| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rpmain.c,v 2.36 2024/11/15 20:47:42 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rpmain.c - main for rpict batch rendering program
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <time.h>
| 11 |
#include <signal.h>
| 12 |
| 13 |
#include "platform.h"
| 14 |
#include "rtprocess.h" /* getpid() */
| 15 |
#include "ray.h"
| 16 |
#include "source.h"
| 17 |
#include "ambient.h"
| 18 |
#include "random.h"
| 19 |
#include "paths.h"
| 20 |
#include "view.h"
| 21 |
#include "pmapray.h"
| 22 |
| 23 |
/* persistent processes define */
| 24 |
#ifdef F_SETLKW
| 25 |
#define PERSIST 1 /* normal persist */
| 26 |
#define PARALLEL 2 /* parallel persist */
| 27 |
#define PCHILD 3 /* child of normal persist */
| 28 |
#endif
| 29 |
| 30 |
char *progname; /* argv[0] */
| 31 |
char *octname; /* octree name */
| 32 |
char *sigerr[NSIG]; /* signal error messages */
| 33 |
char *errfile = NULL; /* error output file */
| 34 |
| 35 |
extern time_t time();
| 36 |
extern time_t tstart; /* start time */
| 37 |
| 38 |
extern int ralrm; /* seconds between reports */
| 39 |
| 40 |
extern VIEW ourview; /* viewing parameters */
| 41 |
| 42 |
extern int hresolu; /* horizontal resolution */
| 43 |
extern int vresolu; /* vertical resolution */
| 44 |
extern double pixaspect; /* pixel aspect ratio */
| 45 |
| 46 |
extern int psample; /* pixel sample size */
| 47 |
extern double maxdiff; /* max. sample difference */
| 48 |
extern double dstrpix; /* square pixel distribution */
| 49 |
| 50 |
extern double mblur; /* motion blur parameter */
| 51 |
| 52 |
extern double dblur; /* depth-of-field blur parameter */
| 53 |
| 54 |
RGBPRIMP out_prims = stdprims; /* output color primitives */
| 55 |
static RGBPRIMS our_prims; /* private output color primitives */
| 56 |
| 57 |
static void onsig(int signo);
| 58 |
static void sigdie(int signo, char *msg);
| 59 |
static void printdefaults(void);
| 60 |
/* rpict additional features */
| 61 |
#ifdef PERSIST
| 62 |
#define RPICT_FEATURES "Persist\nParallelPersist\n" \
| 63 |
"ParticipatingMedia=Mist\n" \
| 64 |
"Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
| 65 |
"HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
| 66 |
"PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
| 67 |
"SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
| 68 |
"AdaptiveShadowTesting\nOutputs=v,l\n" \
| 69 |
"OutputCS=RGB,XYZ,prims\n"
| 70 |
#else
| 71 |
#define RPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
| 72 |
| 73 |
| 74 |
| 75 |
| 76 |
| 77 |
| 78 |
#endif
| 79 |
| 80 |
| 81 |
int
| 82 |
main(int argc, char *argv[])
| 83 |
| 84 |
#define check(ol,al) if (argv[i][ol] || \
| 85 |
badarg(argc-i-1,argv+i+1,al)) \
| 86 |
goto badopt
| 87 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 88 |
case '\0': var = !var; break; \
| 89 |
case 'y': case 'Y': case 't': case 'T': \
| 90 |
case '+': case '1': var = 1; break; \
| 91 |
case 'n': case 'N': case 'f': case 'F': \
| 92 |
case '-': case '0': var = 0; break; \
| 93 |
default: goto badopt; }
| 94 |
char *err;
| 95 |
char *recover = NULL;
| 96 |
char *outfile = NULL;
| 97 |
char *zfile = NULL;
| 98 |
int loadflags = ~IO_FILES;
| 99 |
int seqstart = 0;
| 100 |
int persist = 0;
| 101 |
int duped1 = -1;
| 102 |
int rval;
| 103 |
int i;
| 104 |
/* record start time */
| 105 |
tstart = time((time_t *)NULL);
| 106 |
/* global program name */
| 107 |
progname = argv[0] = fixargv0(argv[0]);
| 108 |
/* feature check only? */
| 109 |
strcat(RFeatureList, RPICT_FEATURES);
| 110 |
if (argc > 1 && !strcmp(argv[1], "-features"))
| 111 |
return feature_status(argc-2, argv+2);
| 112 |
/* option city */
| 113 |
for (i = 1; i < argc; i++) {
| 114 |
/* expand arguments */
| 115 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 116 |
| 117 |
if (rval < 0) {
| 118 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 119 |
error(SYSTEM, errmsg);
| 120 |
| 121 |
if (argv[i] == NULL || argv[i][0] != '-')
| 122 |
break; /* break from options */
| 123 |
if (!strcmp(argv[i], "-version")) {
| 124 |
puts(VersionID);
| 125 |
quit(0);
| 126 |
| 127 |
if (!strcmp(argv[i], "-defaults") ||
| 128 |
!strcmp(argv[i], "-help")) {
| 129 |
printdefaults();
| 130 |
quit(0);
| 131 |
| 132 |
rval = getrenderopt(argc-i, argv+i);
| 133 |
if (rval >= 0) {
| 134 |
i += rval;
| 135 |
continue;
| 136 |
| 137 |
rval = getviewopt(&ourview, argc-i, argv+i);
| 138 |
if (rval >= 0) {
| 139 |
i += rval;
| 140 |
continue;
| 141 |
| 142 |
/* rpict options */
| 143 |
switch (argv[i][1]) {
| 144 |
case 'v': /* view file */
| 145 |
if (argv[i][2] != 'f')
| 146 |
goto badopt;
| 147 |
check(3,"s");
| 148 |
rval = viewfile(argv[++i], &ourview, NULL);
| 149 |
if (rval < 0) {
| 150 |
sprintf(errmsg,
| 151 |
"cannot open view file \"%s\"",
| 152 |
argv[i]);
| 153 |
| 154 |
} else if (rval == 0) {
| 155 |
sprintf(errmsg,
| 156 |
"bad view file \"%s\"",
| 157 |
argv[i]);
| 158 |
error(USER, errmsg);
| 159 |
| 160 |
break;
| 161 |
case 'p': /* pixel */
| 162 |
switch (argv[i][2]) {
| 163 |
case 's': /* sample */
| 164 |
check(3,"i");
| 165 |
psample = atoi(argv[++i]);
| 166 |
break;
| 167 |
case 't': /* threshold */
| 168 |
check(3,"f");
| 169 |
maxdiff = atof(argv[++i]);
| 170 |
break;
| 171 |
case 'j': /* jitter */
| 172 |
check(3,"f");
| 173 |
dstrpix = atof(argv[++i]);
| 174 |
break;
| 175 |
case 'a': /* aspect */
| 176 |
check(3,"f");
| 177 |
pixaspect = atof(argv[++i]);
| 178 |
break;
| 179 |
case 'm': /* motion */
| 180 |
check(3,"f");
| 181 |
mblur = atof(argv[++i]);
| 182 |
break;
| 183 |
case 'd': /* aperture */
| 184 |
check(3,"f");
| 185 |
dblur = atof(argv[++i]);
| 186 |
break;
| 187 |
case 'R': /* standard RGB output */
| 188 |
if (strcmp(argv[i]+2, "RGB"))
| 189 |
goto badopt;
| 190 |
| 191 |
break;
| 192 |
case 'X': /* XYZ output */
| 193 |
if (strcmp(argv[i]+2, "XYZ"))
| 194 |
goto badopt;
| 195 |
out_prims = xyzprims;
| 196 |
break;
| 197 |
case 'c': { /* chromaticities */
| 198 |
int j;
| 199 |
check(3,"ffffffff");
| 200 |
rval = 0;
| 201 |
for (j = 0; j < 8; j++) {
| 202 |
our_prims[0][j] = atof(argv[++i]);
| 203 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
| 204 |
| 205 |
if (rval) {
| 206 |
if (!colorprimsOK(our_prims))
| 207 |
error(USER, "illegal primary chromaticities");
| 208 |
out_prims = our_prims;
| 209 |
} else
| 210 |
| 211 |
} break;
| 212 |
default:
| 213 |
goto badopt;
| 214 |
| 215 |
break;
| 216 |
case 'x': /* x resolution */
| 217 |
check(2,"i");
| 218 |
hresolu = atoi(argv[++i]);
| 219 |
break;
| 220 |
case 'y': /* y resolution */
| 221 |
check(2,"i");
| 222 |
vresolu = atoi(argv[++i]);
| 223 |
break;
| 224 |
case 'S': /* slave index */
| 225 |
check(2,"i");
| 226 |
seqstart = atoi(argv[++i]);
| 227 |
break;
| 228 |
case 'o': /* output file */
| 229 |
check(2,"s");
| 230 |
outfile = argv[++i];
| 231 |
break;
| 232 |
case 'z': /* z file */
| 233 |
check(2,"s");
| 234 |
zfile = argv[++i];
| 235 |
break;
| 236 |
case 'r': /* recover file */
| 237 |
if (argv[i][2] == 'o') { /* +output */
| 238 |
check(3,"s");
| 239 |
outfile = argv[i+1];
| 240 |
} else
| 241 |
check(2,"s");
| 242 |
recover = argv[++i];
| 243 |
break;
| 244 |
#ifdef PERSIST
| 245 |
case 'P': /* persist file */
| 246 |
if (argv[i][2] == 'P') {
| 247 |
check(3,"s");
| 248 |
persist = PARALLEL;
| 249 |
} else {
| 250 |
check(2,"s");
| 251 |
persist = PERSIST;
| 252 |
| 253 |
persistfile(argv[++i]);
| 254 |
break;
| 255 |
#endif
| 256 |
case 't': /* timer */
| 257 |
check(2,"i");
| 258 |
ralrm = atoi(argv[++i]);
| 259 |
break;
| 260 |
case 'w': /* warnings */
| 261 |
rval = erract[WARNING].pf != NULL;
| 262 |
check_bool(2,rval);
| 263 |
if (rval) erract[WARNING].pf = wputs;
| 264 |
else erract[WARNING].pf = NULL;
| 265 |
break;
| 266 |
case 'e': /* error file */
| 267 |
check(2,"s");
| 268 |
errfile = argv[++i];
| 269 |
break;
| 270 |
default:
| 271 |
goto badopt;
| 272 |
| 273 |
| 274 |
/* set/check spectral sampling */
| 275 |
if (setspectrsamp(CNDX, WLPART) <= 0)
| 276 |
error(USER, "unsupported spectral sampling");
| 277 |
| 278 |
err = setview(&ourview); /* set viewing parameters */
| 279 |
if (err != NULL)
| 280 |
error(USER, err);
| 281 |
/* initialize object types */
| 282 |
initotypes();
| 283 |
/* initialize urand */
| 284 |
if (rand_samp) {
| 285 |
srandom((long)time(0));
| 286 |
initurand(0);
| 287 |
} else {
| 288 |
srandom(0L);
| 289 |
initurand(2048);
| 290 |
| 291 |
/* set up signal handling */
| 292 |
sigdie(SIGINT, "Interrupt");
| 293 |
#ifdef SIGHUP
| 294 |
sigdie(SIGHUP, "Hangup");
| 295 |
#endif
| 296 |
sigdie(SIGTERM, "Terminate");
| 297 |
#ifdef SIGPIPE
| 298 |
sigdie(SIGPIPE, "Broken pipe");
| 299 |
#endif
| 300 |
#ifdef SIGALRM
| 301 |
sigdie(SIGALRM, "Alarm clock");
| 302 |
#endif
| 303 |
#ifdef SIGXCPU
| 304 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 305 |
sigdie(SIGXFSZ, "File size exceeded");
| 306 |
#endif
| 307 |
/* open error file */
| 308 |
if (errfile != NULL) {
| 309 |
if (freopen(errfile, "a", stderr) == NULL)
| 310 |
quit(2);
| 311 |
fprintf(stderr, "**************\n*** PID %5d: ",
| 312 |
getpid());
| 313 |
printargs(argc, argv, stderr);
| 314 |
putc('\n', stderr);
| 315 |
fflush(stderr);
| 316 |
| 317 |
#ifdef NICE
| 318 |
nice(NICE); /* lower priority */
| 319 |
#endif
| 320 |
/* get octree */
| 321 |
if (i == argc)
| 322 |
octname = NULL;
| 323 |
else if (i == argc-1)
| 324 |
octname = argv[i];
| 325 |
else
| 326 |
goto badopt;
| 327 |
if (seqstart > 0 && octname == NULL)
| 328 |
error(USER, "missing octree argument");
| 329 |
/* set up output */
| 330 |
#ifdef PERSIST
| 331 |
if (persist) {
| 332 |
if (recover != NULL)
| 333 |
error(USER, "persist option used with recover file");
| 334 |
if (seqstart <= 0)
| 335 |
error(USER, "persist option only for sequences");
| 336 |
if (outfile == NULL)
| 337 |
duped1 = dup(fileno(stdout)); /* don't lose our output */
| 338 |
openheader();
| 339 |
} else
| 340 |
#endif
| 341 |
if (outfile != NULL)
| 342 |
openheader();
| 343 |
SET_FILE_BINARY(stdout);
| 344 |
if (octname == NULL)
| 345 |
SET_FILE_BINARY(stdin);
| 346 |
readoct(octname, loadflags, &thescene, NULL);
| 347 |
nsceneobjs = nobjects;
| 348 |
| 349 |
if (loadflags & IO_INFO) { /* print header */
| 350 |
printargs(i, argv, stdout);
| 351 |
printf("SOFTWARE= %s\n", VersionID);
| 352 |
| 353 |
| 354 |
ray_init_pmap(); /* PMAP: set up & load photon maps */
| 355 |
| 356 |
marksources(); /* find and mark sources */
| 357 |
setambient(); /* initialize ambient calculation */
| 358 |
| 359 |
fflush(stdout); /* in case we're duplicating header */
| 360 |
| 361 |
#ifdef PERSIST
| 362 |
if (persist) {
| 363 |
if (outfile == NULL) { /* reconnect stdout */
| 364 |
dup2(duped1, fileno(stdout));
| 365 |
close(duped1);
| 366 |
| 367 |
if (persist == PARALLEL) { /* multiprocessing */
| 368 |
cow_memshare(); /* preloads scene */
| 369 |
while ((rval=fork()) == 0) { /* keep on forkin' */
| 370 |
pflock(1);
| 371 |
pfhold();
| 372 |
| 373 |
ambsync(); /* load new values */
| 374 |
| 375 |
if (rval < 0)
| 376 |
error(SYSTEM, "cannot fork child for persist function");
| 377 |
pfdetach(); /* parent will run then exit */
| 378 |
| 379 |
| 380 |
runagain:
| 381 |
if (persist) {
| 382 |
if (outfile == NULL) /* if out to stdout */
| 383 |
dupheader(); /* send header */
| 384 |
else /* if out to file */
| 385 |
duped1 = dup(fileno(stdout)); /* hang onto pipe */
| 386 |
| 387 |
#endif
| 388 |
/* batch render picture(s) */
| 389 |
rpict(seqstart, outfile, zfile, recover);
| 390 |
/* flush ambient file */
| 391 |
ambsync();
| 392 |
#ifdef PERSIST
| 393 |
if (persist == PERSIST) { /* first run-through */
| 394 |
if ((rval=fork()) == 0) { /* child loops until killed */
| 395 |
pflock(1);
| 396 |
persist = PCHILD;
| 397 |
} else { /* original process exits */
| 398 |
if (rval < 0)
| 399 |
| 400 |
pfdetach(); /* parent exits */
| 401 |
| 402 |
| 403 |
if (persist == PCHILD) { /* wait for a signal then go again */
| 404 |
| 405 |
close(duped1); /* release output handle */
| 406 |
pfhold();
| 407 |
tstart = time((time_t *)NULL); /* reinitialize */
| 408 |
raynum = nrays = 0;
| 409 |
goto runagain;
| 410 |
| 411 |
#endif
| 412 |
| 413 |
| 414 |
ray_done_pmap(); /* PMAP: free photon maps */
| 415 |
| 416 |
quit(0);
| 417 |
| 418 |
badopt:
| 419 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 420 |
| 421 |
return 1; /* pro forma return */
| 422 |
| 423 |
#undef check
| 424 |
#undef check_bool
| 425 |
| 426 |
| 427 |
| 428 |
void
| 429 |
wputs( /* warning output function */
| 430 |
const char *s
| 431 |
| 432 |
| 433 |
int lasterrno = errno;
| 434 |
if (erract[WARNING].pf == NULL)
| 435 |
return; /* called by calcomp or someone */
| 436 |
eputs(s);
| 437 |
errno = lasterrno;
| 438 |
| 439 |
| 440 |
| 441 |
void
| 442 |
eputs( /* put string to stderr */
| 443 |
const char *s
| 444 |
| 445 |
| 446 |
static int midline = 0;
| 447 |
| 448 |
if (!*s)
| 449 |
return;
| 450 |
if (!midline++) {
| 451 |
fputs(progname, stderr);
| 452 |
fputs(": ", stderr);
| 453 |
| 454 |
fputs(s, stderr);
| 455 |
if (s[strlen(s)-1] == '\n') {
| 456 |
fflush(stderr);
| 457 |
midline = 0;
| 458 |
| 459 |
| 460 |
| 461 |
| 462 |
static void
| 463 |
onsig( /* fatal signal */
| 464 |
int signo
| 465 |
| 466 |
| 467 |
static int gotsig = 0;
| 468 |
| 469 |
if (gotsig++) /* two signals and we're gone! */
| 470 |
_exit(signo);
| 471 |
| 472 |
#ifdef SIGALRM /* XXX how critical is this? */
| 473 |
alarm(15); /* allow 15 seconds to clean up */
| 474 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 475 |
#endif
| 476 |
eputs("signal - ");
| 477 |
eputs(sigerr[signo]);
| 478 |
eputs("\n");
| 479 |
quit(3);
| 480 |
| 481 |
| 482 |
| 483 |
static void
| 484 |
sigdie( /* set fatal signal */
| 485 |
int signo,
| 486 |
char *msg
| 487 |
| 488 |
| 489 |
if (signal(signo, onsig) == SIG_IGN)
| 490 |
signal(signo, SIG_IGN);
| 491 |
sigerr[signo] = msg;
| 492 |
| 493 |
| 494 |
| 495 |
static void
| 496 |
printdefaults(void) /* print default values to stdout */
| 497 |
| 498 |
printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
| 499 |
ourview.type==VT_PER ? "perspective" :
| 500 |
ourview.type==VT_PAR ? "parallel" :
| 501 |
ourview.type==VT_HEM ? "hemispherical" :
| 502 |
ourview.type==VT_ANG ? "angular" :
| 503 |
ourview.type==VT_CYL ? "cylindrical" :
| 504 |
ourview.type==VT_PLS ? "planisphere" :
| 505 |
"unknown");
| 506 |
printf("-vp %f %f %f\t# view point\n",
| 507 |
ourview.vp[0], ourview.vp[1], ourview.vp[2]);
| 508 |
printf("-vd %f %f %f\t# view direction\n",
| 509 |
ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
| 510 |
printf("-vu %f %f %f\t# view up\n",
| 511 |
ourview.vup[0], ourview.vup[1], ourview.vup[2]);
| 512 |
printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
| 513 |
printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
| 514 |
printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
| 515 |
printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
| 516 |
printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
| 517 |
printf("-vl %f\t\t\t# view lift\n", ourview.voff);
| 518 |
printf("-x %-9d\t\t\t# x resolution\n", hresolu);
| 519 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu);
| 520 |
if (out_prims == stdprims)
| 521 |
printf("-pRGB\t\t\t\t# standard RGB color output\n");
| 522 |
else if (out_prims == xyzprims)
| 523 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
| 524 |
else if (out_prims != NULL)
| 525 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
| 526 |
out_prims[RED][0], out_prims[RED][1],
| 527 |
out_prims[GRN][0], out_prims[GRN][1],
| 528 |
out_prims[BLU][0], out_prims[BLU][1],
| 529 |
out_prims[WHT][0], out_prims[WHT][1]);
| 530 |
printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
| 531 |
printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
| 532 |
printf("-pm %f\t\t\t# pixel motion\n", mblur);
| 533 |
printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
| 534 |
printf("-ps %-9d\t\t\t# pixel sample\n", psample);
| 535 |
printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
| 536 |
printf("-t %-9d\t\t\t# time between reports\n", ralrm);
| 537 |
printf(erract[WARNING].pf != NULL ?
| 538 |
"-w+\t\t\t\t# warning messages on\n" :
| 539 |
"-w-\t\t\t\t# warning messages off\n");
| 540 |
print_rdefaults();
| 541 |
