1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rpmain.c,v 2.23 2022/10/20 17:18:33 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rpmain.c - main for rpict batch rendering program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <time.h> |
11 |
#include <signal.h> |
12 |
13 |
#include "platform.h" |
14 |
#include "rtprocess.h" /* getpid() */ |
15 |
#include "ray.h" |
16 |
#include "source.h" |
17 |
#include "ambient.h" |
18 |
#include "random.h" |
19 |
#include "paths.h" |
20 |
#include "view.h" |
21 |
#include "pmapray.h" |
22 |
23 |
/* persistent processes define */ |
24 |
#ifdef F_SETLKW |
25 |
#define PERSIST 1 /* normal persist */ |
26 |
#define PARALLEL 2 /* parallel persist */ |
27 |
#define PCHILD 3 /* child of normal persist */ |
28 |
#endif |
29 |
30 |
char *progname; /* argv[0] */ |
31 |
char *octname; /* octree name */ |
32 |
char *sigerr[NSIG]; /* signal error messages */ |
33 |
char *shm_boundary = NULL; /* boundary of shared memory */ |
34 |
char *errfile = NULL; /* error output file */ |
35 |
36 |
extern time_t time(); |
37 |
extern time_t tstart; /* start time */ |
38 |
39 |
extern int ralrm; /* seconds between reports */ |
40 |
41 |
extern VIEW ourview; /* viewing parameters */ |
42 |
43 |
extern int hresolu; /* horizontal resolution */ |
44 |
extern int vresolu; /* vertical resolution */ |
45 |
extern double pixaspect; /* pixel aspect ratio */ |
46 |
47 |
extern int psample; /* pixel sample size */ |
48 |
extern double maxdiff; /* max. sample difference */ |
49 |
extern double dstrpix; /* square pixel distribution */ |
50 |
51 |
extern double mblur; /* motion blur parameter */ |
52 |
53 |
extern double dblur; /* depth-of-field blur parameter */ |
54 |
55 |
static void onsig(int signo); |
56 |
static void sigdie(int signo, char *msg); |
57 |
static void printdefaults(void); |
58 |
/* rpict additional features */ |
59 |
#ifdef PERSIST |
60 |
#define RPICT_FEATURES "Persist\nParallelPersist\n" \ |
61 |
"Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \ |
62 |
"HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \ |
63 |
"PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \ |
64 |
"SmallSourceDrawing\nViewSequence\nProgressReporting\n" \ |
65 |
"AdaptiveShadowTesting\nOutputs=v,l\n" |
66 |
#else |
67 |
#define RPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \ |
68 |
69 |
70 |
71 |
72 |
#endif |
73 |
74 |
75 |
int |
76 |
main(int argc, char *argv[]) |
77 |
78 |
#define check(ol,al) if (argv[i][ol] || \ |
79 |
badarg(argc-i-1,argv+i+1,al)) \ |
80 |
goto badopt |
81 |
#define check_bool(olen,var) switch (argv[i][olen]) { \ |
82 |
case '\0': var = !var; break; \ |
83 |
case 'y': case 'Y': case 't': case 'T': \ |
84 |
case '+': case '1': var = 1; break; \ |
85 |
case 'n': case 'N': case 'f': case 'F': \ |
86 |
case '-': case '0': var = 0; break; \ |
87 |
default: goto badopt; } |
88 |
char *err; |
89 |
char *recover = NULL; |
90 |
char *outfile = NULL; |
91 |
char *zfile = NULL; |
92 |
int loadflags = ~IO_FILES; |
93 |
int seqstart = 0; |
94 |
int persist = 0; |
95 |
int duped1 = -1; |
96 |
int rval; |
97 |
int i; |
98 |
/* record start time */ |
99 |
tstart = time((time_t *)NULL); |
100 |
/* global program name */ |
101 |
progname = argv[0] = fixargv0(argv[0]); |
102 |
/* feature check only? */ |
103 |
strcat(RFeatureList, RPICT_FEATURES); |
104 |
if (argc == 2 && !strcmp(argv[1], "-features")) |
105 |
return feature_status(argc-2, argv+2); |
106 |
/* option city */ |
107 |
for (i = 1; i < argc; i++) { |
108 |
/* expand arguments */ |
109 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
110 |
111 |
if (rval < 0) { |
112 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
113 |
error(SYSTEM, errmsg); |
114 |
115 |
if (argv[i] == NULL || argv[i][0] != '-') |
116 |
break; /* break from options */ |
117 |
if (!strcmp(argv[i], "-version")) { |
118 |
puts(VersionID); |
119 |
quit(0); |
120 |
121 |
if (!strcmp(argv[i], "-defaults") || |
122 |
!strcmp(argv[i], "-help")) { |
123 |
printdefaults(); |
124 |
quit(0); |
125 |
126 |
rval = getrenderopt(argc-i, argv+i); |
127 |
if (rval >= 0) { |
128 |
i += rval; |
129 |
continue; |
130 |
131 |
rval = getviewopt(&ourview, argc-i, argv+i); |
132 |
if (rval >= 0) { |
133 |
i += rval; |
134 |
continue; |
135 |
136 |
/* rpict options */ |
137 |
switch (argv[i][1]) { |
138 |
case 'v': /* view file */ |
139 |
if (argv[i][2] != 'f') |
140 |
goto badopt; |
141 |
check(3,"s"); |
142 |
rval = viewfile(argv[++i], &ourview, NULL); |
143 |
if (rval < 0) { |
144 |
sprintf(errmsg, |
145 |
"cannot open view file \"%s\"", |
146 |
argv[i]); |
147 |
148 |
} else if (rval == 0) { |
149 |
sprintf(errmsg, |
150 |
"bad view file \"%s\"", |
151 |
argv[i]); |
152 |
error(USER, errmsg); |
153 |
154 |
break; |
155 |
case 'p': /* pixel */ |
156 |
switch (argv[i][2]) { |
157 |
case 's': /* sample */ |
158 |
check(3,"i"); |
159 |
psample = atoi(argv[++i]); |
160 |
break; |
161 |
case 't': /* threshold */ |
162 |
check(3,"f"); |
163 |
maxdiff = atof(argv[++i]); |
164 |
break; |
165 |
case 'j': /* jitter */ |
166 |
check(3,"f"); |
167 |
dstrpix = atof(argv[++i]); |
168 |
break; |
169 |
case 'a': /* aspect */ |
170 |
check(3,"f"); |
171 |
pixaspect = atof(argv[++i]); |
172 |
break; |
173 |
case 'm': /* motion */ |
174 |
check(3,"f"); |
175 |
mblur = atof(argv[++i]); |
176 |
break; |
177 |
case 'd': /* aperture */ |
178 |
check(3,"f"); |
179 |
dblur = atof(argv[++i]); |
180 |
break; |
181 |
default: |
182 |
goto badopt; |
183 |
184 |
break; |
185 |
case 'x': /* x resolution */ |
186 |
check(2,"i"); |
187 |
hresolu = atoi(argv[++i]); |
188 |
break; |
189 |
case 'y': /* y resolution */ |
190 |
check(2,"i"); |
191 |
vresolu = atoi(argv[++i]); |
192 |
break; |
193 |
case 'S': /* slave index */ |
194 |
check(2,"i"); |
195 |
seqstart = atoi(argv[++i]); |
196 |
break; |
197 |
case 'o': /* output file */ |
198 |
check(2,"s"); |
199 |
outfile = argv[++i]; |
200 |
break; |
201 |
case 'z': /* z file */ |
202 |
check(2,"s"); |
203 |
zfile = argv[++i]; |
204 |
break; |
205 |
case 'r': /* recover file */ |
206 |
if (argv[i][2] == 'o') { /* +output */ |
207 |
check(3,"s"); |
208 |
outfile = argv[i+1]; |
209 |
} else |
210 |
check(2,"s"); |
211 |
recover = argv[++i]; |
212 |
break; |
213 |
case 't': /* timer */ |
214 |
check(2,"i"); |
215 |
ralrm = atoi(argv[++i]); |
216 |
break; |
217 |
#ifdef PERSIST |
218 |
case 'P': /* persist file */ |
219 |
if (argv[i][2] == 'P') { |
220 |
check(3,"s"); |
221 |
persist = PARALLEL; |
222 |
} else { |
223 |
check(2,"s"); |
224 |
persist = PERSIST; |
225 |
226 |
persistfile(argv[++i]); |
227 |
break; |
228 |
#endif |
229 |
case 'w': /* warnings */ |
230 |
rval = erract[WARNING].pf != NULL; |
231 |
check_bool(2,rval); |
232 |
if (rval) erract[WARNING].pf = wputs; |
233 |
else erract[WARNING].pf = NULL; |
234 |
break; |
235 |
case 'e': /* error file */ |
236 |
check(2,"s"); |
237 |
errfile = argv[++i]; |
238 |
break; |
239 |
default: |
240 |
goto badopt; |
241 |
242 |
243 |
err = setview(&ourview); /* set viewing parameters */ |
244 |
if (err != NULL) |
245 |
error(USER, err); |
246 |
/* initialize object types */ |
247 |
initotypes(); |
248 |
/* initialize urand */ |
249 |
if (rand_samp) { |
250 |
srandom((long)time(0)); |
251 |
initurand(0); |
252 |
} else { |
253 |
srandom(0L); |
254 |
initurand(2048); |
255 |
256 |
/* set up signal handling */ |
257 |
sigdie(SIGINT, "Interrupt"); |
258 |
#ifdef SIGHUP |
259 |
sigdie(SIGHUP, "Hangup"); |
260 |
#endif |
261 |
sigdie(SIGTERM, "Terminate"); |
262 |
#ifdef SIGPIPE |
263 |
sigdie(SIGPIPE, "Broken pipe"); |
264 |
#endif |
265 |
#ifdef SIGALRM |
266 |
sigdie(SIGALRM, "Alarm clock"); |
267 |
#endif |
268 |
#ifdef SIGXCPU |
269 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
270 |
sigdie(SIGXFSZ, "File size exceeded"); |
271 |
#endif |
272 |
/* open error file */ |
273 |
if (errfile != NULL) { |
274 |
if (freopen(errfile, "a", stderr) == NULL) |
275 |
quit(2); |
276 |
fprintf(stderr, "**************\n*** PID %5d: ", |
277 |
getpid()); |
278 |
printargs(argc, argv, stderr); |
279 |
putc('\n', stderr); |
280 |
fflush(stderr); |
281 |
282 |
#ifdef NICE |
283 |
nice(NICE); /* lower priority */ |
284 |
#endif |
285 |
/* get octree */ |
286 |
if (i == argc) |
287 |
octname = NULL; |
288 |
else if (i == argc-1) |
289 |
octname = argv[i]; |
290 |
else |
291 |
goto badopt; |
292 |
if (seqstart > 0 && octname == NULL) |
293 |
error(USER, "missing octree argument"); |
294 |
/* set up output */ |
295 |
#ifdef PERSIST |
296 |
if (persist) { |
297 |
if (recover != NULL) |
298 |
error(USER, "persist option used with recover file"); |
299 |
if (seqstart <= 0) |
300 |
error(USER, "persist option only for sequences"); |
301 |
if (outfile == NULL) |
302 |
duped1 = dup(fileno(stdout)); /* don't lose our output */ |
303 |
openheader(); |
304 |
} else |
305 |
#endif |
306 |
if (outfile != NULL) |
307 |
openheader(); |
308 |
SET_FILE_BINARY(stdout); |
309 |
if (octname == NULL) |
310 |
SET_FILE_BINARY(stdin); |
311 |
readoct(octname, loadflags, &thescene, NULL); |
312 |
nsceneobjs = nobjects; |
313 |
314 |
if (loadflags & IO_INFO) { /* print header */ |
315 |
printargs(i, argv, stdout); |
316 |
printf("SOFTWARE= %s\n", VersionID); |
317 |
318 |
319 |
ray_init_pmap(); /* PMAP: set up & load photon maps */ |
320 |
321 |
marksources(); /* find and mark sources */ |
322 |
323 |
setambient(); /* initialize ambient calculation */ |
324 |
325 |
fflush(stdout); /* in case we're duplicating header */ |
326 |
327 |
#ifdef PERSIST |
328 |
if (persist) { |
329 |
if (outfile == NULL) { /* reconnect stdout */ |
330 |
dup2(duped1, fileno(stdout)); |
331 |
close(duped1); |
332 |
333 |
if (persist == PARALLEL) { /* multiprocessing */ |
334 |
preload_objs(); /* preload scene */ |
335 |
shm_boundary = (char *)malloc(16); |
336 |
strcpy(shm_boundary, "SHM_BOUNDARY"); |
337 |
while ((rval=fork()) == 0) { /* keep on forkin' */ |
338 |
pflock(1); |
339 |
pfhold(); |
340 |
341 |
ambsync(); /* load new values */ |
342 |
343 |
if (rval < 0) |
344 |
error(SYSTEM, "cannot fork child for persist function"); |
345 |
pfdetach(); /* parent will run then exit */ |
346 |
347 |
348 |
runagain: |
349 |
if (persist) { |
350 |
if (outfile == NULL) /* if out to stdout */ |
351 |
dupheader(); /* send header */ |
352 |
else /* if out to file */ |
353 |
duped1 = dup(fileno(stdout)); /* hang onto pipe */ |
354 |
355 |
#endif |
356 |
/* batch render picture(s) */ |
357 |
rpict(seqstart, outfile, zfile, recover); |
358 |
/* flush ambient file */ |
359 |
ambsync(); |
360 |
#ifdef PERSIST |
361 |
if (persist == PERSIST) { /* first run-through */ |
362 |
if ((rval=fork()) == 0) { /* child loops until killed */ |
363 |
pflock(1); |
364 |
persist = PCHILD; |
365 |
} else { /* original process exits */ |
366 |
if (rval < 0) |
367 |
368 |
pfdetach(); /* parent exits */ |
369 |
370 |
371 |
if (persist == PCHILD) { /* wait for a signal then go again */ |
372 |
373 |
close(duped1); /* release output handle */ |
374 |
pfhold(); |
375 |
tstart = time((time_t *)NULL); /* reinitialize */ |
376 |
raynum = nrays = 0; |
377 |
goto runagain; |
378 |
379 |
#endif |
380 |
381 |
382 |
ray_done_pmap(); /* PMAP: free photon maps */ |
383 |
384 |
quit(0); |
385 |
386 |
badopt: |
387 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
388 |
389 |
return 1; /* pro forma return */ |
390 |
391 |
#undef check |
392 |
#undef check_bool |
393 |
394 |
395 |
396 |
void |
397 |
wputs( /* warning output function */ |
398 |
char *s |
399 |
400 |
401 |
int lasterrno = errno; |
402 |
eputs(s); |
403 |
errno = lasterrno; |
404 |
405 |
406 |
407 |
void |
408 |
eputs( /* put string to stderr */ |
409 |
char *s |
410 |
411 |
412 |
static int midline = 0; |
413 |
414 |
if (!*s) |
415 |
return; |
416 |
if (!midline++) { |
417 |
fputs(progname, stderr); |
418 |
fputs(": ", stderr); |
419 |
420 |
fputs(s, stderr); |
421 |
if (s[strlen(s)-1] == '\n') { |
422 |
fflush(stderr); |
423 |
midline = 0; |
424 |
425 |
426 |
427 |
428 |
static void |
429 |
onsig( /* fatal signal */ |
430 |
int signo |
431 |
432 |
433 |
static int gotsig = 0; |
434 |
435 |
if (gotsig++) /* two signals and we're gone! */ |
436 |
_exit(signo); |
437 |
438 |
#ifdef SIGALRM /* XXX how critical is this? */ |
439 |
alarm(15); /* allow 15 seconds to clean up */ |
440 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
441 |
#endif |
442 |
eputs("signal - "); |
443 |
eputs(sigerr[signo]); |
444 |
eputs("\n"); |
445 |
quit(3); |
446 |
447 |
448 |
449 |
static void |
450 |
sigdie( /* set fatal signal */ |
451 |
int signo, |
452 |
char *msg |
453 |
454 |
455 |
if (signal(signo, onsig) == SIG_IGN) |
456 |
signal(signo, SIG_IGN); |
457 |
sigerr[signo] = msg; |
458 |
459 |
460 |
461 |
static void |
462 |
printdefaults(void) /* print default values to stdout */ |
463 |
464 |
printf("-vt%c\t\t\t\t# view type %s\n", ourview.type, |
465 |
ourview.type==VT_PER ? "perspective" : |
466 |
ourview.type==VT_PAR ? "parallel" : |
467 |
ourview.type==VT_HEM ? "hemispherical" : |
468 |
ourview.type==VT_ANG ? "angular" : |
469 |
ourview.type==VT_CYL ? "cylindrical" : |
470 |
ourview.type==VT_PLS ? "planisphere" : |
471 |
"unknown"); |
472 |
printf("-vp %f %f %f\t# view point\n", |
473 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]); |
474 |
printf("-vd %f %f %f\t# view direction\n", |
475 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]); |
476 |
printf("-vu %f %f %f\t# view up\n", |
477 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]); |
478 |
printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz); |
479 |
printf("-vv %f\t\t\t# view vertical size\n", ourview.vert); |
480 |
printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore); |
481 |
printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft); |
482 |
printf("-vs %f\t\t\t# view shift\n", ourview.hoff); |
483 |
printf("-vl %f\t\t\t# view lift\n", ourview.voff); |
484 |
printf("-x %-9d\t\t\t# x resolution\n", hresolu); |
485 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
486 |
printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect); |
487 |
printf("-pj %f\t\t\t# pixel jitter\n", dstrpix); |
488 |
printf("-pm %f\t\t\t# pixel motion\n", mblur); |
489 |
printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur); |
490 |
printf("-ps %-9d\t\t\t# pixel sample\n", psample); |
491 |
printf("-pt %f\t\t\t# pixel threshold\n", maxdiff); |
492 |
printf("-t %-9d\t\t\t# time between reports\n", ralrm); |
493 |
printf(erract[WARNING].pf != NULL ? |
494 |
"-w+\t\t\t\t# warning messages on\n" : |
495 |
"-w-\t\t\t\t# warning messages off\n"); |
496 |
print_rdefaults(); |
497 |
