root/radiance/ray/src/rt/rpict.c
Revision: 1.36
Committed: Mon Nov 11 14:02:45 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.35: +4 -2 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rpict.c - routines and variables for picture generation.
9 *
10 * 8/14/85
11 */
12
13 #include "ray.h"
14
15 #ifdef BSD
16 #include <sys/time.h>
17 #include <sys/resource.h>
18 #endif
19
20 #include <signal.h>
21 #include <fcntl.h>
22
23 #include "view.h"
24
25 #include "resolu.h"
26
27 #include "random.h"
28
29 int dimlist[MAXDIM]; /* sampling dimensions */
30 int ndims = 0; /* number of sampling dimensions */
31 int samplendx; /* sample index number */
32
33 VIEW ourview = STDVIEW; /* view parameters */
34 int hresolu = 512; /* horizontal resolution */
35 int vresolu = 512; /* vertical resolution */
36 double pixaspect = 1.0; /* pixel aspect ratio */
37
38 int psample = 4; /* pixel sample size */
39 double maxdiff = .05; /* max. difference for interpolation */
40 double dstrpix = 0.67; /* square pixel distribution */
41
42 double dstrsrc = 0.0; /* square source distribution */
43 double shadthresh = .05; /* shadow threshold */
44 double shadcert = .5; /* shadow certainty */
45 int directrelay = 1; /* number of source relays */
46 int vspretest = 512; /* virtual source pretest density */
47 int directinvis = 0; /* sources invisible? */
48 double srcsizerat = .25; /* maximum ratio source size/dist. */
49
50 int maxdepth = 6; /* maximum recursion depth */
51 double minweight = 5e-3; /* minimum ray weight */
52
53 COLOR ambval = BLKCOLOR; /* ambient value */
54 double ambacc = 0.2; /* ambient accuracy */
55 int ambres = 32; /* ambient resolution */
56 int ambdiv = 128; /* ambient divisions */
57 int ambssamp = 0; /* ambient super-samples */
58 int ambounce = 0; /* ambient bounces */
59 char *amblist[128]; /* ambient include/exclude list */
60 int ambincl = -1; /* include == 1, exclude == 0 */
61
62 int ralrm = 0; /* seconds between reports */
63
64 double pctdone = 0.0; /* percentage done */
65
66 long tlastrept = 0L; /* time at last report */
67
68 extern long time();
69 extern long tstart; /* starting time */
70
71 extern long nrays; /* number of rays traced */
72
73 #define MAXDIV 15 /* maximum sample size */
74
75 #define pixjitter() (.5+dstrpix*(.5-frandom()))
76
77 double pixvalue();
78
79
80 quit(code) /* quit program */
81 int code;
82 {
83 if (code || ralrm > 0) /* report status */
84 report();
85
86 exit(code);
87 }
88
89
90 #ifdef BSD
91 report() /* report progress */
92 {
93 struct rusage rubuf;
94 double t;
95
96 getrusage(RUSAGE_SELF, &rubuf);
97 t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
98 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
99 getrusage(RUSAGE_CHILDREN, &rubuf);
100 t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
101 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
102
103 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n",
104 nrays, pctdone, t/3600.0);
105 eputs(errmsg);
106 tlastrept = time((long *)0);
107 }
108 #else
109 report() /* report progress */
110 {
111 signal(SIGALRM, report);
112 tlastrept = time((long *)0);
113 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n",
114 nrays, pctdone, (tlastrept-tstart)/3600.0);
115 eputs(errmsg);
116 }
117 #endif
118
119
120 render(zfile, oldfile) /* render the scene */
121 char *zfile, *oldfile;
122 {
123 extern long lseek();
124 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
125 float *zbar[MAXDIV+1]; /* z values */
126 int ypos; /* current scanline */
127 int ystep; /* current y step size */
128 int hstep; /* h step size */
129 int zfd;
130 COLOR *colptr;
131 float *zptr;
132 register int i;
133 /* check sampling */
134 if (psample < 1)
135 psample = 1;
136 else if (psample > MAXDIV) {
137 sprintf(errmsg, "pixel sampling reduced from %d to %d",
138 psample, MAXDIV);
139 error(WARNING, errmsg);
140 psample = MAXDIV;
141 }
142 /* allocate scanlines */
143 for (i = 0; i <= psample; i++) {
144 scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR));
145 if (scanbar[i] == NULL)
146 goto memerr;
147 }
148 /* open z file */
149 if (zfile != NULL) {
150 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
151 sprintf(errmsg, "cannot open z file \"%s\"", zfile);
152 error(SYSTEM, errmsg);
153 }
154 for (i = 0; i <= psample; i++) {
155 zbar[i] = (float *)malloc(hresolu*sizeof(float));
156 if (zbar[i] == NULL)
157 goto memerr;
158 }
159 } else {
160 zfd = -1;
161 for (i = 0; i <= psample; i++)
162 zbar[i] = NULL;
163 }
164 /* write out boundaries */
165 fprtresolu(hresolu, vresolu, stdout);
166 /* recover file and compute first */
167 i = salvage(oldfile);
168 if (zfd != -1 && i > 0 &&
169 lseek(zfd, (long)i*hresolu*sizeof(float), 0) == -1)
170 error(SYSTEM, "z file seek error in render");
171 pctdone = 100.0*i/vresolu;
172 if (ralrm > 0) /* report init stats */
173 report();
174 #ifndef BSD
175 else
176 #endif
177 signal(SIGALRM, report);
178 ypos = vresolu-1 - i;
179 hstep = (psample*140+49)/99; /* quincunx sampling */
180 ystep = (psample*99+70)/140;
181 fillscanline(scanbar[0], zbar[0], hresolu, ypos, hstep);
182 /* compute scanlines */
183 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
184 /* bottom adjust? */
185 if (ypos < 0) {
186 ystep += ypos;
187 ypos = 0;
188 }
189 colptr = scanbar[ystep]; /* move base to top */
190 scanbar[ystep] = scanbar[0];
191 scanbar[0] = colptr;
192 zptr = zbar[ystep];
193 zbar[ystep] = zbar[0];
194 zbar[0] = zptr;
195 /* fill base line */
196 fillscanline(scanbar[0], zbar[0], hresolu, ypos, hstep);
197 /* fill bar */
198 fillscanbar(scanbar, zbar, hresolu, ypos, ystep);
199 /* write it out */
200 #ifndef BSD
201 signal(SIGALRM, SIG_IGN); /* don't interrupt writes */
202 #endif
203 for (i = ystep; i > 0; i--) {
204 if (zfd != -1 && write(zfd, (char *)zbar[i],
205 hresolu*sizeof(float))
206 < hresolu*sizeof(float))
207 goto writerr;
208 if (fwritescan(scanbar[i], hresolu, stdout) < 0)
209 goto writerr;
210 }
211 if (fflush(stdout) == EOF)
212 goto writerr;
213 /* record progress */
214 pctdone = 100.0*(vresolu-1-ypos)/vresolu;
215 if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm)
216 report();
217 #ifndef BSD
218 else
219 signal(SIGALRM, report);
220 #endif
221 }
222 /* clean up */
223 if (zfd != -1) {
224 if (write(zfd, (char *)zbar[0], hresolu*sizeof(float))
225 < hresolu*sizeof(float))
226 goto writerr;
227 if (close(zfd) == -1)
228 goto writerr;
229 for (i = 0; i <= psample; i++)
230 free((char *)zbar[i]);
231 }
232 fwritescan(scanbar[0], hresolu, stdout);
233 if (fflush(stdout) == EOF)
234 goto writerr;
235 for (i = 0; i <= psample; i++)
236 free((char *)scanbar[i]);
237 pctdone = 100.0;
238 return;
239 writerr:
240 error(SYSTEM, "write error in render");
241 memerr:
242 error(SYSTEM, "out of memory in render");
243 }
244
245
246 fillscanline(scanline, zline, xres, y, xstep) /* fill scan line at y */
247 register COLOR *scanline;
248 register float *zline;
249 int xres, y, xstep;
250 {
251 static int nc = 0; /* number of calls */
252 int b = xstep;
253 double z;
254 register int i;
255
256 z = pixvalue(scanline[0], 0, y);
257 if (zline) zline[0] = z;
258 /* zig-zag start for quincunx pattern */
259 for (i = nc++ & 1 ? xstep/2 : xstep; i < xres-1+xstep; i += xstep) {
260 if (i >= xres) {
261 xstep += xres-1-i;
262 i = xres-1;
263 }
264 z = pixvalue(scanline[i], i, y);
265 if (zline) zline[i] = z;
266
267 b = fillsample(scanline+i-xstep, zline ? zline+i-xstep : NULL,
268 i-xstep, y, xstep, 0, b/2);
269 }
270 }
271
272
273 fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
274 register COLOR *scanbar[];
275 register float *zbar[];
276 int xres, y, ysize;
277 {
278 COLOR vline[MAXDIV+1];
279 float zline[MAXDIV+1];
280 int b = ysize;
281 register int i, j;
282
283 for (i = 0; i < xres; i++) {
284
285 copycolor(vline[0], scanbar[0][i]);
286 copycolor(vline[ysize], scanbar[ysize][i]);
287 if (zbar[0]) {
288 zline[0] = zbar[0][i];
289 zline[ysize] = zbar[ysize][i];
290 }
291
292 b = fillsample(vline, zbar[0] ? zline : NULL,
293 i, y, 0, ysize, b/2);
294
295 for (j = 1; j < ysize; j++)
296 copycolor(scanbar[j][i], vline[j]);
297 if (zbar[0])
298 for (j = 1; j < ysize; j++)
299 zbar[j][i] = zline[j];
300 }
301 }
302
303
304 int
305 fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
306 register COLOR *colline;
307 register float *zline;
308 int x, y;
309 int xlen, ylen;
310 int b;
311 {
312 extern double fabs();
313 double ratio;
314 double z;
315 COLOR ctmp;
316 int ncut;
317 register int len;
318
319 if (xlen > 0) /* x or y length is zero */
320 len = xlen;
321 else
322 len = ylen;
323
324 if (len <= 1) /* limit recursion */
325 return(0);
326
327 if (b > 0
328 || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
329 || bigdiff(colline[0], colline[len], maxdiff)) {
330
331 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
332 if (zline) zline[len>>1] = z;
333 ncut = 1;
334
335 } else { /* interpolate */
336
337 copycolor(colline[len>>1], colline[len]);
338 ratio = (double)(len>>1) / len;
339 scalecolor(colline[len>>1], ratio);
340 if (zline) zline[len>>1] = zline[len] * ratio;
341 ratio = 1.0 - ratio;
342 copycolor(ctmp, colline[0]);
343 scalecolor(ctmp, ratio);
344 addcolor(colline[len>>1], ctmp);
345 if (zline) zline[len>>1] += zline[0] * ratio;
346 ncut = 0;
347 }
348 /* recurse */
349 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
350
351 ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL,
352 x+(xlen>>1), y+(ylen>>1),
353 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
354
355 return(ncut);
356 }
357
358
359 double
360 pixvalue(col, x, y) /* compute pixel value */
361 COLOR col; /* returned color */
362 int x, y; /* pixel position */
363 {
364 static RAY thisray;
365
366 if (viewray(thisray.rorg, thisray.rdir, &ourview,
367 (x+pixjitter())/hresolu, (y+pixjitter())/vresolu) < 0) {
368 setcolor(col, 0.0, 0.0, 0.0);
369 return(0.0);
370 }
371
372 rayorigin(&thisray, NULL, PRIMARY, 1.0);
373
374 samplendx = pixnumber(x,y,hresolu,vresolu); /* set pixel index */
375
376 rayvalue(&thisray); /* trace ray */
377
378 copycolor(col, thisray.rcol); /* return color */
379
380 return(thisray.rt); /* return distance */
381 }
382
383
384 int
385 salvage(oldfile) /* salvage scanlines from killed program */
386 char *oldfile;
387 {
388 COLR *scanline;
389 FILE *fp;
390 int x, y;
391
392 if (oldfile == NULL)
393 return(0);
394
395 if ((fp = fopen(oldfile, "r")) == NULL) {
396 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
397 error(WARNING, errmsg);
398 return(0);
399 }
400 /* discard header */
401 getheader(fp, NULL);
402 /* get picture size */
403 if (!fscnresolu(&x, &y, fp)) {
404 sprintf(errmsg, "bad recover file \"%s\"", oldfile);
405 error(WARNING, errmsg);
406 fclose(fp);
407 return(0);
408 }
409
410 if (x != hresolu || y != vresolu) {
411 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
412 oldfile);
413 error(USER, errmsg);
414 }
415
416 scanline = (COLR *)malloc(hresolu*sizeof(COLR));
417 if (scanline == NULL)
418 error(SYSTEM, "out of memory in salvage");
419 for (y = 0; y < vresolu; y++) {
420 if (freadcolrs(scanline, hresolu, fp) < 0)
421 break;
422 if (fwritecolrs(scanline, hresolu, stdout) < 0)
423 goto writerr;
424 }
425 if (fflush(stdout) == EOF)
426 goto writerr;
427 free((char *)scanline);
428 fclose(fp);
429 unlink(oldfile);
430 return(y);
431 writerr:
432 error(SYSTEM, "write error in salvage");
433 }
434
435
436 int
437 pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
438 register int x, y;
439 int xres, yres;
440 {
441 x -= y;
442 while (x < 0)
443 x += xres;
444 return((((x>>2)*yres + y) << 2) + (x & 3));
445 }
