root/radiance/ray/src/rt/rpmain.c
Revision: 2.33
Committed: Mon Apr 8 17:08:15 2024 UTC (7 weeks, 3 days ago) by greg
Changes since 2.32: +3 -3 lines
fix(rpict): Error in -features OutputCS support string
2 static const char RCSid[] = "$Id: rpmain.c,v 2.32 2024/04/05 16:41:17 greg Exp $";
5 * rpmain.c - main for rpict batch rendering program
6 */
7
8 #include "copyright.h"
9
10 #include <time.h>
11 #include <signal.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "view.h"
21 #include "pmapray.h"
22
23 /* persistent processes define */
24 #ifdef F_SETLKW
25 #define PERSIST 1 /* normal persist */
26 #define PARALLEL 2 /* parallel persist */
27 #define PCHILD 3 /* child of normal persist */
28 #endif
29
30 char *progname; /* argv[0] */
31 char *octname; /* octree name */
32 char *sigerr[NSIG]; /* signal error messages */
33 char *shm_boundary = NULL; /* boundary of shared memory */
34 char *errfile = NULL; /* error output file */
35
36 extern time_t time();
37 extern time_t tstart; /* start time */
38
39 extern int ralrm; /* seconds between reports */
40
41 extern VIEW ourview; /* viewing parameters */
42
43 extern int hresolu; /* horizontal resolution */
44 extern int vresolu; /* vertical resolution */
45 extern double pixaspect; /* pixel aspect ratio */
46
47 extern int psample; /* pixel sample size */
48 extern double maxdiff; /* max. sample difference */
49 extern double dstrpix; /* square pixel distribution */
50
51 extern double mblur; /* motion blur parameter */
52
53 extern double dblur; /* depth-of-field blur parameter */
54
55 RGBPRIMP out_prims = stdprims; /* output color primitives */
56 static RGBPRIMS our_prims; /* private output color primitives */
57
58 static void onsig(int signo);
59 static void sigdie(int signo, char *msg);
60 static void printdefaults(void);
61 /* rpict additional features */
62 #ifdef PERSIST
63 #define RPICT_FEATURES "Persist\nParallelPersist\n" \
64 "ParticipatingMedia=Mist\n" \
65 "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
66 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
67 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
68 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
69 "AdaptiveShadowTesting\nOutputs=v,l\n" \
70 "OutputCS=RGB,XYZ,prims\n"
71 #else
72 #define RPICT_FEATURES "Recovery\nIrradianceCalc\nViewTypes=v,l,a,h,s,c\n" \
73 "ParticipatingMedia=Mist\n" \
74 "HessianAmbientCache\nAmbientAveraging\nAmbientValueSharing\n" \
75 "PixelJitter\nPixelSampling\nPixelMotion\nPixelDepthOfField\n" \
76 "SmallSourceDrawing\nViewSequence\nProgressReporting\n" \
77 "AdaptiveShadowTesting\nOutputs=v,l\n" \
78 "OutputCS=RGB,XYZ,prims\n"
79 #endif
80
81
82 int
83 main(int argc, char *argv[])
84 {
85 #define check(ol,al) if (argv[i][ol] || \
86 badarg(argc-i-1,argv+i+1,al)) \
87 goto badopt
88 #define check_bool(olen,var) switch (argv[i][olen]) { \
89 case '\0': var = !var; break; \
90 case 'y': case 'Y': case 't': case 'T': \
91 case '+': case '1': var = 1; break; \
92 case 'n': case 'N': case 'f': case 'F': \
93 case '-': case '0': var = 0; break; \
94 default: goto badopt; }
95 char *err;
96 char *recover = NULL;
97 char *outfile = NULL;
98 char *zfile = NULL;
99 int loadflags = ~IO_FILES;
100 int seqstart = 0;
101 int persist = 0;
102 int duped1 = -1;
103 int rval;
104 int i;
105 /* record start time */
106 tstart = time((time_t *)NULL);
107 /* global program name */
108 progname = argv[0] = fixargv0(argv[0]);
109 /* feature check only? */
110 strcat(RFeatureList, RPICT_FEATURES);
111 if (argc > 1 && !strcmp(argv[1], "-features"))
112 return feature_status(argc-2, argv+2);
113 /* option city */
114 for (i = 1; i < argc; i++) {
115 /* expand arguments */
116 while ((rval = expandarg(&argc, &argv, i)) > 0)
117 ;
118 if (rval < 0) {
119 sprintf(errmsg, "cannot expand '%s'", argv[i]);
120 error(SYSTEM, errmsg);
121 }
122 if (argv[i] == NULL || argv[i][0] != '-')
123 break; /* break from options */
124 if (!strcmp(argv[i], "-version")) {
125 puts(VersionID);
126 quit(0);
127 }
128 if (!strcmp(argv[i], "-defaults") ||
129 !strcmp(argv[i], "-help")) {
130 printdefaults();
131 quit(0);
132 }
133 rval = getrenderopt(argc-i, argv+i);
134 if (rval >= 0) {
135 i += rval;
136 continue;
137 }
138 rval = getviewopt(&ourview, argc-i, argv+i);
139 if (rval >= 0) {
140 i += rval;
141 continue;
142 }
143 /* rpict options */
144 switch (argv[i][1]) {
145 case 'v': /* view file */
146 if (argv[i][2] != 'f')
147 goto badopt;
148 check(3,"s");
149 rval = viewfile(argv[++i], &ourview, NULL);
150 if (rval < 0) {
151 sprintf(errmsg,
152 "cannot open view file \"%s\"",
153 argv[i]);
154 error(SYSTEM, errmsg);
155 } else if (rval == 0) {
156 sprintf(errmsg,
157 "bad view file \"%s\"",
158 argv[i]);
159 error(USER, errmsg);
160 }
161 break;
162 case 'p': /* pixel */
163 switch (argv[i][2]) {
164 case 's': /* sample */
165 check(3,"i");
166 psample = atoi(argv[++i]);
167 break;
168 case 't': /* threshold */
169 check(3,"f");
170 maxdiff = atof(argv[++i]);
171 break;
172 case 'j': /* jitter */
173 check(3,"f");
174 dstrpix = atof(argv[++i]);
175 break;
176 case 'a': /* aspect */
177 check(3,"f");
178 pixaspect = atof(argv[++i]);
179 break;
180 case 'm': /* motion */
181 check(3,"f");
182 mblur = atof(argv[++i]);
183 break;
184 case 'd': /* aperture */
185 check(3,"f");
186 dblur = atof(argv[++i]);
187 break;
188 case 'R': /* standard RGB output */
189 if (strcmp(argv[i]+2, "RGB"))
190 goto badopt;
191 out_prims = stdprims;
192 break;
193 case 'X': /* XYZ output */
194 if (strcmp(argv[i]+2, "XYZ"))
195 goto badopt;
196 out_prims = xyzprims;
197 break;
198 case 'c': { /* chromaticities */
199 int j;
200 check(3,"ffffffff");
201 rval = 0;
202 for (j = 0; j < 8; j++) {
203 our_prims[0][j] = atof(argv[++i]);
204 rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
205 }
206 if (rval) {
207 if (!colorprimsOK(our_prims))
208 error(USER, "illegal primary chromaticities");
209 out_prims = our_prims;
210 } else
211 out_prims = stdprims;
212 } break;
213 default:
214 goto badopt;
215 }
216 break;
217 case 'x': /* x resolution */
218 check(2,"i");
219 hresolu = atoi(argv[++i]);
220 break;
221 case 'y': /* y resolution */
222 check(2,"i");
223 vresolu = atoi(argv[++i]);
224 break;
225 case 'S': /* slave index */
226 check(2,"i");
227 seqstart = atoi(argv[++i]);
228 break;
229 case 'o': /* output file */
230 check(2,"s");
231 outfile = argv[++i];
232 break;
233 case 'z': /* z file */
234 check(2,"s");
235 zfile = argv[++i];
236 break;
237 case 'r': /* recover file */
238 if (argv[i][2] == 'o') { /* +output */
239 check(3,"s");
240 outfile = argv[i+1];
241 } else
242 check(2,"s");
243 recover = argv[++i];
244 break;
245 case 't': /* timer */
246 check(2,"i");
247 ralrm = atoi(argv[++i]);
248 break;
249 #ifdef PERSIST
250 case 'P': /* persist file */
251 if (argv[i][2] == 'P') {
252 check(3,"s");
253 persist = PARALLEL;
254 } else {
255 check(2,"s");
256 persist = PERSIST;
257 }
258 persistfile(argv[++i]);
259 break;
260 #endif
261 case 'w': /* warnings */
262 rval = erract[WARNING].pf != NULL;
263 check_bool(2,rval);
264 if (rval) erract[WARNING].pf = wputs;
265 else erract[WARNING].pf = NULL;
266 break;
267 case 'e': /* error file */
268 check(2,"s");
269 errfile = argv[++i];
270 break;
271 default:
272 goto badopt;
273 }
274 }
275 /* set/check spectral sampling */
276 if (setspectrsamp(CNDX, WLPART) <= 0)
277 error(USER, "unsupported spectral sampling");
278
279 err = setview(&ourview); /* set viewing parameters */
280 if (err != NULL)
281 error(USER, err);
282 /* initialize object types */
283 initotypes();
284 /* initialize urand */
285 if (rand_samp) {
286 srandom((long)time(0));
287 initurand(0);
288 } else {
289 srandom(0L);
290 initurand(2048);
291 }
292 /* set up signal handling */
293 sigdie(SIGINT, "Interrupt");
294 #ifdef SIGHUP
295 sigdie(SIGHUP, "Hangup");
296 #endif
297 sigdie(SIGTERM, "Terminate");
298 #ifdef SIGPIPE
299 sigdie(SIGPIPE, "Broken pipe");
300 #endif
301 #ifdef SIGALRM
302 sigdie(SIGALRM, "Alarm clock");
303 #endif
304 #ifdef SIGXCPU
305 sigdie(SIGXCPU, "CPU limit exceeded");
306 sigdie(SIGXFSZ, "File size exceeded");
307 #endif
308 /* open error file */
309 if (errfile != NULL) {
310 if (freopen(errfile, "a", stderr) == NULL)
311 quit(2);
312 fprintf(stderr, "**************\n*** PID %5d: ",
313 getpid());
314 printargs(argc, argv, stderr);
315 putc('\n', stderr);
316 fflush(stderr);
317 }
318 #ifdef NICE
319 nice(NICE); /* lower priority */
320 #endif
321 /* get octree */
322 if (i == argc)
323 octname = NULL;
324 else if (i == argc-1)
325 octname = argv[i];
326 else
327 goto badopt;
328 if (seqstart > 0 && octname == NULL)
329 error(USER, "missing octree argument");
330 /* set up output */
331 #ifdef PERSIST
332 if (persist) {
333 if (recover != NULL)
334 error(USER, "persist option used with recover file");
335 if (seqstart <= 0)
336 error(USER, "persist option only for sequences");
337 if (outfile == NULL)
338 duped1 = dup(fileno(stdout)); /* don't lose our output */
339 openheader();
340 } else
341 #endif
342 if (outfile != NULL)
343 openheader();
344 SET_FILE_BINARY(stdout);
345 if (octname == NULL)
346 SET_FILE_BINARY(stdin);
347 readoct(octname, loadflags, &thescene, NULL);
348 nsceneobjs = nobjects;
349
350 if (loadflags & IO_INFO) { /* print header */
351 printargs(i, argv, stdout);
352 printf("SOFTWARE= %s\n", VersionID);
353 }
354
355 ray_init_pmap(); /* PMAP: set up & load photon maps */
356
357 marksources(); /* find and mark sources */
358
359 setambient(); /* initialize ambient calculation */
360
361 fflush(stdout); /* in case we're duplicating header */
362
363 #ifdef PERSIST
364 if (persist) {
365 if (outfile == NULL) { /* reconnect stdout */
366 dup2(duped1, fileno(stdout));
367 close(duped1);
368 }
369 if (persist == PARALLEL) { /* multiprocessing */
370 preload_objs(); /* preload scene */
371 shm_boundary = (char *)malloc(16);
372 strcpy(shm_boundary, "SHM_BOUNDARY");
373 while ((rval=fork()) == 0) { /* keep on forkin' */
374 pflock(1);
375 pfhold();
376 tstart = time((time_t *)NULL);
377 ambsync(); /* load new values */
378 }
379 if (rval < 0)
380 error(SYSTEM, "cannot fork child for persist function");
381 pfdetach(); /* parent will run then exit */
382 }
383 }
384 runagain:
385 if (persist) {
386 if (outfile == NULL) /* if out to stdout */
387 dupheader(); /* send header */
388 else /* if out to file */
389 duped1 = dup(fileno(stdout)); /* hang onto pipe */
390 }
391 #endif
392 /* batch render picture(s) */
393 rpict(seqstart, outfile, zfile, recover);
394 /* flush ambient file */
395 ambsync();
396 #ifdef PERSIST
397 if (persist == PERSIST) { /* first run-through */
398 if ((rval=fork()) == 0) { /* child loops until killed */
399 pflock(1);
400 persist = PCHILD;
401 } else { /* original process exits */
402 if (rval < 0)
403 error(SYSTEM, "cannot fork child for persist function");
404 pfdetach(); /* parent exits */
405 }
406 }
407 if (persist == PCHILD) { /* wait for a signal then go again */
408 if (outfile != NULL)
409 close(duped1); /* release output handle */
410 pfhold();
411 tstart = time((time_t *)NULL); /* reinitialize */
412 raynum = nrays = 0;
413 goto runagain;
414 }
415 #endif
416
417
418 ray_done_pmap(); /* PMAP: free photon maps */
419
420 quit(0);
421
422 badopt:
423 sprintf(errmsg, "command line error at '%s'", argv[i]);
424 error(USER, errmsg);
425 return 1; /* pro forma return */
426
427 #undef check
428 #undef check_bool
429 }
430
431
432 void
433 wputs( /* warning output function */
434 const char *s
435 )
436 {
437 int lasterrno = errno;
438 eputs(s);
439 errno = lasterrno;
440 }
441
442
443 void
444 eputs( /* put string to stderr */
445 const char *s
446 )
447 {
448 static int midline = 0;
449
450 if (!*s)
451 return;
452 if (!midline++) {
453 fputs(progname, stderr);
454 fputs(": ", stderr);
455 }
456 fputs(s, stderr);
457 if (s[strlen(s)-1] == '\n') {
458 fflush(stderr);
459 midline = 0;
460 }
461 }
462
463
464 static void
465 onsig( /* fatal signal */
466 int signo
467 )
468 {
469 static int gotsig = 0;
470
471 if (gotsig++) /* two signals and we're gone! */
472 _exit(signo);
473
474 #ifdef SIGALRM /* XXX how critical is this? */
475 alarm(15); /* allow 15 seconds to clean up */
476 signal(SIGALRM, SIG_DFL); /* make certain we do die */
477 #endif
478 eputs("signal - ");
479 eputs(sigerr[signo]);
480 eputs("\n");
481 quit(3);
482 }
483
484
485 static void
486 sigdie( /* set fatal signal */
487 int signo,
488 char *msg
489 )
490 {
491 if (signal(signo, onsig) == SIG_IGN)
492 signal(signo, SIG_IGN);
493 sigerr[signo] = msg;
494 }
495
496
497 static void
498 printdefaults(void) /* print default values to stdout */
499 {
500 printf("-vt%c\t\t\t\t# view type %s\n", ourview.type,
501 ourview.type==VT_PER ? "perspective" :
502 ourview.type==VT_PAR ? "parallel" :
503 ourview.type==VT_HEM ? "hemispherical" :
504 ourview.type==VT_ANG ? "angular" :
505 ourview.type==VT_CYL ? "cylindrical" :
506 ourview.type==VT_PLS ? "planisphere" :
507 "unknown");
508 printf("-vp %f %f %f\t# view point\n",
509 ourview.vp[0], ourview.vp[1], ourview.vp[2]);
510 printf("-vd %f %f %f\t# view direction\n",
511 ourview.vdir[0], ourview.vdir[1], ourview.vdir[2]);
512 printf("-vu %f %f %f\t# view up\n",
513 ourview.vup[0], ourview.vup[1], ourview.vup[2]);
514 printf("-vh %f\t\t\t# view horizontal size\n", ourview.horiz);
515 printf("-vv %f\t\t\t# view vertical size\n", ourview.vert);
516 printf("-vo %f\t\t\t# view fore clipping plane\n", ourview.vfore);
517 printf("-va %f\t\t\t# view aft clipping plane\n", ourview.vaft);
518 printf("-vs %f\t\t\t# view shift\n", ourview.hoff);
519 printf("-vl %f\t\t\t# view lift\n", ourview.voff);
520 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
521 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
522 if (out_prims == stdprims)
523 printf("-pRGB\t\t\t\t# standard RGB color output\n");
524 else if (out_prims == xyzprims)
525 printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
526 else if (out_prims != NULL)
527 printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
528 out_prims[RED][0], out_prims[RED][1],
529 out_prims[GRN][0], out_prims[GRN][1],
530 out_prims[BLU][0], out_prims[BLU][1],
531 out_prims[WHT][0], out_prims[WHT][1]);
532 printf("-pa %f\t\t\t# pixel aspect ratio\n", pixaspect);
533 printf("-pj %f\t\t\t# pixel jitter\n", dstrpix);
534 printf("-pm %f\t\t\t# pixel motion\n", mblur);
535 printf("-pd %f\t\t\t# pixel depth-of-field\n", dblur);
536 printf("-ps %-9d\t\t\t# pixel sample\n", psample);
537 printf("-pt %f\t\t\t# pixel threshold\n", maxdiff);
538 printf("-t %-9d\t\t\t# time between reports\n", ralrm);
539 printf(erract[WARNING].pf != NULL ?
540 "-w+\t\t\t\t# warning messages on\n" :
541 "-w-\t\t\t\t# warning messages off\n");
542 print_rdefaults();
543 }
