fix: Functio prototypes and other fixes to reduce compiler warnings
refactor: Removed experimental SRCSKIPOPT code
fix(rpict,rtrace,rcontrib): Removed spurious warnings
refactor: moved memory sharing routines to preload.c with common call interface
fix(rpict): Error in -features OutputCS support string
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
fix(rcontrib, rpict, rvu): Better check for spectral sampling
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
fix(rcontrib): Removed participating media from rcontrib -features
fix: Actually, need to allow -features to have arguments
fix: fixed crash when executed with no arguments
feat(rpict,rtrace,rcontrib): Added Output= list to -features
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
fix(rpict): Bug in header output with -o option
Added exclusive output file locking (not tested under Windows)
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Added ambient pre-synchronization in parallel persist mode
Made -u+ option truly random
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Moved some more platform dependencies to common header files. Included a few necessary system headers.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
