--- ray/src/rt/rpict.c 1989/09/13 15:21:41 1.8 +++ ray/src/rt/rpict.c 1989/09/29 08:16:41 1.9 @@ -49,8 +49,6 @@ double pctdone = 0.0; /* percentage done */ extern long nrays; /* number of rays traced */ -static int xres, yres; /* output x and y resolution */ - #define MAXDIV 32 /* maximum sample size */ #define pixjitter() (.5+dstrpix*(.5-frandom())) @@ -96,45 +94,53 @@ char *oldfile; { COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ int ypos; /* current scanline */ + int xres, yres; /* rendered x and y resolution */ COLOR *colptr; register int i; - - if (psample < 1) + /* set rendered resolution */ + xres = ourview.hresolu; + yres = ourview.vresolu; + /* adjust for sampling */ + if (psample <= 1) psample = 1; - else if (psample > MAXDIV) - psample = MAXDIV; - /* output resolution may be smaller */ - xres = ourview.hresolu - (ourview.hresolu % psample); - yres = ourview.vresolu - (ourview.vresolu % psample); - + else { + if (psample > MAXDIV) + psample = MAXDIV; + /* rendered resolution may be larger */ + xres += psample-1 - ((ourview.hresolu-2)%psample); + yres += psample-1 - ((ourview.vresolu-2)%psample); + } + /* allocate scanlines */ for (i = 0; i <= psample; i++) { - scanbar[i] = (COLOR *)malloc((xres+1)*sizeof(COLOR)); + scanbar[i] = (COLOR *)malloc(xres*sizeof(COLOR)); if (scanbar[i] == NULL) error(SYSTEM, "out of memory in render"); } /* write out boundaries */ - fputresolu(YMAJOR|YDECR, xres, yres, stdout); + fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, stdout); - ypos = yres - salvage(oldfile); /* find top line */ - fillscanline(scanbar[0], ypos, psample); /* top scan */ + ypos = ourview.vresolu-1 - salvage(oldfile); /* find top line */ + fillscanline(scanbar[0], xres, ypos, psample); /* top scan */ for (ypos -= psample; ypos > -psample; ypos -= psample) { - colptr = scanbar[psample]; /* get last scanline */ + pctdone = 100.0*(ourview.vresolu-ypos+psample)/ourview.vresolu; + + colptr = scanbar[psample]; /* move base to top */ scanbar[psample] = scanbar[0]; scanbar[0] = colptr; - fillscanline(scanbar[0], ypos, psample); /* base scan */ + fillscanline(scanbar[0], xres, ypos, psample); /* fill base */ - fillscanbar(scanbar, ypos, psample); + fillscanbar(scanbar, xres, ypos, psample); /* fill bar */ - for (i = psample-1; i >= 0; i--) - if (fwritescan(scanbar[i], xres, stdout) < 0) + for (i = psample; (ypos>0) ? i > 0 : ypos+i >= 0; i--) + if (fwritescan(scanbar[i], ourview.hresolu, stdout) < 0) goto writerr; if (fflush(stdout) == EOF) goto writerr; - pctdone = 100.0*(yres-ypos)/yres; } + pctdone = 100.0; for (i = 0; i <= psample; i++) free((char *)scanbar[i]); @@ -144,16 +150,16 @@ writerr: } -fillscanline(scanline, y, xstep) /* fill scan line at y */ +fillscanline(scanline, xres, y, xstep) /* fill scan line at y */ register COLOR *scanline; -int y, xstep; +int xres, y, xstep; { int b = xstep; register int i; pixvalue(scanline[0], 0, y); - for (i = xstep; i <= xres; i += xstep) { + for (i = xstep; i < xres; i += xstep) { pixvalue(scanline[i], i, y); @@ -162,9 +168,9 @@ int y, xstep; } -fillscanbar(scanbar, y, ysize) /* fill interior */ +fillscanbar(scanbar, xres, y, ysize) /* fill interior */ register COLOR *scanbar[]; -int y, ysize; +int xres, y, ysize; { COLOR vline[MAXDIV+1]; int b = ysize; @@ -256,7 +262,8 @@ char *oldfile; if (oldfile == NULL) return(0); - else if ((fp = fopen(oldfile, "r")) == NULL) { + + if ((fp = fopen(oldfile, "r")) == NULL) { sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); error(WARNING, errmsg); return(0); @@ -271,20 +278,19 @@ char *oldfile; return(0); } - if (x != xres || y != yres) { + if (x != ourview.hresolu || y != ourview.vresolu) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); - return(0); } - scanline = (COLR *)malloc(xres*sizeof(COLR)); + scanline = (COLR *)malloc(ourview.hresolu*sizeof(COLR)); if (scanline == NULL) error(SYSTEM, "out of memory in salvage"); - for (y = 0; y < yres; y++) { - if (freadcolrs(scanline, xres, fp) < 0) + for (y = 0; y < ourview.vresolu; y++) { + if (freadcolrs(scanline, ourview.hresolu, fp) < 0) break; - if (fwritecolrs(scanline, xres, stdout) < 0) + if (fwritecolrs(scanline, ourview.hresolu, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF)
