root/radiance/ray/src/rt/rpmain.c
Mon Apr 8 17:08:15 2024 UTC (2 months ago) by greg
Changes since 2.32: +3 -3 lines
Diff to previous 2.32 , to selected 2.15
fix(rpict): Error in -features OutputCS support string
Fri Apr 5 16:41:17 2024 UTC (2 months, 1 week ago) by greg
Changes since 2.31: +5 -3 lines
Diff to previous 2.31 , to selected 2.15
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
Thu Jan 18 00:28:54 2024 UTC (4 months, 3 weeks ago) by greg
Changes since 2.30: +2 -3 lines
Diff to previous 2.30 , to selected 2.15
fix(rcontrib, rpict, rvu): Better check for spectral sampling
Wed Jan 17 01:31:08 2024 UTC (4 months, 3 weeks ago) by greg
Changes since 2.29: +6 -1 lines
Diff to previous 2.29 , to selected 2.15
fix(rpict,rvu,rcontrib): Fixed luminance estimate during spectral rendering
Fri Nov 17 20:02:07 2023 UTC (6 months, 3 weeks ago) by greg
Changes since 2.28: +3 -35 lines
Diff to previous 2.28 , to selected 2.15
Wed Nov 15 18:02:53 2023 UTC (6 months, 4 weeks ago) by greg
Changes since 2.27: +73 -3 lines
Diff to previous 2.27 , to selected 2.15
Tue Aug 15 01:19:37 2023 UTC (9 months, 4 weeks ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26 , to selected 2.15
fix(rcontrib): Removed participating media from rcontrib -features
Mon Feb 6 22:40:21 2023 UTC (16 months ago) by greg
Diff to previous 2.25 , to selected 2.15
Mon Feb 6 20:37:06 2023 UTC (16 months ago) by greg
Diff to previous 2.24 , to selected 2.15
fix: Actually, need to allow -features to have arguments
Mon Feb 6 20:34:17 2023 UTC (16 months ago) by greg
Diff to previous 2.23 , to selected 2.15
fix: fixed crash when executed with no arguments
Thu Oct 20 17:18:33 2022 UTC (19 months, 3 weeks ago) by greg
Diff to previous 2.22 , to selected 2.15
feat(rpict,rtrace,rcontrib): Added Output= list to -features
Wed Oct 19 23:10:34 2022 UTC (19 months, 3 weeks ago) by greg
Changes since 2.21: +10 -8 lines
Diff to previous 2.21 , to selected 2.15
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
Wed Oct 19 21:25:20 2022 UTC (19 months, 3 weeks ago) by greg
Changes since 2.20: +19 -2 lines
Diff to previous 2.20 , to selected 2.15
Tue Apr 5 03:02:15 2022 UTC (2 years, 2 months ago) by greg
Diff to previous 2.19 , to selected 2.15
fix(rpict): Bug in header output with -o option
Thu Mar 21 16:52:40 2019 UTC (5 years, 2 months ago) by greg
Changes since 2.18: +1 -3 lines
Diff to previous 2.18 , to selected 2.15
Added exclusive output file locking (not tested under Windows)
Thu Mar 10 18:25:46 2016 UTC (8 years, 3 months ago) by schorsch
CVS Tags: rad5R1, rad5R2
Diff to previous 2.17 , to selected 2.15
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Sun Mar 6 01:13:18 2016 UTC (8 years, 3 months ago) by schorsch
Diff to previous 2.16 , to selected 2.15
Tue Feb 24 19:39:27 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.15: +9 -2 lines
Diff to previous 2.15
Revision 2.15 - (view) (download) (annotate) - [selected]
Wed Aug 7 05:10:09 2013 UTC (10 years, 10 months ago) by greg
Diff to previous 2.14
Tue Mar 11 02:21:47 2008 UTC (16 years, 3 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Diff to previous 2.13 , to selected 2.15
Thu Sep 13 20:02:11 2007 UTC (16 years, 9 months ago) by greg
Diff to previous 2.12 , to selected 2.15
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (18 years, 2 months ago) by greg
Changes since 2.11: +8 -3 lines
Diff to previous 2.11 , to selected 2.15
Made -u+ option truly random
Tue Jun 21 00:26:44 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 2.15
Wed Jun 15 15:36:52 2005 UTC (19 years ago) by greg
Changes since 2.9: +3 -2 lines
Diff to previous 2.9 , to selected 2.15
Tue Jan 18 00:33:16 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.8: +8 -1 lines
Diff to previous 2.8 , to selected 2.15
Changes since 2.7: +23 -24 lines
Diff to previous 2.7 , to selected 2.15
Diff to previous 2.6 , to selected 2.15
Mon Jul 14 20:02:30 2003 UTC (20 years, 11 months ago) by schorsch
Diff to previous 2.5 , to selected 2.15
Thu Jul 3 18:03:58 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 2.4 , to selected 2.15
Changes since 2.3: +12 -1 lines
Diff to previous 2.3 , to selected 2.15
Changes since 2.2: +8 -14 lines
Diff to previous 2.2 , to selected 2.15
Diff to previous 2.1 , to selected 2.15
Diff to selected 2.15
