root/radiance/ray/src/rt/rpict.c
Revision: 2.69
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.68: +91 -52 lines
2 static const char RCSid[] = "$Id";
5 * rpict.c - routines and variables for picture generation.
6 */
7
8 #include "copyright.h"
9
10 #include <sys/types.h>
11
12 #ifndef NON_POSIX
13 #ifdef BSD
14 #include <sys/time.h>
15 #include <sys/resource.h>
16 #else
17 #include <sys/times.h>
18 #include <unistd.h>
19 #endif
20 #endif
21
22 #include <time.h>
23 #include <signal.h>
24
25 #include "platform.h"
26 #include "ray.h"
27 #include "paths.h"
28 #include "ambient.h"
29 #include "view.h"
30 #include "random.h"
31 #include "paths.h"
32 #include "rtmisc.h" /* myhostname() */
33
34
35 #define RFTEMPLATE "rfXXXXXX"
36
37 #ifndef SIGCONT
38 #ifdef SIGIO /* XXX can we live without this? */
39 #define SIGCONT SIGIO
40 #endif
41 #endif
42
43 CUBE thescene; /* our scene */
44 OBJECT nsceneobjs; /* number of objects in our scene */
45
46 int dimlist[MAXDIM]; /* sampling dimensions */
47 int ndims = 0; /* number of sampling dimensions */
48 int samplendx; /* sample index number */
49
50 //extern void ambnotify();
51 void (*addobjnotify[])() = {ambnotify, NULL};
52
53 VIEW ourview = STDVIEW; /* view parameters */
54 int hresolu = 512; /* horizontal resolution */
55 int vresolu = 512; /* vertical resolution */
56 double pixaspect = 1.0; /* pixel aspect ratio */
57
58 int psample = 4; /* pixel sample size */
59 double maxdiff = .05; /* max. difference for interpolation */
60 double dstrpix = 0.67; /* square pixel distribution */
61
62 double mblur = 0.; /* motion blur parameter */
63
64 void (*trace)() = NULL; /* trace call */
65
66 int do_irrad = 0; /* compute irradiance? */
67
68 double dstrsrc = 0.0; /* square source distribution */
69 double shadthresh = .05; /* shadow threshold */
70 double shadcert = .5; /* shadow certainty */
71 int directrelay = 1; /* number of source relays */
72 int vspretest = 512; /* virtual source pretest density */
73 int directvis = 1; /* sources visible? */
74 double srcsizerat = .25; /* maximum ratio source size/dist. */
75
76 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
77 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
78 double seccg = 0.; /* global scattering eccentricity */
79 double ssampdist = 0.; /* scatter sampling distance */
80
81 double specthresh = .15; /* specular sampling threshold */
82 double specjitter = 1.; /* specular sampling jitter */
83
84 int backvis = 1; /* back face visibility */
85
86 int maxdepth = 7; /* maximum recursion depth */
87 double minweight = 4e-3; /* minimum ray weight */
88
89 char *ambfile = NULL; /* ambient file name */
90 COLOR ambval = BLKCOLOR; /* ambient value */
91 int ambvwt = 0; /* initial weight for ambient value */
92 double ambacc = 0.2; /* ambient accuracy */
93 int ambres = 64; /* ambient resolution */
94 int ambdiv = 512; /* ambient divisions */
95 int ambssamp = 128; /* ambient super-samples */
96 int ambounce = 0; /* ambient bounces */
97 char *amblist[128]; /* ambient include/exclude list */
98 int ambincl = -1; /* include == 1, exclude == 0 */
99
100 int ralrm = 0; /* seconds between reports */
101
102 double pctdone = 0.0; /* percentage done */
103 time_t tlastrept = 0L; /* time at last report */
104 time_t tstart; /* starting time */
105
106 #define MAXDIV 16 /* maximum sample size */
107
108 #define pixjitter() (.5+dstrpix*(.5-frandom()))
109
110 int hres, vres; /* resolution for this frame */
111
112 static VIEW lastview; /* the previous view input */
113
114 //extern char *mktemp(); /* XXX should be in stdlib.h or unistd.h */
115
116 //double pixvalue();
117
118 static void report(int);
119 static int nextview(FILE *fp);
120 static void render(char *zfile, char *oldfile);
121 static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres,
122 int y, int xstep);
123 static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres,
124 int y, int ysize);
125 static int fillsample(COLOR *colline, float *zline, int x, int y,
126 int xlen, int ylen, int b);
127 static double pixvalue(COLOR col, int x, int y);
128 static int salvage(char *oldfile);
129 static int pixnumber(int x, int y, int xres, int yres);
130
131
132
133 #ifdef RHAS_STAT
134 #include <sys/types.h>
135 #include <sys/stat.h>
136 int
137 file_exists(fname) /* ordinary file exists? */
138 char *fname;
139 {
140 struct stat sbuf;
141 if (stat(fname, &sbuf) < 0) return(0);
142 return((sbuf.st_mode & S_IFREG) != 0);
143 }
144 #else
145 #define file_exists(f) (access(f,F_OK)==0)
146 #endif
147
148
149 void
150 quit(code) /* quit program */
151 int code;
152 {
153 if (code) /* report status */
154 report(0);
155 #ifndef NON_POSIX
156 headclean(); /* delete header file */
157 pfclean(); /* clean up persist files */
158 #endif
159 exit(code);
160 }
161
162
163 #ifndef NON_POSIX
164 static void
165 report(int dummy) /* report progress */
166 {
167 double u, s;
168 #ifdef BSD
169 struct rusage rubuf;
170 #else
171 struct tms tbuf;
172 double period;
173 #endif
174
175 tlastrept = time((time_t *)NULL);
176 #ifdef BSD
177 getrusage(RUSAGE_SELF, &rubuf);
178 u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6;
179 s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6;
180 getrusage(RUSAGE_CHILDREN, &rubuf);
181 u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6;
182 s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6;
183 #else
184 times(&tbuf);
185 #ifdef _SC_CLK_TCK
186 period = 1.0 / sysconf(_SC_CLK_TCK);
187 #else
188 period = 1.0 / 60.0;
189 #endif
190 u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period;
191 s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period;
192 #endif
193
194 sprintf(errmsg,
195 "%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n",
196 nrays, pctdone, u/3600., s/3600.,
197 (tlastrept-tstart)/3600., myhostname());
198 eputs(errmsg);
199 #ifdef SIGCONT
200 signal(SIGCONT, report);
201 #endif
202 }
203 #else
204 static void
205 report(int) /* report progress */
206 {
207 tlastrept = time((time_t *)NULL);
208 sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n",
209 nrays, pctdone, (tlastrept-tstart)/3600.0);
210 eputs(errmsg);
211 }
212 #endif
213
214
215 extern void
216 rpict( /* generate image(s) */
217 int seq,
218 char *pout,
219 char *zout,
220 char *prvr
221 )
222 /*
223 * If seq is greater than zero, then we will render a sequence of
224 * images based on view parameter strings read from the standard input.
225 * If pout is NULL, then all images will be sent to the standard ouput.
226 * If seq is greater than zero and prvr is an integer, then it is the
227 * frame number at which rendering should begin. Preceeding view parameter
228 * strings will be skipped in the input.
229 * If pout and prvr are the same, prvr is renamed to avoid overwriting.
230 * Note that pout and zout should contain %d format specifications for
231 * sequenced file naming.
232 */
233 {
234 char fbuf[128], fbuf2[128];
235 int npicts;
236 register char *cp;
237 RESOLU rs;
238 double pa;
239 /* check sampling */
240 if (psample < 1)
241 psample = 1;
242 else if (psample > MAXDIV) {
243 sprintf(errmsg, "pixel sampling reduced from %d to %d",
244 psample, MAXDIV);
245 error(WARNING, errmsg);
246 psample = MAXDIV;
247 }
248 /* get starting frame */
249 if (seq <= 0)
250 seq = 0;
251 else if (prvr != NULL && isint(prvr)) {
252 register int rn; /* skip to specified view */
253 if ((rn = atoi(prvr)) < seq)
254 error(USER, "recover frame less than start frame");
255 if (pout == NULL)
256 error(USER, "missing output file specification");
257 for ( ; seq < rn; seq++)
258 if (nextview(stdin) == EOF)
259 error(USER, "unexpected EOF on view input");
260 setview(&ourview);
261 prvr = fbuf; /* mark for renaming */
262 }
263 if ((pout != NULL) & (prvr != NULL)) {
264 sprintf(fbuf, pout, seq);
265 if (!strcmp(prvr, fbuf)) { /* rename */
266 strcpy(fbuf2, fbuf);
267 for (cp = fbuf2; *cp; cp++)
268 ;
269 while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
270 cp--;
271 strcpy(cp, RFTEMPLATE);
272 prvr = mktemp(fbuf2);
273 if (rename(fbuf, prvr) < 0) {
274 if (errno == ENOENT) { /* ghost file */
275 sprintf(errmsg,
276 "new output file \"%s\"",
277 fbuf);
278 error(WARNING, errmsg);
279 prvr = NULL;
280 } else { /* serious error */
281 sprintf(errmsg,
282 "cannot rename \"%s\" to \"%s\"",
283 fbuf, prvr);
284 error(SYSTEM, errmsg);
285 }
286 }
287 }
288 }
289 npicts = 0; /* render sequence */
290 do {
291 if (seq && nextview(stdin) == EOF)
292 break;
293 pctdone = 0.0;
294 if (pout != NULL) {
295 sprintf(fbuf, pout, seq);
296 if (file_exists(fbuf)) {
297 if (prvr != NULL || !strcmp(fbuf, pout)) {
298 sprintf(errmsg,
299 "output file \"%s\" exists",
300 fbuf);
301 error(USER, errmsg);
302 }
303 setview(&ourview);
304 continue; /* don't clobber */
305 }
306 if (freopen(fbuf, "w", stdout) == NULL) {
307 sprintf(errmsg,
308 "cannot open output file \"%s\"", fbuf);
309 error(SYSTEM, errmsg);
310 }
311 SET_FILE_BINARY(stdout);
312 dupheader();
313 }
314 hres = hresolu; vres = vresolu; pa = pixaspect;
315 if (prvr != NULL) {
316 if (viewfile(prvr, &ourview, &rs) <= 0) {
317 sprintf(errmsg,
318 "cannot recover view parameters from \"%s\"", prvr);
319 error(WARNING, errmsg);
320 } else {
321 pa = 0.0;
322 hres = scanlen(&rs);
323 vres = numscans(&rs);
324 }
325 }
326 if ((cp = setview(&ourview)) != NULL)
327 error(USER, cp);
328 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
329 if (seq) {
330 if (ralrm > 0) {
331 fprintf(stderr, "FRAME %d:", seq);
332 fprintview(&ourview, stderr);
333 putc('\n', stderr);
334 fflush(stderr);
335 }
336 printf("FRAME=%d\n", seq);
337 }
338 fputs(VIEWSTR, stdout);
339 fprintview(&ourview, stdout);
340 putchar('\n');
341 if (pa < .99 || pa > 1.01)
342 fputaspect(pa, stdout);
343 fputnow(stdout);
344 fputformat(COLRFMT, stdout);
345 putchar('\n');
346 if (zout != NULL)
347 sprintf(cp=fbuf, zout, seq);
348 else
349 cp = NULL;
350 render(cp, prvr);
351 prvr = NULL;
352 npicts++;
353 } while (seq++);
354 /* check that we did something */
355 if (npicts == 0)
356 error(WARNING, "no output produced");
357 }
358
359
360 static int
361 nextview( /* get next view from fp */
362 FILE *fp
363 )
364 {
365 char linebuf[256];
366
367 lastview = ourview;
368 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
369 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
370 return(0);
371 return(EOF);
372 }
373
374
375 static void
376 render( /* render the scene */
377 char *zfile,
378 char *oldfile
379 )
380 {
381 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
382 float *zbar[MAXDIV+1]; /* z values */
383 char *sampdens; /* previous sample density */
384 int ypos; /* current scanline */
385 int ystep; /* current y step size */
386 int hstep; /* h step size */
387 int zfd;
388 COLOR *colptr;
389 float *zptr;
390 register int i;
391 /* check for empty image */
392 if (hres <= 0 || vres <= 0) {
393 error(WARNING, "empty output picture");
394 fprtresolu(0, 0, stdout);
395 return;
396 }
397 /* allocate scanlines */
398 for (i = 0; i <= psample; i++) {
399 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
400 if (scanbar[i] == NULL)
401 goto memerr;
402 }
403 hstep = (psample*140+49)/99; /* quincunx sampling */
404 ystep = (psample*99+70)/140;
405 if (hstep > 2) {
406 i = hres/hstep + 2;
407 if ((sampdens = (char *)malloc(i)) == NULL)
408 goto memerr;
409 while (i--)
410 sampdens[i] = hstep;
411 } else
412 sampdens = NULL;
413 /* open z-file */
414 if (zfile != NULL) {
415 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
416 sprintf(errmsg, "cannot open z-file \"%s\"", zfile);
417 error(SYSTEM, errmsg);
418 }
419 SET_FD_BINARY(zfd);
420 for (i = 0; i <= psample; i++) {
421 zbar[i] = (float *)malloc(hres*sizeof(float));
422 if (zbar[i] == NULL)
423 goto memerr;
424 }
425 } else {
426 zfd = -1;
427 for (i = 0; i <= psample; i++)
428 zbar[i] = NULL;
429 }
430 /* write out boundaries */
431 fprtresolu(hres, vres, stdout);
432 /* recover file and compute first */
433 i = salvage(oldfile);
434 if (i >= vres)
435 goto alldone;
436 if (zfd != -1 && i > 0 &&
437 lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0)
438 error(SYSTEM, "z-file seek error in render");
439 pctdone = 100.0*i/vres;
440 if (ralrm > 0) /* report init stats */
441 report(0);
442 #ifdef SIGCONT
443 else
444 signal(SIGCONT, report);
445 #endif
446 ypos = vres-1 - i; /* initialize sampling */
447 if (directvis)
448 init_drawsources(psample);
449 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
450 /* compute scanlines */
451 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
452 /* bottom adjust? */
453 if (ypos < 0) {
454 ystep += ypos;
455 ypos = 0;
456 }
457 colptr = scanbar[ystep]; /* move base to top */
458 scanbar[ystep] = scanbar[0];
459 scanbar[0] = colptr;
460 zptr = zbar[ystep];
461 zbar[ystep] = zbar[0];
462 zbar[0] = zptr;
463 /* fill base line */
464 fillscanline(scanbar[0], zbar[0], sampdens,
465 hres, ypos, hstep);
466 /* fill bar */
467 fillscanbar(scanbar, zbar, hres, ypos, ystep);
468 if (directvis) /* add bitty sources */
469 drawsources(scanbar, zbar, 0, hres, ypos, ystep);
470 /* write it out */
471 #ifdef SIGCONT
472 signal(SIGCONT, SIG_IGN); /* don't interrupt writes */
473 #endif
474 for (i = ystep; i > 0; i--) {
475 if (zfd != -1 && write(zfd, (char *)zbar[i],
476 hres*sizeof(float))
477 < hres*sizeof(float))
478 goto writerr;
479 if (fwritescan(scanbar[i], hres, stdout) < 0)
480 goto writerr;
481 }
482 if (fflush(stdout) == EOF)
483 goto writerr;
484 /* record progress */
485 pctdone = 100.0*(vres-1-ypos)/vres;
486 if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm)
487 report(0);
488 #ifdef SIGCONT
489 else
490 signal(SIGCONT, report);
491 #endif
492 }
493 /* clean up */
494 #ifdef SIGCONT
495 signal(SIGCONT, SIG_IGN);
496 #endif
497 if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float))
498 < hres*sizeof(float))
499 goto writerr;
500 fwritescan(scanbar[0], hres, stdout);
501 if (fflush(stdout) == EOF)
502 goto writerr;
503 alldone:
504 if (zfd != -1) {
505 if (close(zfd) == -1)
506 goto writerr;
507 for (i = 0; i <= psample; i++)
508 free((void *)zbar[i]);
509 }
510 for (i = 0; i <= psample; i++)
511 free((void *)scanbar[i]);
512 if (sampdens != NULL)
513 free(sampdens);
514 pctdone = 100.0;
515 if (ralrm > 0)
516 report(0);
517 #ifdef SIGCONT
518 signal(SIGCONT, SIG_DFL);
519 #endif
520 return;
521 writerr:
522 error(SYSTEM, "write error in render");
523 memerr:
524 error(SYSTEM, "out of memory in render");
525 }
526
527
528 static void
529 fillscanline( /* fill scan at y */
530 register COLOR *scanline,
531 register float *zline,
532 register char *sd,
533 int xres,
534 int y,
535 int xstep
536 )
537 {
538 static int nc = 0; /* number of calls */
539 int bl = xstep, b = xstep;
540 double z;
541 register int i;
542
543 z = pixvalue(scanline[0], 0, y);
544 if (zline) zline[0] = z;
545 /* zig-zag start for quincunx pattern */
546 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
547 if (i >= xres) {
548 xstep += xres-1-i;
549 i = xres-1;
550 }
551 z = pixvalue(scanline[i], i, y);
552 if (zline) zline[i] = z;
553 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
554 if (i <= xstep)
555 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
556 else
557 b = fillsample(scanline+i-xstep,
558 zline ? zline+i-xstep : (float *)NULL,
559 i-xstep, y, xstep, 0, b/2);
560 if (sd) *sd++ = nc & 1 ? bl : b;
561 bl = b;
562 }
563 if (sd && nc & 1) *sd = bl;
564 }
565
566
567 static void
568 fillscanbar( /* fill interior */
569 register COLOR *scanbar[],
570 register float *zbar[],
571 int xres,
572 int y,
573 int ysize
574 )
575 {
576 COLOR vline[MAXDIV+1];
577 float zline[MAXDIV+1];
578 int b = ysize;
579 register int i, j;
580
581 for (i = 0; i < xres; i++) {
582 copycolor(vline[0], scanbar[0][i]);
583 copycolor(vline[ysize], scanbar[ysize][i]);
584 if (zbar[0]) {
585 zline[0] = zbar[0][i];
586 zline[ysize] = zbar[ysize][i];
587 }
588 b = fillsample(vline, zbar[0] ? zline : (float *)NULL,
589 i, y, 0, ysize, b/2);
590
591 for (j = 1; j < ysize; j++)
592 copycolor(scanbar[j][i], vline[j]);
593 if (zbar[0])
594 for (j = 1; j < ysize; j++)
595 zbar[j][i] = zline[j];
596 }
597 }
598
599
600 static int
601 fillsample( /* fill interior points */
602 register COLOR *colline,
603 register float *zline,
604 int x,
605 int y,
606 int xlen,
607 int ylen,
608 int b
609 )
610 {
611 double ratio;
612 double z;
613 COLOR ctmp;
614 int ncut;
615 register int len;
616
617 if (xlen > 0) /* x or y length is zero */
618 len = xlen;
619 else
620 len = ylen;
621
622 if (len <= 1) /* limit recursion */
623 return(0);
624
625 if (b > 0 ||
626 (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
627 || bigdiff(colline[0], colline[len], maxdiff)) {
628
629 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
630 if (zline) zline[len>>1] = z;
631 ncut = 1;
632 } else { /* interpolate */
633 copycolor(colline[len>>1], colline[len]);
634 ratio = (double)(len>>1) / len;
635 scalecolor(colline[len>>1], ratio);
636 if (zline) zline[len>>1] = zline[len] * ratio;
637 ratio = 1.0 - ratio;
638 copycolor(ctmp, colline[0]);
639 scalecolor(ctmp, ratio);
640 addcolor(colline[len>>1], ctmp);
641 if (zline) zline[len>>1] += zline[0] * ratio;
642 ncut = 0;
643 }
644 /* recurse */
645 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
646
647 ncut += fillsample(colline+(len>>1),
648 zline ? zline+(len>>1) : (float *)NULL,
649 x+(xlen>>1), y+(ylen>>1),
650 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
651
652 return(ncut);
653 }
654
655
656 static double
657 pixvalue( /* compute pixel value */
658 COLOR col, /* returned color */
659 int x, /* pixel position */
660 int y
661 )
662 {
663 RAY thisray;
664 FVECT lorg, ldir;
665 double hpos, vpos, lmax;
666 /* compute view ray */
667 hpos = (x+pixjitter())/hres;
668 vpos = (y+pixjitter())/vres;
669 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
670 &ourview, hpos, vpos)) < -FTINY) {
671 setcolor(col, 0.0, 0.0, 0.0);
672 return(0.0);
673 }
674
675 samplendx = pixnumber(x,y,hres,vres); /* set pixel index */
676
677 /* optional motion blur */
678 if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir,
679 &lastview, hpos, vpos)) >= -FTINY) {
680 register int i;
681 register double d = mblur*(.5-urand(281+samplendx));
682
683 thisray.rmax = (1.-d)*thisray.rmax + d*lmax;
684 for (i = 3; i--; ) {
685 thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i];
686 thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i];
687 }
688 if (normalize(thisray.rdir) == 0.0)
689 return(0.0);
690 }
691
692 rayorigin(&thisray, NULL, PRIMARY, 1.0);
693
694 rayvalue(&thisray); /* trace ray */
695
696 copycolor(col, thisray.rcol); /* return color */
697
698 return(thisray.rt); /* return distance */
699 }
700
701
702 static int
703 salvage( /* salvage scanlines from killed program */
704 char *oldfile
705 )
706 {
707 COLR *scanline;
708 FILE *fp;
709 int x, y;
710
711 if (oldfile == NULL)
712 goto gotzip;
713
714 if ((fp = fopen(oldfile, "r")) == NULL) {
715 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
716 error(WARNING, errmsg);
717 goto gotzip;
718 }
719 SET_FILE_BINARY(fp);
720 /* discard header */
721 getheader(fp, NULL, NULL);
722 /* get picture size */
723 if (!fscnresolu(&x, &y, fp)) {
724 sprintf(errmsg, "bad recover file \"%s\" - not removed",
725 oldfile);
726 error(WARNING, errmsg);
727 fclose(fp);
728 goto gotzip;
729 }
730
731 if (x != hres || y != vres) {
732 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
733 oldfile);
734 error(USER, errmsg);
735 }
736
737 scanline = (COLR *)malloc(hres*sizeof(COLR));
738 if (scanline == NULL)
739 error(SYSTEM, "out of memory in salvage");
740 for (y = 0; y < vres; y++) {
741 if (freadcolrs(scanline, hres, fp) < 0)
742 break;
743 if (fwritecolrs(scanline, hres, stdout) < 0)
744 goto writerr;
745 }
746 if (fflush(stdout) == EOF)
747 goto writerr;
748 free((void *)scanline);
749 fclose(fp);
750 unlink(oldfile);
751 return(y);
752 gotzip:
753 if (fflush(stdout) == EOF)
754 error(SYSTEM, "error writing picture header");
755 return(0);
756 writerr:
757 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
758 error(SYSTEM, errmsg);
759 return -1; /* pro forma return */
760 }
761
762
763 static int
764 pixnumber( /* compute pixel index (brushed) */
765 register int x,
766 register int y,
767 int xres,
768 int yres
769 )
770 {
771 x -= y;
772 while (x < 0)
773 x += xres;
774 return((((x>>2)*yres + y) << 2) + (x & 3));
775 }
