| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rpict.c,v 2.89 2015/02/24 19:39:27 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rpict.c - routines and variables for picture generation.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <sys/types.h>
| 11 |
| 12 |
#include "platform.h"
| 13 |
#ifdef NON_POSIX
| 14 |
#ifdef MINGW
| 15 |
#include <sys/time.h>
| 16 |
#endif
| 17 |
#else
| 18 |
#ifdef BSD
| 19 |
| 20 |
#include <sys/resource.h>
| 21 |
#else
| 22 |
#include <sys/times.h>
| 23 |
#include <unistd.h>
| 24 |
#endif
| 25 |
#endif
| 26 |
| 27 |
#include <time.h>
| 28 |
#include <signal.h>
| 29 |
| 30 |
#include "ray.h"
| 31 |
#include "paths.h"
| 32 |
#include "ambient.h"
| 33 |
#include "view.h"
| 34 |
#include "random.h"
| 35 |
#include "paths.h"
| 36 |
#include "hilbert.h"
| 37 |
#include "pmapbias.h"
| 38 |
#include "pmapdiag.h"
| 39 |
| 40 |
#define RFTEMPLATE "rfXXXXXX"
| 41 |
| 42 |
#ifndef SIGCONT
| 43 |
#ifdef SIGIO /* XXX can we live without this? */
| 44 |
#define SIGCONT SIGIO
| 45 |
#endif
| 46 |
#endif
| 47 |
| 48 |
CUBE thescene; /* our scene */
| 49 |
OBJECT nsceneobjs; /* number of objects in our scene */
| 50 |
| 51 |
int dimlist[MAXDIM]; /* sampling dimensions */
| 52 |
int ndims = 0; /* number of sampling dimensions */
| 53 |
int samplendx; /* sample index number */
| 54 |
| 55 |
void (*addobjnotify[])() = {ambnotify, NULL};
| 56 |
| 57 |
VIEW ourview = STDVIEW; /* view parameters */
| 58 |
int hresolu = 512; /* horizontal resolution */
| 59 |
int vresolu = 512; /* vertical resolution */
| 60 |
double pixaspect = 1.0; /* pixel aspect ratio */
| 61 |
| 62 |
int psample = 4; /* pixel sample size */
| 63 |
double maxdiff = .05; /* max. difference for interpolation */
| 64 |
double dstrpix = 0.67; /* square pixel distribution */
| 65 |
| 66 |
double mblur = 0.; /* motion blur parameter */
| 67 |
| 68 |
double dblur = 0.; /* depth-of-field blur parameter */
| 69 |
| 70 |
void (*trace)() = NULL; /* trace call */
| 71 |
| 72 |
int do_irrad = 0; /* compute irradiance? */
| 73 |
| 74 |
int rand_samp = 0; /* pure Monte Carlo sampling? */
| 75 |
| 76 |
double dstrsrc = 0.0; /* square source distribution */
| 77 |
double shadthresh = .05; /* shadow threshold */
| 78 |
double shadcert = .5; /* shadow certainty */
| 79 |
int directrelay = 1; /* number of source relays */
| 80 |
int vspretest = 512; /* virtual source pretest density */
| 81 |
int directvis = 1; /* sources visible? */
| 82 |
double srcsizerat = .25; /* maximum ratio source size/dist. */
| 83 |
| 84 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
| 85 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */
| 86 |
double seccg = 0.; /* global scattering eccentricity */
| 87 |
double ssampdist = 0.; /* scatter sampling distance */
| 88 |
| 89 |
double specthresh = .15; /* specular sampling threshold */
| 90 |
double specjitter = 1.; /* specular sampling jitter */
| 91 |
| 92 |
int backvis = 1; /* back face visibility */
| 93 |
| 94 |
int maxdepth = 7; /* maximum recursion depth */
| 95 |
double minweight = 1e-3; /* minimum ray weight */
| 96 |
| 97 |
char *ambfile = NULL; /* ambient file name */
| 98 |
COLOR ambval = BLKCOLOR; /* ambient value */
| 99 |
int ambvwt = 0; /* initial weight for ambient value */
| 100 |
double ambacc = 0.2; /* ambient accuracy */
| 101 |
int ambres = 64; /* ambient resolution */
| 102 |
int ambdiv = 512; /* ambient divisions */
| 103 |
int ambssamp = 128; /* ambient super-samples */
| 104 |
int ambounce = 0; /* ambient bounces */
| 105 |
char *amblist[AMBLLEN]; /* ambient include/exclude list */
| 106 |
int ambincl = -1; /* include == 1, exclude == 0 */
| 107 |
| 108 |
int ralrm = 0; /* seconds between reports */
| 109 |
| 110 |
double pctdone = 0.0; /* percentage done */
| 111 |
time_t tlastrept = 0L; /* time at last report */
| 112 |
time_t tstart; /* starting time */
| 113 |
| 114 |
#define MAXDIV 16 /* maximum sample size */
| 115 |
| 116 |
#define pixjitter() (.5+dstrpix*(.5-frandom()))
| 117 |
| 118 |
int hres, vres; /* resolution for this frame */
| 119 |
| 120 |
static VIEW lastview; /* the previous view input */
| 121 |
| 122 |
static void report(int);
| 123 |
static int nextview(FILE *fp);
| 124 |
static void render(char *zfile, char *oldfile);
| 125 |
static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres,
| 126 |
int y, int xstep);
| 127 |
static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres,
| 128 |
int y, int ysize);
| 129 |
static int fillsample(COLOR *colline, float *zline, int x, int y,
| 130 |
int xlen, int ylen, int b);
| 131 |
static double pixvalue(COLOR col, int x, int y);
| 132 |
static int salvage(char *oldfile);
| 133 |
static int pixnumber(int x, int y, int xres, int yres);
| 134 |
| 135 |
| 136 |
| 137 |
#ifdef RHAS_STAT
| 138 |
| 139 |
#include <sys/stat.h>
| 140 |
int
| 141 |
file_exists(fname) /* ordinary file exists? */
| 142 |
char *fname;
| 143 |
| 144 |
struct stat sbuf;
| 145 |
if (stat(fname, &sbuf) < 0) return(0);
| 146 |
return((sbuf.st_mode & S_IFREG) != 0);
| 147 |
| 148 |
#else
| 149 |
#define file_exists(f) (access(f,F_OK)==0)
| 150 |
#endif
| 151 |
| 152 |
| 153 |
void
| 154 |
quit(code) /* quit program */
| 155 |
int code;
| 156 |
| 157 |
if (code) /* report status */
| 158 |
report(0);
| 159 |
#ifndef NON_POSIX
| 160 |
headclean(); /* delete header file */
| 161 |
pfclean(); /* clean up persist files */
| 162 |
#endif
| 163 |
exit(code);
| 164 |
| 165 |
| 166 |
| 167 |
#ifndef NON_POSIX
| 168 |
static void
| 169 |
report(int dummy) /* report progress */
| 170 |
| 171 |
char bcStat [128];
| 172 |
double u, s;
| 173 |
#ifdef BSD
| 174 |
struct rusage rubuf;
| 175 |
#else
| 176 |
double period = 1.0 / 60.0;
| 177 |
struct tms tbuf;
| 178 |
#endif
| 179 |
| 180 |
tlastrept = time((time_t *)NULL);
| 181 |
#ifdef BSD
| 182 |
getrusage(RUSAGE_SELF, &rubuf);
| 183 |
u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
| 184 |
s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
| 185 |
getrusage(RUSAGE_CHILDREN, &rubuf);
| 186 |
u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec*1e-6;
| 187 |
s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec*1e-6;
| 188 |
#else
| 189 |
times(&tbuf);
| 190 |
#ifdef _SC_CLK_TCK
| 191 |
period = 1.0 / sysconf(_SC_CLK_TCK);
| 192 |
#endif
| 193 |
u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period;
| 194 |
s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period;
| 195 |
#endif
| 196 |
| 197 |
/* PMAP: Get photon map bias compensation statistics */
| 198 |
pmapBiasCompReport(bcStat);
| 199 |
| 200 |
sprintf(errmsg,
| 201 |
"%lu rays, %s%4.2f%% after %.3fu %.3fs %.3fr hours on %s (PID %d)\n",
| 202 |
nrays, bcStat, pctdone, u*(1./3600.), s*(1./3600.),
| 203 |
(tlastrept-tstart)*(1./3600.), myhostname(), getpid());
| 204 |
eputs(errmsg);
| 205 |
#ifdef SIGCONT
| 206 |
signal(SIGCONT, report);
| 207 |
#endif
| 208 |
| 209 |
#else
| 210 |
static void
| 211 |
| 212 |
| 213 |
char bcStat [128];
| 214 |
| 215 |
| 216 |
| 217 |
| 218 |
| 219 |
| 220 |
sprintf(errmsg, "%lu rays, %s%4.2f%% after %5.4f hours\n",
| 221 |
nrays, bcStat, pctdone, (tlastrept-tstart)/3600.0);
| 222 |
eputs(errmsg);
| 223 |
| 224 |
#endif
| 225 |
| 226 |
| 227 |
void
| 228 |
rpict( /* generate image(s) */
| 229 |
int seq,
| 230 |
char *pout,
| 231 |
char *zout,
| 232 |
char *prvr
| 233 |
| 234 |
| 235 |
* If seq is greater than zero, then we will render a sequence of
| 236 |
* images based on view parameter strings read from the standard input.
| 237 |
* If pout is NULL, then all images will be sent to the standard ouput.
| 238 |
* If seq is greater than zero and prvr is an integer, then it is the
| 239 |
* frame number at which rendering should begin. Preceeding view parameter
| 240 |
* strings will be skipped in the input.
| 241 |
* If pout and prvr are the same, prvr is renamed to avoid overwriting.
| 242 |
* Note that pout and zout should contain %d format specifications for
| 243 |
* sequenced file naming.
| 244 |
| 245 |
| 246 |
char fbuf[128], fbuf2[128];
| 247 |
int npicts;
| 248 |
char *cp;
| 249 |
RESOLU rs;
| 250 |
double pa;
| 251 |
/* check sampling */
| 252 |
if (psample < 1)
| 253 |
psample = 1;
| 254 |
else if (psample > MAXDIV) {
| 255 |
sprintf(errmsg, "pixel sampling reduced from %d to %d",
| 256 |
psample, MAXDIV);
| 257 |
error(WARNING, errmsg);
| 258 |
psample = MAXDIV;
| 259 |
| 260 |
/* get starting frame */
| 261 |
if (seq <= 0)
| 262 |
seq = 0;
| 263 |
else if (prvr != NULL && isint(prvr)) {
| 264 |
int rn; /* skip to specified view */
| 265 |
if ((rn = atoi(prvr)) < seq)
| 266 |
error(USER, "recover frame less than start frame");
| 267 |
if (pout == NULL)
| 268 |
error(USER, "missing output file specification");
| 269 |
for ( ; seq < rn; seq++)
| 270 |
if (nextview(stdin) == EOF)
| 271 |
error(USER, "unexpected EOF on view input");
| 272 |
setview(&ourview);
| 273 |
prvr = fbuf; /* mark for renaming */
| 274 |
| 275 |
if ((pout != NULL) & (prvr != NULL)) {
| 276 |
sprintf(fbuf, pout, seq);
| 277 |
if (!strcmp(prvr, fbuf)) { /* rename */
| 278 |
strcpy(fbuf2, fbuf);
| 279 |
for (cp = fbuf2; *cp; cp++)
| 280 |
| 281 |
while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
| 282 |
cp--;
| 283 |
strcpy(cp, RFTEMPLATE);
| 284 |
prvr = mktemp(fbuf2);
| 285 |
if (rename(fbuf, prvr) < 0) {
| 286 |
if (errno == ENOENT) { /* ghost file */
| 287 |
sprintf(errmsg,
| 288 |
"new output file \"%s\"",
| 289 |
fbuf);
| 290 |
| 291 |
prvr = NULL;
| 292 |
} else { /* serious error */
| 293 |
sprintf(errmsg,
| 294 |
"cannot rename \"%s\" to \"%s\"",
| 295 |
fbuf, prvr);
| 296 |
error(SYSTEM, errmsg);
| 297 |
| 298 |
| 299 |
| 300 |
| 301 |
npicts = 0; /* render sequence */
| 302 |
do {
| 303 |
if (seq && nextview(stdin) == EOF)
| 304 |
break;
| 305 |
pctdone = 0.0;
| 306 |
if (pout != NULL) {
| 307 |
| 308 |
if (file_exists(fbuf)) {
| 309 |
if (prvr != NULL || !strcmp(fbuf, pout)) {
| 310 |
sprintf(errmsg,
| 311 |
"output file \"%s\" exists",
| 312 |
fbuf);
| 313 |
error(USER, errmsg);
| 314 |
| 315 |
setview(&ourview);
| 316 |
continue; /* don't clobber */
| 317 |
| 318 |
if (freopen(fbuf, "w", stdout) == NULL) {
| 319 |
sprintf(errmsg,
| 320 |
"cannot open output file \"%s\"", fbuf);
| 321 |
| 322 |
| 323 |
SET_FILE_BINARY(stdout);
| 324 |
dupheader();
| 325 |
| 326 |
hres = hresolu; vres = vresolu; pa = pixaspect;
| 327 |
if (prvr != NULL) {
| 328 |
if (viewfile(prvr, &ourview, &rs) <= 0) {
| 329 |
sprintf(errmsg,
| 330 |
"cannot recover view parameters from \"%s\"", prvr);
| 331 |
| 332 |
} else {
| 333 |
pa = 0.0;
| 334 |
hres = scanlen(&rs);
| 335 |
vres = numscans(&rs);
| 336 |
| 337 |
| 338 |
if ((cp = setview(&ourview)) != NULL)
| 339 |
error(USER, cp);
| 340 |
normaspect(viewaspect(&ourview), &pa, &hres, &vres);
| 341 |
if (seq) {
| 342 |
if (ralrm > 0) {
| 343 |
fprintf(stderr, "FRAME %d:", seq);
| 344 |
fprintview(&ourview, stderr);
| 345 |
putc('\n', stderr);
| 346 |
fflush(stderr);
| 347 |
| 348 |
printf("FRAME=%d\n", seq);
| 349 |
| 350 |
fputs(VIEWSTR, stdout);
| 351 |
fprintview(&ourview, stdout);
| 352 |
putchar('\n');
| 353 |
if ((pa < .99) | (pa > 1.01))
| 354 |
fputaspect(pa, stdout);
| 355 |
fputnow(stdout);
| 356 |
fputformat(COLRFMT, stdout);
| 357 |
putchar('\n');
| 358 |
if (zout != NULL)
| 359 |
sprintf(cp=fbuf, zout, seq);
| 360 |
else
| 361 |
cp = NULL;
| 362 |
render(cp, prvr);
| 363 |
prvr = NULL;
| 364 |
npicts++;
| 365 |
} while (seq++);
| 366 |
/* check that we did something */
| 367 |
if (npicts == 0)
| 368 |
error(WARNING, "no output produced");
| 369 |
| 370 |
| 371 |
| 372 |
static int
| 373 |
nextview( /* get next view from fp */
| 374 |
FILE *fp
| 375 |
| 376 |
| 377 |
char linebuf[256];
| 378 |
| 379 |
lastview = ourview;
| 380 |
while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
| 381 |
if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
| 382 |
return(0);
| 383 |
return(EOF);
| 384 |
| 385 |
| 386 |
| 387 |
static void
| 388 |
render( /* render the scene */
| 389 |
char *zfile,
| 390 |
char *oldfile
| 391 |
| 392 |
| 393 |
COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
| 394 |
float *zbar[MAXDIV+1]; /* z values */
| 395 |
char *sampdens; /* previous sample density */
| 396 |
int ypos; /* current scanline */
| 397 |
int ystep; /* current y step size */
| 398 |
int hstep; /* h step size */
| 399 |
int zfd;
| 400 |
COLOR *colptr;
| 401 |
float *zptr;
| 402 |
int i;
| 403 |
/* check for empty image */
| 404 |
if ((hres <= 0) | (vres <= 0)) {
| 405 |
error(WARNING, "empty output picture");
| 406 |
fprtresolu(0, 0, stdout);
| 407 |
return;
| 408 |
| 409 |
/* allocate scanlines */
| 410 |
for (i = 0; i <= psample; i++) {
| 411 |
scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
| 412 |
if (scanbar[i] == NULL)
| 413 |
goto memerr;
| 414 |
| 415 |
hstep = (psample*140+49)/99; /* quincunx sampling */
| 416 |
ystep = (psample*99+70)/140;
| 417 |
if (hstep > 2) {
| 418 |
i = hres/hstep + 2;
| 419 |
if ((sampdens = (char *)malloc(i)) == NULL)
| 420 |
goto memerr;
| 421 |
while (i--)
| 422 |
sampdens[i] = hstep;
| 423 |
} else
| 424 |
sampdens = NULL;
| 425 |
/* open z-file */
| 426 |
if (zfile != NULL) {
| 427 |
if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
| 428 |
sprintf(errmsg, "cannot open z-file \"%s\"", zfile);
| 429 |
| 430 |
| 431 |
SET_FD_BINARY(zfd);
| 432 |
| 433 |
zbar[i] = (float *)malloc(hres*sizeof(float));
| 434 |
if (zbar[i] == NULL)
| 435 |
goto memerr;
| 436 |
| 437 |
} else {
| 438 |
zfd = -1;
| 439 |
| 440 |
zbar[i] = NULL;
| 441 |
| 442 |
/* write out boundaries */
| 443 |
fprtresolu(hres, vres, stdout);
| 444 |
/* recover file and compute first */
| 445 |
i = salvage(oldfile);
| 446 |
if (i >= vres)
| 447 |
goto alldone;
| 448 |
if ((zfd != -1) & (i > 0) &&
| 449 |
lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0)
| 450 |
error(SYSTEM, "z-file seek error in render");
| 451 |
pctdone = 100.0*i/vres;
| 452 |
if (ralrm > 0) /* report init stats */
| 453 |
report(0);
| 454 |
#ifdef SIGCONT
| 455 |
else
| 456 |
| 457 |
#endif
| 458 |
ypos = vres-1 - i; /* initialize sampling */
| 459 |
if (directvis)
| 460 |
init_drawsources(psample);
| 461 |
fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
| 462 |
/* compute scanlines */
| 463 |
for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
| 464 |
/* bottom adjust? */
| 465 |
if (ypos < 0) {
| 466 |
ystep += ypos;
| 467 |
ypos = 0;
| 468 |
| 469 |
colptr = scanbar[ystep]; /* move base to top */
| 470 |
scanbar[ystep] = scanbar[0];
| 471 |
scanbar[0] = colptr;
| 472 |
zptr = zbar[ystep];
| 473 |
zbar[ystep] = zbar[0];
| 474 |
zbar[0] = zptr;
| 475 |
/* fill base line */
| 476 |
| 477 |
hres, ypos, hstep);
| 478 |
/* fill bar */
| 479 |
fillscanbar(scanbar, zbar, hres, ypos, ystep);
| 480 |
if (directvis) /* add bitty sources */
| 481 |
drawsources(scanbar, zbar, 0, hres, ypos, ystep);
| 482 |
/* write it out */
| 483 |
#ifdef SIGCONT
| 484 |
signal(SIGCONT, SIG_IGN); /* don't interrupt writes */
| 485 |
#endif
| 486 |
for (i = ystep; i > 0; i--) {
| 487 |
if (zfd != -1 && write(zfd, (char *)zbar[i],
| 488 |
hres*sizeof(float))
| 489 |
< hres*sizeof(float))
| 490 |
goto writerr;
| 491 |
if (fwritescan(scanbar[i], hres, stdout) < 0)
| 492 |
goto writerr;
| 493 |
| 494 |
if (fflush(stdout) == EOF)
| 495 |
goto writerr;
| 496 |
/* record progress */
| 497 |
pctdone = 100.0*(vres-1-ypos)/vres;
| 498 |
if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm)
| 499 |
report(0);
| 500 |
#ifdef SIGCONT
| 501 |
else
| 502 |
| 503 |
#endif
| 504 |
| 505 |
/* clean up */
| 506 |
#ifdef SIGCONT
| 507 |
| 508 |
#endif
| 509 |
if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float))
| 510 |
| 511 |
goto writerr;
| 512 |
fwritescan(scanbar[0], hres, stdout);
| 513 |
| 514 |
goto writerr;
| 515 |
alldone:
| 516 |
if (zfd != -1) {
| 517 |
if (close(zfd) == -1)
| 518 |
goto writerr;
| 519 |
| 520 |
free((void *)zbar[i]);
| 521 |
| 522 |
| 523 |
free((void *)scanbar[i]);
| 524 |
if (sampdens != NULL)
| 525 |
free(sampdens);
| 526 |
pctdone = 100.0;
| 527 |
if (ralrm > 0)
| 528 |
report(0);
| 529 |
#ifdef SIGCONT
| 530 |
signal(SIGCONT, SIG_DFL);
| 531 |
#endif
| 532 |
return;
| 533 |
writerr:
| 534 |
error(SYSTEM, "write error in render");
| 535 |
memerr:
| 536 |
error(SYSTEM, "out of memory in render");
| 537 |
| 538 |
| 539 |
| 540 |
static void
| 541 |
fillscanline( /* fill scan at y */
| 542 |
COLOR *scanline,
| 543 |
float *zline,
| 544 |
char *sd,
| 545 |
int xres,
| 546 |
int y,
| 547 |
int xstep
| 548 |
| 549 |
| 550 |
static int nc = 0; /* number of calls */
| 551 |
int bl = xstep, b = xstep;
| 552 |
double z;
| 553 |
int i;
| 554 |
| 555 |
z = pixvalue(scanline[0], 0, y);
| 556 |
if (zline) zline[0] = z;
| 557 |
/* zig-zag start for quincunx pattern */
| 558 |
for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
| 559 |
if (i >= xres) {
| 560 |
xstep += xres-1-i;
| 561 |
i = xres-1;
| 562 |
| 563 |
z = pixvalue(scanline[i], i, y);
| 564 |
if (zline) zline[i] = z;
| 565 |
if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
| 566 |
if (i <= xstep)
| 567 |
b = fillsample(scanline, zline, 0, y, i, 0, b/2);
| 568 |
else
| 569 |
b = fillsample(scanline+i-xstep,
| 570 |
zline ? zline+i-xstep : (float *)NULL,
| 571 |
i-xstep, y, xstep, 0, b/2);
| 572 |
if (sd) *sd++ = nc & 1 ? bl : b;
| 573 |
bl = b;
| 574 |
| 575 |
if (sd && nc & 1) *sd = bl;
| 576 |
| 577 |
| 578 |
| 579 |
static void
| 580 |
fillscanbar( /* fill interior */
| 581 |
COLOR *scanbar[],
| 582 |
float *zbar[],
| 583 |
int xres,
| 584 |
int y,
| 585 |
int ysize
| 586 |
| 587 |
| 588 |
COLOR vline[MAXDIV+1];
| 589 |
float zline[MAXDIV+1];
| 590 |
int b = ysize;
| 591 |
int i, j;
| 592 |
| 593 |
for (i = 0; i < xres; i++) {
| 594 |
copycolor(vline[0], scanbar[0][i]);
| 595 |
copycolor(vline[ysize], scanbar[ysize][i]);
| 596 |
if (zbar[0]) {
| 597 |
zline[0] = zbar[0][i];
| 598 |
zline[ysize] = zbar[ysize][i];
| 599 |
| 600 |
b = fillsample(vline, zbar[0] ? zline : (float *)NULL,
| 601 |
i, y, 0, ysize, b/2);
| 602 |
| 603 |
for (j = 1; j < ysize; j++)
| 604 |
copycolor(scanbar[j][i], vline[j]);
| 605 |
if (zbar[0])
| 606 |
| 607 |
zbar[j][i] = zline[j];
| 608 |
| 609 |
| 610 |
| 611 |
| 612 |
static int
| 613 |
fillsample( /* fill interior points */
| 614 |
COLOR *colline,
| 615 |
float *zline,
| 616 |
int x,
| 617 |
int y,
| 618 |
int xlen,
| 619 |
int ylen,
| 620 |
int b
| 621 |
| 622 |
| 623 |
double ratio;
| 624 |
double z;
| 625 |
COLOR ctmp;
| 626 |
int ncut;
| 627 |
int len;
| 628 |
| 629 |
if (xlen > 0) /* x or y length is zero */
| 630 |
len = xlen;
| 631 |
else
| 632 |
len = ylen;
| 633 |
| 634 |
if (len <= 1) /* limit recursion */
| 635 |
return(0);
| 636 |
| 637 |
if (b > 0 ||
| 638 |
(zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
| 639 |
|| bigdiff(colline[0], colline[len], maxdiff)) {
| 640 |
| 641 |
z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
| 642 |
if (zline) zline[len>>1] = z;
| 643 |
ncut = 1;
| 644 |
} else { /* interpolate */
| 645 |
copycolor(colline[len>>1], colline[len]);
| 646 |
ratio = (double)(len>>1) / len;
| 647 |
scalecolor(colline[len>>1], ratio);
| 648 |
if (zline) zline[len>>1] = zline[len] * ratio;
| 649 |
ratio = 1.0 - ratio;
| 650 |
copycolor(ctmp, colline[0]);
| 651 |
scalecolor(ctmp, ratio);
| 652 |
addcolor(colline[len>>1], ctmp);
| 653 |
if (zline) zline[len>>1] += zline[0] * ratio;
| 654 |
ncut = 0;
| 655 |
| 656 |
/* recurse */
| 657 |
ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
| 658 |
| 659 |
ncut += fillsample(colline+(len>>1),
| 660 |
zline ? zline+(len>>1) : (float *)NULL,
| 661 |
x+(xlen>>1), y+(ylen>>1),
| 662 |
xlen-(xlen>>1), ylen-(ylen>>1), b/2);
| 663 |
| 664 |
return(ncut);
| 665 |
| 666 |
| 667 |
| 668 |
static double
| 669 |
pixvalue( /* compute pixel value */
| 670 |
COLOR col, /* returned color */
| 671 |
int x, /* pixel position */
| 672 |
int y
| 673 |
| 674 |
| 675 |
extern void SDsquare2disk(double ds[2], double seedx, double seedy);
| 676 |
RAY thisray;
| 677 |
FVECT lorg, ldir;
| 678 |
double hpos, vpos, vdist, lmax;
| 679 |
int i;
| 680 |
/* compute view ray */
| 681 |
setcolor(col, 0.0, 0.0, 0.0);
| 682 |
hpos = (x+pixjitter())/hres;
| 683 |
vpos = (y+pixjitter())/vres;
| 684 |
if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
| 685 |
&ourview, hpos, vpos)) < -FTINY)
| 686 |
return(0.0);
| 687 |
| 688 |
vdist = ourview.vdist;
| 689 |
/* set pixel index */
| 690 |
samplendx = pixnumber(x,y,hres,vres);
| 691 |
/* optional motion blur */
| 692 |
if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir,
| 693 |
&lastview, hpos, vpos)) >= -FTINY) {
| 694 |
double d = mblur*(.5-urand(281+samplendx));
| 695 |
| 696 |
thisray.rmax = (1.-d)*thisray.rmax + d*lmax;
| 697 |
for (i = 3; i--; ) {
| 698 |
thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i];
| 699 |
thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i];
| 700 |
| 701 |
if (normalize(thisray.rdir) == 0.0)
| 702 |
return(0.0);
| 703 |
vdist = (1.-d)*vdist + d*lastview.vdist;
| 704 |
| 705 |
/* optional depth-of-field */
| 706 |
if (dblur > FTINY) {
| 707 |
double vc, df[2];
| 708 |
/* random point on disk */
| 709 |
SDsquare2disk(df, frandom(), frandom());
| 710 |
df[0] *= .5*dblur;
| 711 |
df[1] *= .5*dblur;
| 712 |
if ((ourview.type == VT_PER) | (ourview.type == VT_PAR)) {
| 713 |
double adj = 1.0;
| 714 |
if (ourview.type == VT_PER)
| 715 |
adj /= DOT(thisray.rdir, ourview.vdir);
| 716 |
df[0] /= sqrt(ourview.hn2);
| 717 |
df[1] /= sqrt(ourview.vn2);
| 718 |
| 719 |
vc = ourview.vp[i] + adj*vdist*thisray.rdir[i];
| 720 |
thisray.rorg[i] += df[0]*ourview.hvec[i] +
| 721 |
df[1]*ourview.vvec[i] ;
| 722 |
thisray.rdir[i] = vc - thisray.rorg[i];
| 723 |
| 724 |
} else { /* non-standard view case */
| 725 |
double dfd = PI/4.*dblur*(.5 - frandom());
| 726 |
if ((ourview.type != VT_ANG) & (ourview.type != VT_PLS)) {
| 727 |
if (ourview.type != VT_CYL)
| 728 |
| 729 |
| 730 |
| 731 |
| 732 |
vc = ourview.vp[i] + vdist*thisray.rdir[i];
| 733 |
| 734 |
df[1]*ourview.vvec[i] +
| 735 |
dfd*ourview.vdir[i] ;
| 736 |
| 737 |
| 738 |
| 739 |
| 740 |
return(0.0);
| 741 |
| 742 |
| 743 |
rayorigin(&thisray, PRIMARY, NULL, NULL);
| 744 |
| 745 |
rayvalue(&thisray); /* trace ray */
| 746 |
| 747 |
copycolor(col, thisray.rcol); /* return color */
| 748 |
| 749 |
return(thisray.rt); /* return distance */
| 750 |
| 751 |
| 752 |
| 753 |
static int
| 754 |
salvage( /* salvage scanlines from killed program */
| 755 |
char *oldfile
| 756 |
| 757 |
| 758 |
COLR *scanline;
| 759 |
FILE *fp;
| 760 |
int x, y;
| 761 |
| 762 |
if (oldfile == NULL)
| 763 |
goto gotzip;
| 764 |
| 765 |
if ((fp = fopen(oldfile, "r")) == NULL) {
| 766 |
sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
| 767 |
| 768 |
goto gotzip;
| 769 |
| 770 |
SET_FILE_BINARY(fp);
| 771 |
/* discard header */
| 772 |
getheader(fp, NULL, NULL);
| 773 |
/* get picture size */
| 774 |
if (!fscnresolu(&x, &y, fp)) {
| 775 |
sprintf(errmsg, "bad recover file \"%s\" - not removed",
| 776 |
oldfile);
| 777 |
| 778 |
fclose(fp);
| 779 |
goto gotzip;
| 780 |
| 781 |
| 782 |
if ((x != hres) | (y != vres)) {
| 783 |
sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
| 784 |
oldfile);
| 785 |
| 786 |
| 787 |
| 788 |
scanline = (COLR *)malloc(hres*sizeof(COLR));
| 789 |
if (scanline == NULL)
| 790 |
error(SYSTEM, "out of memory in salvage");
| 791 |
for (y = 0; y < vres; y++) {
| 792 |
if (freadcolrs(scanline, hres, fp) < 0)
| 793 |
break;
| 794 |
if (fwritecolrs(scanline, hres, stdout) < 0)
| 795 |
goto writerr;
| 796 |
| 797 |
| 798 |
goto writerr;
| 799 |
free((void *)scanline);
| 800 |
fclose(fp);
| 801 |
unlink(oldfile);
| 802 |
return(y);
| 803 |
gotzip:
| 804 |
| 805 |
error(SYSTEM, "error writing picture header");
| 806 |
return(0);
| 807 |
writerr:
| 808 |
sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
| 809 |
| 810 |
return -1; /* pro forma return */
| 811 |
| 812 |
| 813 |
static int
| 814 |
pixnumber( /* compute pixel index (screen door) */
| 815 |
int x,
| 816 |
int y,
| 817 |
int xres,
| 818 |
int yres
| 819 |
| 820 |
| 821 |
unsigned nbits = 0;
| 822 |
bitmask_t coord[2];
| 823 |
| 824 |
if (xres < yres) xres = yres;
| 825 |
while (xres > 0) {
| 826 |
xres >>= 1;
| 827 |
++nbits;
| 828 |
| 829 |
coord[0] = x; coord[1] = y;
| 830 |
return ((int)hilbert_c2i(2, nbits, coord));
| 831 |
