root/radiance/ray/src/rt/rpmain.c
Revision: 2.11
Committed: Tue Jun 21 00:26:44 2005 UTC (19 years, 11 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
2 static const char RCSid[] = "$Id: rpmain.c,v 2.10 2005/06/15 15:36:52 greg Exp $";
5 * rpmain.c - main for rpict batch rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "view.h"
21
22 /* persistent processes define */
23 #ifdef F_SETLKW
24 #define PERSIST 1 /* normal persist */
25 #define PARALLEL 2 /* parallel persist */
26 #define PCHILD 3 /* child of normal persist */
27 #endif
28
29 char *progname; /* argv[0] */
30 char *octname; /* octree name */
31 char *sigerr[NSIG]; /* signal error messages */
32 char *shm_boundary = NULL; /* boundary of shared memory */
33 char *errfile = NULL; /* error output file */
34
35 extern time_t time();
36 extern time_t tstart; /* start time */
37
38 extern int ralrm; /* seconds between reports */
39
40 extern VIEW ourview; /* viewing parameters */
41
42 extern int hresolu; /* horizontal resolution */
43 extern int vresolu; /* vertical resolution */
44 extern double pixaspect; /* pixel aspect ratio */
45
46 extern int psample; /* pixel sample size */
47 extern double maxdiff; /* max. sample difference */
48 extern double dstrpix; /* square pixel distribution */
49
50 extern double mblur; /* motion blur parameter */
51
52 extern double dblur; /* depth-of-field blur parameter */
53
54 static void onsig(int signo);
55 static void sigdie(int signo, char *msg);
56 static void printdefaults(void);
57
58
59 int
60 main(int argc, char *argv[])
61 {
62 #define check(ol,al) if (argv[i][ol] || \
63 badarg(argc-i-1,argv+i+1,al)) \
64 goto badopt
65 #define bool(olen,var) switch (argv[i][olen]) { \
66 case '\0': var = !var; break; \
67 case 'y': case 'Y': case 't': case 'T': \
68 case '+': case '1': var = 1; break; \
69 case 'n': case 'N': case 'f': case 'F': \
70 case '-': case '0': var = 0; break; \
71 default: goto badopt; }
72 char *err;
73 char *recover = NULL;
74 char *outfile = NULL;
75 char *zfile = NULL;
76 int loadflags = ~IO_FILES;
77 int seqstart = 0;
78 int persist = 0;
79 int duped1;
80 int rval;
81 int i;
82 /* record start time */
83 tstart = time((time_t *)NULL);
84 /* global program name */
85 progname = argv[0] = fixargv0(argv[0]);
86 /* option city */
87 for (i = 1; i < argc; i++) {
88 /* expand arguments */
89 while ((rval = expandarg(&argc, &argv, i)) > 0)
90 ;
91 if (rval < 0) {
92 sprintf(errmsg, "cannot expand '%s'", argv[i]);
93 error(SYSTEM, errmsg);
94 }
95 if (argv[i] == NULL || argv[i][0] != '-')
96 break; /* break from options */
97 if (!strcmp(argv[i], "-version")) {
98 puts(VersionID);
99 quit(0);
100 }
101 if (!strcmp(argv[i], "-defaults") ||
102 !strcmp(argv[i], "-help")) {
103 printdefaults();
104 quit(0);
105 }
106 rval = getrenderopt(argc-i, argv+i);
107 if (rval >= 0) {
108 i += rval;
109 continue;
110 }
111 rval = getviewopt(&ourview, argc-i, argv+i);
112 if (rval >= 0) {
113 i += rval;
114 continue;
115 }
116 /* rpict options */
117 switch (argv[i][1]) {
118 case 'v': /* view file */
119 if (argv[i][2] != 'f')
120 goto badopt;
121 check(3,"s");
122 rval = viewfile(argv[++i], &ourview, NULL);
123 if (rval < 0) {
124 sprintf(errmsg,
125 "cannot open view file \"%s\"",
126 argv[i]);
127 error(SYSTEM, errmsg);
128 } else if (rval == 0) {
129 sprintf(errmsg,
130 "bad view file \"%s\"",
131 argv[i]);
132 error(USER, errmsg);
133 }
134 break;
135 case 'p': /* pixel */
136 switch (argv[i][2]) {
137 case 's': /* sample */
138 check(3,"i");
139 psample = atoi(argv[++i]);
140 break;
141 case 't': /* threshold */
142 check(3,"f");
143 maxdiff = atof(argv[++i]);
144 break;
145 case 'j': /* jitter */
146 check(3,"f");
147 dstrpix = atof(argv[++i]);
148 break;
149 case 'a': /* aspect */
150 check(3,"f");
151 pixaspect = atof(argv[++i]);
152 break;
153 case 'm': /* motion */
154 check(3,"f");
155 mblur = atof(argv[++i]);
156 break;
157 case 'd': /* aperture */
158 check(3,"f");
159 dblur = atof(argv[++i]);
160 break;
161 default:
162 goto badopt;
163 }
164 break;
165 case 'x': /* x resolution */
166 check(2,"i");
167 hresolu = atoi(argv[++i]);
168 break;
169 case 'y': /* y resolution */
170 check(2,"i");
171 vresolu = atoi(argv[++i]);
172 break;
173 case 'S': /* slave index */
174 check(2,"i");
175 seqstart = atoi(argv[++i]);
176 break;
177 case 'o': /* output file */
178 check(2,"s");
179 outfile = argv[++i];
180 break;
181 case 'z': /* z file */
182 check(2,"s");
183 zfile = argv[++i];
184 break;
185 case 'r': /* recover file */
186 if (argv[i][2] == 'o') { /* +output */
187 check(3,"s");
188 outfile = argv[i+1];
189 } else
190 check(2,"s");
191 recover = argv[++i];
192 break;
193 case 't': /* timer */
194 check(2,"i");
195 ralrm = atoi(argv[++i]);
196 break;
197 #ifdef PERSIST
198 case 'P': /* persist file */
199 if (argv[i][2] == 'P') {
200 check(3,"s");
201 persist = PARALLEL;
202 } else {
203 check(2,"s");
204 persist = PERSIST;
205 }
206 persistfile(argv[++i]);
207 break;
208 #endif
209 case 'w': /* warnings */
210 rval = erract[WARNING].pf != NULL;
211 bool(2,rval);
212 if (rval) erract[WARNING].pf = wputs;
213 else erract[WARNING].pf = NULL;
214 break;
215 case 'e': /* error file */
216 check(2,"s");
217 errfile = argv[++i];
218 break;
219 default:
220 goto badopt;
221 }
222 }
223 err = setview(&ourview); /* set viewing parameters */
224 if (err != NULL)
225 error(USER, err);
226 /* initialize object types */
227 initotypes();
228 /* initialize urand */
229 srandom(rand_samp ? (long)time(0) : 0L);
230 initurand(2048);
231 /* set up signal handling */
232 sigdie(SIGINT, "Interrupt");
233 #ifdef SIGHUP
234 sigdie(SIGHUP, "Hangup");
235 #endif
236 sigdie(SIGTERM, "Terminate");
237 #ifdef SIGPIPE
238 sigdie(SIGPIPE, "Broken pipe");
239 #endif
240 #ifdef SIGALRM
241 sigdie(SIGALRM, "Alarm clock");
242 #endif
243 #ifdef SIGXCPU
244 sigdie(SIGXCPU, "CPU limit exceeded");
245 sigdie(SIGXFSZ, "File size exceeded");
246 #endif
247 /* open error file */
248 if (errfile != NULL) {
249 if (freopen(errfile, "a", stderr) == NULL)
250 quit(2);
251 fprintf(stderr, "**************\n*** PID %5d: ",
252 getpid());
253 printargs(argc, argv, stderr);
254 putc('\n', stderr);
255 fflush(stderr);
256 }
257 #ifdef NICE
258 nice(NICE); /* lower priority */
259 #endif
260 /* get octree */
261 if (i == argc)
262 octname = NULL;
263 else if (i == argc-1)
264 octname = argv[i];
265 else
266 goto badopt;
267 if (seqstart > 0 && octname == NULL)
268 error(USER, "missing octree argument");
269 /* set up output */
270 #ifdef PERSIST
271 if (persist) {
272 if (recover != NULL)
273 error(USER, "persist option used with recover file");
274 if (seqstart <= 0)
275 error(USER, "persist option only for sequences");
276 if (outfile == NULL)
277 duped1 = dup(fileno(stdout)); /* don't lose our output */
278 openheader();
279 } else
280 #endif
281 if (outfile != NULL)
282 openheader();
283 #ifdef _WIN32
284 SET_FILE_BINARY(stdout);
285 if (octname == NULL)
286 SET_FILE_BINARY(stdin);
287 #endif
288 readoct(octname, loadflags, &thescene, NULL);
289 nsceneobjs = nobjects;
290
291 if (loadflags & IO_INFO) { /* print header */
292 printargs(i, argv, stdout);
293 printf("SOFTWARE= %s\n", VersionID);
294 }
295
296 marksources(); /* find and mark sources */
297
298 setambient(); /* initialize ambient calculation */
299
300 #ifdef PERSIST
301 if (persist) {
302 fflush(stdout);
303 if (outfile == NULL) { /* reconnect stdout */
304 dup2(duped1, fileno(stdout));
305 close(duped1);
306 }
307 if (persist == PARALLEL) { /* multiprocessing */
308 preload_objs(); /* preload scene */
309 shm_boundary = (char *)malloc(16);
310 strcpy(shm_boundary, "SHM_BOUNDARY");
311 while ((rval=fork()) == 0) { /* keep on forkin' */
312 pflock(1);
313 pfhold();
314 tstart = time((time_t *)NULL);
315 }
316 if (rval < 0)
317 error(SYSTEM, "cannot fork child for persist function");
318 pfdetach(); /* parent exits */
319 }
320 }
321 runagain:
322 if (persist) {
323 if (outfile == NULL) /* if out to stdout */
324 dupheader(); /* send header */
325 else /* if out to file */
326 duped1 = dup(fileno(stdout)); /* hang onto pipe */
327 }
328 #endif
329 /* batch render picture(s) */
330 rpict(seqstart, outfile, zfile, recover);
331 /* flush ambient file */
332 ambsync();
333 #ifdef PERSIST
334 if (persist == PERSIST) { /* first run-through */
335 if ((rval=fork()) == 0) { /* child loops until killed */
336 pflock(1);
337 persist = PCHILD;
338 } else { /* original process exits */
339 if (rval < 0)
340 error(SYSTEM, "cannot fork child for persist function");
341 pfdetach(); /* parent exits */
342 }
343 }
344 if (persist == PCHILD) { /* wait for a signal then go again */
345 if (outfile != NULL)
346 close(duped1); /* release output handle */
347 pfhold();
348 tstart = time((time_t *)NULL); /* reinitialize */
349 raynum = nrays = 0;
350 goto runagain;
351 }
352 #endif
353 quit(0);
354
355 badopt:
356 sprintf(errmsg, "command line error at '%s'", argv[i]);
357 error(USER, errmsg);
358 return 1; /* pro forma return */
359
360 #undef check
361 #undef bool
362 }
363
364
365 void
366 wputs( /* warning output function */
367 char *s
368 )
369 {
370 int lasterrno = errno;
371 eputs(s);
372 errno = lasterrno;
373 }
374
375
376 void
377 eputs( /* put string to stderr */
378 register char *s
379 )
380 {
381 static int midline = 0;
382
383 if (!*s)
384 return;
385 if (!midline++) {
386 fputs(progname, stderr);
387 fputs(": ", stderr);
388 }
389 fputs(s, stderr);
390 if (s[strlen(s)-1] == '\n') {
391 fflush(stderr);
392 midline = 0;
393 }
394 }
395
396
397 static void
398 onsig( /* fatal signal */
399 int signo
400 )
401 {
402 static int gotsig = 0;
403
404 if (gotsig++) /* two signals and we're gone! */
405 _exit(signo);
406
407 #ifdef SIGALRM /* XXX how critical is this? */
408 alarm(15); /* allow 15 seconds to clean up */
409 signal(SIGALRM, SIG_DFL); /* make certain we do die */
410 #endif
411 eputs("signal - ");
412 eputs(sigerr[signo]);
413 eputs("\n");
414 quit(3);
415 }
416
417
418 static void
419 sigdie( /* set fatal signal */
420 int signo,
421 char *msg
422 )
423 {
424 if (signal(signo, onsig) == SIG_IGN)
425 signal(signo, SIG_IGN);
426 sigerr[signo] = msg;
427 }
428
429
430 static void
431 printdefaults(void) /* print default values to stdout */
432 {
433 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
434 ourview.type==VT_PER ? "perspective" :
435 ourview.type==VT_PAR ? "parallel" :
436 ourview.type==VT_HEM ? "hemispherical" :
437 ourview.type==VT_ANG ? "angular" :
438 ourview.type==VT_CYL ? "cylindrical" :
439 "unknown");
440 printf("-vp %f %f %f\t# view point\n",
441 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
442 printf("-vd %f %f %f\t# view direction\n",
443 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
444 printf("-vu %f %f %f\t# view up\n",
445 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
446 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
447 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
448 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
449 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
450 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
451 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
452 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
453 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
454 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
455 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
456 printf("-pm %f\t\t\t# pixel motion\n", mblur);
457 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
458 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
459 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
460 printf("-t %-9d\t\t\t# time between reports\n", ralrm);
461 printf(erract[WARNING].pf != NULL ?
462 "-w+\t\t\t\t# warning messages on\n" :
463 "-w-\t\t\t\t# warning messages off\n");
464 print_rdefaults();
465 }
