root/radiance/ray/src/rt/rpmain.c
Wed Aug 7 05:10:09 2013 UTC (10 years, 8 months ago) by greg
Diff to previous 2.14 , to selected 2.4
Tue Mar 11 02:21:47 2008 UTC (16 years, 1 month ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Diff to previous 2.13 , to selected 2.4
Thu Sep 13 20:02:11 2007 UTC (16 years, 7 months ago) by greg
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (18 years, 1 month ago) by greg
Changes since 2.11: +8 -3 lines
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (18 years, 10 months ago) by greg
Wed Jun 15 15:36:52 2005 UTC (18 years, 10 months ago) by greg
Changes since 2.9: +3 -2 lines
Tue Jan 18 00:33:16 2005 UTC (19 years, 3 months ago) by greg
Changes since 2.8: +8 -1 lines
Changes since 2.7: +23 -24 lines
Mon Jul 14 20:02:30 2003 UTC (20 years, 9 months ago) by schorsch
Thu Jul 3 18:03:58 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.3: +12 -1 lines
Changes since 2.2: +8 -14 lines
Diff to selected 2.4
