root/radiance/ray/src/rt/rpict.c
Revision: 2.109
Committed: Tue Jul 1 19:40:35 2025 UTC (5 weeks, 4 days ago) by greg
Changes since 2.108: +2 -2 lines
fix: Made PIXASPECT= output a little more stringent (+/-0.1% rather than 1%)
2 static const char RCSid[] = "$Id: rpict.c,v 2.108 2025/06/20 03:43:17 greg Exp $";
5 * rpict.c - routines and variables for picture generation.
6 */
7
8 #include "copyright.h"
9
10 #include <sys/types.h>
11
12 #include "platform.h"
13 #ifdef NON_POSIX
14 #ifdef MINGW
15 #include <sys/time.h>
16 #endif
17 #else
18 #ifdef BSD
19 #include <sys/time.h>
20 #include <sys/resource.h>
21 #else
22 #include <sys/times.h>
23 #include <unistd.h>
24 #endif
25 #endif
26
27 #include <time.h>
28 #include <signal.h>
29
30 #include "ray.h"
31 #include "paths.h"
32 #include "ambient.h"
33 #include "view.h"
34 #include "random.h"
35 #include "paths.h"
36 #include "hilbert.h"
37 #include "pmapbias.h"
38 #include "pmapdiag.h"
39
40 #define RFTEMPLATE "rfXXXXXX"
41
42 #ifndef SIGCONT
43 #ifdef SIGIO /* XXX can we live without this? */
44 #define SIGCONT SIGIO
45 #endif
46 #endif
47
48 CUBE thescene; /* our scene */
49 OBJECT nsceneobjs; /* number of objects in our scene */
50
51 extern RGBPRIMP out_prims; /* output color primitives (NULL if spectral) */
52
53 int dimlist[MAXDIM]; /* sampling dimensions */
54 int ndims = 0; /* number of sampling dimensions */
55 unsigned long samplendx; /* sample index number */
56
57 void (*addobjnotify[])() = {ambnotify, NULL};
58
59 VIEW ourview = STDVIEW; /* view parameters */
60 int hresolu = 512; /* horizontal resolution */
61 int vresolu = 512; /* vertical resolution */
62 double pixaspect = 1.0; /* pixel aspect ratio */
63
64 int psample = 4; /* pixel sample size */
65 double maxdiff = .05; /* max. difference for interpolation */
66 double dstrpix = 0.67; /* square pixel distribution */
67
68 double mblur = 0.; /* motion blur parameter */
69
70 double dblur = 0.; /* depth-of-field blur parameter */
71
72 void (*trace)() = NULL; /* trace call */
73
74 int do_irrad = 0; /* compute irradiance? */
75
76 int rand_samp = 0; /* pure Monte Carlo sampling? */
77
78 double dstrsrc = 0.0; /* square source distribution */
79 double shadthresh = .05; /* shadow threshold */
80 double shadcert = .5; /* shadow certainty */
81 int directrelay = 1; /* number of source relays */
82 int vspretest = 512; /* virtual source pretest density */
83 int directvis = 1; /* sources visible? */
84 double srcsizerat = .25; /* maximum ratio source size/dist. */
85
86 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
87 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
88 double seccg = 0.; /* global scattering eccentricity */
89 double ssampdist = 0.; /* scatter sampling distance */
90
91 double specthresh = .15; /* specular sampling threshold */
92 double specjitter = 1.; /* specular sampling jitter */
93
94 int backvis = 1; /* back face visibility */
95
96 int maxdepth = 7; /* maximum recursion depth */
97 double minweight = 1e-4; /* minimum ray weight */
98
99 char *ambfile = NULL; /* ambient file name */
100 COLOR ambval = BLKCOLOR; /* ambient value */
101 int ambvwt = 0; /* initial weight for ambient value */
102 double ambacc = 0.2; /* ambient accuracy */
103 int ambres = 64; /* ambient resolution */
104 int ambdiv = 512; /* ambient divisions */
105 int ambssamp = 128; /* ambient super-samples */
106 int ambounce = 0; /* ambient bounces */
107 char *amblist[AMBLLEN]; /* ambient include/exclude list */
108 int ambincl = -1; /* include == 1, exclude == 0 */
109
110 int ralrm = 0; /* seconds between reports */
111
112 double pctdone = 0.0; /* percentage done */
113 time_t tlastrept = 0L; /* time at last report */
114 time_t tstart; /* starting time */
115
116 #define MAXDIV 16 /* maximum sample size */
117
118 #define pixjitter() (.5+dstrpix*(.5-frandom()))
119
120 int hres, vres; /* resolution for this frame */
121
122 extern void sskip_ray(RAY *r, double h, double v);
123
124 static VIEW lastview; /* the previous view input */
125
126 static void report(int);
127 static int nextview(FILE *fp);
128 static void render(char *zfile, char *oldfile);
129 static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres,
130 int y, int xstep);
131 static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres,
132 int y, int ysize);
133 static int fillsample(COLOR *colline, float *zline, int x, int y,
134 int xlen, int ylen, int b);
135 static double pixvalue(COLOR col, int x, int y);
136 static int salvage(char *oldfile);
137 static unsigned long pixnumber(int x, int y, int xres, int yres);
138
139
140
141 void
142 quit(int code) /* quit program */
143 {
144 if (code) /* report status */
145 report(0);
146 #ifndef NON_POSIX
147 headclean(); /* delete header file */
148 pfclean(); /* clean up persist files */
149 #endif
150 exit(code);
151 }
152
153
154 #ifndef NON_POSIX
155 static void
156 report(int dummy) /* report progress */
157 {
158 char bcStat [128];
159 double u, s;
160 #ifdef BSD
161 struct rusage rubuf;
162 #else
163 double period = 1.0 / 60.0;
164 struct tms tbuf;
165 #endif
166
167 tlastrept = time((time_t *)NULL);
168 #ifdef BSD
169 getrusage(RUSAGE_SELF, &rubuf);
170 u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
171 s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
172 getrusage(RUSAGE_CHILDREN, &rubuf);
173 u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
174 s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
175 #else
176 times(&tbuf);
177 #ifdef _SC_CLK_TCK
178 period = 1.0 / sysconf(_SC_CLK_TCK);
179 #endif
180 u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period;
181 s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period;
182 #endif
183
184 /* PMAP: Get photon map bias compensation statistics */
185 pmapBiasCompReport(bcStat);
186
187 sprintf(errmsg,
188 "%lu rays, %s%4.2f%% after %.3fu %.3fs %.3fr hours on %s (PID %d)\n",
189 nrays, bcStat, pctdone, u*(1./3600.), s*(1./3600.),
190 (tlastrept-tstart)*(1./3600.), myhostname(), getpid());
191 eputs(errmsg);
192 #ifdef SIGCONT
193 signal(SIGCONT, report);
194 #endif
195 }
196 #else
197 static void
198 report(int dummy) /* report progress */
199 {
200 char bcStat [128];
201
202 tlastrept = time((time_t *)NULL);
203
204 /* PMAP: Get photon map bias compensation statistics */
205 pmapBiasCompReport(bcStat);
206
207 sprintf(errmsg, "%lu rays, %s%4.2f%% after %5.4f hours\n",
208 nrays, bcStat, pctdone, (tlastrept-tstart)/3600.0);
209 eputs(errmsg);
210 }
211 #endif
212
213
214 void
215 rpict( /* generate image(s) */
216 int seq,
217 char *pout,
218 char *zout,
219 char *prvr
220 )
221 /*
222 * If seq is greater than zero, then we will render a sequence of
223 * images based on view parameter strings read from the standard input.
224 * If pout is NULL, then all images will be sent to the standard ouput.
225 * If seq is greater than zero and prvr is an integer, then it is the
226 * frame number at which rendering should begin. Preceeding view parameter
227 * strings will be skipped in the input.
228 * If pout and prvr are the same, prvr is renamed to avoid overwriting.
229 * Note that pout and zout should contain %d format specifications for
230 * sequenced file naming.
231 */
232 {
233 char fbuf[128], fbuf2[128];
234 int npicts;
235 char *cp;
236 RESOLU rs;
237 double pa;
238 /* check sampling */
239 if (psample < 1)
240 psample = 1;
241 else if (psample > MAXDIV) {
242 sprintf(errmsg, "pixel sampling reduced from %d to %d",
243 psample, MAXDIV);
244 error(WARNING, errmsg);
245 psample = MAXDIV;
246 }
247 /* get starting frame */
248 if (seq <= 0)
249 seq = 0;
250 else if (prvr != NULL && isint(prvr)) {
251 int rn; /* skip to specified view */
252 if ((rn = atoi(prvr)) < seq)
253 error(USER, "recover frame less than start frame");
254 if (pout == NULL)
255 error(USER, "missing output file specification");
256 for ( ; seq < rn; seq++)
257 if (nextview(stdin) == EOF)
258 error(USER, "unexpected EOF on view input");
259 setview(&ourview);
260 prvr = fbuf; /* mark for renaming */
261 }
262 if ((pout != NULL) & (prvr != NULL)) {
263 sprintf(fbuf, pout, seq);
264 if (!strcmp(prvr, fbuf)) { /* rename */
265 strcpy(fbuf2, fbuf);
266 for (cp = fbuf2; *cp; cp++)
267 ;
268 while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
269 cp--;
270 strcpy(cp, RFTEMPLATE);
271 prvr = mktemp(fbuf2);
272 if (rename(fbuf, prvr) < 0) {
273 if (errno == ENOENT) { /* ghost file */
274 sprintf(errmsg,
275 "new output file \"%s\"",
276 fbuf);
277 error(WARNING, errmsg);
278 prvr = NULL;
279 } else { /* serious error */
280 sprintf(errmsg,
281 "cannot rename \"%s\" to \"%s\"",
282 fbuf, prvr);
283 error(SYSTEM, errmsg);
284 }
285 }
286 }
287 }
288 npicts = 0; /* render sequence */
289 do {
290 if (seq && nextview(stdin) == EOF)
291 break;
292 lastview.type *= seq > 1;
293 pctdone = 0.0;
294 if (pout != NULL) {
295 int myfd;
296 close(1); /* reassign stdout */
297 sprintf(fbuf, pout, seq);
298 tryagain:
299 errno = 0; /* exclusive open */
300 if ((myfd = open(fbuf, O_WRONLY|O_CREAT|O_EXCL, 0666)) < 0) {
301 if ((errno != EEXIST) | (prvr != NULL) ||
302 !strcmp(fbuf, pout)) {
303 sprintf(errmsg,
304 "cannot open output file \"%s\"",
305 fbuf);
306 error(SYSTEM, errmsg);
307 }
308 setview(&ourview);
309 continue; /* don't clobber */
310 }
311 if (myfd != 1) {
312 unlink(fbuf);
313 goto tryagain; /* leave it open */
314 }
315 SET_FD_BINARY(1);
316 dupheader();
317 }
318 hres = hresolu; vres = vresolu; pa = pixaspect;
319 if (prvr != NULL) {
320 if (viewfile(prvr, &ourview, &rs) <= 0) {
321 sprintf(errmsg,
322 "cannot recover view parameters from \"%s\"", prvr);
323 error(WARNING, errmsg);
324 } else {
325 pa = 0.0;
326 hres = scanlen(&rs);
327 vres = numscans(&rs);
328 }
329 }
330 if ((cp = setview(&ourview)) != NULL)
331 error(USER, cp);
332 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
333 if (seq) {
334 if (ralrm > 0) {
335 fprintf(stderr, "FRAME %d:", seq);
336 fprintview(&ourview, stderr);
337 putc('\n', stderr);
338 fflush(stderr);
339 }
340 printf("FRAME=%d\n", seq);
341 }
342 fputs(VIEWSTR, stdout);
343 fprintview(&ourview, stdout);
344 putchar('\n');
345 if ((pa < .999) | (pa > 1.001))
346 fputaspect(pa, stdout);
347 fputnow(stdout);
348 if (out_prims == xyzprims) {
349 fputformat(CIEFMT, stdout);
350 } else {
351 fputprims(out_prims, stdout);
352 fputformat(COLRFMT, stdout);
353 }
354 putchar('\n'); /* close header */
355 if (zout != NULL)
356 sprintf(cp=fbuf, zout, seq);
357 else
358 cp = NULL;
359 render(cp, prvr);
360 prvr = NULL;
361 npicts++;
362 } while (seq++);
363 /* check that we did something */
364 if (npicts == 0)
365 error(WARNING, "no output produced");
366 }
367
368
369 static int
370 nextview( /* get next view from fp */
371 FILE *fp
372 )
373 {
374 char linebuf[256];
375
376 lastview = ourview;
377 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
378 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
379 return(0);
380 return(EOF);
381 }
382
383
384 static void
385 render( /* render the scene */
386 char *zfile,
387 char *oldfile
388 )
389 {
390 const int srcdrawing = /* manually draw tiny light sources? */
391 (directvis && dblur <= FTINY && (mblur <= FTINY) | !lastview.type);
392 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
393 float *zbar[MAXDIV+1]; /* z values */
394 char *sampdens; /* previous sample density */
395 int ypos; /* current scanline */
396 int ystep; /* current y step size */
397 int hstep; /* h step size */
398 int zfd;
399 COLOR *colptr;
400 float *zptr;
401 int i;
402 /* check for empty image */
403 if ((hres <= 0) | (vres <= 0)) {
404 error(WARNING, "empty output picture");
405 fprtresolu(0, 0, stdout);
406 return;
407 }
408 /* allocate scanlines */
409 for (i = 0; i <= psample; i++) {
410 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
411 if (scanbar[i] == NULL)
412 goto memerr;
413 }
414 hstep = (psample*140+49)/99; /* quincunx sampling */
415 ystep = (psample*99+70)/140;
416 if (hstep > 2) {
417 i = hres/hstep + 2;
418 if ((sampdens = (char *)malloc(i)) == NULL)
419 goto memerr;
420 while (i--)
421 sampdens[i] = hstep;
422 } else
423 sampdens = NULL;
424 /* open z-file */
425 if (zfile != NULL) {
426 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
427 sprintf(errmsg, "cannot open z-file \"%s\"", zfile);
428 error(SYSTEM, errmsg);
429 }
430 SET_FD_BINARY(zfd);
431 for (i = 0; i <= psample; i++) {
432 zbar[i] = (float *)malloc(hres*sizeof(float));
433 if (zbar[i] == NULL)
434 goto memerr;
435 }
436 } else {
437 zfd = -1;
438 for (i = 0; i <= psample; i++)
439 zbar[i] = NULL;
440 }
441 /* write out boundaries */
442 fprtresolu(hres, vres, stdout);
443 /* recover file and compute first */
444 i = salvage(oldfile);
445 if (i >= vres)
446 goto alldone;
447 if ((zfd != -1) & (i > 0) &&
448 lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0)
449 error(SYSTEM, "z-file seek error in render");
450 pctdone = 100.0*i/vres;
451 if (ralrm > 0) /* report init stats */
452 report(0);
453 #ifdef SIGCONT
454 else
455 signal(SIGCONT, report);
456 #endif
457 ypos = vres-1 - i; /* initialize sampling */
458 if (srcdrawing)
459 init_drawsources(psample);
460 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
461 /* compute scanlines */
462 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
463 /* bottom adjust? */
464 if (ypos < 0) {
465 ystep += ypos;
466 ypos = 0;
467 }
468 colptr = scanbar[ystep]; /* move base to top */
469 scanbar[ystep] = scanbar[0];
470 scanbar[0] = colptr;
471 zptr = zbar[ystep];
472 zbar[ystep] = zbar[0];
473 zbar[0] = zptr;
474 /* fill base line */
475 fillscanline(scanbar[0], zbar[0], sampdens,
476 hres, ypos, hstep);
477 /* fill bar */
478 fillscanbar(scanbar, zbar, hres, ypos, ystep);
479 if (srcdrawing) /* add bitty sources */
480 drawsources((COLORV **)scanbar, out_prims, zbar, 0, hres, ypos, ystep);
481 /* write it out */
482 #ifdef SIGCONT
483 signal(SIGCONT, SIG_IGN); /* don't interrupt writes */
484 #endif
485 for (i = ystep; i > 0; i--) {
486 if (zfd != -1 && write(zfd, (char *)zbar[i],
487 hres*sizeof(float))
488 < hres*sizeof(float))
489 goto writerr;
490 if (fwritescan(scanbar[i], hres, stdout) < 0)
491 goto writerr;
492 }
493 if (fflush(stdout) == EOF)
494 goto writerr;
495 /* record progress */
496 pctdone = 100.0*(vres-1-ypos)/vres;
497 if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm)
498 report(0);
499 #ifdef SIGCONT
500 else
501 signal(SIGCONT, report);
502 #endif
503 }
504 /* clean up */
505 #ifdef SIGCONT
506 signal(SIGCONT, SIG_IGN);
507 #endif
508 if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float))
509 < hres*sizeof(float))
510 goto writerr;
511 fwritescan(scanbar[0], hres, stdout);
512 if (fflush(stdout) == EOF)
513 goto writerr;
514 alldone:
515 if (zfd != -1) {
516 if (close(zfd) == -1)
517 goto writerr;
518 for (i = 0; i <= psample; i++)
519 free((void *)zbar[i]);
520 }
521 for (i = 0; i <= psample; i++)
522 free((void *)scanbar[i]);
523 if (sampdens != NULL)
524 free(sampdens);
525 pctdone = 100.0;
526 if (ralrm > 0)
527 report(0);
528 #ifdef SIGCONT
529 signal(SIGCONT, SIG_DFL);
530 #endif
531 return;
532 writerr:
533 error(SYSTEM, "write error in render");
534 memerr:
535 error(SYSTEM, "out of memory in render");
536 }
537
538
539 static void
540 fillscanline( /* fill scan at y */
541 COLOR *scanline,
542 float *zline,
543 char *sd,
544 int xres,
545 int y,
546 int xstep
547 )
548 {
549 static int nc = 0; /* number of calls */
550 int bl = xstep, b = xstep;
551 double z;
552 int i;
553
554 z = pixvalue(scanline[0], 0, y);
555 if (zline) zline[0] = z;
556 /* zig-zag start for quincunx pattern */
557 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
558 if (i >= xres) {
559 xstep += xres-1-i;
560 i = xres-1;
561 }
562 z = pixvalue(scanline[i], i, y);
563 if (zline) zline[i] = z;
564 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
565 if (i <= xstep)
566 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
567 else
568 b = fillsample(scanline+i-xstep,
569 zline ? zline+i-xstep : (float *)NULL,
570 i-xstep, y, xstep, 0, b/2);
571 if (sd) *sd++ = nc & 1 ? bl : b;
572 bl = b;
573 }
574 if (sd && nc & 1) *sd = bl;
575 }
576
577
578 static void
579 fillscanbar( /* fill interior */
580 COLOR *scanbar[],
581 float *zbar[],
582 int xres,
583 int y,
584 int ysize
585 )
586 {
587 COLOR vline[MAXDIV+1];
588 float zline[MAXDIV+1];
589 int b = ysize;
590 int i, j;
591
592 for (i = 0; i < xres; i++) {
593 copycolor(vline[0], scanbar[0][i]);
594 copycolor(vline[ysize], scanbar[ysize][i]);
595 if (zbar[0]) {
596 zline[0] = zbar[0][i];
597 zline[ysize] = zbar[ysize][i];
598 }
599 b = fillsample(vline, zbar[0] ? zline : (float *)NULL,
600 i, y, 0, ysize, b/2);
601
602 for (j = 1; j < ysize; j++)
603 copycolor(scanbar[j][i], vline[j]);
604 if (zbar[0])
605 for (j = 1; j < ysize; j++)
606 zbar[j][i] = zline[j];
607 }
608 }
609
610
611 static int
612 fillsample( /* fill interior points */
613 COLOR *colline,
614 float *zline,
615 int x,
616 int y,
617 int xlen,
618 int ylen,
619 int b
620 )
621 {
622 double ratio;
623 double z;
624 COLOR ctmp;
625 int ncut;
626 int len;
627
628 if (xlen > 0) /* x or y length is zero */
629 len = xlen;
630 else
631 len = ylen;
632
633 if (len <= 1) /* limit recursion */
634 return(0);
635
636 if (b > 0 ||
637 (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
638 || bigdiff(colline[0], colline[len], maxdiff)) {
639
640 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
641 if (zline) zline[len>>1] = z;
642 ncut = 1;
643 } else { /* interpolate */
644 copycolor(colline[len>>1], colline[len]);
645 ratio = (double)(len>>1) / len;
646 scalecolor(colline[len>>1], ratio);
647 if (zline) zline[len>>1] = zline[len] * ratio;
648 ratio = 1.0 - ratio;
649 copycolor(ctmp, colline[0]);
650 scalecolor(ctmp, ratio);
651 addcolor(colline[len>>1], ctmp);
652 if (zline) zline[len>>1] += zline[0] * ratio;
653 ncut = 0;
654 }
655 /* recurse */
656 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
657
658 ncut += fillsample(colline+(len>>1),
659 zline ? zline+(len>>1) : (float *)NULL,
660 x+(xlen>>1), y+(ylen>>1),
661 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
662
663 return(ncut);
664 }
665
666
667 static double
668 pixvalue( /* compute pixel value */
669 COLOR col, /* returned color */
670 int x, /* pixel position */
671 int y
672 )
673 {
674 RAY thisray;
675 FVECT lorg, ldir;
676 double hpos, vpos, lmax;
677 int i;
678 /* compute view ray */
679 setcolor(col, 0.0, 0.0, 0.0);
680 hpos = (x+pixjitter())/hres;
681 vpos = (y+pixjitter())/vres;
682 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
683 &ourview, hpos, vpos)) < -FTINY)
684 return(0.0);
685 /* set pixel index */
686 samplendx = pixnumber(x,y,hres,vres);
687 /* optional motion blur */
688 if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir,
689 &lastview, hpos, vpos)) >= -FTINY) {
690 double d = mblur*(.5-urand(281+samplendx));
691
692 thisray.rmax = (1.-d)*thisray.rmax + d*lmax;
693 for (i = 3; i--; ) {
694 thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i];
695 thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i];
696 }
697 if (normalize(thisray.rdir) == 0.0)
698 return(0.0);
699 }
700 /* depth-of-field */
701 if (!jitteraperture(thisray.rorg, thisray.rdir, &ourview, dblur))
702 return(0.0);
703
704 rayorigin(&thisray, PRIMARY, NULL, NULL);
705
706 rayvalue(&thisray); /* trace ray */
707 /* -> color */
708 scolor_out(col, out_prims, thisray.rcol);
709
710 return(raydistance(&thisray)); /* return distance */
711 }
712
713
714 static int
715 salvage( /* salvage scanlines from killed program */
716 char *oldfile
717 )
718 {
719 COLR *scanline;
720 FILE *fp;
721 int x, y;
722
723 if (oldfile == NULL)
724 goto gotzip;
725
726 if ((fp = fopen(oldfile, "r")) == NULL) {
727 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
728 error(WARNING, errmsg);
729 goto gotzip;
730 }
731 SET_FILE_BINARY(fp);
732 /* discard header */
733 getheader(fp, NULL, NULL);
734 /* get picture size */
735 if (!fscnresolu(&x, &y, fp)) {
736 sprintf(errmsg, "bad recover file \"%s\" - not removed",
737 oldfile);
738 error(WARNING, errmsg);
739 fclose(fp);
740 goto gotzip;
741 }
742
743 if ((x != hres) | (y != vres)) {
744 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
745 oldfile);
746 error(USER, errmsg);
747 }
748
749 scanline = (COLR *)malloc(hres*sizeof(COLR));
750 if (scanline == NULL)
751 error(SYSTEM, "out of memory in salvage");
752 for (y = 0; y < vres; y++) {
753 if (freadcolrs(scanline, hres, fp) < 0)
754 break;
755 if (fwritecolrs(scanline, hres, stdout) < 0)
756 goto writerr;
757 }
758 if (fflush(stdout) == EOF)
759 goto writerr;
760 free((void *)scanline);
761 fclose(fp);
762 unlink(oldfile);
763 return(y);
764 gotzip:
765 if (fflush(stdout) == EOF)
766 error(SYSTEM, "error writing picture header");
767 return(0);
768 writerr:
769 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
770 error(SYSTEM, errmsg);
771 return -1; /* pro forma return */
772 }
773
774 static unsigned long
775 pixnumber( /* compute pixel index (screen door) */
776 int x,
777 int y,
778 int xres,
779 int yres
780 )
781 {
782 unsigned nbits = 0;
783 bitmask_t coord[2];
784
785 if (xres < yres) xres = yres;
786 while (xres > 0) {
787 xres >>= 1;
788 ++nbits;
789 }
790 coord[0] = x; coord[1] = y;
791 return((unsigned long)hilbert_c2i(2, nbits, coord));
792 }
