root/radiance/ray/src/rt/rpict.c
Revision: 1.35
Committed: Mon Oct 21 12:57:57 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.34: +2 -1 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rpict.c - routines and variables for picture generation.
9 *
10 * 8/14/85
11 */
12
13 #include "ray.h"
14
15 #ifdef BSD
16 #include <sys/time.h>
17 #include <sys/resource.h>
18 #endif
19
20 #include <signal.h>
21 #include <fcntl.h>
22
23 #include "view.h"
24
25 #include "random.h"
26
27 int dimlist[MAXDIM]; /* sampling dimensions */
28 int ndims = 0; /* number of sampling dimensions */
29 int samplendx; /* sample index number */
30
31 VIEW ourview = STDVIEW; /* view parameters */
32 int hresolu = 512; /* horizontal resolution */
33 int vresolu = 512; /* vertical resolution */
34 double pixaspect = 1.0; /* pixel aspect ratio */
35
36 int psample = 4; /* pixel sample size */
37 double maxdiff = .05; /* max. difference for interpolation */
38 double dstrpix = 0.67; /* square pixel distribution */
39
40 double dstrsrc = 0.0; /* square source distribution */
41 double shadthresh = .05; /* shadow threshold */
42 double shadcert = .5; /* shadow certainty */
43 int directrelay = 1; /* number of source relays */
44 int vspretest = 512; /* virtual source pretest density */
45 int directinvis = 0; /* sources invisible? */
46 double srcsizerat = .25; /* maximum ratio source size/dist. */
47
48 int maxdepth = 6; /* maximum recursion depth */
49 double minweight = 5e-3; /* minimum ray weight */
50
51 COLOR ambval = BLKCOLOR; /* ambient value */
52 double ambacc = 0.2; /* ambient accuracy */
53 int ambres = 32; /* ambient resolution */
54 int ambdiv = 128; /* ambient divisions */
55 int ambssamp = 0; /* ambient super-samples */
56 int ambounce = 0; /* ambient bounces */
57 char *amblist[128]; /* ambient include/exclude list */
58 int ambincl = -1; /* include == 1, exclude == 0 */
59
60 int ralrm = 0; /* seconds between reports */
61
62 double pctdone = 0.0; /* percentage done */
63
64 long tlastrept = 0L; /* time at last report */
65
66 extern long time();
67 extern long tstart; /* starting time */
68
69 extern long nrays; /* number of rays traced */
70
71 #define MAXDIV 15 /* maximum sample size */
72
73 #define pixjitter() (.5+dstrpix*(.5-frandom()))
74
75 double pixvalue();
76
77
78 quit(code) /* quit program */
79 int code;
80 {
81 if (code || ralrm > 0) /* report status */
82 report();
83
84 exit(code);
85 }
86
87
88 #ifdef BSD
89 report() /* report progress */
90 {
91 struct rusage rubuf;
92 double t;
93
94 getrusage(RUSAGE_SELF, &rubuf);
95 t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
96 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
97 getrusage(RUSAGE_CHILDREN, &rubuf);
98 t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
99 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
100
101 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n",
102 nrays, pctdone, t/3600.0);
103 eputs(errmsg);
104 tlastrept = time((long *)0);
105 }
106 #else
107 report() /* report progress */
108 {
109 signal(SIGALRM, report);
110 tlastrept = time((long *)0);
111 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n",
112 nrays, pctdone, (tlastrept-tstart)/3600.0);
113 eputs(errmsg);
114 }
115 #endif
116
117
118 render(zfile, oldfile) /* render the scene */
119 char *zfile, *oldfile;
120 {
121 extern long lseek();
122 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
123 float *zbar[MAXDIV+1]; /* z values */
124 int ypos; /* current scanline */
125 int ystep; /* current y step size */
126 int hstep; /* h step size */
127 int zfd;
128 COLOR *colptr;
129 float *zptr;
130 register int i;
131 /* check sampling */
132 if (psample < 1)
133 psample = 1;
134 else if (psample > MAXDIV) {
135 sprintf(errmsg, "pixel sampling reduced from %d to %d",
136 psample, MAXDIV);
137 error(WARNING, errmsg);
138 psample = MAXDIV;
139 }
140 /* allocate scanlines */
141 for (i = 0; i <= psample; i++) {
142 scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR));
143 if (scanbar[i] == NULL)
144 goto memerr;
145 }
146 /* open z file */
147 if (zfile != NULL) {
148 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
149 sprintf(errmsg, "cannot open z file \"%s\"", zfile);
150 error(SYSTEM, errmsg);
151 }
152 for (i = 0; i <= psample; i++) {
153 zbar[i] = (float *)malloc(hresolu*sizeof(float));
154 if (zbar[i] == NULL)
155 goto memerr;
156 }
157 } else {
158 zfd = -1;
159 for (i = 0; i <= psample; i++)
160 zbar[i] = NULL;
161 }
162 /* write out boundaries */
163 fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout);
164 /* recover file and compute first */
165 i = salvage(oldfile);
166 if (zfd != -1 && i > 0 &&
167 lseek(zfd, (long)i*hresolu*sizeof(float), 0) == -1)
168 error(SYSTEM, "z file seek error in render");
169 pctdone = 100.0*i/vresolu;
170 if (ralrm > 0) /* report init stats */
171 report();
172 #ifndef BSD
173 else
174 #endif
175 signal(SIGALRM, report);
176 ypos = vresolu-1 - i;
177 hstep = (psample*140+49)/99; /* quincunx sampling */
178 ystep = (psample*99+70)/140;
179 fillscanline(scanbar[0], zbar[0], hresolu, ypos, hstep);
180 /* compute scanlines */
181 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
182 /* bottom adjust? */
183 if (ypos < 0) {
184 ystep += ypos;
185 ypos = 0;
186 }
187 colptr = scanbar[ystep]; /* move base to top */
188 scanbar[ystep] = scanbar[0];
189 scanbar[0] = colptr;
190 zptr = zbar[ystep];
191 zbar[ystep] = zbar[0];
192 zbar[0] = zptr;
193 /* fill base line */
194 fillscanline(scanbar[0], zbar[0], hresolu, ypos, hstep);
195 /* fill bar */
196 fillscanbar(scanbar, zbar, hresolu, ypos, ystep);
197 /* write it out */
198 #ifndef BSD
199 signal(SIGALRM, SIG_IGN); /* don't interrupt writes */
200 #endif
201 for (i = ystep; i > 0; i--) {
202 if (zfd != -1 && write(zfd, (char *)zbar[i],
203 hresolu*sizeof(float))
204 < hresolu*sizeof(float))
205 goto writerr;
206 if (fwritescan(scanbar[i], hresolu, stdout) < 0)
207 goto writerr;
208 }
209 if (fflush(stdout) == EOF)
210 goto writerr;
211 /* record progress */
212 pctdone = 100.0*(vresolu-1-ypos)/vresolu;
213 if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm)
214 report();
215 #ifndef BSD
216 else
217 signal(SIGALRM, report);
218 #endif
219 }
220 /* clean up */
221 if (zfd != -1) {
222 if (write(zfd, (char *)zbar[0], hresolu*sizeof(float))
223 < hresolu*sizeof(float))
224 goto writerr;
225 if (close(zfd) == -1)
226 goto writerr;
227 for (i = 0; i <= psample; i++)
228 free((char *)zbar[i]);
229 }
230 fwritescan(scanbar[0], hresolu, stdout);
231 if (fflush(stdout) == EOF)
232 goto writerr;
233 for (i = 0; i <= psample; i++)
234 free((char *)scanbar[i]);
235 pctdone = 100.0;
236 return;
237 writerr:
238 error(SYSTEM, "write error in render");
239 memerr:
240 error(SYSTEM, "out of memory in render");
241 }
242
243
244 fillscanline(scanline, zline, xres, y, xstep) /* fill scan line at y */
245 register COLOR *scanline;
246 register float *zline;
247 int xres, y, xstep;
248 {
249 static int nc = 0; /* number of calls */
250 int b = xstep;
251 double z;
252 register int i;
253
254 z = pixvalue(scanline[0], 0, y);
255 if (zline) zline[0] = z;
256 /* zig-zag start for quincunx pattern */
257 for (i = nc++ & 1 ? xstep/2 : xstep; i < xres-1+xstep; i += xstep) {
258 if (i >= xres) {
259 xstep += xres-1-i;
260 i = xres-1;
261 }
262 z = pixvalue(scanline[i], i, y);
263 if (zline) zline[i] = z;
264
265 b = fillsample(scanline+i-xstep, zline ? zline+i-xstep : NULL,
266 i-xstep, y, xstep, 0, b/2);
267 }
268 }
269
270
271 fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
272 register COLOR *scanbar[];
273 register float *zbar[];
274 int xres, y, ysize;
275 {
276 COLOR vline[MAXDIV+1];
277 float zline[MAXDIV+1];
278 int b = ysize;
279 register int i, j;
280
281 for (i = 0; i < xres; i++) {
282
283 copycolor(vline[0], scanbar[0][i]);
284 copycolor(vline[ysize], scanbar[ysize][i]);
285 if (zbar[0]) {
286 zline[0] = zbar[0][i];
287 zline[ysize] = zbar[ysize][i];
288 }
289
290 b = fillsample(vline, zbar[0] ? zline : NULL,
291 i, y, 0, ysize, b/2);
292
293 for (j = 1; j < ysize; j++)
294 copycolor(scanbar[j][i], vline[j]);
295 if (zbar[0])
296 for (j = 1; j < ysize; j++)
297 zbar[j][i] = zline[j];
298 }
299 }
300
301
302 int
303 fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
304 register COLOR *colline;
305 register float *zline;
306 int x, y;
307 int xlen, ylen;
308 int b;
309 {
310 extern double fabs();
311 double ratio;
312 double z;
313 COLOR ctmp;
314 int ncut;
315 register int len;
316
317 if (xlen > 0) /* x or y length is zero */
318 len = xlen;
319 else
320 len = ylen;
321
322 if (len <= 1) /* limit recursion */
323 return(0);
324
325 if (b > 0
326 || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
327 || bigdiff(colline[0], colline[len], maxdiff)) {
328
329 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
330 if (zline) zline[len>>1] = z;
331 ncut = 1;
332
333 } else { /* interpolate */
334
335 copycolor(colline[len>>1], colline[len]);
336 ratio = (double)(len>>1) / len;
337 scalecolor(colline[len>>1], ratio);
338 if (zline) zline[len>>1] = zline[len] * ratio;
339 ratio = 1.0 - ratio;
340 copycolor(ctmp, colline[0]);
341 scalecolor(ctmp, ratio);
342 addcolor(colline[len>>1], ctmp);
343 if (zline) zline[len>>1] += zline[0] * ratio;
344 ncut = 0;
345 }
346 /* recurse */
347 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
348
349 ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL,
350 x+(xlen>>1), y+(ylen>>1),
351 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
352
353 return(ncut);
354 }
355
356
357 double
358 pixvalue(col, x, y) /* compute pixel value */
359 COLOR col; /* returned color */
360 int x, y; /* pixel position */
361 {
362 static RAY thisray;
363
364 if (viewray(thisray.rorg, thisray.rdir, &ourview,
365 (x+pixjitter())/hresolu, (y+pixjitter())/vresolu) < 0) {
366 setcolor(col, 0.0, 0.0, 0.0);
367 return(0.0);
368 }
369
370 rayorigin(&thisray, NULL, PRIMARY, 1.0);
371
372 samplendx = pixnumber(x,y,hresolu,vresolu); /* set pixel index */
373
374 rayvalue(&thisray); /* trace ray */
375
376 copycolor(col, thisray.rcol); /* return color */
377
378 return(thisray.rt); /* return distance */
379 }
380
381
382 int
383 salvage(oldfile) /* salvage scanlines from killed program */
384 char *oldfile;
385 {
386 COLR *scanline;
387 FILE *fp;
388 int x, y;
389
390 if (oldfile == NULL)
391 return(0);
392
393 if ((fp = fopen(oldfile, "r")) == NULL) {
394 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
395 error(WARNING, errmsg);
396 return(0);
397 }
398 /* discard header */
399 getheader(fp, NULL);
400 /* get picture size */
401 if (fgetresolu(&x, &y, fp) != (YMAJOR|YDECR)) {
402 sprintf(errmsg, "bad recover file \"%s\"", oldfile);
403 error(WARNING, errmsg);
404 fclose(fp);
405 return(0);
406 }
407
408 if (x != hresolu || y != vresolu) {
409 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
410 oldfile);
411 error(USER, errmsg);
412 }
413
414 scanline = (COLR *)malloc(hresolu*sizeof(COLR));
415 if (scanline == NULL)
416 error(SYSTEM, "out of memory in salvage");
417 for (y = 0; y < vresolu; y++) {
418 if (freadcolrs(scanline, hresolu, fp) < 0)
419 break;
420 if (fwritecolrs(scanline, hresolu, stdout) < 0)
421 goto writerr;
422 }
423 if (fflush(stdout) == EOF)
424 goto writerr;
425 free((char *)scanline);
426 fclose(fp);
427 unlink(oldfile);
428 return(y);
429 writerr:
430 error(SYSTEM, "write error in salvage");
431 }
432
433
434 int
435 pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
436 register int x, y;
437 int xres, yres;
438 {
439 x -= y;
440 while (x < 0)
441 x += xres;
442 return((((x>>2)*yres + y) << 2) + (x & 3));
443 }
