root/radiance/ray/src/rt/rpmain.c
Revision: 2.41
Committed: Sat Jun 7 05:09:46 2025 UTC (2 weeks, 3 days ago) by greg
Changes since 2.40: +1 -2 lines
2 static const char RCSid[] = "$Id: rpmain.c,v 2.40 2025/06/05 18:26:46 greg Exp $";
5 * rpmain.c - main for rpict batch rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "ray.h"
16 #include "func.h"
17 #include "source.h"
18 #include "ambient.h"
19 #include "random.h"
20 #include "view.h"
21 #include "pmapray.h"
22
23 /* persistent processes define */
24 #ifdef F_SETLKW
25 #define PERSIST 1 /* normal persist */
26 #define PARALLEL 2 /* parallel persist */
27 #define PCHILD 3 /* child of normal persist */
28 #endif
29
30 char *octname; /* octree name */
31 char *sigerr[NSIG]; /* signal error messages */
32 char *errfile = NULL; /* error output file */
33
34 extern time_t tstart; /* start time */
35
36 extern int ralrm; /* seconds between reports */
37
38 extern VIEW ourview; /* viewing parameters */
39
40 extern int hresolu; /* horizontal resolution */
41 extern int vresolu; /* vertical resolution */
42 extern double pixaspect; /* pixel aspect ratio */
43
44 extern int psample; /* pixel sample size */
45 extern double maxdiff; /* max. sample difference */
46 extern double dstrpix; /* square pixel distribution */
47
48 extern double mblur; /* motion blur parameter */
49
50 extern double dblur; /* depth-of-field blur parameter */
51
52 RGBPRIMP out_prims = stdprims; /* output color primitives */
53 static RGBPRIMS our_prims; /* private output color primitives */
54
55 static void onsig(int signo);
56 static void sigdie(int signo, char *msg);
57 static void printdefaults(void);
58 /* rpict additional features */
59 #ifdef PERSIST
60 #define RPICT_FEATURES "Persist\nParallelPersist\n" \
61 "ParticipatingMedia=Mist\n" \
62 "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
63 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
64 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
65 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
66 "AdaptiveShadowTesting\nOutputs=v,l\n" \
67 "OutputCS=RGB,XYZ,prims\n"
68 #else
69 #define RPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
70 "ParticipatingMedia=Mist\n" \
71 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
72 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
73 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
74 "AdaptiveShadowTesting\nOutputs=v,l\n" \
75 "OutputCS=RGB,XYZ,prims\n"
76 #endif
77
78
79 int
80 main(int argc, char *argv[])
81 {
82 #define check(ol,al) if (argv[i][ol] || \
83 badarg(argc-i-1,argv+i+1,al)) \
84 goto badopt
85 #define check_bool(olen,var) switch (argv[i][olen]) { \
86 case '\0': var = !var; break; \
87 case 'y': case 'Y': case 't': case 'T': \
88 case '+': case '1': var = 1; break; \
89 case 'n': case 'N': case 'f': case 'F': \
90 case '-': case '0': var = 0; break; \
91 default: goto badopt; }
92 char *err;
93 char *recover = NULL;
94 char *outfile = NULL;
95 char *zfile = NULL;
96 int loadflags = ~IO_FILES;
97 int seqstart = 0;
98 int persist = 0;
99 int duped1 = -1;
100 int rval;
101 int i;
102 /* record start time */
103 tstart = time((time_t *)NULL);
104 /* global program name */
105 progname = argv[0] = fixargv0(argv[0]);
106 /* feature check only? */
107 strcat(RFeatureList, RPICT_FEATURES);
108 if (argc > 1 && !strcmp(argv[1], "-features"))
109 return feature_status(argc-2, argv+2);
110 /* initialize calcomp routines */
111 initfunc();
112 /* option city */
113 for (i = 1; i < argc; i++) {
114 /* expand arguments */
115 while ((rval = expandarg(&argc, &argv, i)) > 0)
116 ;
117 if (rval < 0) {
118 sprintf(errmsg, "cannot expand '%s'", argv[i]);
119 error(SYSTEM, errmsg);
120 }
121 if (argv[i] == NULL || argv[i][0] != '-')
122 break; /* break from options */
123 if (!strcmp(argv[i], "-version")) {
124 puts(VersionID);
125 quit(0);
126 }
127 if (!strcmp(argv[i], "-defaults") ||
128 !strcmp(argv[i], "-help")) {
129 printdefaults();
130 quit(0);
131 }
132 rval = getrenderopt(argc-i, argv+i);
133 if (rval >= 0) {
134 i += rval;
135 continue;
136 }
137 rval = getviewopt(&ourview, argc-i, argv+i);
138 if (rval >= 0) {
139 i += rval;
140 continue;
141 }
142 /* rpict options */
143 switch (argv[i][1]) {
144 case 'v': /* view file */
145 if (argv[i][2] != 'f')
146 goto badopt;
147 check(3,"s");
148 rval = viewfile(argv[++i], &ourview, NULL);
149 if (rval < 0) {
150 sprintf(errmsg,
151 "cannot open view file \"%s\"",
152 argv[i]);
153 error(SYSTEM, errmsg);
154 } else if (rval == 0) {
155 sprintf(errmsg,
156 "bad view file \"%s\"",
157 argv[i]);
158 error(USER, errmsg);
159 }
160 break;
161 case 'p': /* pixel */
162 switch (argv[i][2]) {
163 case 's': /* sample */
164 check(3,"i");
165 psample = atoi(argv[++i]);
166 break;
167 case 't': /* threshold */
168 check(3,"f");
169 maxdiff = atof(argv[++i]);
170 break;
171 case 'j': /* jitter */
172 check(3,"f");
173 dstrpix = atof(argv[++i]);
174 break;
175 case 'a': /* aspect */
176 check(3,"f");
177 pixaspect = atof(argv[++i]);
178 break;
179 case 'm': /* motion */
180 check(3,"f");
181 mblur = atof(argv[++i]);
182 break;
183 case 'd': /* aperture */
184 check(3,"f");
185 dblur = atof(argv[++i]);
186 break;
187 case 'R': /* standard RGB output */
188 if (strcmp(argv[i]+2, "RGB"))
189 goto badopt;
190 out_prims = stdprims;
191 break;
192 case 'X': /* XYZ output */
193 if (strcmp(argv[i]+2, "XYZ"))
194 goto badopt;
195 out_prims = xyzprims;
196 break;
197 case 'c': { /* chromaticities */
198 int j;
199 check(3,"ffffffff");
200 rval = 0;
201 for (j = 0; j < 8; j++) {
202 our_prims[0][j] = atof(argv[++i]);
203 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
204 }
205 if (rval) {
206 if (!colorprimsOK(our_prims))
207 error(USER, "illegal primary chromaticities");
208 out_prims = our_prims;
209 } else
210 out_prims = stdprims;
211 } break;
212 default:
213 goto badopt;
214 }
215 break;
216 case 'x': /* x resolution */
217 check(2,"i");
218 hresolu = atoi(argv[++i]);
219 break;
220 case 'y': /* y resolution */
221 check(2,"i");
222 vresolu = atoi(argv[++i]);
223 break;
224 case 'S': /* slave index */
225 check(2,"i");
226 seqstart = atoi(argv[++i]);
227 break;
228 case 'o': /* output file */
229 check(2,"s");
230 outfile = argv[++i];
231 break;
232 case 'z': /* z file */
233 check(2,"s");
234 zfile = argv[++i];
235 break;
236 case 'r': /* recover file */
237 if (argv[i][2] == 'o') { /* +output */
238 check(3,"s");
239 outfile = argv[i+1];
240 } else
241 check(2,"s");
242 recover = argv[++i];
243 break;
244 #ifdef PERSIST
245 case 'P': /* persist file */
246 if (argv[i][2] == 'P') {
247 check(3,"s");
248 persist = PARALLEL;
249 } else {
250 check(2,"s");
251 persist = PERSIST;
252 }
253 persistfile(argv[++i]);
254 break;
255 #endif
256 case 't': /* timer */
257 check(2,"i");
258 ralrm = atoi(argv[++i]);
259 break;
260 case 'w': /* warnings */
261 rval = erract[WARNING].pf != NULL;
262 check_bool(2,rval);
263 if (rval) erract[WARNING].pf = wputs;
264 else erract[WARNING].pf = NULL;
265 break;
266 case 'e': /* error file */
267 check(2,"s");
268 errfile = argv[++i];
269 break;
270 default:
271 goto badopt;
272 }
273 }
274 /* set/check spectral sampling */
275 if (setspectrsamp(CNDX, WLPART) <= 0)
276 error(USER, "unsupported spectral sampling");
277
278 err = setview(&ourview); /* set viewing parameters */
279 if (err != NULL)
280 error(USER, err);
281 /* initialize object types */
282 initotypes();
283 /* initialize urand */
284 if (rand_samp) {
285 srandom((long)time(0));
286 initurand(0);
287 } else {
288 srandom(0L);
289 initurand(2048);
290 }
291 /* set up signal handling */
292 sigdie(SIGINT, "Interrupt");
293 #ifdef SIGHUP
294 sigdie(SIGHUP, "Hangup");
295 #endif
296 sigdie(SIGTERM, "Terminate");
297 #ifdef SIGPIPE
298 sigdie(SIGPIPE, "Broken pipe");
299 #endif
300 #ifdef SIGALRM
301 sigdie(SIGALRM, "Alarm clock");
302 #endif
303 #ifdef SIGXCPU
304 sigdie(SIGXCPU, "CPU limit exceeded");
305 sigdie(SIGXFSZ, "File size exceeded");
306 #endif
307 /* open error file */
308 if (errfile != NULL) {
309 if (freopen(errfile, "a", stderr) == NULL)
310 quit(2);
311 fprintf(stderr, "**************\n*** PID %5d: ",
312 getpid());
313 printargs(argc, argv, stderr);
314 putc('\n', stderr);
315 fflush(stderr);
316 }
317 #ifdef NICE
318 nice(NICE); /* lower priority */
319 #endif
320 /* get octree */
321 if (i == argc)
322 octname = NULL;
323 else if (i == argc-1)
324 octname = argv[i];
325 else
326 goto badopt;
327 if (seqstart > 0 && octname == NULL)
328 error(USER, "missing octree argument");
329 /* set up output */
330 #ifdef PERSIST
331 if (persist) {
332 if (recover != NULL)
333 error(USER, "persist option used with recover file");
334 if (seqstart <= 0)
335 error(USER, "persist option only for sequences");
336 if (outfile == NULL)
337 duped1 = dup(fileno(stdout)); /* don't lose our output */
338 openheader();
339 } else
340 #endif
341 if (outfile != NULL)
342 openheader();
343 SET_FILE_BINARY(stdout);
344 if (octname == NULL)
345 SET_FILE_BINARY(stdin);
346 readoct(octname, loadflags, &thescene, NULL);
347 nsceneobjs = nobjects;
348
349 if (loadflags & IO_INFO) { /* print header */
350 printargs(i, argv, stdout);
351 printf("SOFTWARE= %s\n", VersionID);
352 }
353
354 ray_init_pmap(); /* PMAP: set up & load photon maps */
355
356 marksources(); /* find and mark sources */
357 setambient(); /* initialize ambient calculation */
358
359 fflush(stdout); /* in case we're duplicating header */
360
361 #ifdef PERSIST
362 if (persist) {
363 if (outfile == NULL) { /* reconnect stdout */
364 dup2(duped1, fileno(stdout));
365 close(duped1);
366 }
367 if (persist == PARALLEL) { /* multiprocessing */
368 cow_memshare(); /* preloads scene */
369 while ((rval=fork()) == 0) { /* keep on forkin' */
370 pflock(1);
371 pfhold();
372 tstart = time((time_t *)NULL);
373 ambsync(); /* load new values */
374 }
375 if (rval < 0)
376 error(SYSTEM, "cannot fork child for persist function");
377 pfdetach(); /* parent will run then exit */
378 }
379 }
380 runagain:
381 if (persist) {
382 if (outfile == NULL) /* if out to stdout */
383 dupheader(); /* send header */
384 else /* if out to file */
385 duped1 = dup(fileno(stdout)); /* hang onto pipe */
386 }
387 #endif
388 /* batch render picture(s) */
389 rpict(seqstart, outfile, zfile, recover);
390 /* flush ambient file */
391 ambsync();
392 #ifdef PERSIST
393 if (persist == PERSIST) { /* first run-through */
394 if ((rval=fork()) == 0) { /* child loops until killed */
395 pflock(1);
396 persist = PCHILD;
397 } else { /* original process exits */
398 if (rval < 0)
399 error(SYSTEM, "cannot fork child for persist function");
400 pfdetach(); /* parent exits */
401 }
402 }
403 if (persist == PCHILD) { /* wait for a signal then go again */
404 if (outfile != NULL)
405 close(duped1); /* release output handle */
406 pfhold();
407 tstart = time((time_t *)NULL); /* reinitialize */
408 raynum = nrays = 0;
409 goto runagain;
410 }
411 #endif
412
413
414 ray_done_pmap(); /* PMAP: free photon maps */
415
416 quit(0);
417
418 badopt:
419 sprintf(errmsg, "command line error at '%s'", argv[i]);
420 error(USER, errmsg);
421 return 1; /* pro forma return */
422
423 #undef check
424 #undef check_bool
425 }
426
427
428 void
429 wputs( /* warning output function */
430 const char *s
431 )
432 {
433 int lasterrno = errno;
434 if (erract[WARNING].pf == NULL)
435 return; /* called by calcomp or someone */
436 eputs(s);
437 errno = lasterrno;
438 }
439
440
441 void
442 eputs( /* put string to stderr */
443 const char *s
444 )
445 {
446 static int midline = 0;
447
448 if (!*s)
449 return;
450 if (!midline++) {
451 fputs(progname, stderr);
452 fputs(": ", stderr);
453 }
454 fputs(s, stderr);
455 if (s[strlen(s)-1] == '\n') {
456 fflush(stderr);
457 midline = 0;
458 }
459 }
460
461
462 static void
463 onsig( /* fatal signal */
464 int signo
465 )
466 {
467 static int gotsig = 0;
468
469 if (gotsig++) /* two signals and we're gone! */
470 _exit(signo);
471
472 #ifdef SIGALRM /* XXX how critical is this? */
473 alarm(15); /* allow 15 seconds to clean up */
474 signal(SIGALRM, SIG_DFL); /* make certain we do die */
475 #endif
476 eputs("signal - ");
477 eputs(sigerr[signo]);
478 eputs("\n");
479 quit(3);
480 }
481
482
483 static void
484 sigdie( /* set fatal signal */
485 int signo,
486 char *msg
487 )
488 {
489 if (signal(signo, onsig) == SIG_IGN)
490 signal(signo, SIG_IGN);
491 sigerr[signo] = msg;
492 }
493
494
495 static void
496 printdefaults(void) /* print default values to stdout */
497 {
498 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
499 ourview.type==VT_PER ? "perspective" :
500 ourview.type==VT_PAR ? "parallel" :
501 ourview.type==VT_HEM ? "hemispherical" :
502 ourview.type==VT_ANG ? "angular" :
503 ourview.type==VT_CYL ? "cylindrical" :
504 ourview.type==VT_PLS ? "planisphere" :
505 "unknown");
506 printf("-vp %f %f %f\t# view point\n",
507 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
508 printf("-vd %f %f %f\t# view direction\n",
509 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
510 printf("-vu %f %f %f\t# view up\n",
511 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
512 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
513 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
514 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
515 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
516 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
517 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
518 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
519 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
520 if (out_prims == stdprims)
521 printf("-pRGB\t\t\t\t# standard RGB color output\n");
522 else if (out_prims == xyzprims)
523 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
524 else if (out_prims != NULL)
525 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
526 out_prims[RED][0], out_prims[RED][1],
527 out_prims[GRN][0], out_prims[GRN][1],
528 out_prims[BLU][0], out_prims[BLU][1],
529 out_prims[WHT][0], out_prims[WHT][1]);
530 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
531 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
532 printf("-pm %f\t\t\t# pixel motion\n", mblur);
533 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
534 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
535 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
536 printf("-t %-9d\t\t\t# time between reports\n", ralrm);
537 printf(erract[WARNING].pf != NULL ?
538 "-w+\t\t\t\t# warning messages on\n" :
539 "-w-\t\t\t\t# warning messages off\n");
540 print_rdefaults();
541 }
