| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* rpict.c - routines and variables for picture generation.
| 9 |
| 10 |
* 8/14/85
| 11 |
| 12 |
| 13 |
#include "ray.h"
| 14 |
| 15 |
#ifdef BSD
| 16 |
#include <sys/time.h>
| 17 |
#include <sys/resource.h>
| 18 |
#endif
| 19 |
| 20 |
#include <signal.h>
| 21 |
#include <fcntl.h>
| 22 |
| 23 |
#include "view.h"
| 24 |
| 25 |
#include "resolu.h"
| 26 |
| 27 |
#include "random.h"
| 28 |
| 29 |
int dimlist[MAXDIM]; /* sampling dimensions */
| 30 |
int ndims = 0; /* number of sampling dimensions */
| 31 |
int samplendx; /* sample index number */
| 32 |
| 33 |
VIEW ourview = STDVIEW; /* view parameters */
| 34 |
int hresolu = 512; /* horizontal resolution */
| 35 |
int vresolu = 512; /* vertical resolution */
| 36 |
double pixaspect = 1.0; /* pixel aspect ratio */
| 37 |
| 38 |
int psample = 4; /* pixel sample size */
| 39 |
double maxdiff = .05; /* max. difference for interpolation */
| 40 |
double dstrpix = 0.67; /* square pixel distribution */
| 41 |
| 42 |
double dstrsrc = 0.0; /* square source distribution */
| 43 |
double shadthresh = .05; /* shadow threshold */
| 44 |
double shadcert = .5; /* shadow certainty */
| 45 |
int directrelay = 1; /* number of source relays */
| 46 |
int vspretest = 512; /* virtual source pretest density */
| 47 |
int directinvis = 0; /* sources invisible? */
| 48 |
double srcsizerat = .25; /* maximum ratio source size/dist. */
| 49 |
| 50 |
double specthresh = .15; /* specular sampling threshold */
| 51 |
double specjitter = 1.; /* specular sampling jitter */
| 52 |
| 53 |
int maxdepth = 6; /* maximum recursion depth */
| 54 |
double minweight = 5e-3; /* minimum ray weight */
| 55 |
| 56 |
COLOR ambval = BLKCOLOR; /* ambient value */
| 57 |
double ambacc = 0.2; /* ambient accuracy */
| 58 |
int ambres = 32; /* ambient resolution */
| 59 |
int ambdiv = 128; /* ambient divisions */
| 60 |
int ambssamp = 0; /* ambient super-samples */
| 61 |
int ambounce = 0; /* ambient bounces */
| 62 |
char *amblist[128]; /* ambient include/exclude list */
| 63 |
int ambincl = -1; /* include == 1, exclude == 0 */
| 64 |
| 65 |
int ralrm = 0; /* seconds between reports */
| 66 |
| 67 |
double pctdone = 0.0; /* percentage done */
| 68 |
| 69 |
long tlastrept = 0L; /* time at last report */
| 70 |
| 71 |
extern long time();
| 72 |
extern long tstart; /* starting time */
| 73 |
| 74 |
extern long nrays; /* number of rays traced */
| 75 |
| 76 |
#define MAXDIV 16 /* maximum sample size */
| 77 |
| 78 |
#define pixjitter() (.5+dstrpix*(.5-frandom()))
| 79 |
| 80 |
#define HFTEMPLATE "/tmp/hfXXXXXX"
| 81 |
| 82 |
static char *hfname = NULL; /* header file name */
| 83 |
static FILE *hfp = NULL; /* header file pointer */
| 84 |
| 85 |
static int hres, vres; /* resolution for this frame */
| 86 |
| 87 |
extern char *mktemp();
| 88 |
| 89 |
double pixvalue();
| 90 |
| 91 |
| 92 |
quit(code) /* quit program */
| 93 |
int code;
| 94 |
| 95 |
if (code) /* report status */
| 96 |
report();
| 97 |
if (hfname != NULL) { /* delete header file */
| 98 |
if (hfp != NULL)
| 99 |
fclose(hfp);
| 100 |
unlink(hfname);
| 101 |
| 102 |
exit(code);
| 103 |
| 104 |
| 105 |
| 106 |
#ifdef BSD
| 107 |
report() /* report progress */
| 108 |
| 109 |
struct rusage rubuf;
| 110 |
double t;
| 111 |
| 112 |
getrusage(RUSAGE_SELF, &rubuf);
| 113 |
t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
| 114 |
t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
| 115 |
getrusage(RUSAGE_CHILDREN, &rubuf);
| 116 |
t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
| 117 |
| 118 |
| 119 |
sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n",
| 120 |
nrays, pctdone, t/3600.0);
| 121 |
eputs(errmsg);
| 122 |
tlastrept = time((long *)0);
| 123 |
| 124 |
#else
| 125 |
| 126 |
| 127 |
| 128 |
sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n",
| 129 |
nrays, pctdone, (tlastrept-tstart)/3600.0);
| 130 |
eputs(errmsg);
| 131 |
signal(SIGALRM, report);
| 132 |
| 133 |
#endif
| 134 |
| 135 |
| 136 |
openheader() /* save standard output to header file */
| 137 |
| 138 |
hfname = mktemp(HFTEMPLATE);
| 139 |
if (freopen(hfname, "w", stdout) == NULL) {
| 140 |
sprintf(errmsg, "cannot open header file \"%s\"", hfname);
| 141 |
error(SYSTEM, errmsg);
| 142 |
| 143 |
| 144 |
| 145 |
| 146 |
closeheader() /* done with header output */
| 147 |
| 148 |
if (hfname == NULL)
| 149 |
return;
| 150 |
if (fflush(stdout) == EOF || (hfp = fopen(hfname, "r")) == NULL)
| 151 |
error(SYSTEM, "error reopening header file");
| 152 |
| 153 |
| 154 |
| 155 |
dupheader() /* repeat header on standard output */
| 156 |
| 157 |
register int c;
| 158 |
| 159 |
if (fseek(hfp, 0L, 0) < 0)
| 160 |
error(SYSTEM, "seek error on header file");
| 161 |
while ((c = getc(hfp)) != EOF)
| 162 |
putchar(c);
| 163 |
| 164 |
| 165 |
| 166 |
rpict(seq, pout, zout, prvr) /* generate image(s) */
| 167 |
int seq;
| 168 |
char *pout, *zout, *prvr;
| 169 |
| 170 |
* If seq is greater than zero, then we will render a sequence of
| 171 |
* images based on view parameter strings read from the standard input.
| 172 |
* If pout is NULL, then all images will be sent to the standard ouput.
| 173 |
* If seq is greater than zero and prvr is an integer, then it is the
| 174 |
* frame number at which rendering should begin. Preceeding view parameter
| 175 |
* strings will be skipped in the input.
| 176 |
* If pout and prvr are the same, prvr is renamed to avoid overwriting.
| 177 |
* Note that pout and zout should contain %d format specifications for
| 178 |
* sequenced file naming.
| 179 |
| 180 |
| 181 |
extern char *rindex(), *strncpy(), *strcat();
| 182 |
char fbuf[128], fbuf2[128], *zf;
| 183 |
RESOLU rs;
| 184 |
double pa;
| 185 |
/* finished writing header */
| 186 |
closeheader();
| 187 |
/* check sampling */
| 188 |
if (psample < 1)
| 189 |
psample = 1;
| 190 |
else if (psample > MAXDIV) {
| 191 |
sprintf(errmsg, "pixel sampling reduced from %d to %d",
| 192 |
psample, MAXDIV);
| 193 |
error(WARNING, errmsg);
| 194 |
psample = MAXDIV;
| 195 |
| 196 |
/* get starting frame */
| 197 |
if (seq <= 0)
| 198 |
seq = 0;
| 199 |
else if (prvr != NULL && isint(prvr)) {
| 200 |
int rn; /* skip to specified view */
| 201 |
if ((rn = atoi(prvr)) < seq)
| 202 |
error(USER, "recover frame less than start frame");
| 203 |
if (pout == NULL)
| 204 |
error(USER, "missing output file specification");
| 205 |
for ( ; seq < rn; seq++)
| 206 |
if (nextview(stdin) == EOF)
| 207 |
error(USER, "unexpected EOF on view input");
| 208 |
prvr = fbuf; /* mark for renaming */
| 209 |
| 210 |
if (pout != NULL) {
| 211 |
sprintf(fbuf, pout, seq);
| 212 |
if (!strcmp(prvr, fbuf)) { /* rename recover file */
| 213 |
fbuf2[0] = '\0';
| 214 |
if ((prvr = rindex(fbuf, '/')) != NULL)
| 215 |
strncpy(fbuf2, fbuf, prvr-fbuf+1);
| 216 |
strcat(fbuf2, "rfXXXXXX");
| 217 |
prvr = mktemp(fbuf2);
| 218 |
if (rename(fbuf, prvr) < 0 && errno != ENOENT) {
| 219 |
sprintf(errmsg,
| 220 |
"cannot rename \"%s\" to \"%s\"",
| 221 |
fbuf, prvr);
| 222 |
| 223 |
| 224 |
| 225 |
| 226 |
/* render sequence */
| 227 |
do {
| 228 |
if (seq && nextview(stdin) == EOF)
| 229 |
break;
| 230 |
if (pout != NULL) {
| 231 |
| 232 |
if (freopen(fbuf, "w", stdout) == NULL) {
| 233 |
sprintf(errmsg,
| 234 |
"cannot open output file \"%s\"", fbuf);
| 235 |
| 236 |
| 237 |
dupheader();
| 238 |
| 239 |
hres = hresolu; vres = vresolu; pa = pixaspect;
| 240 |
if (prvr != NULL)
| 241 |
if (viewfile(prvr, &ourview, &rs) <= 0
| 242 |
|| rs.or != PIXSTANDARD) {
| 243 |
sprintf(errmsg,
| 244 |
"cannot recover view parameters from \"%s\"", prvr);
| 245 |
| 246 |
} else {
| 247 |
char *err;
| 248 |
if ((err = setview(&ourview)) != NULL)
| 249 |
error(USER, err);
| 250 |
pa = 0.0;
| 251 |
hres = scanlen(&rs);
| 252 |
vres = numscans(&rs);
| 253 |
| 254 |
normaspect(viewaspect(&ourview), &pa, &hres, &vres);
| 255 |
if (seq) {
| 256 |
if (ralrm > 0) {
| 257 |
sprintf(errmsg, "starting frame %d\n", seq);
| 258 |
eputs(errmsg);
| 259 |
| 260 |
printf("FRAME=%d\n", seq);
| 261 |
| 262 |
fputs(VIEWSTR, stdout);
| 263 |
fprintview(&ourview, stdout);
| 264 |
putchar('\n');
| 265 |
if (pa < .99 || pa > 1.01)
| 266 |
fputaspect(pa, stdout);
| 267 |
fputformat(COLRFMT, stdout);
| 268 |
putchar('\n');
| 269 |
if (zout != NULL)
| 270 |
sprintf(zf=fbuf, zout, seq);
| 271 |
else
| 272 |
zf = NULL;
| 273 |
render(zf, prvr);
| 274 |
prvr = NULL;
| 275 |
} while (seq++);
| 276 |
| 277 |
| 278 |
| 279 |
nextview(fp) /* get next view from fp */
| 280 |
FILE *fp;
| 281 |
| 282 |
char linebuf[256], *err;
| 283 |
| 284 |
while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
| 285 |
if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) {
| 286 |
| 287 |
error(USER, err);
| 288 |
return(0);
| 289 |
| 290 |
return(EOF);
| 291 |
| 292 |
| 293 |
| 294 |
render(zfile, oldfile) /* render the scene */
| 295 |
char *zfile, *oldfile;
| 296 |
| 297 |
extern long lseek();
| 298 |
COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
| 299 |
float *zbar[MAXDIV+1]; /* z values */
| 300 |
char *sampdens; /* previous sample density */
| 301 |
int ypos; /* current scanline */
| 302 |
int ystep; /* current y step size */
| 303 |
int hstep; /* h step size */
| 304 |
int zfd;
| 305 |
COLOR *colptr;
| 306 |
float *zptr;
| 307 |
register int i;
| 308 |
/* allocate scanlines */
| 309 |
for (i = 0; i <= psample; i++) {
| 310 |
scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
| 311 |
if (scanbar[i] == NULL)
| 312 |
goto memerr;
| 313 |
| 314 |
hstep = (psample*140+49)/99; /* quincunx sampling */
| 315 |
ystep = (psample*99+70)/140;
| 316 |
if (hstep > 2) {
| 317 |
i = hres/hstep + 2;
| 318 |
if ((sampdens = malloc(i)) == NULL)
| 319 |
goto memerr;
| 320 |
while (i--)
| 321 |
sampdens[i] = hstep;
| 322 |
} else
| 323 |
sampdens = NULL;
| 324 |
/* open z file */
| 325 |
if (zfile != NULL) {
| 326 |
if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
| 327 |
sprintf(errmsg, "cannot open z file \"%s\"", zfile);
| 328 |
| 329 |
| 330 |
| 331 |
zbar[i] = (float *)malloc(hres*sizeof(float));
| 332 |
if (zbar[i] == NULL)
| 333 |
goto memerr;
| 334 |
| 335 |
} else {
| 336 |
zfd = -1;
| 337 |
| 338 |
zbar[i] = NULL;
| 339 |
| 340 |
/* write out boundaries */
| 341 |
fprtresolu(hres, vres, stdout);
| 342 |
/* recover file and compute first */
| 343 |
i = salvage(oldfile);
| 344 |
if (zfd != -1 && i > 0 &&
| 345 |
lseek(zfd, (long)i*hres*sizeof(float), 0) == -1)
| 346 |
error(SYSTEM, "z file seek error in render");
| 347 |
pctdone = 100.0*i/vres;
| 348 |
if (ralrm > 0) /* report init stats */
| 349 |
report();
| 350 |
#ifndef BSD
| 351 |
else
| 352 |
#endif
| 353 |
| 354 |
ypos = vres-1 - i;
| 355 |
fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
| 356 |
/* compute scanlines */
| 357 |
for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
| 358 |
/* bottom adjust? */
| 359 |
if (ypos < 0) {
| 360 |
ystep += ypos;
| 361 |
ypos = 0;
| 362 |
| 363 |
colptr = scanbar[ystep]; /* move base to top */
| 364 |
scanbar[ystep] = scanbar[0];
| 365 |
scanbar[0] = colptr;
| 366 |
zptr = zbar[ystep];
| 367 |
zbar[ystep] = zbar[0];
| 368 |
zbar[0] = zptr;
| 369 |
/* fill base line */
| 370 |
| 371 |
hres, ypos, hstep);
| 372 |
/* fill bar */
| 373 |
fillscanbar(scanbar, zbar, hres, ypos, ystep);
| 374 |
/* write it out */
| 375 |
#ifndef BSD
| 376 |
signal(SIGALRM, SIG_IGN); /* don't interrupt writes */
| 377 |
#endif
| 378 |
for (i = ystep; i > 0; i--) {
| 379 |
if (zfd != -1 && write(zfd, (char *)zbar[i],
| 380 |
hres*sizeof(float))
| 381 |
< hres*sizeof(float))
| 382 |
goto writerr;
| 383 |
if (fwritescan(scanbar[i], hres, stdout) < 0)
| 384 |
goto writerr;
| 385 |
| 386 |
if (fflush(stdout) == EOF)
| 387 |
goto writerr;
| 388 |
/* record progress */
| 389 |
pctdone = 100.0*(vres-1-ypos)/vres;
| 390 |
if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm)
| 391 |
report();
| 392 |
#ifndef BSD
| 393 |
else
| 394 |
| 395 |
#endif
| 396 |
| 397 |
/* clean up */
| 398 |
| 399 |
if (zfd != -1) {
| 400 |
if (write(zfd, (char *)zbar[0], hres*sizeof(float))
| 401 |
| 402 |
goto writerr;
| 403 |
if (close(zfd) == -1)
| 404 |
goto writerr;
| 405 |
| 406 |
free((char *)zbar[i]);
| 407 |
| 408 |
fwritescan(scanbar[0], hres, stdout);
| 409 |
| 410 |
goto writerr;
| 411 |
| 412 |
free((char *)scanbar[i]);
| 413 |
if (sampdens != NULL)
| 414 |
free(sampdens);
| 415 |
pctdone = 100.0;
| 416 |
return;
| 417 |
writerr:
| 418 |
error(SYSTEM, "write error in render");
| 419 |
memerr:
| 420 |
error(SYSTEM, "out of memory in render");
| 421 |
| 422 |
| 423 |
| 424 |
fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */
| 425 |
register COLOR *scanline;
| 426 |
register float *zline;
| 427 |
register char *sd;
| 428 |
int xres, y, xstep;
| 429 |
| 430 |
static int nc = 0; /* number of calls */
| 431 |
int bl = xstep, b = xstep;
| 432 |
double z;
| 433 |
register int i;
| 434 |
| 435 |
z = pixvalue(scanline[0], 0, y);
| 436 |
if (zline) zline[0] = z;
| 437 |
/* zig-zag start for quincunx pattern */
| 438 |
for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
| 439 |
if (i >= xres) {
| 440 |
xstep += xres-1-i;
| 441 |
i = xres-1;
| 442 |
| 443 |
z = pixvalue(scanline[i], i, y);
| 444 |
if (zline) zline[i] = z;
| 445 |
if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
| 446 |
if (i <= xstep)
| 447 |
b = fillsample(scanline, zline, 0, y, i, 0, b/2);
| 448 |
else
| 449 |
b = fillsample(scanline+i-xstep,
| 450 |
zline ? zline+i-xstep : NULL,
| 451 |
i-xstep, y, xstep, 0, b/2);
| 452 |
if (sd) *sd++ = nc & 1 ? bl : b;
| 453 |
bl = b;
| 454 |
| 455 |
if (sd && nc & 1) *sd = bl;
| 456 |
| 457 |
| 458 |
| 459 |
fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
| 460 |
register COLOR *scanbar[];
| 461 |
register float *zbar[];
| 462 |
int xres, y, ysize;
| 463 |
| 464 |
COLOR vline[MAXDIV+1];
| 465 |
float zline[MAXDIV+1];
| 466 |
int b = ysize;
| 467 |
register int i, j;
| 468 |
| 469 |
for (i = 0; i < xres; i++) {
| 470 |
| 471 |
copycolor(vline[0], scanbar[0][i]);
| 472 |
copycolor(vline[ysize], scanbar[ysize][i]);
| 473 |
if (zbar[0]) {
| 474 |
zline[0] = zbar[0][i];
| 475 |
zline[ysize] = zbar[ysize][i];
| 476 |
| 477 |
| 478 |
b = fillsample(vline, zbar[0] ? zline : NULL,
| 479 |
i, y, 0, ysize, b/2);
| 480 |
| 481 |
for (j = 1; j < ysize; j++)
| 482 |
copycolor(scanbar[j][i], vline[j]);
| 483 |
if (zbar[0])
| 484 |
| 485 |
zbar[j][i] = zline[j];
| 486 |
| 487 |
| 488 |
| 489 |
| 490 |
int
| 491 |
fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
| 492 |
register COLOR *colline;
| 493 |
| 494 |
int x, y;
| 495 |
int xlen, ylen;
| 496 |
int b;
| 497 |
| 498 |
extern double fabs();
| 499 |
double ratio;
| 500 |
double z;
| 501 |
COLOR ctmp;
| 502 |
int ncut;
| 503 |
register int len;
| 504 |
| 505 |
if (xlen > 0) /* x or y length is zero */
| 506 |
len = xlen;
| 507 |
else
| 508 |
len = ylen;
| 509 |
| 510 |
if (len <= 1) /* limit recursion */
| 511 |
return(0);
| 512 |
| 513 |
if (b > 0
| 514 |
|| (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
| 515 |
|| bigdiff(colline[0], colline[len], maxdiff)) {
| 516 |
| 517 |
z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
| 518 |
if (zline) zline[len>>1] = z;
| 519 |
ncut = 1;
| 520 |
| 521 |
} else { /* interpolate */
| 522 |
| 523 |
copycolor(colline[len>>1], colline[len]);
| 524 |
ratio = (double)(len>>1) / len;
| 525 |
scalecolor(colline[len>>1], ratio);
| 526 |
if (zline) zline[len>>1] = zline[len] * ratio;
| 527 |
ratio = 1.0 - ratio;
| 528 |
copycolor(ctmp, colline[0]);
| 529 |
scalecolor(ctmp, ratio);
| 530 |
addcolor(colline[len>>1], ctmp);
| 531 |
if (zline) zline[len>>1] += zline[0] * ratio;
| 532 |
ncut = 0;
| 533 |
| 534 |
/* recurse */
| 535 |
ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
| 536 |
| 537 |
ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL,
| 538 |
x+(xlen>>1), y+(ylen>>1),
| 539 |
xlen-(xlen>>1), ylen-(ylen>>1), b/2);
| 540 |
| 541 |
return(ncut);
| 542 |
| 543 |
| 544 |
| 545 |
double
| 546 |
pixvalue(col, x, y) /* compute pixel value */
| 547 |
COLOR col; /* returned color */
| 548 |
int x, y; /* pixel position */
| 549 |
| 550 |
static RAY thisray;
| 551 |
| 552 |
if (viewray(thisray.rorg, thisray.rdir, &ourview,
| 553 |
(x+pixjitter())/hres, (y+pixjitter())/vres) < 0) {
| 554 |
setcolor(col, 0.0, 0.0, 0.0);
| 555 |
return(0.0);
| 556 |
| 557 |
| 558 |
rayorigin(&thisray, NULL, PRIMARY, 1.0);
| 559 |
| 560 |
samplendx = pixnumber(x,y,hres,vres); /* set pixel index */
| 561 |
| 562 |
rayvalue(&thisray); /* trace ray */
| 563 |
| 564 |
copycolor(col, thisray.rcol); /* return color */
| 565 |
| 566 |
return(thisray.rt); /* return distance */
| 567 |
| 568 |
| 569 |
| 570 |
int
| 571 |
salvage(oldfile) /* salvage scanlines from killed program */
| 572 |
char *oldfile;
| 573 |
| 574 |
COLR *scanline;
| 575 |
FILE *fp;
| 576 |
int x, y;
| 577 |
| 578 |
if (oldfile == NULL)
| 579 |
return(0);
| 580 |
| 581 |
if ((fp = fopen(oldfile, "r")) == NULL) {
| 582 |
sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
| 583 |
| 584 |
return(0);
| 585 |
| 586 |
/* discard header */
| 587 |
getheader(fp, NULL);
| 588 |
/* get picture size */
| 589 |
if (!fscnresolu(&x, &y, fp)) {
| 590 |
sprintf(errmsg, "bad recover file \"%s\"", oldfile);
| 591 |
| 592 |
fclose(fp);
| 593 |
return(0);
| 594 |
| 595 |
| 596 |
if (x != hres || y != vres) {
| 597 |
sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
| 598 |
oldfile);
| 599 |
error(USER, errmsg);
| 600 |
| 601 |
| 602 |
scanline = (COLR *)malloc(hres*sizeof(COLR));
| 603 |
if (scanline == NULL)
| 604 |
error(SYSTEM, "out of memory in salvage");
| 605 |
for (y = 0; y < vres; y++) {
| 606 |
if (freadcolrs(scanline, hres, fp) < 0)
| 607 |
break;
| 608 |
if (fwritecolrs(scanline, hres, stdout) < 0)
| 609 |
goto writerr;
| 610 |
| 611 |
| 612 |
goto writerr;
| 613 |
free((char *)scanline);
| 614 |
fclose(fp);
| 615 |
unlink(oldfile);
| 616 |
return(y);
| 617 |
writerr:
| 618 |
error(SYSTEM, "write error in salvage");
| 619 |
| 620 |
| 621 |
| 622 |
int
| 623 |
pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
| 624 |
register int x, y;
| 625 |
int xres, yres;
| 626 |
| 627 |
x -= y;
| 628 |
while (x < 0)
| 629 |
x += xres;
| 630 |
return((((x>>2)*yres + y) << 2) + (x & 3));
| 631 |
