root/radiance/ray/src/rt/rpmain.c
Tue Mar 11 02:21:47 2008 UTC (17 years, 5 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Thu Sep 13 20:02:11 2007 UTC (17 years, 10 months ago) by greg
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (19 years, 4 months ago) by greg
Changes since 2.11: +8 -3 lines
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (20 years, 1 month ago) by greg
Wed Jun 15 15:36:52 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.9: +3 -2 lines
Tue Jan 18 00:33:16 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.8: +8 -1 lines
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.7: +23 -24 lines
Mon Jul 21 22:30:19 2003 UTC (22 years ago) by schorsch
Mon Jul 14 20:02:30 2003 UTC (22 years, 1 month ago) by schorsch
Thu Jul 3 18:03:58 2003 UTC (22 years, 1 month ago) by greg
Thu Jun 26 00:58:10 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.3: +12 -1 lines
Thu Jun 5 19:29:34 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.2: +8 -14 lines
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Diff to selected 2.9
