root/radiance/ray/src/rt/rpict.c
Revision: 2.98
Committed: Tue Jan 24 21:54:49 2023 UTC (2 years, 6 months ago) by greg
Changes since 2.97: +2 -2 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.98 static const char RCSid[] = "$Id: rpict.c,v 2.97 2021/12/03 18:10:48 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * rpict.c - routines and variables for picture generation.
6     */
7
8 greg 2.53 #include "copyright.h"
9 greg 2.52
10 greg 2.32 #include <sys/types.h>
11
12 schorsch 2.80 #include "platform.h"
13     #ifdef NON_POSIX
14     #ifdef MINGW
15     #include <sys/time.h>
16     #endif
17 schorsch 2.79 #else
18 schorsch 2.80 #ifdef BSD
19     #include <sys/time.h>
20     #include <sys/resource.h>
21     #else
22     #include <sys/times.h>
23     #include <unistd.h>
24     #endif
25 greg 2.30 #endif
26 greg 1.34
27 schorsch 2.55 #include <time.h>
28 greg 1.14 #include <signal.h>
29 greg 1.1
30 schorsch 2.69 #include "ray.h"
31     #include "paths.h"
32     #include "ambient.h"
33 greg 1.1 #include "view.h"
34     #include "random.h"
35 schorsch 2.55 #include "paths.h"
36 greg 2.87 #include "hilbert.h"
37 greg 2.89 #include "pmapbias.h"
38     #include "pmapdiag.h"
39 greg 2.12
40 greg 2.21 #define RFTEMPLATE "rfXXXXXX"
41
42 greg 2.22 #ifndef SIGCONT
43 schorsch 2.56 #ifdef SIGIO /* XXX can we live without this? */
44 greg 2.22 #define SIGCONT SIGIO
45     #endif
46 schorsch 2.56 #endif
47 greg 2.22
48 greg 2.52 CUBE thescene; /* our scene */
49     OBJECT nsceneobjs; /* number of objects in our scene */
50
51 greg 1.25 int dimlist[MAXDIM]; /* sampling dimensions */
52     int ndims = 0; /* number of sampling dimensions */
53     int samplendx; /* sample index number */
54
55 greg 2.52 void (*addobjnotify[])() = {ambnotify, NULL};
56
57 greg 1.12 VIEW ourview = STDVIEW; /* view parameters */
58     int hresolu = 512; /* horizontal resolution */
59     int vresolu = 512; /* vertical resolution */
60 greg 2.14 double pixaspect = 1.0; /* pixel aspect ratio */
61 greg 1.1
62     int psample = 4; /* pixel sample size */
63 greg 2.14 double maxdiff = .05; /* max. difference for interpolation */
64     double dstrpix = 0.67; /* square pixel distribution */
65 greg 1.1
66 gwlarson 2.49 double mblur = 0.; /* motion blur parameter */
67
68 greg 2.73 double dblur = 0.; /* depth-of-field blur parameter */
69
70 greg 2.52 void (*trace)() = NULL; /* trace call */
71
72     int do_irrad = 0; /* compute irradiance? */
73
74 greg 2.76 int rand_samp = 0; /* pure Monte Carlo sampling? */
75
76 greg 2.14 double dstrsrc = 0.0; /* square source distribution */
77     double shadthresh = .05; /* shadow threshold */
78     double shadcert = .5; /* shadow certainty */
79 greg 1.35 int directrelay = 1; /* number of source relays */
80 greg 1.29 int vspretest = 512; /* virtual source pretest density */
81 greg 2.20 int directvis = 1; /* sources visible? */
82 greg 2.14 double srcsizerat = .25; /* maximum ratio source size/dist. */
83 greg 2.41
84     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
85 greg 2.46 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
86 greg 2.41 double seccg = 0.; /* global scattering eccentricity */
87     double ssampdist = 0.; /* scatter sampling distance */
88 greg 1.1
89 greg 2.14 double specthresh = .15; /* specular sampling threshold */
90     double specjitter = 1.; /* specular sampling jitter */
91 greg 2.5
92 greg 2.40 int backvis = 1; /* back face visibility */
93
94 greg 2.63 int maxdepth = 7; /* maximum recursion depth */
95 greg 2.98 double minweight = 1e-4; /* minimum ray weight */
96 greg 1.1
97 greg 2.52 char *ambfile = NULL; /* ambient file name */
98 greg 1.1 COLOR ambval = BLKCOLOR; /* ambient value */
99 greg 2.44 int ambvwt = 0; /* initial weight for ambient value */
100 greg 2.68 double ambacc = 0.2; /* ambient accuracy */
101 greg 2.63 int ambres = 64; /* ambient resolution */
102     int ambdiv = 512; /* ambient divisions */
103     int ambssamp = 128; /* ambient super-samples */
104 greg 1.1 int ambounce = 0; /* ambient bounces */
105 greg 2.72 char *amblist[AMBLLEN]; /* ambient include/exclude list */
106 greg 1.1 int ambincl = -1; /* include == 1, exclude == 0 */
107
108     int ralrm = 0; /* seconds between reports */
109
110 greg 2.14 double pctdone = 0.0; /* percentage done */
111 greg 2.32 time_t tlastrept = 0L; /* time at last report */
112 greg 2.52 time_t tstart; /* starting time */
113 greg 1.1
114 greg 2.14 #define MAXDIV 16 /* maximum sample size */
115 greg 1.1
116 greg 2.14 #define pixjitter() (.5+dstrpix*(.5-frandom()))
117 greg 1.1
118 greg 2.47 int hres, vres; /* resolution for this frame */
119 greg 2.8
120 gwlarson 2.49 static VIEW lastview; /* the previous view input */
121
122 schorsch 2.69 static void report(int);
123     static int nextview(FILE *fp);
124     static void render(char *zfile, char *oldfile);
125     static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres,
126     int y, int xstep);
127     static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres,
128     int y, int ysize);
129     static int fillsample(COLOR *colline, float *zline, int x, int y,
130     int xlen, int ylen, int b);
131     static double pixvalue(COLOR col, int x, int y);
132     static int salvage(char *oldfile);
133     static int pixnumber(int x, int y, int xres, int yres);
134 greg 2.8
135 greg 2.52
136 greg 1.1
137 greg 2.52 void
138 greg 2.94 quit(int code) /* quit program */
139 greg 1.1 {
140 greg 2.8 if (code) /* report status */
141 schorsch 2.69 report(0);
142 schorsch 2.57 #ifndef NON_POSIX
143 greg 2.21 headclean(); /* delete header file */
144     pfclean(); /* clean up persist files */
145 greg 2.52 #endif
146 greg 1.1 exit(code);
147     }
148
149
150 schorsch 2.57 #ifndef NON_POSIX
151 schorsch 2.69 static void
152     report(int dummy) /* report progress */
153 greg 1.1 {
154 greg 2.89 char bcStat [128];
155 greg 2.88 double u, s;
156 greg 2.30 #ifdef BSD
157 greg 2.88 struct rusage rubuf;
158 greg 2.30 #else
159 greg 2.88 double period = 1.0 / 60.0;
160     struct tms tbuf;
161 greg 2.30 #endif
162 greg 1.1
163 greg 2.32 tlastrept = time((time_t *)NULL);
164 greg 2.30 #ifdef BSD
165 greg 1.1 getrusage(RUSAGE_SELF, &rubuf);
166 greg 2.88 u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
167     s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
168 greg 1.1 getrusage(RUSAGE_CHILDREN, &rubuf);
169 greg 2.88 u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
170     s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
171 greg 2.30 #else
172     times(&tbuf);
173 greg 2.36 #ifdef _SC_CLK_TCK
174 greg 2.33 period = 1.0 / sysconf(_SC_CLK_TCK);
175 greg 2.36 #endif
176 greg 2.33 u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period;
177     s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period;
178 greg 2.30 #endif
179 greg 1.1
180 greg 2.89 /* PMAP: Get photon map bias compensation statistics */
181     pmapBiasCompReport(bcStat);
182
183 greg 2.30 sprintf(errmsg,
184 rschregle 2.90 "%lu rays, %s%4.2f%% after %.3fu %.3fs %.3fr hours on %s (PID %d)\n",
185 greg 2.89 nrays, bcStat, pctdone, u*(1./3600.), s*(1./3600.),
186 greg 2.88 (tlastrept-tstart)*(1./3600.), myhostname(), getpid());
187 greg 1.24 eputs(errmsg);
188 schorsch 2.56 #ifdef SIGCONT
189 greg 2.35 signal(SIGCONT, report);
190     #endif
191 greg 1.24 }
192 greg 1.1 #else
193 schorsch 2.69 static void
194 schorsch 2.71 report(int dummy) /* report progress */
195 greg 1.24 {
196 greg 2.89 char bcStat [128];
197
198 greg 2.32 tlastrept = time((time_t *)NULL);
199 greg 2.89
200     /* PMAP: Get photon map bias compensation statistics */
201     pmapBiasCompReport(bcStat);
202
203 rschregle 2.90 sprintf(errmsg, "%lu rays, %s%4.2f%% after %5.4f hours\n",
204 greg 2.89 nrays, bcStat, pctdone, (tlastrept-tstart)/3600.0);
205 greg 1.1 eputs(errmsg);
206     }
207 greg 1.24 #endif
208 greg 1.1
209
210 greg 2.88 void
211 schorsch 2.69 rpict( /* generate image(s) */
212     int seq,
213     char *pout,
214     char *zout,
215     char *prvr
216     )
217 greg 2.8 /*
218     * If seq is greater than zero, then we will render a sequence of
219     * images based on view parameter strings read from the standard input.
220     * If pout is NULL, then all images will be sent to the standard ouput.
221     * If seq is greater than zero and prvr is an integer, then it is the
222     * frame number at which rendering should begin. Preceeding view parameter
223     * strings will be skipped in the input.
224     * If pout and prvr are the same, prvr is renamed to avoid overwriting.
225     * Note that pout and zout should contain %d format specifications for
226     * sequenced file naming.
227     */
228     {
229 greg 2.9 char fbuf[128], fbuf2[128];
230 greg 2.26 int npicts;
231 greg 2.85 char *cp;
232 greg 2.14 RESOLU rs;
233     double pa;
234 greg 2.8 /* check sampling */
235     if (psample < 1)
236     psample = 1;
237     else if (psample > MAXDIV) {
238     sprintf(errmsg, "pixel sampling reduced from %d to %d",
239     psample, MAXDIV);
240     error(WARNING, errmsg);
241     psample = MAXDIV;
242     }
243     /* get starting frame */
244     if (seq <= 0)
245     seq = 0;
246     else if (prvr != NULL && isint(prvr)) {
247 greg 2.85 int rn; /* skip to specified view */
248 greg 2.8 if ((rn = atoi(prvr)) < seq)
249     error(USER, "recover frame less than start frame");
250     if (pout == NULL)
251     error(USER, "missing output file specification");
252     for ( ; seq < rn; seq++)
253     if (nextview(stdin) == EOF)
254     error(USER, "unexpected EOF on view input");
255 gwlarson 2.50 setview(&ourview);
256 greg 2.8 prvr = fbuf; /* mark for renaming */
257     }
258 schorsch 2.62 if ((pout != NULL) & (prvr != NULL)) {
259 greg 2.8 sprintf(fbuf, pout, seq);
260 greg 2.18 if (!strcmp(prvr, fbuf)) { /* rename */
261     strcpy(fbuf2, fbuf);
262     for (cp = fbuf2; *cp; cp++)
263     ;
264     while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
265     cp--;
266     strcpy(cp, RFTEMPLATE);
267 greg 2.8 prvr = mktemp(fbuf2);
268 schorsch 2.61 if (rename(fbuf, prvr) < 0) {
269 greg 2.28 if (errno == ENOENT) { /* ghost file */
270     sprintf(errmsg,
271     "new output file \"%s\"",
272     fbuf);
273     error(WARNING, errmsg);
274     prvr = NULL;
275     } else { /* serious error */
276     sprintf(errmsg,
277 greg 2.8 "cannot rename \"%s\" to \"%s\"",
278     fbuf, prvr);
279 greg 2.28 error(SYSTEM, errmsg);
280     }
281 schorsch 2.61 }
282 greg 2.8 }
283     }
284 greg 2.26 npicts = 0; /* render sequence */
285 greg 2.8 do {
286     if (seq && nextview(stdin) == EOF)
287     break;
288 greg 2.25 pctdone = 0.0;
289 greg 2.8 if (pout != NULL) {
290 greg 2.93 int myfd;
291 greg 2.92 close(1); /* reassign stdout */
292 greg 2.8 sprintf(fbuf, pout, seq);
293 greg 2.93 tryagain:
294 greg 2.92 errno = 0; /* exclusive open */
295 greg 2.93 if ((myfd = open(fbuf, O_WRONLY|O_CREAT|O_EXCL, 0666)) < 0) {
296 greg 2.92 if ((errno != EEXIST) | (prvr != NULL) ||
297     !strcmp(fbuf, pout)) {
298 greg 2.27 sprintf(errmsg,
299 greg 2.92 "cannot open output file \"%s\"",
300 greg 2.27 fbuf);
301 greg 2.92 error(SYSTEM, errmsg);
302 greg 2.27 }
303 gwlarson 2.50 setview(&ourview);
304 greg 2.26 continue; /* don't clobber */
305 greg 2.27 }
306 greg 2.93 if (myfd != 1) {
307     unlink(fbuf);
308     goto tryagain; /* leave it open */
309     }
310 greg 2.92 SET_FD_BINARY(1);
311 greg 2.8 dupheader();
312     }
313     hres = hresolu; vres = vresolu; pa = pixaspect;
314 schorsch 2.61 if (prvr != NULL) {
315 greg 2.66 if (viewfile(prvr, &ourview, &rs) <= 0) {
316 greg 2.8 sprintf(errmsg,
317     "cannot recover view parameters from \"%s\"", prvr);
318     error(WARNING, errmsg);
319     } else {
320     pa = 0.0;
321     hres = scanlen(&rs);
322     vres = numscans(&rs);
323     }
324 schorsch 2.61 }
325 greg 2.9 if ((cp = setview(&ourview)) != NULL)
326     error(USER, cp);
327 greg 2.8 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
328     if (seq) {
329     if (ralrm > 0) {
330 greg 2.11 fprintf(stderr, "FRAME %d:", seq);
331     fprintview(&ourview, stderr);
332     putc('\n', stderr);
333     fflush(stderr);
334 greg 2.8 }
335     printf("FRAME=%d\n", seq);
336     }
337     fputs(VIEWSTR, stdout);
338     fprintview(&ourview, stdout);
339     putchar('\n');
340 greg 2.85 if ((pa < .99) | (pa > 1.01))
341 greg 2.8 fputaspect(pa, stdout);
342 schorsch 2.60 fputnow(stdout);
343 greg 2.95 fputprims(stdprims, stdout);
344 greg 2.8 fputformat(COLRFMT, stdout);
345     putchar('\n');
346     if (zout != NULL)
347 greg 2.9 sprintf(cp=fbuf, zout, seq);
348 greg 2.8 else
349 greg 2.9 cp = NULL;
350     render(cp, prvr);
351 greg 2.8 prvr = NULL;
352 greg 2.26 npicts++;
353 greg 2.8 } while (seq++);
354 greg 2.26 /* check that we did something */
355     if (npicts == 0)
356     error(WARNING, "no output produced");
357 greg 2.8 }
358
359
360 schorsch 2.69 static int
361     nextview( /* get next view from fp */
362     FILE *fp
363     )
364 greg 2.8 {
365 greg 2.9 char linebuf[256];
366 greg 2.8
367 schorsch 2.61 lastview = ourview;
368 greg 2.8 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
369 greg 2.9 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
370 greg 2.8 return(0);
371     return(EOF);
372     }
373
374
375 schorsch 2.69 static void
376     render( /* render the scene */
377     char *zfile,
378     char *oldfile
379     )
380 greg 1.1 {
381     COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
382 greg 1.11 float *zbar[MAXDIV+1]; /* z values */
383 greg 2.2 char *sampdens; /* previous sample density */
384 greg 1.1 int ypos; /* current scanline */
385 greg 1.15 int ystep; /* current y step size */
386 greg 1.33 int hstep; /* h step size */
387 greg 1.16 int zfd;
388 greg 1.1 COLOR *colptr;
389 greg 1.11 float *zptr;
390 greg 2.85 int i;
391 greg 2.52 /* check for empty image */
392 greg 2.85 if ((hres <= 0) | (vres <= 0)) {
393 greg 2.52 error(WARNING, "empty output picture");
394     fprtresolu(0, 0, stdout);
395     return;
396     }
397 greg 1.9 /* allocate scanlines */
398 greg 1.1 for (i = 0; i <= psample; i++) {
399 greg 2.8 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
400 greg 1.1 if (scanbar[i] == NULL)
401 greg 1.11 goto memerr;
402 greg 1.1 }
403 greg 2.2 hstep = (psample*140+49)/99; /* quincunx sampling */
404     ystep = (psample*99+70)/140;
405     if (hstep > 2) {
406 greg 2.8 i = hres/hstep + 2;
407 greg 2.52 if ((sampdens = (char *)malloc(i)) == NULL)
408 greg 2.2 goto memerr;
409     while (i--)
410     sampdens[i] = hstep;
411     } else
412     sampdens = NULL;
413 greg 2.26 /* open z-file */
414 greg 1.11 if (zfile != NULL) {
415 greg 1.16 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
416 greg 2.26 sprintf(errmsg, "cannot open z-file \"%s\"", zfile);
417 greg 1.11 error(SYSTEM, errmsg);
418     }
419 schorsch 2.55 SET_FD_BINARY(zfd);
420 greg 1.11 for (i = 0; i <= psample; i++) {
421 greg 2.8 zbar[i] = (float *)malloc(hres*sizeof(float));
422 greg 1.11 if (zbar[i] == NULL)
423     goto memerr;
424     }
425     } else {
426 greg 1.16 zfd = -1;
427 greg 1.11 for (i = 0; i <= psample; i++)
428     zbar[i] = NULL;
429     }
430 greg 1.1 /* write out boundaries */
431 greg 2.8 fprtresolu(hres, vres, stdout);
432 greg 1.10 /* recover file and compute first */
433 greg 1.11 i = salvage(oldfile);
434 greg 2.42 if (i >= vres)
435     goto alldone;
436 greg 2.85 if ((zfd != -1) & (i > 0) &&
437 greg 2.64 lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0)
438 greg 2.26 error(SYSTEM, "z-file seek error in render");
439 greg 2.8 pctdone = 100.0*i/vres;
440 greg 1.24 if (ralrm > 0) /* report init stats */
441 schorsch 2.69 report(0);
442 schorsch 2.56 #ifdef SIGCONT
443 greg 1.32 else
444 schorsch 2.56 signal(SIGCONT, report);
445 greg 1.32 #endif
446 greg 2.47 ypos = vres-1 - i; /* initialize sampling */
447 gregl 2.48 if (directvis)
448     init_drawsources(psample);
449 greg 2.8 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
450 greg 1.10 /* compute scanlines */
451 greg 1.15 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
452     /* bottom adjust? */
453     if (ypos < 0) {
454     ystep += ypos;
455     ypos = 0;
456     }
457     colptr = scanbar[ystep]; /* move base to top */
458     scanbar[ystep] = scanbar[0];
459 greg 1.1 scanbar[0] = colptr;
460 greg 1.15 zptr = zbar[ystep];
461     zbar[ystep] = zbar[0];
462 greg 1.11 zbar[0] = zptr;
463 greg 1.10 /* fill base line */
464 greg 2.2 fillscanline(scanbar[0], zbar[0], sampdens,
465 greg 2.8 hres, ypos, hstep);
466 greg 1.10 /* fill bar */
467 greg 2.8 fillscanbar(scanbar, zbar, hres, ypos, ystep);
468 gregl 2.48 if (directvis) /* add bitty sources */
469     drawsources(scanbar, zbar, 0, hres, ypos, ystep);
470 greg 1.10 /* write it out */
471 schorsch 2.56 #ifdef SIGCONT
472 greg 2.22 signal(SIGCONT, SIG_IGN); /* don't interrupt writes */
473 greg 1.32 #endif
474 greg 1.15 for (i = ystep; i > 0; i--) {
475 greg 1.17 if (zfd != -1 && write(zfd, (char *)zbar[i],
476 greg 2.8 hres*sizeof(float))
477     < hres*sizeof(float))
478 greg 1.1 goto writerr;
479 greg 2.8 if (fwritescan(scanbar[i], hres, stdout) < 0)
480 greg 1.11 goto writerr;
481     }
482 greg 1.1 if (fflush(stdout) == EOF)
483     goto writerr;
484 greg 1.24 /* record progress */
485 greg 2.8 pctdone = 100.0*(vres-1-ypos)/vres;
486 greg 2.32 if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm)
487 schorsch 2.69 report(0);
488 schorsch 2.56 #ifdef SIGCONT
489 greg 1.32 else
490 greg 2.22 signal(SIGCONT, report);
491 greg 1.32 #endif
492 greg 1.1 }
493 greg 1.11 /* clean up */
494 schorsch 2.56 #ifdef SIGCONT
495 greg 2.22 signal(SIGCONT, SIG_IGN);
496 schorsch 2.56 #endif
497 greg 2.42 if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float))
498     < hres*sizeof(float))
499     goto writerr;
500     fwritescan(scanbar[0], hres, stdout);
501     if (fflush(stdout) == EOF)
502     goto writerr;
503     alldone:
504 greg 1.16 if (zfd != -1) {
505 greg 1.20 if (close(zfd) == -1)
506     goto writerr;
507 greg 1.11 for (i = 0; i <= psample; i++)
508 greg 2.52 free((void *)zbar[i]);
509 greg 1.11 }
510 greg 1.1 for (i = 0; i <= psample; i++)
511 greg 2.52 free((void *)scanbar[i]);
512 greg 2.2 if (sampdens != NULL)
513     free(sampdens);
514 greg 1.11 pctdone = 100.0;
515 greg 2.13 if (ralrm > 0)
516 schorsch 2.69 report(0);
517 schorsch 2.56 #ifdef SIGCONT
518 greg 2.23 signal(SIGCONT, SIG_DFL);
519 schorsch 2.56 #endif
520 greg 1.1 return;
521     writerr:
522     error(SYSTEM, "write error in render");
523 greg 1.11 memerr:
524     error(SYSTEM, "out of memory in render");
525 greg 1.1 }
526
527
528 schorsch 2.69 static void
529     fillscanline( /* fill scan at y */
530 greg 2.85 COLOR *scanline,
531     float *zline,
532     char *sd,
533 schorsch 2.69 int xres,
534     int y,
535     int xstep
536     )
537 greg 1.1 {
538 greg 1.33 static int nc = 0; /* number of calls */
539 greg 2.2 int bl = xstep, b = xstep;
540 greg 2.14 double z;
541 greg 2.85 int i;
542 greg 2.45
543 greg 1.11 z = pixvalue(scanline[0], 0, y);
544     if (zline) zline[0] = z;
545 greg 1.33 /* zig-zag start for quincunx pattern */
546 greg 2.2 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
547 greg 1.15 if (i >= xres) {
548     xstep += xres-1-i;
549     i = xres-1;
550     }
551 greg 1.11 z = pixvalue(scanline[i], i, y);
552     if (zline) zline[i] = z;
553 greg 2.2 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
554 greg 2.3 if (i <= xstep)
555     b = fillsample(scanline, zline, 0, y, i, 0, b/2);
556     else
557     b = fillsample(scanline+i-xstep,
558 greg 2.38 zline ? zline+i-xstep : (float *)NULL,
559 greg 2.3 i-xstep, y, xstep, 0, b/2);
560 greg 2.2 if (sd) *sd++ = nc & 1 ? bl : b;
561     bl = b;
562 greg 1.1 }
563 greg 2.2 if (sd && nc & 1) *sd = bl;
564 greg 1.1 }
565
566
567 schorsch 2.69 static void
568     fillscanbar( /* fill interior */
569 greg 2.85 COLOR *scanbar[],
570     float *zbar[],
571 schorsch 2.69 int xres,
572     int y,
573     int ysize
574     )
575 greg 1.1 {
576     COLOR vline[MAXDIV+1];
577 greg 1.11 float zline[MAXDIV+1];
578 greg 1.1 int b = ysize;
579 greg 2.85 int i, j;
580 greg 2.45
581 greg 1.8 for (i = 0; i < xres; i++) {
582 greg 1.1 copycolor(vline[0], scanbar[0][i]);
583     copycolor(vline[ysize], scanbar[ysize][i]);
584 greg 1.11 if (zbar[0]) {
585     zline[0] = zbar[0][i];
586     zline[ysize] = zbar[ysize][i];
587     }
588 greg 2.38 b = fillsample(vline, zbar[0] ? zline : (float *)NULL,
589 greg 1.11 i, y, 0, ysize, b/2);
590 greg 2.45
591 greg 1.1 for (j = 1; j < ysize; j++)
592     copycolor(scanbar[j][i], vline[j]);
593 greg 1.11 if (zbar[0])
594     for (j = 1; j < ysize; j++)
595     zbar[j][i] = zline[j];
596 greg 1.1 }
597     }
598
599
600 schorsch 2.69 static int
601     fillsample( /* fill interior points */
602 greg 2.85 COLOR *colline,
603     float *zline,
604 schorsch 2.69 int x,
605     int y,
606     int xlen,
607     int ylen,
608     int b
609     )
610 greg 1.1 {
611 greg 2.14 double ratio;
612     double z;
613 greg 1.1 COLOR ctmp;
614     int ncut;
615 greg 2.85 int len;
616 greg 2.45
617 greg 1.1 if (xlen > 0) /* x or y length is zero */
618     len = xlen;
619     else
620     len = ylen;
621 greg 2.45
622 greg 1.1 if (len <= 1) /* limit recursion */
623     return(0);
624 greg 2.45
625     if (b > 0 ||
626     (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
627 greg 1.11 || bigdiff(colline[0], colline[len], maxdiff)) {
628 greg 2.45
629 greg 1.11 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
630     if (zline) zline[len>>1] = z;
631 greg 1.1 ncut = 1;
632     } else { /* interpolate */
633     copycolor(colline[len>>1], colline[len]);
634     ratio = (double)(len>>1) / len;
635     scalecolor(colline[len>>1], ratio);
636 greg 1.11 if (zline) zline[len>>1] = zline[len] * ratio;
637     ratio = 1.0 - ratio;
638 greg 1.1 copycolor(ctmp, colline[0]);
639     scalecolor(ctmp, ratio);
640     addcolor(colline[len>>1], ctmp);
641 greg 1.11 if (zline) zline[len>>1] += zline[0] * ratio;
642 greg 1.1 ncut = 0;
643     }
644     /* recurse */
645 greg 1.11 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
646 greg 2.45
647 greg 2.38 ncut += fillsample(colline+(len>>1),
648     zline ? zline+(len>>1) : (float *)NULL,
649 greg 1.11 x+(xlen>>1), y+(ylen>>1),
650     xlen-(xlen>>1), ylen-(ylen>>1), b/2);
651 greg 1.1
652     return(ncut);
653     }
654
655
656 schorsch 2.69 static double
657     pixvalue( /* compute pixel value */
658     COLOR col, /* returned color */
659     int x, /* pixel position */
660     int y
661     )
662 greg 1.1 {
663 gwlarson 2.49 RAY thisray;
664     FVECT lorg, ldir;
665 greg 2.97 double hpos, vpos, lmax;
666 greg 2.85 int i;
667 gwlarson 2.49 /* compute view ray */
668 greg 2.85 setcolor(col, 0.0, 0.0, 0.0);
669 gwlarson 2.49 hpos = (x+pixjitter())/hres;
670     vpos = (y+pixjitter())/vres;
671     if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
672 greg 2.85 &ourview, hpos, vpos)) < -FTINY)
673 greg 1.22 return(0.0);
674 greg 2.77 /* set pixel index */
675     samplendx = pixnumber(x,y,hres,vres);
676 gwlarson 2.49 /* optional motion blur */
677     if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir,
678     &lastview, hpos, vpos)) >= -FTINY) {
679 greg 2.85 double d = mblur*(.5-urand(281+samplendx));
680 gwlarson 2.49
681     thisray.rmax = (1.-d)*thisray.rmax + d*lmax;
682     for (i = 3; i--; ) {
683     thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i];
684     thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i];
685     }
686     if (normalize(thisray.rdir) == 0.0)
687     return(0.0);
688     }
689 greg 2.97 /* depth-of-field */
690     if (!jitteraperture(thisray.rorg, thisray.rdir, &ourview, dblur))
691     return(0.0);
692 gwlarson 2.49
693 greg 2.75 rayorigin(&thisray, PRIMARY, NULL, NULL);
694 greg 1.25
695 greg 1.1 rayvalue(&thisray); /* trace ray */
696
697     copycolor(col, thisray.rcol); /* return color */
698 greg 2.45
699 greg 2.91 return(raydistance(&thisray)); /* return distance */
700 greg 1.1 }
701
702
703 schorsch 2.69 static int
704     salvage( /* salvage scanlines from killed program */
705     char *oldfile
706     )
707 greg 1.1 {
708     COLR *scanline;
709     FILE *fp;
710     int x, y;
711
712     if (oldfile == NULL)
713 greg 2.37 goto gotzip;
714
715 greg 1.9 if ((fp = fopen(oldfile, "r")) == NULL) {
716 greg 1.1 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
717     error(WARNING, errmsg);
718 greg 2.37 goto gotzip;
719 greg 1.1 }
720 schorsch 2.55 SET_FILE_BINARY(fp);
721 greg 1.1 /* discard header */
722 greg 2.19 getheader(fp, NULL, NULL);
723 greg 1.1 /* get picture size */
724 greg 1.36 if (!fscnresolu(&x, &y, fp)) {
725 greg 2.29 sprintf(errmsg, "bad recover file \"%s\" - not removed",
726     oldfile);
727 greg 1.2 error(WARNING, errmsg);
728 greg 1.1 fclose(fp);
729 greg 2.37 goto gotzip;
730 greg 1.1 }
731
732 greg 2.85 if ((x != hres) | (y != vres)) {
733 greg 1.1 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
734     oldfile);
735     error(USER, errmsg);
736     }
737
738 greg 2.8 scanline = (COLR *)malloc(hres*sizeof(COLR));
739 greg 1.1 if (scanline == NULL)
740     error(SYSTEM, "out of memory in salvage");
741 greg 2.8 for (y = 0; y < vres; y++) {
742     if (freadcolrs(scanline, hres, fp) < 0)
743 greg 1.1 break;
744 greg 2.8 if (fwritecolrs(scanline, hres, stdout) < 0)
745 greg 1.1 goto writerr;
746     }
747     if (fflush(stdout) == EOF)
748     goto writerr;
749 greg 2.52 free((void *)scanline);
750 greg 1.1 fclose(fp);
751     unlink(oldfile);
752     return(y);
753 greg 2.37 gotzip:
754     if (fflush(stdout) == EOF)
755     error(SYSTEM, "error writing picture header");
756     return(0);
757 greg 1.1 writerr:
758 greg 2.9 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
759     error(SYSTEM, errmsg);
760 schorsch 2.69 return -1; /* pro forma return */
761 greg 1.31 }
762
763 schorsch 2.69 static int
764 greg 2.87 pixnumber( /* compute pixel index (screen door) */
765 greg 2.85 int x,
766     int y,
767 schorsch 2.69 int xres,
768     int yres
769     )
770 greg 1.31 {
771 greg 2.87 unsigned nbits = 0;
772     bitmask_t coord[2];
773
774     if (xres < yres) xres = yres;
775     while (xres > 0) {
776     xres >>= 1;
777     ++nbits;
778     }
779     coord[0] = x; coord[1] = y;
780     return ((int)hilbert_c2i(2, nbits, coord));
781 greg 1.1 }
