root/radiance/ray/src/rt/rpict.c
Revision: 2.56
Committed: Thu Jun 26 00:58:10 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.55: +11 -5 lines
2 static const char RCSid[] = "$Id";
5 * rpict.c - routines and variables for picture generation.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11
12 #include <sys/types.h>
13
14 #ifndef NIX
15 #ifdef BSD
16 #include <sys/time.h>
17 #include <sys/resource.h>
18 #else
19 #include <sys/times.h>
20 #include <unistd.h>
21 #endif
22 #endif
23
24 #include <time.h>
25 #include <signal.h>
26
27 #include "platform.h"
28 #include "view.h"
29 #include "random.h"
30 #include "paths.h"
31
32
33 #define RFTEMPLATE "rfXXXXXX"
34
35 #ifndef SIGCONT
36 #ifdef SIGIO /* XXX can we live without this? */
37 #define SIGCONT SIGIO
38 #endif
39 #endif
40
41 CUBE thescene; /* our scene */
42 OBJECT nsceneobjs; /* number of objects in our scene */
43
44 int dimlist[MAXDIM]; /* sampling dimensions */
45 int ndims = 0; /* number of sampling dimensions */
46 int samplendx; /* sample index number */
47
48 extern void ambnotify();
49 void (*addobjnotify[])() = {ambnotify, NULL};
50
51 VIEW ourview = STDVIEW; /* view parameters */
52 int hresolu = 512; /* horizontal resolution */
53 int vresolu = 512; /* vertical resolution */
54 double pixaspect = 1.0; /* pixel aspect ratio */
55
56 int psample = 4; /* pixel sample size */
57 double maxdiff = .05; /* max. difference for interpolation */
58 double dstrpix = 0.67; /* square pixel distribution */
59
60 double mblur = 0.; /* motion blur parameter */
61
62 void (*trace)() = NULL; /* trace call */
63
64 int do_irrad = 0; /* compute irradiance? */
65
66 double dstrsrc = 0.0; /* square source distribution */
67 double shadthresh = .05; /* shadow threshold */
68 double shadcert = .5; /* shadow certainty */
69 int directrelay = 1; /* number of source relays */
70 int vspretest = 512; /* virtual source pretest density */
71 int directvis = 1; /* sources visible? */
72 double srcsizerat = .25; /* maximum ratio source size/dist. */
73
74 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
75 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
76 double seccg = 0.; /* global scattering eccentricity */
77 double ssampdist = 0.; /* scatter sampling distance */
78
79 double specthresh = .15; /* specular sampling threshold */
80 double specjitter = 1.; /* specular sampling jitter */
81
82 int backvis = 1; /* back face visibility */
83
84 int maxdepth = 6; /* maximum recursion depth */
85 double minweight = 5e-3; /* minimum ray weight */
86
87 char *ambfile = NULL; /* ambient file name */
88 COLOR ambval = BLKCOLOR; /* ambient value */
89 int ambvwt = 0; /* initial weight for ambient value */
90 double ambacc = 0.2; /* ambient accuracy */
91 int ambres = 32; /* ambient resolution */
92 int ambdiv = 128; /* ambient divisions */
93 int ambssamp = 0; /* ambient super-samples */
94 int ambounce = 0; /* ambient bounces */
95 char *amblist[128]; /* ambient include/exclude list */
96 int ambincl = -1; /* include == 1, exclude == 0 */
97
98 int ralrm = 0; /* seconds between reports */
99
100 double pctdone = 0.0; /* percentage done */
101 time_t tlastrept = 0L; /* time at last report */
102 time_t tstart; /* starting time */
103
104 #define MAXDIV 16 /* maximum sample size */
105
106 #define pixjitter() (.5+dstrpix*(.5-frandom()))
107
108 int hres, vres; /* resolution for this frame */
109
110 static VIEW lastview; /* the previous view input */
111
112 extern char *mktemp(); /* XXX should be in stdlib.h or unistd.h */
113
114 void report();
115
116 double pixvalue();
117
118 #ifdef NIX
119 #define file_exists(f) (access(f,F_OK)==0)
120 #else
121 #include <sys/types.h>
122 #include <sys/stat.h>
123 int
124 file_exists(fname) /* ordinary file exists? */
125 char *fname;
126 {
127 struct stat sbuf;
128 if (stat(fname, &sbuf) < 0) return(0);
129 return((sbuf.st_mode & S_IFREG) != 0);
130 }
131 #endif
132
133
134 void
135 quit(code) /* quit program */
136 int code;
137 {
138 if (code) /* report status */
139 report();
140 #ifndef NIX
141 headclean(); /* delete header file */
142 pfclean(); /* clean up persist files */
143 #endif
144 exit(code);
145 }
146
147
148 #ifndef NIX
149 void
150 report() /* report progress */
151 {
152 extern char *myhostname();
153 double u, s;
154 #ifdef BSD
155 struct rusage rubuf;
156 #else
157 struct tms tbuf;
158 double period;
159 #endif
160
161 tlastrept = time((time_t *)NULL);
162 #ifdef BSD
163 getrusage(RUSAGE_SELF, &rubuf);
164 u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6;
165 s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6;
166 getrusage(RUSAGE_CHILDREN, &rubuf);
167 u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6;
168 s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6;
169 #else
170 times(&tbuf);
171 #ifdef _SC_CLK_TCK
172 period = 1.0 / sysconf(_SC_CLK_TCK);
173 #else
174 period = 1.0 / 60.0;
175 #endif
176 u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period;
177 s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period;
178 #endif
179
180 sprintf(errmsg,
181 "%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n",
182 nrays, pctdone, u/3600., s/3600.,
183 (tlastrept-tstart)/3600., myhostname());
184 eputs(errmsg);
185 #ifdef SIGCONT
186 signal(SIGCONT, report);
187 #endif
188 }
189 #else
190 void
191 report() /* report progress */
192 {
193 tlastrept = time((time_t *)NULL);
194 sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n",
195 nrays, pctdone, (tlastrept-tstart)/3600.0);
196 eputs(errmsg);
197 }
198 #endif
199
200
201 void
202 rpict(seq, pout, zout, prvr) /* generate image(s) */
203 int seq;
204 char *pout, *zout, *prvr;
205 /*
206 * If seq is greater than zero, then we will render a sequence of
207 * images based on view parameter strings read from the standard input.
208 * If pout is NULL, then all images will be sent to the standard ouput.
209 * If seq is greater than zero and prvr is an integer, then it is the
210 * frame number at which rendering should begin. Preceeding view parameter
211 * strings will be skipped in the input.
212 * If pout and prvr are the same, prvr is renamed to avoid overwriting.
213 * Note that pout and zout should contain %d format specifications for
214 * sequenced file naming.
215 */
216 {
217 char fbuf[128], fbuf2[128];
218 int npicts;
219 register char *cp;
220 RESOLU rs;
221 double pa;
222 /* check sampling */
223 if (psample < 1)
224 psample = 1;
225 else if (psample > MAXDIV) {
226 sprintf(errmsg, "pixel sampling reduced from %d to %d",
227 psample, MAXDIV);
228 error(WARNING, errmsg);
229 psample = MAXDIV;
230 }
231 /* get starting frame */
232 if (seq <= 0)
233 seq = 0;
234 else if (prvr != NULL && isint(prvr)) {
235 register int rn; /* skip to specified view */
236 if ((rn = atoi(prvr)) < seq)
237 error(USER, "recover frame less than start frame");
238 if (pout == NULL)
239 error(USER, "missing output file specification");
240 for ( ; seq < rn; seq++)
241 if (nextview(stdin) == EOF)
242 error(USER, "unexpected EOF on view input");
243 setview(&ourview);
244 prvr = fbuf; /* mark for renaming */
245 }
246 if (pout != NULL & prvr != NULL) {
247 sprintf(fbuf, pout, seq);
248 if (!strcmp(prvr, fbuf)) { /* rename */
249 strcpy(fbuf2, fbuf);
250 for (cp = fbuf2; *cp; cp++)
251 ;
252 while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
253 cp--;
254 strcpy(cp, RFTEMPLATE);
255 prvr = mktemp(fbuf2);
256 if (rename(fbuf, prvr) < 0)
257 if (errno == ENOENT) { /* ghost file */
258 sprintf(errmsg,
259 "new output file \"%s\"",
260 fbuf);
261 error(WARNING, errmsg);
262 prvr = NULL;
263 } else { /* serious error */
264 sprintf(errmsg,
265 "cannot rename \"%s\" to \"%s\"",
266 fbuf, prvr);
267 error(SYSTEM, errmsg);
268 }
269 }
270 }
271 npicts = 0; /* render sequence */
272 do {
273 if (seq && nextview(stdin) == EOF)
274 break;
275 pctdone = 0.0;
276 if (pout != NULL) {
277 sprintf(fbuf, pout, seq);
278 if (file_exists(fbuf)) {
279 if (prvr != NULL || !strcmp(fbuf, pout)) {
280 sprintf(errmsg,
281 "output file \"%s\" exists",
282 fbuf);
283 error(USER, errmsg);
284 }
285 setview(&ourview);
286 continue; /* don't clobber */
287 }
288 if (freopen(fbuf, "w", stdout) == NULL) {
289 sprintf(errmsg,
290 "cannot open output file \"%s\"", fbuf);
291 error(SYSTEM, errmsg);
292 }
293 SET_FILE_BINARY(stdout);
294 dupheader();
295 }
296 hres = hresolu; vres = vresolu; pa = pixaspect;
297 if (prvr != NULL)
298 if (viewfile(prvr, &ourview, &rs) <= 0
299 || rs.rt != PIXSTANDARD) {
300 sprintf(errmsg,
301 "cannot recover view parameters from \"%s\"", prvr);
302 error(WARNING, errmsg);
303 } else {
304 pa = 0.0;
305 hres = scanlen(&rs);
306 vres = numscans(&rs);
307 }
308 if ((cp = setview(&ourview)) != NULL)
309 error(USER, cp);
310 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
311 if (seq) {
312 if (ralrm > 0) {
313 fprintf(stderr, "FRAME %d:", seq);
314 fprintview(&ourview, stderr);
315 putc('\n', stderr);
316 fflush(stderr);
317 }
318 printf("FRAME=%d\n", seq);
319 }
320 fputs(VIEWSTR, stdout);
321 fprintview(&ourview, stdout);
322 putchar('\n');
323 if (pa < .99 || pa > 1.01)
324 fputaspect(pa, stdout);
325 fputformat(COLRFMT, stdout);
326 putchar('\n');
327 if (zout != NULL)
328 sprintf(cp=fbuf, zout, seq);
329 else
330 cp = NULL;
331 render(cp, prvr);
332 prvr = NULL;
333 npicts++;
334 } while (seq++);
335 /* check that we did something */
336 if (npicts == 0)
337 error(WARNING, "no output produced");
338 }
339
340
341 nextview(fp) /* get next view from fp */
342 FILE *fp;
343 {
344 char linebuf[256];
345
346 copystruct(&lastview, &ourview);
347 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
348 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
349 return(0);
350 return(EOF);
351 }
352
353
354 render(zfile, oldfile) /* render the scene */
355 char *zfile, *oldfile;
356 {
357 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
358 float *zbar[MAXDIV+1]; /* z values */
359 char *sampdens; /* previous sample density */
360 int ypos; /* current scanline */
361 int ystep; /* current y step size */
362 int hstep; /* h step size */
363 int zfd;
364 COLOR *colptr;
365 float *zptr;
366 register int i;
367 /* check for empty image */
368 if (hres <= 0 || vres <= 0) {
369 error(WARNING, "empty output picture");
370 fprtresolu(0, 0, stdout);
371 return;
372 }
373 /* allocate scanlines */
374 for (i = 0; i <= psample; i++) {
375 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
376 if (scanbar[i] == NULL)
377 goto memerr;
378 }
379 hstep = (psample*140+49)/99; /* quincunx sampling */
380 ystep = (psample*99+70)/140;
381 if (hstep > 2) {
382 i = hres/hstep + 2;
383 if ((sampdens = (char *)malloc(i)) == NULL)
384 goto memerr;
385 while (i--)
386 sampdens[i] = hstep;
387 } else
388 sampdens = NULL;
389 /* open z-file */
390 if (zfile != NULL) {
391 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
392 sprintf(errmsg, "cannot open z-file \"%s\"", zfile);
393 error(SYSTEM, errmsg);
394 }
395 SET_FD_BINARY(zfd);
396 for (i = 0; i <= psample; i++) {
397 zbar[i] = (float *)malloc(hres*sizeof(float));
398 if (zbar[i] == NULL)
399 goto memerr;
400 }
401 } else {
402 zfd = -1;
403 for (i = 0; i <= psample; i++)
404 zbar[i] = NULL;
405 }
406 /* write out boundaries */
407 fprtresolu(hres, vres, stdout);
408 /* recover file and compute first */
409 i = salvage(oldfile);
410 if (i >= vres)
411 goto alldone;
412 if (zfd != -1 && i > 0 &&
413 lseek(zfd, (off_t)i*hres*sizeof(float), 0) < 0)
414 error(SYSTEM, "z-file seek error in render");
415 pctdone = 100.0*i/vres;
416 if (ralrm > 0) /* report init stats */
417 report();
418 #ifdef SIGCONT
419 else
420 signal(SIGCONT, report);
421 #endif
422 ypos = vres-1 - i; /* initialize sampling */
423 if (directvis)
424 init_drawsources(psample);
425 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
426 /* compute scanlines */
427 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
428 /* bottom adjust? */
429 if (ypos < 0) {
430 ystep += ypos;
431 ypos = 0;
432 }
433 colptr = scanbar[ystep]; /* move base to top */
434 scanbar[ystep] = scanbar[0];
435 scanbar[0] = colptr;
436 zptr = zbar[ystep];
437 zbar[ystep] = zbar[0];
438 zbar[0] = zptr;
439 /* fill base line */
440 fillscanline(scanbar[0], zbar[0], sampdens,
441 hres, ypos, hstep);
442 /* fill bar */
443 fillscanbar(scanbar, zbar, hres, ypos, ystep);
444 if (directvis) /* add bitty sources */
445 drawsources(scanbar, zbar, 0, hres, ypos, ystep);
446 /* write it out */
447 #ifdef SIGCONT
448 signal(SIGCONT, SIG_IGN); /* don't interrupt writes */
449 #endif
450 for (i = ystep; i > 0; i--) {
451 if (zfd != -1 && write(zfd, (char *)zbar[i],
452 hres*sizeof(float))
453 < hres*sizeof(float))
454 goto writerr;
455 if (fwritescan(scanbar[i], hres, stdout) < 0)
456 goto writerr;
457 }
458 if (fflush(stdout) == EOF)
459 goto writerr;
460 /* record progress */
461 pctdone = 100.0*(vres-1-ypos)/vres;
462 if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm)
463 report();
464 #ifdef SIGCONT
465 else
466 signal(SIGCONT, report);
467 #endif
468 }
469 /* clean up */
470 #ifdef SIGCONT
471 signal(SIGCONT, SIG_IGN);
472 #endif
473 if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float))
474 < hres*sizeof(float))
475 goto writerr;
476 fwritescan(scanbar[0], hres, stdout);
477 if (fflush(stdout) == EOF)
478 goto writerr;
479 alldone:
480 if (zfd != -1) {
481 if (close(zfd) == -1)
482 goto writerr;
483 for (i = 0; i <= psample; i++)
484 free((void *)zbar[i]);
485 }
486 for (i = 0; i <= psample; i++)
487 free((void *)scanbar[i]);
488 if (sampdens != NULL)
489 free(sampdens);
490 pctdone = 100.0;
491 if (ralrm > 0)
492 report();
493 #ifdef SIGCONT
494 signal(SIGCONT, SIG_DFL);
495 #endif
496 return;
497 writerr:
498 error(SYSTEM, "write error in render");
499 memerr:
500 error(SYSTEM, "out of memory in render");
501 }
502
503
504 fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */
505 register COLOR *scanline;
506 register float *zline;
507 register char *sd;
508 int xres, y, xstep;
509 {
510 static int nc = 0; /* number of calls */
511 int bl = xstep, b = xstep;
512 double z;
513 register int i;
514
515 z = pixvalue(scanline[0], 0, y);
516 if (zline) zline[0] = z;
517 /* zig-zag start for quincunx pattern */
518 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
519 if (i >= xres) {
520 xstep += xres-1-i;
521 i = xres-1;
522 }
523 z = pixvalue(scanline[i], i, y);
524 if (zline) zline[i] = z;
525 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
526 if (i <= xstep)
527 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
528 else
529 b = fillsample(scanline+i-xstep,
530 zline ? zline+i-xstep : (float *)NULL,
531 i-xstep, y, xstep, 0, b/2);
532 if (sd) *sd++ = nc & 1 ? bl : b;
533 bl = b;
534 }
535 if (sd && nc & 1) *sd = bl;
536 }
537
538
539 fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
540 register COLOR *scanbar[];
541 register float *zbar[];
542 int xres, y, ysize;
543 {
544 COLOR vline[MAXDIV+1];
545 float zline[MAXDIV+1];
546 int b = ysize;
547 register int i, j;
548
549 for (i = 0; i < xres; i++) {
550 copycolor(vline[0], scanbar[0][i]);
551 copycolor(vline[ysize], scanbar[ysize][i]);
552 if (zbar[0]) {
553 zline[0] = zbar[0][i];
554 zline[ysize] = zbar[ysize][i];
555 }
556 b = fillsample(vline, zbar[0] ? zline : (float *)NULL,
557 i, y, 0, ysize, b/2);
558
559 for (j = 1; j < ysize; j++)
560 copycolor(scanbar[j][i], vline[j]);
561 if (zbar[0])
562 for (j = 1; j < ysize; j++)
563 zbar[j][i] = zline[j];
564 }
565 }
566
567
568 int
569 fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
570 register COLOR *colline;
571 register float *zline;
572 int x, y;
573 int xlen, ylen;
574 int b;
575 {
576 double ratio;
577 double z;
578 COLOR ctmp;
579 int ncut;
580 register int len;
581
582 if (xlen > 0) /* x or y length is zero */
583 len = xlen;
584 else
585 len = ylen;
586
587 if (len <= 1) /* limit recursion */
588 return(0);
589
590 if (b > 0 ||
591 (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
592 || bigdiff(colline[0], colline[len], maxdiff)) {
593
594 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
595 if (zline) zline[len>>1] = z;
596 ncut = 1;
597 } else { /* interpolate */
598 copycolor(colline[len>>1], colline[len]);
599 ratio = (double)(len>>1) / len;
600 scalecolor(colline[len>>1], ratio);
601 if (zline) zline[len>>1] = zline[len] * ratio;
602 ratio = 1.0 - ratio;
603 copycolor(ctmp, colline[0]);
604 scalecolor(ctmp, ratio);
605 addcolor(colline[len>>1], ctmp);
606 if (zline) zline[len>>1] += zline[0] * ratio;
607 ncut = 0;
608 }
609 /* recurse */
610 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
611
612 ncut += fillsample(colline+(len>>1),
613 zline ? zline+(len>>1) : (float *)NULL,
614 x+(xlen>>1), y+(ylen>>1),
615 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
616
617 return(ncut);
618 }
619
620
621 double
622 pixvalue(col, x, y) /* compute pixel value */
623 COLOR col; /* returned color */
624 int x, y; /* pixel position */
625 {
626 RAY thisray;
627 FVECT lorg, ldir;
628 double hpos, vpos, lmax, d;
629 /* compute view ray */
630 hpos = (x+pixjitter())/hres;
631 vpos = (y+pixjitter())/vres;
632 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
633 &ourview, hpos, vpos)) < -FTINY) {
634 setcolor(col, 0.0, 0.0, 0.0);
635 return(0.0);
636 }
637
638 samplendx = pixnumber(x,y,hres,vres); /* set pixel index */
639
640 /* optional motion blur */
641 if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir,
642 &lastview, hpos, vpos)) >= -FTINY) {
643 register int i;
644 register double d = mblur*(.5-urand(281+samplendx));
645
646 thisray.rmax = (1.-d)*thisray.rmax + d*lmax;
647 for (i = 3; i--; ) {
648 thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i];
649 thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i];
650 }
651 if (normalize(thisray.rdir) == 0.0)
652 return(0.0);
653 }
654
655 rayorigin(&thisray, NULL, PRIMARY, 1.0);
656
657 rayvalue(&thisray); /* trace ray */
658
659 copycolor(col, thisray.rcol); /* return color */
660
661 return(thisray.rt); /* return distance */
662 }
663
664
665 int
666 salvage(oldfile) /* salvage scanlines from killed program */
667 char *oldfile;
668 {
669 COLR *scanline;
670 FILE *fp;
671 int x, y;
672
673 if (oldfile == NULL)
674 goto gotzip;
675
676 if ((fp = fopen(oldfile, "r")) == NULL) {
677 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
678 error(WARNING, errmsg);
679 goto gotzip;
680 }
681 SET_FILE_BINARY(fp);
682 /* discard header */
683 getheader(fp, NULL, NULL);
684 /* get picture size */
685 if (!fscnresolu(&x, &y, fp)) {
686 sprintf(errmsg, "bad recover file \"%s\" - not removed",
687 oldfile);
688 error(WARNING, errmsg);
689 fclose(fp);
690 goto gotzip;
691 }
692
693 if (x != hres || y != vres) {
694 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
695 oldfile);
696 error(USER, errmsg);
697 }
698
699 scanline = (COLR *)malloc(hres*sizeof(COLR));
700 if (scanline == NULL)
701 error(SYSTEM, "out of memory in salvage");
702 for (y = 0; y < vres; y++) {
703 if (freadcolrs(scanline, hres, fp) < 0)
704 break;
705 if (fwritecolrs(scanline, hres, stdout) < 0)
706 goto writerr;
707 }
708 if (fflush(stdout) == EOF)
709 goto writerr;
710 free((void *)scanline);
711 fclose(fp);
712 unlink(oldfile);
713 return(y);
714 gotzip:
715 if (fflush(stdout) == EOF)
716 error(SYSTEM, "error writing picture header");
717 return(0);
718 writerr:
719 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
720 error(SYSTEM, errmsg);
721 }
722
723
724 int
725 pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
726 register int x, y;
727 int xres, yres;
728 {
729 x -= y;
730 while (x < 0)
731 x += xres;
732 return((((x>>2)*yres + y) << 2) + (x & 3));
733 }
