1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rpict.c,v 2.86 2013/03/21 00:03:09 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rpict.c - routines and variables for picture generation. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <sys/types.h> |
11 |
12 |
#include "platform.h" |
13 |
#ifdef NON_POSIX |
14 |
#ifdef MINGW |
15 |
#include <sys/time.h> |
16 |
#endif |
17 |
#else |
18 |
#ifdef BSD |
19 |
20 |
#include <sys/resource.h> |
21 |
#else |
22 |
#include <sys/times.h> |
23 |
#include <unistd.h> |
24 |
#endif |
25 |
#endif |
26 |
27 |
#include <time.h> |
28 |
#include <signal.h> |
29 |
30 |
#include "ray.h" |
31 |
#include "paths.h" |
32 |
#include "ambient.h" |
33 |
#include "view.h" |
34 |
#include "random.h" |
35 |
36 |
#include "hilbert.h" |
37 |
38 |
39 |
#define RFTEMPLATE "rfXXXXXX" |
40 |
41 |
#ifndef SIGCONT |
42 |
#ifdef SIGIO /* XXX can we live without this? */ |
43 |
#define SIGCONT SIGIO |
44 |
#endif |
45 |
#endif |
46 |
47 |
CUBE thescene; /* our scene */ |
48 |
OBJECT nsceneobjs; /* number of objects in our scene */ |
49 |
50 |
int dimlist[MAXDIM]; /* sampling dimensions */ |
51 |
int ndims = 0; /* number of sampling dimensions */ |
52 |
int samplendx; /* sample index number */ |
53 |
54 |
void (*addobjnotify[])() = {ambnotify, NULL}; |
55 |
56 |
VIEW ourview = STDVIEW; /* view parameters */ |
57 |
int hresolu = 512; /* horizontal resolution */ |
58 |
int vresolu = 512; /* vertical resolution */ |
59 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
60 |
61 |
int psample = 4; /* pixel sample size */ |
62 |
double maxdiff = .05; /* max. difference for interpolation */ |
63 |
double dstrpix = 0.67; /* square pixel distribution */ |
64 |
65 |
double mblur = 0.; /* motion blur parameter */ |
66 |
67 |
double dblur = 0.; /* depth-of-field blur parameter */ |
68 |
69 |
void (*trace)() = NULL; /* trace call */ |
70 |
71 |
int do_irrad = 0; /* compute irradiance? */ |
72 |
73 |
int rand_samp = 0; /* pure Monte Carlo sampling? */ |
74 |
75 |
double dstrsrc = 0.0; /* square source distribution */ |
76 |
double shadthresh = .05; /* shadow threshold */ |
77 |
double shadcert = .5; /* shadow certainty */ |
78 |
int directrelay = 1; /* number of source relays */ |
79 |
int vspretest = 512; /* virtual source pretest density */ |
80 |
int directvis = 1; /* sources visible? */ |
81 |
double srcsizerat = .25; /* maximum ratio source size/dist. */ |
82 |
83 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ |
84 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */ |
85 |
double seccg = 0.; /* global scattering eccentricity */ |
86 |
double ssampdist = 0.; /* scatter sampling distance */ |
87 |
88 |
double specthresh = .15; /* specular sampling threshold */ |
89 |
double specjitter = 1.; /* specular sampling jitter */ |
90 |
91 |
int backvis = 1; /* back face visibility */ |
92 |
93 |
int maxdepth = 7; /* maximum recursion depth */ |
94 |
double minweight = 1e-3; /* minimum ray weight */ |
95 |
96 |
char *ambfile = NULL; /* ambient file name */ |
97 |
COLOR ambval = BLKCOLOR; /* ambient value */ |
98 |
int ambvwt = 0; /* initial weight for ambient value */ |
99 |
double ambacc = 0.2; /* ambient accuracy */ |
100 |
int ambres = 64; /* ambient resolution */ |
101 |
int ambdiv = 512; /* ambient divisions */ |
102 |
int ambssamp = 128; /* ambient super-samples */ |
103 |
int ambounce = 0; /* ambient bounces */ |
104 |
char *amblist[AMBLLEN]; /* ambient include/exclude list */ |
105 |
int ambincl = -1; /* include == 1, exclude == 0 */ |
106 |
107 |
int ralrm = 0; /* seconds between reports */ |
108 |
109 |
double pctdone = 0.0; /* percentage done */ |
110 |
time_t tlastrept = 0L; /* time at last report */ |
111 |
time_t tstart; /* starting time */ |
112 |
113 |
#define MAXDIV 16 /* maximum sample size */ |
114 |
115 |
#define pixjitter() (.5+dstrpix*(.5-frandom())) |
116 |
117 |
int hres, vres; /* resolution for this frame */ |
118 |
119 |
static VIEW lastview; /* the previous view input */ |
120 |
121 |
static void report(int); |
122 |
static int nextview(FILE *fp); |
123 |
static void render(char *zfile, char *oldfile); |
124 |
static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres, |
125 |
int y, int xstep); |
126 |
static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres, |
127 |
int y, int ysize); |
128 |
static int fillsample(COLOR *colline, float *zline, int x, int y, |
129 |
int xlen, int ylen, int b); |
130 |
static double pixvalue(COLOR col, int x, int y); |
131 |
static int salvage(char *oldfile); |
132 |
static int pixnumber(int x, int y, int xres, int yres); |
133 |
134 |
135 |
136 |
#ifdef RHAS_STAT |
137 |
138 |
#include <sys/stat.h> |
139 |
int |
140 |
file_exists(fname) /* ordinary file exists? */ |
141 |
char *fname; |
142 |
143 |
struct stat sbuf; |
144 |
if (stat(fname, &sbuf) < 0) return(0); |
145 |
return((sbuf.st_mode & S_IFREG) != 0); |
146 |
147 |
#else |
148 |
#define file_exists(f) (access(f,F_OK)==0) |
149 |
#endif |
150 |
151 |
152 |
void |
153 |
quit(code) /* quit program */ |
154 |
int code; |
155 |
156 |
if (code) /* report status */ |
157 |
report(0); |
158 |
#ifndef NON_POSIX |
159 |
headclean(); /* delete header file */ |
160 |
pfclean(); /* clean up persist files */ |
161 |
#endif |
162 |
exit(code); |
163 |
164 |
165 |
166 |
#ifndef NON_POSIX |
167 |
static void |
168 |
report(int dummy) /* report progress */ |
169 |
170 |
double u, s; |
171 |
#ifdef BSD |
172 |
struct rusage rubuf; |
173 |
#else |
174 |
struct tms tbuf; |
175 |
double period; |
176 |
#endif |
177 |
178 |
tlastrept = time((time_t *)NULL); |
179 |
#ifdef BSD |
180 |
getrusage(RUSAGE_SELF, &rubuf); |
181 |
u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; |
182 |
s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; |
183 |
getrusage(RUSAGE_CHILDREN, &rubuf); |
184 |
u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; |
185 |
s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; |
186 |
#else |
187 |
times(&tbuf); |
188 |
#ifdef _SC_CLK_TCK |
189 |
period = 1.0 / sysconf(_SC_CLK_TCK); |
190 |
#else |
191 |
period = 1.0 / 60.0; |
192 |
#endif |
193 |
u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period; |
194 |
s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period; |
195 |
#endif |
196 |
197 |
sprintf(errmsg, |
198 |
"%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n", |
199 |
nrays, pctdone, u/3600., s/3600., |
200 |
(tlastrept-tstart)/3600., myhostname()); |
201 |
eputs(errmsg); |
202 |
#ifdef SIGCONT |
203 |
signal(SIGCONT, report); |
204 |
#endif |
205 |
206 |
#else |
207 |
static void |
208 |
209 |
210 |
211 |
sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n", |
212 |
nrays, pctdone, (tlastrept-tstart)/3600.0); |
213 |
eputs(errmsg); |
214 |
215 |
#endif |
216 |
217 |
218 |
extern void |
219 |
rpict( /* generate image(s) */ |
220 |
int seq, |
221 |
char *pout, |
222 |
char *zout, |
223 |
char *prvr |
224 |
225 |
226 |
* If seq is greater than zero, then we will render a sequence of |
227 |
* images based on view parameter strings read from the standard input. |
228 |
* If pout is NULL, then all images will be sent to the standard ouput. |
229 |
* If seq is greater than zero and prvr is an integer, then it is the |
230 |
* frame number at which rendering should begin. Preceeding view parameter |
231 |
* strings will be skipped in the input. |
232 |
* If pout and prvr are the same, prvr is renamed to avoid overwriting. |
233 |
* Note that pout and zout should contain %d format specifications for |
234 |
* sequenced file naming. |
235 |
236 |
237 |
char fbuf[128], fbuf2[128]; |
238 |
int npicts; |
239 |
char *cp; |
240 |
RESOLU rs; |
241 |
double pa; |
242 |
/* check sampling */ |
243 |
if (psample < 1) |
244 |
psample = 1; |
245 |
else if (psample > MAXDIV) { |
246 |
sprintf(errmsg, "pixel sampling reduced from %d to %d", |
247 |
psample, MAXDIV); |
248 |
error(WARNING, errmsg); |
249 |
psample = MAXDIV; |
250 |
251 |
/* get starting frame */ |
252 |
if (seq <= 0) |
253 |
seq = 0; |
254 |
else if (prvr != NULL && isint(prvr)) { |
255 |
int rn; /* skip to specified view */ |
256 |
if ((rn = atoi(prvr)) < seq) |
257 |
error(USER, "recover frame less than start frame"); |
258 |
if (pout == NULL) |
259 |
error(USER, "missing output file specification"); |
260 |
for ( ; seq < rn; seq++) |
261 |
if (nextview(stdin) == EOF) |
262 |
error(USER, "unexpected EOF on view input"); |
263 |
setview(&ourview); |
264 |
prvr = fbuf; /* mark for renaming */ |
265 |
266 |
if ((pout != NULL) & (prvr != NULL)) { |
267 |
sprintf(fbuf, pout, seq); |
268 |
if (!strcmp(prvr, fbuf)) { /* rename */ |
269 |
strcpy(fbuf2, fbuf); |
270 |
for (cp = fbuf2; *cp; cp++) |
271 |
272 |
while (cp > fbuf2 && !ISDIRSEP(cp[-1])) |
273 |
cp--; |
274 |
strcpy(cp, RFTEMPLATE); |
275 |
prvr = mktemp(fbuf2); |
276 |
if (rename(fbuf, prvr) < 0) { |
277 |
if (errno == ENOENT) { /* ghost file */ |
278 |
sprintf(errmsg, |
279 |
"new output file \"%s\"", |
280 |
fbuf); |
281 |
282 |
prvr = NULL; |
283 |
} else { /* serious error */ |
284 |
sprintf(errmsg, |
285 |
"cannot rename \"%s\" to \"%s\"", |
286 |
fbuf, prvr); |
287 |
error(SYSTEM, errmsg); |
288 |
289 |
290 |
291 |
292 |
npicts = 0; /* render sequence */ |
293 |
do { |
294 |
if (seq && nextview(stdin) == EOF) |
295 |
break; |
296 |
pctdone = 0.0; |
297 |
if (pout != NULL) { |
298 |
299 |
if (file_exists(fbuf)) { |
300 |
if (prvr != NULL || !strcmp(fbuf, pout)) { |
301 |
sprintf(errmsg, |
302 |
"output file \"%s\" exists", |
303 |
fbuf); |
304 |
error(USER, errmsg); |
305 |
306 |
307 |
continue; /* don't clobber */ |
308 |
309 |
if (freopen(fbuf, "w", stdout) == NULL) { |
310 |
sprintf(errmsg, |
311 |
"cannot open output file \"%s\"", fbuf); |
312 |
313 |
314 |
SET_FILE_BINARY(stdout); |
315 |
dupheader(); |
316 |
317 |
hres = hresolu; vres = vresolu; pa = pixaspect; |
318 |
if (prvr != NULL) { |
319 |
if (viewfile(prvr, &ourview, &rs) <= 0) { |
320 |
sprintf(errmsg, |
321 |
"cannot recover view parameters from \"%s\"", prvr); |
322 |
323 |
} else { |
324 |
pa = 0.0; |
325 |
hres = scanlen(&rs); |
326 |
vres = numscans(&rs); |
327 |
328 |
329 |
if ((cp = setview(&ourview)) != NULL) |
330 |
error(USER, cp); |
331 |
normaspect(viewaspect(&ourview), &pa, &hres, &vres); |
332 |
if (seq) { |
333 |
if (ralrm > 0) { |
334 |
fprintf(stderr, "FRAME %d:", seq); |
335 |
fprintview(&ourview, stderr); |
336 |
putc('\n', stderr); |
337 |
fflush(stderr); |
338 |
339 |
printf("FRAME=%d\n", seq); |
340 |
341 |
fputs(VIEWSTR, stdout); |
342 |
fprintview(&ourview, stdout); |
343 |
putchar('\n'); |
344 |
if ((pa < .99) | (pa > 1.01)) |
345 |
fputaspect(pa, stdout); |
346 |
fputnow(stdout); |
347 |
fputformat(COLRFMT, stdout); |
348 |
putchar('\n'); |
349 |
if (zout != NULL) |
350 |
sprintf(cp=fbuf, zout, seq); |
351 |
else |
352 |
cp = NULL; |
353 |
render(cp, prvr); |
354 |
prvr = NULL; |
355 |
npicts++; |
356 |
} while (seq++); |
357 |
/* check that we did something */ |
358 |
if (npicts == 0) |
359 |
error(WARNING, "no output produced"); |
360 |
361 |
362 |
363 |
static int |
364 |
nextview( /* get next view from fp */ |
365 |
FILE *fp |
366 |
367 |
368 |
char linebuf[256]; |
369 |
370 |
lastview = ourview; |
371 |
while (fgets(linebuf, sizeof(linebuf), fp) != NULL) |
372 |
if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) |
373 |
return(0); |
374 |
return(EOF); |
375 |
376 |
377 |
378 |
static void |
379 |
render( /* render the scene */ |
380 |
char *zfile, |
381 |
char *oldfile |
382 |
383 |
384 |
COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ |
385 |
float *zbar[MAXDIV+1]; /* z values */ |
386 |
char *sampdens; /* previous sample density */ |
387 |
int ypos; /* current scanline */ |
388 |
int ystep; /* current y step size */ |
389 |
int hstep; /* h step size */ |
390 |
int zfd; |
391 |
COLOR *colptr; |
392 |
float *zptr; |
393 |
int i; |
394 |
/* check for empty image */ |
395 |
if ((hres <= 0) | (vres <= 0)) { |
396 |
error(WARNING, "empty output picture"); |
397 |
fprtresolu(0, 0, stdout); |
398 |
return; |
399 |
400 |
/* allocate scanlines */ |
401 |
for (i = 0; i <= psample; i++) { |
402 |
scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); |
403 |
if (scanbar[i] == NULL) |
404 |
goto memerr; |
405 |
406 |
hstep = (psample*140+49)/99; /* quincunx sampling */ |
407 |
ystep = (psample*99+70)/140; |
408 |
if (hstep > 2) { |
409 |
i = hres/hstep + 2; |
410 |
if ((sampdens = (char *)malloc(i)) == NULL) |
411 |
goto memerr; |
412 |
while (i--) |
413 |
sampdens[i] = hstep; |
414 |
} else |
415 |
sampdens = NULL; |
416 |
/* open z-file */ |
417 |
if (zfile != NULL) { |
418 |
if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { |
419 |
sprintf(errmsg, "cannot open z-file \"%s\"", zfile); |
420 |
421 |
422 |
SET_FD_BINARY(zfd); |
423 |
424 |
zbar[i] = (float *)malloc(hres*sizeof(float)); |
425 |
if (zbar[i] == NULL) |
426 |
goto memerr; |
427 |
428 |
} else { |
429 |
zfd = -1; |
430 |
for (i = 0; i <= psample; i++) |
431 |
zbar[i] = NULL; |
432 |
433 |
/* write out boundaries */ |
434 |
fprtresolu(hres, vres, stdout); |
435 |
/* recover file and compute first */ |
436 |
i = salvage(oldfile); |
437 |
if (i >= vres) |
438 |
goto alldone; |
439 |
if ((zfd != -1) & (i > 0) && |
440 |
lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0) |
441 |
error(SYSTEM, "z-file seek error in render"); |
442 |
pctdone = 100.0*i/vres; |
443 |
if (ralrm > 0) /* report init stats */ |
444 |
report(0); |
445 |
#ifdef SIGCONT |
446 |
else |
447 |
448 |
#endif |
449 |
ypos = vres-1 - i; /* initialize sampling */ |
450 |
if (directvis) |
451 |
init_drawsources(psample); |
452 |
fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); |
453 |
/* compute scanlines */ |
454 |
for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { |
455 |
/* bottom adjust? */ |
456 |
if (ypos < 0) { |
457 |
ystep += ypos; |
458 |
ypos = 0; |
459 |
460 |
colptr = scanbar[ystep]; /* move base to top */ |
461 |
scanbar[ystep] = scanbar[0]; |
462 |
scanbar[0] = colptr; |
463 |
zptr = zbar[ystep]; |
464 |
zbar[ystep] = zbar[0]; |
465 |
zbar[0] = zptr; |
466 |
/* fill base line */ |
467 |
fillscanline(scanbar[0], zbar[0], sampdens, |
468 |
469 |
/* fill bar */ |
470 |
fillscanbar(scanbar, zbar, hres, ypos, ystep); |
471 |
if (directvis) /* add bitty sources */ |
472 |
drawsources(scanbar, zbar, 0, hres, ypos, ystep); |
473 |
/* write it out */ |
474 |
#ifdef SIGCONT |
475 |
signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ |
476 |
#endif |
477 |
for (i = ystep; i > 0; i--) { |
478 |
if (zfd != -1 && write(zfd, (char *)zbar[i], |
479 |
hres*sizeof(float)) |
480 |
< hres*sizeof(float)) |
481 |
goto writerr; |
482 |
if (fwritescan(scanbar[i], hres, stdout) < 0) |
483 |
goto writerr; |
484 |
485 |
if (fflush(stdout) == EOF) |
486 |
goto writerr; |
487 |
/* record progress */ |
488 |
pctdone = 100.0*(vres-1-ypos)/vres; |
489 |
if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm) |
490 |
report(0); |
491 |
#ifdef SIGCONT |
492 |
else |
493 |
494 |
#endif |
495 |
496 |
/* clean up */ |
497 |
#ifdef SIGCONT |
498 |
signal(SIGCONT, SIG_IGN); |
499 |
#endif |
500 |
if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float)) |
501 |
502 |
goto writerr; |
503 |
fwritescan(scanbar[0], hres, stdout); |
504 |
505 |
goto writerr; |
506 |
alldone: |
507 |
if (zfd != -1) { |
508 |
if (close(zfd) == -1) |
509 |
goto writerr; |
510 |
511 |
free((void *)zbar[i]); |
512 |
513 |
514 |
free((void *)scanbar[i]); |
515 |
if (sampdens != NULL) |
516 |
free(sampdens); |
517 |
pctdone = 100.0; |
518 |
if (ralrm > 0) |
519 |
report(0); |
520 |
#ifdef SIGCONT |
521 |
signal(SIGCONT, SIG_DFL); |
522 |
#endif |
523 |
return; |
524 |
writerr: |
525 |
error(SYSTEM, "write error in render"); |
526 |
memerr: |
527 |
error(SYSTEM, "out of memory in render"); |
528 |
529 |
530 |
531 |
static void |
532 |
fillscanline( /* fill scan at y */ |
533 |
COLOR *scanline, |
534 |
float *zline, |
535 |
char *sd, |
536 |
int xres, |
537 |
int y, |
538 |
int xstep |
539 |
540 |
541 |
static int nc = 0; /* number of calls */ |
542 |
int bl = xstep, b = xstep; |
543 |
double z; |
544 |
int i; |
545 |
546 |
z = pixvalue(scanline[0], 0, y); |
547 |
if (zline) zline[0] = z; |
548 |
/* zig-zag start for quincunx pattern */ |
549 |
for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) { |
550 |
if (i >= xres) { |
551 |
xstep += xres-1-i; |
552 |
i = xres-1; |
553 |
554 |
z = pixvalue(scanline[i], i, y); |
555 |
if (zline) zline[i] = z; |
556 |
if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1]; |
557 |
if (i <= xstep) |
558 |
b = fillsample(scanline, zline, 0, y, i, 0, b/2); |
559 |
else |
560 |
b = fillsample(scanline+i-xstep, |
561 |
zline ? zline+i-xstep : (float *)NULL, |
562 |
i-xstep, y, xstep, 0, b/2); |
563 |
if (sd) *sd++ = nc & 1 ? bl : b; |
564 |
bl = b; |
565 |
566 |
if (sd && nc & 1) *sd = bl; |
567 |
568 |
569 |
570 |
static void |
571 |
fillscanbar( /* fill interior */ |
572 |
COLOR *scanbar[], |
573 |
float *zbar[], |
574 |
int xres, |
575 |
int y, |
576 |
int ysize |
577 |
578 |
579 |
COLOR vline[MAXDIV+1]; |
580 |
float zline[MAXDIV+1]; |
581 |
int b = ysize; |
582 |
int i, j; |
583 |
584 |
for (i = 0; i < xres; i++) { |
585 |
copycolor(vline[0], scanbar[0][i]); |
586 |
copycolor(vline[ysize], scanbar[ysize][i]); |
587 |
if (zbar[0]) { |
588 |
zline[0] = zbar[0][i]; |
589 |
zline[ysize] = zbar[ysize][i]; |
590 |
591 |
b = fillsample(vline, zbar[0] ? zline : (float *)NULL, |
592 |
i, y, 0, ysize, b/2); |
593 |
594 |
for (j = 1; j < ysize; j++) |
595 |
copycolor(scanbar[j][i], vline[j]); |
596 |
if (zbar[0]) |
597 |
598 |
zbar[j][i] = zline[j]; |
599 |
600 |
601 |
602 |
603 |
static int |
604 |
fillsample( /* fill interior points */ |
605 |
COLOR *colline, |
606 |
float *zline, |
607 |
int x, |
608 |
int y, |
609 |
int xlen, |
610 |
int ylen, |
611 |
int b |
612 |
613 |
614 |
double ratio; |
615 |
double z; |
616 |
COLOR ctmp; |
617 |
int ncut; |
618 |
int len; |
619 |
620 |
if (xlen > 0) /* x or y length is zero */ |
621 |
len = xlen; |
622 |
else |
623 |
len = ylen; |
624 |
625 |
if (len <= 1) /* limit recursion */ |
626 |
return(0); |
627 |
628 |
if (b > 0 || |
629 |
(zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) |
630 |
|| bigdiff(colline[0], colline[len], maxdiff)) { |
631 |
632 |
z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); |
633 |
if (zline) zline[len>>1] = z; |
634 |
ncut = 1; |
635 |
} else { /* interpolate */ |
636 |
copycolor(colline[len>>1], colline[len]); |
637 |
ratio = (double)(len>>1) / len; |
638 |
scalecolor(colline[len>>1], ratio); |
639 |
if (zline) zline[len>>1] = zline[len] * ratio; |
640 |
ratio = 1.0 - ratio; |
641 |
copycolor(ctmp, colline[0]); |
642 |
scalecolor(ctmp, ratio); |
643 |
addcolor(colline[len>>1], ctmp); |
644 |
if (zline) zline[len>>1] += zline[0] * ratio; |
645 |
ncut = 0; |
646 |
647 |
/* recurse */ |
648 |
ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); |
649 |
650 |
ncut += fillsample(colline+(len>>1), |
651 |
zline ? zline+(len>>1) : (float *)NULL, |
652 |
x+(xlen>>1), y+(ylen>>1), |
653 |
xlen-(xlen>>1), ylen-(ylen>>1), b/2); |
654 |
655 |
return(ncut); |
656 |
657 |
658 |
659 |
static double |
660 |
pixvalue( /* compute pixel value */ |
661 |
COLOR col, /* returned color */ |
662 |
int x, /* pixel position */ |
663 |
int y |
664 |
665 |
666 |
extern void SDsquare2disk(double ds[2], double seedx, double seedy); |
667 |
RAY thisray; |
668 |
FVECT lorg, ldir; |
669 |
double hpos, vpos, vdist, lmax; |
670 |
int i; |
671 |
/* compute view ray */ |
672 |
setcolor(col, 0.0, 0.0, 0.0); |
673 |
hpos = (x+pixjitter())/hres; |
674 |
vpos = (y+pixjitter())/vres; |
675 |
if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, |
676 |
&ourview, hpos, vpos)) < -FTINY) |
677 |
return(0.0); |
678 |
679 |
vdist = ourview.vdist; |
680 |
/* set pixel index */ |
681 |
samplendx = pixnumber(x,y,hres,vres); |
682 |
/* optional motion blur */ |
683 |
if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir, |
684 |
&lastview, hpos, vpos)) >= -FTINY) { |
685 |
double d = mblur*(.5-urand(281+samplendx)); |
686 |
687 |
thisray.rmax = (1.-d)*thisray.rmax + d*lmax; |
688 |
for (i = 3; i--; ) { |
689 |
thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i]; |
690 |
thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i]; |
691 |
692 |
if (normalize(thisray.rdir) == 0.0) |
693 |
return(0.0); |
694 |
vdist = (1.-d)*vdist + d*lastview.vdist; |
695 |
696 |
/* optional depth-of-field */ |
697 |
if (dblur > FTINY) { |
698 |
double vc, df[2]; |
699 |
/* random point on disk */ |
700 |
SDsquare2disk(df, frandom(), frandom()); |
701 |
df[0] *= .5*dblur; |
702 |
df[1] *= .5*dblur; |
703 |
if ((ourview.type == VT_PER) | (ourview.type == VT_PAR)) { |
704 |
double adj = 1.0; |
705 |
if (ourview.type == VT_PER) |
706 |
adj /= DOT(thisray.rdir, ourview.vdir); |
707 |
df[0] /= sqrt(ourview.hn2); |
708 |
df[1] /= sqrt(ourview.vn2); |
709 |
710 |
vc = ourview.vp[i] + adj*vdist*thisray.rdir[i]; |
711 |
thisray.rorg[i] += df[0]*ourview.hvec[i] + |
712 |
df[1]*ourview.vvec[i] ; |
713 |
thisray.rdir[i] = vc - thisray.rorg[i]; |
714 |
715 |
} else { /* non-standard view case */ |
716 |
double dfd = PI/4.*dblur*(.5 - frandom()); |
717 |
if ((ourview.type != VT_ANG) & (ourview.type != VT_PLS)) { |
718 |
if (ourview.type != VT_CYL) |
719 |
720 |
721 |
722 |
723 |
vc = ourview.vp[i] + vdist*thisray.rdir[i]; |
724 |
725 |
df[1]*ourview.vvec[i] + |
726 |
dfd*ourview.vdir[i] ; |
727 |
728 |
729 |
730 |
731 |
return(0.0); |
732 |
733 |
734 |
rayorigin(&thisray, PRIMARY, NULL, NULL); |
735 |
736 |
rayvalue(&thisray); /* trace ray */ |
737 |
738 |
copycolor(col, thisray.rcol); /* return color */ |
739 |
740 |
return(thisray.rt); /* return distance */ |
741 |
742 |
743 |
744 |
static int |
745 |
salvage( /* salvage scanlines from killed program */ |
746 |
char *oldfile |
747 |
748 |
749 |
COLR *scanline; |
750 |
FILE *fp; |
751 |
int x, y; |
752 |
753 |
if (oldfile == NULL) |
754 |
goto gotzip; |
755 |
756 |
if ((fp = fopen(oldfile, "r")) == NULL) { |
757 |
sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); |
758 |
759 |
goto gotzip; |
760 |
761 |
SET_FILE_BINARY(fp); |
762 |
/* discard header */ |
763 |
getheader(fp, NULL, NULL); |
764 |
/* get picture size */ |
765 |
if (!fscnresolu(&x, &y, fp)) { |
766 |
sprintf(errmsg, "bad recover file \"%s\" - not removed", |
767 |
oldfile); |
768 |
769 |
fclose(fp); |
770 |
goto gotzip; |
771 |
772 |
773 |
if ((x != hres) | (y != vres)) { |
774 |
sprintf(errmsg, "resolution mismatch in recover file \"%s\"", |
775 |
oldfile); |
776 |
777 |
778 |
779 |
scanline = (COLR *)malloc(hres*sizeof(COLR)); |
780 |
if (scanline == NULL) |
781 |
error(SYSTEM, "out of memory in salvage"); |
782 |
for (y = 0; y < vres; y++) { |
783 |
if (freadcolrs(scanline, hres, fp) < 0) |
784 |
break; |
785 |
if (fwritecolrs(scanline, hres, stdout) < 0) |
786 |
goto writerr; |
787 |
788 |
789 |
goto writerr; |
790 |
free((void *)scanline); |
791 |
fclose(fp); |
792 |
unlink(oldfile); |
793 |
return(y); |
794 |
gotzip: |
795 |
796 |
error(SYSTEM, "error writing picture header"); |
797 |
return(0); |
798 |
writerr: |
799 |
sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); |
800 |
801 |
return -1; /* pro forma return */ |
802 |
803 |
804 |
static int |
805 |
pixnumber( /* compute pixel index (screen door) */ |
806 |
int x, |
807 |
int y, |
808 |
int xres, |
809 |
int yres |
810 |
811 |
812 |
unsigned nbits = 0; |
813 |
bitmask_t coord[2]; |
814 |
815 |
if (xres < yres) xres = yres; |
816 |
while (xres > 0) { |
817 |
xres >>= 1; |
818 |
++nbits; |
819 |
820 |
coord[0] = x; coord[1] = y; |
821 |
return ((int)hilbert_c2i(2, nbits, coord)); |
822 |
