] || \
85 badarg(argc-i-1,argv+i+1,al)) \
86 goto badopt
87 #define check_bool(olen,var) switch (argv[i][olen]) { \
88 case '\0': var = !var; break; \
89 case 'y': case 'Y': case 't': case 'T': \
90 case '+': case '1': var = 1; break; \
91 case 'n': case 'N': case 'f': case 'F': \
92 case '-': case '0': var = 0; break; \
93 default: goto badopt; }
94 char *err;
95 char *recover = NULL;
96 char *outfile = NULL;
97 char *zfile = NULL;
98 int loadflags = ~IO_FILES;
99 int seqstart = 0;
100 int persist = 0;
101 int duped1 = -1;
102 int rval;
103 int i;
104 /* record start time */
105 tstart = time((time_t *)NULL);
106 /* global program name */
107 progname = argv[0] = fixargv0(argv[0]);
108 /* feature check only? */
109 strcat(RFeatureList, RPICT_FEATURES);
110 if (argc > 1 && !strcmp(argv[1], "-features"))
111 return feature_status(argc-2, argv+2);
112 /* option city */
113 for (i = 1; i < argc; i++) {
114 /* expand arguments */
115 while ((rval = expandarg(&argc, &argv, i)) > 0)
116 ;
117 if (rval < 0) {
118 sprintf(errmsg, "cannot expand '%s'", argv[i]);
119 error(SYSTEM, errmsg);
120 }
121 if (argv[i] == NULL || argv[i][0] != '-')
122 break; /* break from options */
123 if (!strcmp(argv[i], "-version")) {
124 puts(VersionID);
125 quit(0);
126 }
127 if (!strcmp(argv[i], "-defaults") ||
128 !strcmp(argv[i], "-help")) {
129 printdefaults();
130 quit(0);
131 }
132 rval = getrenderopt(argc-i, argv+i);
133 if (rval >= 0) {
134 i += rval;
135 continue;
136 }
137 rval = getviewopt(&ourview, argc-i, argv+i);
138 if (rval >= 0) {
139 i += rval;
140 continue;
141 }
142 /* rpict options */
143 switch (argv[i][1]) {
144 case 'v': /* view file */
145 if (argv[i][2] != 'f')
146 goto badopt;
147 check(3,"s");
148 rval = viewfile(argv[++i], &ourview, NULL);
149 if (rval < 0) {
150 sprintf(errmsg,
151 "cannot open view file \"%s\"",
152 argv[i]);
153 error(SYSTEM, errmsg);
154 } else if (rval == 0) {
155 sprintf(errmsg,
156 "bad view file \"%s\"",
157 argv[i]);
158 error(USER, errmsg);
159 }
160 break;
161 case 'p': /* pixel */
162 switch (argv[i][2]) {
163 case 's': /* sample */
164 check(3,"i");
165 psample = atoi(argv[++i]);
166 break;
167 case 't': /* threshold */
168 check(3,"f");
169 maxdiff = atof(argv[++i]);
170 break;
171 case 'j': /* jitter */
172 check(3,"f");
173 dstrpix = atof(argv[++i]);
174 break;
175 case 'a': /* aspect */
176 check(3,"f");
177 pixaspect = atof(argv[++i]);
178 break;
179 case 'm': /* motion */
180 check(3,"f");
181 mblur = atof(argv[++i]);
182 break;
183 case 'd': /* aperture */
184 check(3,"f");
185 dblur = atof(argv[++i]);
186 break;
187 case 'R': /* standard RGB output */
188 if (strcmp(argv[i]+2, "RGB"))
189 goto badopt;
190 out_prims = stdprims;
191 break;
192 case 'X': /* XYZ output */
193 if (strcmp(argv[i]+2, "XYZ"))
194 goto badopt;
195 out_prims = xyzprims;
196 break;
197 case 'c': { /* chromaticities */
198 int j;
199 check(3,"ffffffff");
200 rval = 0;
201 for (j = 0; j < 8; j++) {
202 our_prims[0][j] = atof(argv[++i]);
203 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
204 }
205 if (rval) {
206 if (!colorprimsOK(our_prims))
207 error(USER, "illegal primary chromaticities");
208 out_prims = our_prims;
209 } else
210 out_prims = stdprims;
211 } break;
212 default:
213 goto badopt;
214 }
215 break;
216 case 'x': /* x resolution */
217 check(2,"i");
218 hresolu = atoi(argv[++i]);
219 break;
220 case 'y': /* y resolution */
221 check(2,"i");
222 vresolu = atoi(argv[++i]);
223 break;
224 case 'S': /* slave index */
225 check(2,"i");
226 seqstart = atoi(argv[++i]);
227 break;
228 case 'o': /* output file */
229 check(2,"s");
230 outfile = argv[++i];
231 break;
232 case 'z': /* z file */
233 check(2,"s");
234 zfile = argv[++i];
235 break;
236 case 'r': /* recover file */
237 if (argv[i][2] == 'o') { /* +output */
238 check(3,"s");
239 outfile = argv[i+1];
240 } else
241 check(2,"s");
242 recover = argv[++i];
243 break;
244 case 't': /* timer */
245 check(2,"i");
246 ralrm = atoi(argv[++i]);
247 break;
248 #ifdef PERSIST
249 case 'P': /* persist file */
250 if (argv[i][2] == 'P') {
251 check(3,"s");
252 persist = PARALLEL;
253 } else {
254 check(2,"s");
255 persist = PERSIST;
256 }
257 persistfile(argv[++i]);
258 break;
259 #endif
260 case 'w': /* warnings */
261 rval = erract[WARNING].pf != NULL;
262 check_bool(2,rval);
263 if (rval) erract[WARNING].pf = wputs;
264 else erract[WARNING].pf = NULL;
265 break;
266 case 'e': /* error file */
267 check(2,"s");
268 errfile = argv[++i];
269 break;
270 default:
271 goto badopt;
272 }
273 }
274 /* set/check spectral sampling */
275 if (setspectrsamp(CNDX, WLPART) <= 0)
276 error(USER, "unsupported spectral sampling");
277
278 err = setview(&ourview); /* set viewing parameters */
279 if (err != NULL)
280 error(USER, err);
281 /* initialize object types */
282 initotypes();
283 /* initialize urand */
284 if (rand_samp) {
285 srandom((long)time(0));
286 initurand(0);
287 } else {
288 srandom(0L);
289 initurand(2048);
290 }
291 /* set up signal handling */
292 sigdie(SIGINT, "Interrupt");
293 #ifdef SIGHUP
294 sigdie(SIGHUP, "Hangup");
295 #endif
296 sigdie(SIGTERM, "Terminate");
297 #ifdef SIGPIPE
298 sigdie(SIGPIPE, "Broken pipe");
299 #endif
300 #ifdef SIGALRM
301 sigdie(SIGALRM, "Alarm clock");
302 #endif
303 #ifdef SIGXCPU
304 sigdie(SIGXCPU, "CPU limit exceeded");
305 sigdie(SIGXFSZ, "File size exceeded");
306 #endif
307 /* open error file */
308 if (errfile != NULL) {
309 if (freopen(errfile, "a", stderr) == NULL)
310 quit(2);
311 fprintf(stderr, "**************\n*** PID %5d: ",
312 getpid());
313 printargs(argc, argv, stderr);
314 putc('\n', stderr);
315 fflush(stderr);
316 }
317 #ifdef NICE
318 nice(NICE); /* lower priority */
319 #endif
320 /* get octree */
321 if (i == argc)
322 octname = NULL;
323 else if (i == argc-1)
324 octname = argv[i];
325 else
326 goto badopt;
327 if (seqstart > 0 && octname == NULL)
328 error(USER, "missing octree argument");
329 /* set up output */
330 #ifdef PERSIST
331 if (persist) {
332 if (recover != NULL)
333 error(USER, "persist option used with recover file");
334 if (seqstart <= 0)
335 error(USER, "persist option only for sequences");
336 if (outfile == NULL)
337 duped1 = dup(fileno(stdout)); /* don't lose our output */
338 openheader();
339 } else
340 #endif
341 if (outfile != NULL)
342 openheader();
343 SET_FILE_BINARY(stdout);
344 if (octname == NULL)
345 SET_FILE_BINARY(stdin);
346 readoct(octname, loadflags, &thescene, NULL);
347 nsceneobjs = nobjects;
348
349 if (loadflags & IO_INFO) { /* print header */
350 printargs(i, argv, stdout);
351 printf("SOFTWARE= %s\n", VersionID);
352 }
353
354 ray_init_pmap(); /* PMAP: set up & load photon maps */
355
356 marksources(); /* find and mark sources */
357
358 setambient(); /* initialize ambient calculation */
359
360 fflush(stdout); /* in case we're duplicating header */
361
362 #ifdef PERSIST
363 if (persist) {
364 if (outfile == NULL) { /* reconnect stdout */
365 dup2(duped1, fileno(stdout));
366 close(duped1);
367 }
368 if (persist == PARALLEL) { /* multiprocessing */
369 cow_memshare(); /* preloads scene */
370 while ((rval=fork()) == 0) { /* keep on forkin' */
371 pflock(1);
372 pfhold();
373 tstart = time((time_t *)NULL);
374 ambsync(); /* load new values */
375 }
376 if (rval < 0)
377 error(SYSTEM, "cannot fork child for persist function");
378 pfdetach(); /* parent will run then exit */
379 }
380 }
381 runagain:
382 if (persist) {
383 if (outfile == NULL) /* if out to stdout */
384 dupheader(); /* send header */
385 else /* if out to file */
386 duped1 = dup(fileno(stdout)); /* hang onto pipe */
387 }
388 #endif
389 /* batch render picture(s) */
390 rpict(seqstart, outfile, zfile, recover);
391 /* flush ambient file */
392 ambsync();
393 #ifdef PERSIST
394 if (persist == PERSIST) { /* first run-through */
395 if ((rval=fork()) == 0) { /* child loops until killed */
396 pflock(1);
397 persist = PCHILD;
398 } else { /* original process exits */
399 if (rval < 0)
400 error(SYSTEM, "cannot fork child for persist function");
401 pfdetach(); /* parent exits */
402 }
403 }
404 if (persist == PCHILD) { /* wait for a signal then go again */
405 if (outfile != NULL)
406 close(duped1); /* release output handle */
407 pfhold();
408 tstart = time((time_t *)NULL); /* reinitialize */
409 raynum = nrays = 0;
410 goto runagain;
411 }
412 #endif
413
414
415 ray_done_pmap(); /* PMAP: free photon maps */
416
417 quit(0);
418
419 badopt:
420 sprintf(errmsg, "command line error at '%s'", argv[i]);
421 error(USER, errmsg);
422 return 1; /* pro forma return */
423
424 #undef check
425 #undef check_bool
426 }
427
428
429 void
430 wputs( /* warning output function */
431 const char *s
432 )
433 {
434 int lasterrno = errno;
435 eputs(s);
436 errno = lasterrno;
437 }
438
439
440 void
441 eputs( /* put string to stderr */
442 const char *s
443 )
444 {
445 static int midline = 0;
446
447 if (!*s)
448 return;
449 if (!midline++) {
450 fputs(progname, stderr);
451 fputs(": ", stderr);
452 }
453 fputs(s, stderr);
454 if (s[strlen(s)-1] == '\n') {
455 fflush(stderr);
456 midline = 0;
457 }
458 }
459
460
461 static void
462 onsig( /* fatal signal */
463 int signo
464 )
465 {
466 static int gotsig = 0;
467
468 if (gotsig++) /* two signals and we're gone! */
469 _exit(signo);
470
471 #ifdef SIGALRM /* XXX how critical is this? */
472 alarm(15); /* allow 15 seconds to clean up */
473 signal(SIGALRM, SIG_DFL); /* make certain we do die */
474 #endif
475 eputs("signal - ");
476 eputs(sigerr[signo]);
477 eputs("\n");
478 quit(3);
479 }
480
481
482 static void
483 sigdie( /* set fatal signal */
484 int signo,
485 char *msg
486 )
487 {
488 if (signal(signo, onsig) == SIG_IGN)
489 signal(signo, SIG_IGN);
490 sigerr[signo] = msg;
491 }
492
493
494 static void
495 printdefaults(void) /* print default values to stdout */
496 {
497 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
498 ourview.type==VT_PER ? "perspective" :
499 ourview.type==VT_PAR ? "parallel" :
500 ourview.type==VT_HEM ? "hemispherical" :
501 ourview.type==VT_ANG ? "angular" :
502 ourview.type==VT_CYL ? "cylindrical" :
503 ourview.type==VT_PLS ? "planisphere" :
504 "unknown");
505 printf("-vp %f %f %f\t# view point\n",
506 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
507 printf("-vd %f %f %f\t# view direction\n",
508 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
509 printf("-vu %f %f %f\t# view up\n",
510 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
511 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
512 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
513 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
514 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
515 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
516 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
517 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
518 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
519 if (out_prims == stdprims)
520 printf("-pRGB\t\t\t\t# standard RGB color output\n");
521 else if (out_prims == xyzprims)
522 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
523 else if (out_prims != NULL)
524 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
525 out_prims[RED][0], out_prims[RED][1],
526 out_prims[GRN][0], out_prims[GRN][1],
527 out_prims[BLU][0], out_prims[BLU][1],
528 out_prims[WHT][0], out_prims[WHT][1]);
529 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
530 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
531 printf("-pm %f\t\t\t# pixel motion\n", mblur);
532 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
533 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
534 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
535 printf("-t %-9d\t\t\t# time between reports\n", ralrm);
536 printf(erract[WARNING].pf != NULL ?
537 "-w+\t\t\t\t# warning messages on\n" :
538 "-w-\t\t\t\t# warning messages off\n");
539 print_rdefaults();
540 }
