root/Development/ray/src/rt/rpmain.c
Revision: 2.16
Committed: Tue Feb 24 19:39:27 2015 UTC (10 years, 10 months ago) by greg
Changes since 2.15: +9 -2 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.16 static const char RCSid[] = "$Id: rpmain.c,v 1.2 2014/09/24 10:59:27 taschreg Exp taschreg $";
3 greg 2.1 #endif
4     /*
5     * rpmain.c - main for rpict batch rendering program
6     */
7
8 greg 2.2 #include "copyright.h"
9 greg 2.1
10 greg 2.10 #include <time.h>
11 schorsch 2.3 #include <signal.h>
12
13     #include "platform.h"
14 schorsch 2.6 #include "rtprocess.h" /* getpid() */
15 greg 2.1 #include "ray.h"
16     #include "source.h"
17     #include "ambient.h"
18     #include "random.h"
19     #include "paths.h"
20     #include "view.h"
21 greg 2.16 #include "pmapray.h"
22 greg 2.1
23     /* persistent processes define */
24     #ifdef F_SETLKW
25     #define PERSIST 1 /* normal persist */
26     #define PARALLEL 2 /* parallel persist */
27     #define PCHILD 3 /* child of normal persist */
28     #endif
29
30     char *progname; /* argv[0] */
31     char *octname; /* octree name */
32     char *sigerr[NSIG]; /* signal error messages */
33     char *shm_boundary = NULL; /* boundary of shared memory */
34     char *errfile = NULL; /* error output file */
35
36     extern time_t time();
37     extern time_t tstart; /* start time */
38
39     extern int ralrm; /* seconds between reports */
40
41     extern VIEW ourview; /* viewing parameters */
42
43     extern int hresolu; /* horizontal resolution */
44     extern int vresolu; /* vertical resolution */
45     extern double pixaspect; /* pixel aspect ratio */
46
47     extern int psample; /* pixel sample size */
48     extern double maxdiff; /* max. sample difference */
49     extern double dstrpix; /* square pixel distribution */
50
51     extern double mblur; /* motion blur parameter */
52
53 greg 2.9 extern double dblur; /* depth-of-field blur parameter */
54
55 schorsch 2.8 static void onsig(int signo);
56     static void sigdie(int signo, char *msg);
57     static void printdefaults(void);
58 greg 2.1
59
60     int
61 schorsch 2.8 main(int argc, char *argv[])
62 greg 2.1 {
63     #define check(ol,al) if (argv[i][ol] || \
64     badarg(argc-i-1,argv+i+1,al)) \
65     goto badopt
66     #define bool(olen,var) switch (argv[i][olen]) { \
67     case '\0': var = !var; break; \
68     case 'y': case 'Y': case 't': case 'T': \
69     case '+': case '1': var = 1; break; \
70     case 'n': case 'N': case 'f': case 'F': \
71     case '-': case '0': var = 0; break; \
72     default: goto badopt; }
73     char *err;
74     char *recover = NULL;
75     char *outfile = NULL;
76     char *zfile = NULL;
77     int loadflags = ~IO_FILES;
78     int seqstart = 0;
79     int persist = 0;
80 greg 2.15 int duped1 = -1;
81 greg 2.1 int rval;
82     int i;
83     /* record start time */
84     tstart = time((time_t *)NULL);
85     /* global program name */
86     progname = argv[0] = fixargv0(argv[0]);
87     /* option city */
88     for (i = 1; i < argc; i++) {
89     /* expand arguments */
90     while ((rval = expandarg(&argc, &argv, i)) > 0)
91     ;
92     if (rval < 0) {
93     sprintf(errmsg, "cannot expand '%s'", argv[i]);
94     error(SYSTEM, errmsg);
95     }
96     if (argv[i] == NULL || argv[i][0] != '-')
97     break; /* break from options */
98     if (!strcmp(argv[i], "-version")) {
99     puts(VersionID);
100     quit(0);
101     }
102     if (!strcmp(argv[i], "-defaults") ||
103     !strcmp(argv[i], "-help")) {
104     printdefaults();
105     quit(0);
106     }
107     rval = getrenderopt(argc-i, argv+i);
108     if (rval >= 0) {
109     i += rval;
110     continue;
111     }
112     rval = getviewopt(&ourview, argc-i, argv+i);
113     if (rval >= 0) {
114     i += rval;
115     continue;
116     }
117     /* rpict options */
118     switch (argv[i][1]) {
119     case 'v': /* view file */
120     if (argv[i][2] != 'f')
121     goto badopt;
122     check(3,"s");
123     rval = viewfile(argv[++i], &ourview, NULL);
124     if (rval < 0) {
125     sprintf(errmsg,
126     "cannot open view file \"%s\"",
127     argv[i]);
128     error(SYSTEM, errmsg);
129     } else if (rval == 0) {
130     sprintf(errmsg,
131     "bad view file \"%s\"",
132     argv[i]);
133     error(USER, errmsg);
134     }
135     break;
136     case 'p': /* pixel */
137     switch (argv[i][2]) {
138     case 's': /* sample */
139     check(3,"i");
140     psample = atoi(argv[++i]);
141     break;
142     case 't': /* threshold */
143     check(3,"f");
144     maxdiff = atof(argv[++i]);
145     break;
146     case 'j': /* jitter */
147     check(3,"f");
148     dstrpix = atof(argv[++i]);
149     break;
150     case 'a': /* aspect */
151     check(3,"f");
152     pixaspect = atof(argv[++i]);
153     break;
154     case 'm': /* motion */
155     check(3,"f");
156     mblur = atof(argv[++i]);
157     break;
158 greg 2.9 case 'd': /* aperture */
159     check(3,"f");
160     dblur = atof(argv[++i]);
161     break;
162 greg 2.1 default:
163     goto badopt;
164     }
165     break;
166     case 'x': /* x resolution */
167     check(2,"i");
168     hresolu = atoi(argv[++i]);
169     break;
170     case 'y': /* y resolution */
171     check(2,"i");
172     vresolu = atoi(argv[++i]);
173     break;
174     case 'S': /* slave index */
175     check(2,"i");
176     seqstart = atoi(argv[++i]);
177     break;
178     case 'o': /* output file */
179     check(2,"s");
180     outfile = argv[++i];
181     break;
182     case 'z': /* z file */
183     check(2,"s");
184     zfile = argv[++i];
185     break;
186     case 'r': /* recover file */
187     if (argv[i][2] == 'o') { /* +output */
188     check(3,"s");
189     outfile = argv[i+1];
190     } else
191     check(2,"s");
192     recover = argv[++i];
193     break;
194     case 't': /* timer */
195     check(2,"i");
196     ralrm = atoi(argv[++i]);
197     break;
198     #ifdef PERSIST
199     case 'P': /* persist file */
200     if (argv[i][2] == 'P') {
201     check(3,"s");
202     persist = PARALLEL;
203     } else {
204     check(2,"s");
205     persist = PERSIST;
206     }
207     persistfile(argv[++i]);
208     break;
209     #endif
210     case 'w': /* warnings */
211     rval = erract[WARNING].pf != NULL;
212     bool(2,rval);
213     if (rval) erract[WARNING].pf = wputs;
214     else erract[WARNING].pf = NULL;
215     break;
216     case 'e': /* error file */
217     check(2,"s");
218     errfile = argv[++i];
219     break;
220     default:
221     goto badopt;
222     }
223     }
224     err = setview(&ourview); /* set viewing parameters */
225     if (err != NULL)
226     error(USER, err);
227     /* initialize object types */
228     initotypes();
229     /* initialize urand */
230 greg 2.12 if (rand_samp) {
231     srandom((long)time(0));
232     initurand(0);
233     } else {
234     srandom(0L);
235     initurand(2048);
236     }
237 greg 2.1 /* set up signal handling */
238     sigdie(SIGINT, "Interrupt");
239 schorsch 2.4 #ifdef SIGHUP
240 greg 2.1 sigdie(SIGHUP, "Hangup");
241 schorsch 2.4 #endif
242 greg 2.1 sigdie(SIGTERM, "Terminate");
243 schorsch 2.4 #ifdef SIGPIPE
244 greg 2.1 sigdie(SIGPIPE, "Broken pipe");
245 schorsch 2.4 #endif
246     #ifdef SIGALRM
247 greg 2.1 sigdie(SIGALRM, "Alarm clock");
248 schorsch 2.4 #endif
249 greg 2.1 #ifdef SIGXCPU
250     sigdie(SIGXCPU, "CPU limit exceeded");
251     sigdie(SIGXFSZ, "File size exceeded");
252     #endif
253     /* open error file */
254     if (errfile != NULL) {
255     if (freopen(errfile, "a", stderr) == NULL)
256     quit(2);
257     fprintf(stderr, "**************\n*** PID %5d: ",
258     getpid());
259     printargs(argc, argv, stderr);
260     putc('\n', stderr);
261     fflush(stderr);
262     }
263     #ifdef NICE
264     nice(NICE); /* lower priority */
265     #endif
266     /* get octree */
267     if (i == argc)
268     octname = NULL;
269     else if (i == argc-1)
270     octname = argv[i];
271     else
272     goto badopt;
273     if (seqstart > 0 && octname == NULL)
274     error(USER, "missing octree argument");
275     /* set up output */
276     #ifdef PERSIST
277     if (persist) {
278     if (recover != NULL)
279     error(USER, "persist option used with recover file");
280     if (seqstart <= 0)
281     error(USER, "persist option only for sequences");
282     if (outfile == NULL)
283     duped1 = dup(fileno(stdout)); /* don't lose our output */
284     openheader();
285     } else
286     #endif
287     if (outfile != NULL)
288     openheader();
289 schorsch 2.3 #ifdef _WIN32
290     SET_FILE_BINARY(stdout);
291 greg 2.1 if (octname == NULL)
292 schorsch 2.3 SET_FILE_BINARY(stdin);
293 greg 2.1 #endif
294     readoct(octname, loadflags, &thescene, NULL);
295     nsceneobjs = nobjects;
296
297     if (loadflags & IO_INFO) { /* print header */
298     printargs(i, argv, stdout);
299     printf("SOFTWARE= %s\n", VersionID);
300     }
301 greg 2.16
302     ray_init_pmap(); /* PMAP: set up & load photon maps */
303 greg 2.1
304     marksources(); /* find and mark sources */
305
306     setambient(); /* initialize ambient calculation */
307 greg 2.16
308 greg 2.1 #ifdef PERSIST
309     if (persist) {
310     fflush(stdout);
311     if (outfile == NULL) { /* reconnect stdout */
312     dup2(duped1, fileno(stdout));
313     close(duped1);
314     }
315     if (persist == PARALLEL) { /* multiprocessing */
316     preload_objs(); /* preload scene */
317     shm_boundary = (char *)malloc(16);
318     strcpy(shm_boundary, "SHM_BOUNDARY");
319     while ((rval=fork()) == 0) { /* keep on forkin' */
320     pflock(1);
321     pfhold();
322     tstart = time((time_t *)NULL);
323 greg 2.13 ambsync(); /* load new values */
324 greg 2.1 }
325     if (rval < 0)
326     error(SYSTEM, "cannot fork child for persist function");
327 greg 2.13 pfdetach(); /* parent will run then exit */
328 greg 2.1 }
329     }
330     runagain:
331 schorsch 2.7 if (persist) {
332 greg 2.1 if (outfile == NULL) /* if out to stdout */
333     dupheader(); /* send header */
334     else /* if out to file */
335     duped1 = dup(fileno(stdout)); /* hang onto pipe */
336 schorsch 2.7 }
337 greg 2.1 #endif
338     /* batch render picture(s) */
339     rpict(seqstart, outfile, zfile, recover);
340     /* flush ambient file */
341     ambsync();
342     #ifdef PERSIST
343     if (persist == PERSIST) { /* first run-through */
344     if ((rval=fork()) == 0) { /* child loops until killed */
345     pflock(1);
346     persist = PCHILD;
347     } else { /* original process exits */
348     if (rval < 0)
349     error(SYSTEM, "cannot fork child for persist function");
350     pfdetach(); /* parent exits */
351     }
352     }
353     if (persist == PCHILD) { /* wait for a signal then go again */
354     if (outfile != NULL)
355     close(duped1); /* release output handle */
356     pfhold();
357     tstart = time((time_t *)NULL); /* reinitialize */
358     raynum = nrays = 0;
359     goto runagain;
360     }
361     #endif
362 greg 2.16
363
364     ray_done_pmap(); /* PMAP: free photon maps */
365
366 greg 2.1 quit(0);
367
368     badopt:
369     sprintf(errmsg, "command line error at '%s'", argv[i]);
370     error(USER, errmsg);
371 schorsch 2.8 return 1; /* pro forma return */
372 greg 2.1
373     #undef check
374     #undef bool
375     }
376
377
378     void
379 schorsch 2.8 wputs( /* warning output function */
380     char *s
381     )
382 greg 2.1 {
383     int lasterrno = errno;
384     eputs(s);
385     errno = lasterrno;
386     }
387
388
389     void
390 schorsch 2.8 eputs( /* put string to stderr */
391     register char *s
392     )
393 greg 2.1 {
394     static int midline = 0;
395
396     if (!*s)
397     return;
398     if (!midline++) {
399     fputs(progname, stderr);
400     fputs(": ", stderr);
401     }
402     fputs(s, stderr);
403     if (s[strlen(s)-1] == '\n') {
404     fflush(stderr);
405     midline = 0;
406     }
407     }
408
409
410 schorsch 2.8 static void
411     onsig( /* fatal signal */
412     int signo
413     )
414 greg 2.1 {
415     static int gotsig = 0;
416
417     if (gotsig++) /* two signals and we're gone! */
418     _exit(signo);
419
420 schorsch 2.4 #ifdef SIGALRM /* XXX how critical is this? */
421 greg 2.1 alarm(15); /* allow 15 seconds to clean up */
422     signal(SIGALRM, SIG_DFL); /* make certain we do die */
423 schorsch 2.4 #endif
424 greg 2.1 eputs("signal - ");
425     eputs(sigerr[signo]);
426     eputs("\n");
427     quit(3);
428     }
429
430
431 schorsch 2.8 static void
432     sigdie( /* set fatal signal */
433     int signo,
434     char *msg
435     )
436 greg 2.1 {
437     if (signal(signo, onsig) == SIG_IGN)
438     signal(signo, SIG_IGN);
439     sigerr[signo] = msg;
440     }
441
442
443 schorsch 2.8 static void
444     printdefaults(void) /* print default values to stdout */
445 greg 2.1 {
446     printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
447     ourview.type==VT_PER ? "perspective" :
448     ourview.type==VT_PAR ? "parallel" :
449     ourview.type==VT_HEM ? "hemispherical" :
450     ourview.type==VT_ANG ? "angular" :
451     ourview.type==VT_CYL ? "cylindrical" :
452 greg 2.14 ourview.type==VT_PLS ? "planisphere" :
453 greg 2.1 "unknown");
454     printf("-vp %f %f %f\t# view point\n",
455     ourview.vp[0], ourview.vp[1], ourview.vp[2]);
456     printf("-vd %f %f %f\t# view direction\n",
457     ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
458     printf("-vu %f %f %f\t# view up\n",
459     ourview.vup[0], ourview.vup[1], ourview.vup[2]);
460     printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
461     printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
462     printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
463     printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
464     printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
465     printf("-vl %f\t\t\t# view lift\n", ourview.voff);
466     printf("-x %-9d\t\t\t# x resolution\n", hresolu);
467     printf("-y %-9d\t\t\t# y resolution\n", vresolu);
468     printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
469     printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
470     printf("-pm %f\t\t\t# pixel motion\n", mblur);
471 greg 2.9 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
472 greg 2.1 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
473     printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
474     printf("-t %-9d\t\t\t# time between reports\n", ralrm);
475     printf(erract[WARNING].pf != NULL ?
476     "-w+\t\t\t\t# warning messages on\n" :
477     "-w-\t\t\t\t# warning messages off\n");
478     print_rdefaults();
479     }
