root/Development/ray/src/rt/rpmain.c
Sat Jun 7 05:09:46 2025 UTC (5 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.40: +1 -2 lines
Diff to previous 2.40
Thu Jun 5 18:26:46 2025 UTC (5 months ago) by greg
Changes since 2.39: +1 -2 lines
Diff to previous 2.39
fix: Removed unnecessary or redundant progname declarations
Wed Apr 23 01:57:04 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.38: +1 -2 lines
Diff to previous 2.38
fix: Functio prototypes and other fixes to reduce compiler warnings
Tue Apr 22 17:12:25 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.37: +4 -1 lines
Diff to previous 2.37
Sat Jan 18 03:49:00 2025 UTC (9 months, 3 weeks ago) by greg
Changes since 2.36: +2 -61 lines
Diff to previous 2.36
refactor: Removed experimental SRCSKIPOPT code
Fri Nov 15 20:47:42 2024 UTC (11 months, 3 weeks ago) by greg
Changes since 2.35: +64 -6 lines
Diff to previous 2.35
Wed Oct 30 16:47:03 2024 UTC (12 months, 1 week ago) by greg
Changes since 2.34: +3 -1 lines
Diff to previous 2.34
fix(rpict,rtrace,rcontrib): Removed spurious warnings
Wed Aug 21 20:42:20 2024 UTC (14 months, 2 weeks ago) by greg
Changes since 2.33: +2 -5 lines
Diff to previous 2.33
refactor: moved memory sharing routines to preload.c with common call interface
Mon Apr 8 17:08:15 2024 UTC (19 months ago) by greg
Changes since 2.32: +3 -3 lines
Diff to previous 2.32
fix(rpict): Error in -features OutputCS support string
Fri Apr 5 16:41:17 2024 UTC (19 months ago) by greg
Changes since 2.31: +5 -3 lines
Diff to previous 2.31
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
Thu Jan 18 00:28:54 2024 UTC (21 months, 3 weeks ago) by greg
Changes since 2.30: +2 -3 lines
Diff to previous 2.30
fix(rcontrib, rpict, rvu): Better check for spectral sampling
Wed Jan 17 01:31:08 2024 UTC (21 months, 3 weeks ago) by greg
Changes since 2.29: +6 -1 lines
Diff to previous 2.29
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
Fri Nov 17 20:02:07 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 2.28: +3 -35 lines
Diff to previous 2.28
Wed Nov 15 18:02:53 2023 UTC (23 months, 3 weeks ago) by greg
Changes since 2.27: +73 -3 lines
Diff to previous 2.27
Tue Aug 15 01:19:37 2023 UTC (2 years, 2 months ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26
fix(rcontrib): Removed participating media from rcontrib -features
Mon Feb 6 22:40:21 2023 UTC (2 years, 9 months ago) by greg
Diff to previous 2.25
Mon Feb 6 20:37:06 2023 UTC (2 years, 9 months ago) by greg
Diff to previous 2.24
fix: Actually, need to allow -features to have arguments
Mon Feb 6 20:34:17 2023 UTC (2 years, 9 months ago) by greg
Diff to previous 2.23
fix: fixed crash when executed with no arguments
Thu Oct 20 17:18:33 2022 UTC (3 years ago) by greg
Diff to previous 2.22
feat(rpict,rtrace,rcontrib): Added Output= list to -features
Wed Oct 19 23:10:34 2022 UTC (3 years ago) by greg
Changes since 2.21: +10 -8 lines
Diff to previous 2.21
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
Wed Oct 19 21:25:20 2022 UTC (3 years ago) by greg
Changes since 2.20: +19 -2 lines
Diff to previous 2.20
Tue Apr 5 03:02:15 2022 UTC (3 years, 7 months ago) by greg
Diff to previous 2.19
fix(rpict): Bug in header output with -o option
Thu Mar 21 16:52:40 2019 UTC (6 years, 7 months ago) by greg
Changes since 2.18: +1 -3 lines
Diff to previous 2.18
Added exclusive output file locking (not tested under Windows)
Thu Mar 10 18:25:46 2016 UTC (9 years, 8 months ago) by schorsch
CVS Tags: rad5R1, rad5R2
Diff to previous 2.17
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Sun Mar 6 01:13:18 2016 UTC (9 years, 8 months ago) by schorsch
Diff to previous 2.16
Tue Feb 24 19:39:27 2015 UTC (10 years, 8 months ago) by greg
Changes since 2.15: +9 -2 lines
Diff to previous 2.15
Wed Aug 7 05:10:09 2013 UTC (12 years, 3 months ago) by greg
Diff to previous 2.14
Tue Mar 11 02:21:47 2008 UTC (17 years, 8 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Diff to previous 2.13
Thu Sep 13 20:02:11 2007 UTC (18 years, 2 months ago) by greg
Diff to previous 2.12
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (19 years, 7 months ago) by greg
Changes since 2.11: +8 -3 lines
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (20 years, 4 months ago) by greg
Wed Jun 15 15:36:52 2005 UTC (20 years, 5 months ago) by greg
Changes since 2.9: +3 -2 lines
Tue Jan 18 00:33:16 2005 UTC (20 years, 9 months ago) by greg
Changes since 2.8: +8 -1 lines
Tue Mar 30 16:13:01 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.7: +23 -24 lines
Mon Jul 21 22:30:19 2003 UTC (22 years, 3 months ago) by schorsch
Mon Jul 14 20:02:30 2003 UTC (22 years, 4 months ago) by schorsch
Thu Jul 3 18:03:58 2003 UTC (22 years, 4 months ago) by greg
Thu Jun 26 00:58:10 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.3: +12 -1 lines
Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.2: +8 -14 lines
Tue Feb 25 02:47:23 2003 UTC (22 years, 8 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 8 months ago) by greg
