root/radiance/ray/src/rt/rpict.c
Revision: 2.82
Committed: Sat May 15 15:31:30 2010 UTC (15 years, 1 month ago) by greg
Changes since 2.81: +3 -3 lines
Implemented Mark Stock's fix for depth-of-field blur
2 static const char RCSid[] = "$Id: rpict.c,v 2.81 2009/05/11 21:46:31 greg Exp $";
5 * rpict.c - routines and variables for picture generation.
6 */
7
8 #include "copyright.h"
9
10 #include <sys/types.h>
11
12 #include "platform.h"
13 #ifdef NON_POSIX
14 #ifdef MINGW
15 #include <sys/time.h>
16 #endif
17 #else
18 #ifdef BSD
19 #include <sys/time.h>
20 #include <sys/resource.h>
21 #else
22 #include <sys/times.h>
23 #include <unistd.h>
24 #endif
25 #endif
26
27 #include <time.h>
28 #include <signal.h>
29
30 #include "ray.h"
31 #include "paths.h"
32 #include "ambient.h"
33 #include "view.h"
34 #include "random.h"
35 #include "paths.h"
36 #include "rtmisc.h" /* myhostname() */
37
38
39 #define RFTEMPLATE "rfXXXXXX"
40
41 #ifndef SIGCONT
42 #ifdef SIGIO /* XXX can we live without this? */
43 #define SIGCONT SIGIO
44 #endif
45 #endif
46
47 CUBE thescene; /* our scene */
48 OBJECT nsceneobjs; /* number of objects in our scene */
49
50 int dimlist[MAXDIM]; /* sampling dimensions */
51 int ndims = 0; /* number of sampling dimensions */
52 int samplendx; /* sample index number */
53
54 //extern void ambnotify();
55 void (*addobjnotify[])() = {ambnotify, NULL};
56
57 VIEW ourview = STDVIEW; /* view parameters */
58 int hresolu = 512; /* horizontal resolution */
59 int vresolu = 512; /* vertical resolution */
60 double pixaspect = 1.0; /* pixel aspect ratio */
61
62 int psample = 4; /* pixel sample size */
63 double maxdiff = .05; /* max. difference for interpolation */
64 double dstrpix = 0.67; /* square pixel distribution */
65
66 double mblur = 0.; /* motion blur parameter */
67
68 double dblur = 0.; /* depth-of-field blur parameter */
69
70 void (*trace)() = NULL; /* trace call */
71
72 int do_irrad = 0; /* compute irradiance? */
73
74 int rand_samp = 0; /* pure Monte Carlo sampling? */
75
76 double dstrsrc = 0.0; /* square source distribution */
77 double shadthresh = .05; /* shadow threshold */
78 double shadcert = .5; /* shadow certainty */
79 int directrelay = 1; /* number of source relays */
80 int vspretest = 512; /* virtual source pretest density */
81 int directvis = 1; /* sources visible? */
82 double srcsizerat = .25; /* maximum ratio source size/dist. */
83
84 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
85 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
86 double seccg = 0.; /* global scattering eccentricity */
87 double ssampdist = 0.; /* scatter sampling distance */
88
89 double specthresh = .15; /* specular sampling threshold */
90 double specjitter = 1.; /* specular sampling jitter */
91
92 int backvis = 1; /* back face visibility */
93
94 int maxdepth = 7; /* maximum recursion depth */
95 double minweight = 4e-3; /* minimum ray weight */
96
97 char *ambfile = NULL; /* ambient file name */
98 COLOR ambval = BLKCOLOR; /* ambient value */
99 int ambvwt = 0; /* initial weight for ambient value */
100 double ambacc = 0.2; /* ambient accuracy */
101 int ambres = 64; /* ambient resolution */
102 int ambdiv = 512; /* ambient divisions */
103 int ambssamp = 128; /* ambient super-samples */
104 int ambounce = 0; /* ambient bounces */
105 char *amblist[AMBLLEN]; /* ambient include/exclude list */
106 int ambincl = -1; /* include == 1, exclude == 0 */
107
108 int ralrm = 0; /* seconds between reports */
109
110 double pctdone = 0.0; /* percentage done */
111 time_t tlastrept = 0L; /* time at last report */
112 time_t tstart; /* starting time */
113
114 #define MAXDIV 16 /* maximum sample size */
115
116 #define pixjitter() (.5+dstrpix*(.5-frandom()))
117
118 int hres, vres; /* resolution for this frame */
119
120 static VIEW lastview; /* the previous view input */
121
122 //extern char *mktemp(); /* XXX should be in stdlib.h or unistd.h */
123
124 //double pixvalue();
125
126 static void report(int);
127 static int nextview(FILE *fp);
128 static void render(char *zfile, char *oldfile);
129 static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres,
130 int y, int xstep);
131 static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres,
132 int y, int ysize);
133 static int fillsample(COLOR *colline, float *zline, int x, int y,
134 int xlen, int ylen, int b);
135 static double pixvalue(COLOR col, int x, int y);
136 static int salvage(char *oldfile);
137 static int pixnumber(int x, int y, int xres, int yres);
138
139
140
141 #ifdef RHAS_STAT
142 #include <sys/types.h>
143 #include <sys/stat.h>
144 int
145 file_exists(fname) /* ordinary file exists? */
146 char *fname;
147 {
148 struct stat sbuf;
149 if (stat(fname, &sbuf) < 0) return(0);
150 return((sbuf.st_mode & S_IFREG) != 0);
151 }
152 #else
153 #define file_exists(f) (access(f,F_OK)==0)
154 #endif
155
156
157 void
158 quit(code) /* quit program */
159 int code;
160 {
161 if (code) /* report status */
162 report(0);
163 #ifndef NON_POSIX
164 headclean(); /* delete header file */
165 pfclean(); /* clean up persist files */
166 #endif
167 exit(code);
168 }
169
170
171 #ifndef NON_POSIX
172 static void
173 report(int dummy) /* report progress */
174 {
175 double u, s;
176 #ifdef BSD
177 struct rusage rubuf;
178 #else
179 struct tms tbuf;
180 double period;
181 #endif
182
183 tlastrept = time((time_t *)NULL);
184 #ifdef BSD
185 getrusage(RUSAGE_SELF, &rubuf);
186 u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6;
187 s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6;
188 getrusage(RUSAGE_CHILDREN, &rubuf);
189 u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6;
190 s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6;
191 #else
192 times(&tbuf);
193 #ifdef _SC_CLK_TCK
194 period = 1.0 / sysconf(_SC_CLK_TCK);
195 #else
196 period = 1.0 / 60.0;
197 #endif
198 u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period;
199 s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period;
200 #endif
201
202 sprintf(errmsg,
203 "%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n",
204 nrays, pctdone, u/3600., s/3600.,
205 (tlastrept-tstart)/3600., myhostname());
206 eputs(errmsg);
207 #ifdef SIGCONT
208 signal(SIGCONT, report);
209 #endif
210 }
211 #else
212 static void
213 report(int dummy) /* report progress */
214 {
215 tlastrept = time((time_t *)NULL);
216 sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n",
217 nrays, pctdone, (tlastrept-tstart)/3600.0);
218 eputs(errmsg);
219 }
220 #endif
221
222
223 extern void
224 rpict( /* generate image(s) */
225 int seq,
226 char *pout,
227 char *zout,
228 char *prvr
229 )
230 /*
231 * If seq is greater than zero, then we will render a sequence of
232 * images based on view parameter strings read from the standard input.
233 * If pout is NULL, then all images will be sent to the standard ouput.
234 * If seq is greater than zero and prvr is an integer, then it is the
235 * frame number at which rendering should begin. Preceeding view parameter
236 * strings will be skipped in the input.
237 * If pout and prvr are the same, prvr is renamed to avoid overwriting.
238 * Note that pout and zout should contain %d format specifications for
239 * sequenced file naming.
240 */
241 {
242 char fbuf[128], fbuf2[128];
243 int npicts;
244 register char *cp;
245 RESOLU rs;
246 double pa;
247 /* check sampling */
248 if (psample < 1)
249 psample = 1;
250 else if (psample > MAXDIV) {
251 sprintf(errmsg, "pixel sampling reduced from %d to %d",
252 psample, MAXDIV);
253 error(WARNING, errmsg);
254 psample = MAXDIV;
255 }
256 /* get starting frame */
257 if (seq <= 0)
258 seq = 0;
259 else if (prvr != NULL && isint(prvr)) {
260 register int rn; /* skip to specified view */
261 if ((rn = atoi(prvr)) < seq)
262 error(USER, "recover frame less than start frame");
263 if (pout == NULL)
264 error(USER, "missing output file specification");
265 for ( ; seq < rn; seq++)
266 if (nextview(stdin) == EOF)
267 error(USER, "unexpected EOF on view input");
268 setview(&ourview);
269 prvr = fbuf; /* mark for renaming */
270 }
271 if ((pout != NULL) & (prvr != NULL)) {
272 sprintf(fbuf, pout, seq);
273 if (!strcmp(prvr, fbuf)) { /* rename */
274 strcpy(fbuf2, fbuf);
275 for (cp = fbuf2; *cp; cp++)
276 ;
277 while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
278 cp--;
279 strcpy(cp, RFTEMPLATE);
280 prvr = mktemp(fbuf2);
281 if (rename(fbuf, prvr) < 0) {
282 if (errno == ENOENT) { /* ghost file */
283 sprintf(errmsg,
284 "new output file \"%s\"",
285 fbuf);
286 error(WARNING, errmsg);
287 prvr = NULL;
288 } else { /* serious error */
289 sprintf(errmsg,
290 "cannot rename \"%s\" to \"%s\"",
291 fbuf, prvr);
292 error(SYSTEM, errmsg);
293 }
294 }
295 }
296 }
297 npicts = 0; /* render sequence */
298 do {
299 if (seq && nextview(stdin) == EOF)
300 break;
301 pctdone = 0.0;
302 if (pout != NULL) {
303 sprintf(fbuf, pout, seq);
304 if (file_exists(fbuf)) {
305 if (prvr != NULL || !strcmp(fbuf, pout)) {
306 sprintf(errmsg,
307 "output file \"%s\" exists",
308 fbuf);
309 error(USER, errmsg);
310 }
311 setview(&ourview);
312 continue; /* don't clobber */
313 }
314 if (freopen(fbuf, "w", stdout) == NULL) {
315 sprintf(errmsg,
316 "cannot open output file \"%s\"", fbuf);
317 error(SYSTEM, errmsg);
318 }
319 SET_FILE_BINARY(stdout);
320 dupheader();
321 }
322 hres = hresolu; vres = vresolu; pa = pixaspect;
323 if (prvr != NULL) {
324 if (viewfile(prvr, &ourview, &rs) <= 0) {
325 sprintf(errmsg,
326 "cannot recover view parameters from \"%s\"", prvr);
327 error(WARNING, errmsg);
328 } else {
329 pa = 0.0;
330 hres = scanlen(&rs);
331 vres = numscans(&rs);
332 }
333 }
334 if ((cp = setview(&ourview)) != NULL)
335 error(USER, cp);
336 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
337 if (seq) {
338 if (ralrm > 0) {
339 fprintf(stderr, "FRAME %d:", seq);
340 fprintview(&ourview, stderr);
341 putc('\n', stderr);
342 fflush(stderr);
343 }
344 printf("FRAME=%d\n", seq);
345 }
346 fputs(VIEWSTR, stdout);
347 fprintview(&ourview, stdout);
348 putchar('\n');
349 if (pa < .99 || pa > 1.01)
350 fputaspect(pa, stdout);
351 fputnow(stdout);
352 fputformat(COLRFMT, stdout);
353 putchar('\n');
354 if (zout != NULL)
355 sprintf(cp=fbuf, zout, seq);
356 else
357 cp = NULL;
358 render(cp, prvr);
359 prvr = NULL;
360 npicts++;
361 } while (seq++);
362 /* check that we did something */
363 if (npicts == 0)
364 error(WARNING, "no output produced");
365 }
366
367
368 static int
369 nextview( /* get next view from fp */
370 FILE *fp
371 )
372 {
373 char linebuf[256];
374
375 lastview = ourview;
376 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
377 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
378 return(0);
379 return(EOF);
380 }
381
382
383 static void
384 render( /* render the scene */
385 char *zfile,
386 char *oldfile
387 )
388 {
389 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
390 float *zbar[MAXDIV+1]; /* z values */
391 char *sampdens; /* previous sample density */
392 int ypos; /* current scanline */
393 int ystep; /* current y step size */
394 int hstep; /* h step size */
395 int zfd;
396 COLOR *colptr;
397 float *zptr;
398 register int i;
399 /* check for empty image */
400 if (hres <= 0 || vres <= 0) {
401 error(WARNING, "empty output picture");
402 fprtresolu(0, 0, stdout);
403 return;
404 }
405 /* allocate scanlines */
406 for (i = 0; i <= psample; i++) {
407 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
408 if (scanbar[i] == NULL)
409 goto memerr;
410 }
411 hstep = (psample*140+49)/99; /* quincunx sampling */
412 ystep = (psample*99+70)/140;
413 if (hstep > 2) {
414 i = hres/hstep + 2;
415 if ((sampdens = (char *)malloc(i)) == NULL)
416 goto memerr;
417 while (i--)
418 sampdens[i] = hstep;
419 } else
420 sampdens = NULL;
421 /* open z-file */
422 if (zfile != NULL) {
423 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
424 sprintf(errmsg, "cannot open z-file \"%s\"", zfile);
425 error(SYSTEM, errmsg);
426 }
427 SET_FD_BINARY(zfd);
428 for (i = 0; i <= psample; i++) {
429 zbar[i] = (float *)malloc(hres*sizeof(float));
430 if (zbar[i] == NULL)
431 goto memerr;
432 }
433 } else {
434 zfd = -1;
435 for (i = 0; i <= psample; i++)
436 zbar[i] = NULL;
437 }
438 /* write out boundaries */
439 fprtresolu(hres, vres, stdout);
440 /* recover file and compute first */
441 i = salvage(oldfile);
442 if (i >= vres)
443 goto alldone;
444 if (zfd != -1 && i > 0 &&
445 lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0)
446 error(SYSTEM, "z-file seek error in render");
447 pctdone = 100.0*i/vres;
448 if (ralrm > 0) /* report init stats */
449 report(0);
450 #ifdef SIGCONT
451 else
452 signal(SIGCONT, report);
453 #endif
454 ypos = vres-1 - i; /* initialize sampling */
455 if (directvis)
456 init_drawsources(psample);
457 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
458 /* compute scanlines */
459 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
460 /* bottom adjust? */
461 if (ypos < 0) {
462 ystep += ypos;
463 ypos = 0;
464 }
465 colptr = scanbar[ystep]; /* move base to top */
466 scanbar[ystep] = scanbar[0];
467 scanbar[0] = colptr;
468 zptr = zbar[ystep];
469 zbar[ystep] = zbar[0];
470 zbar[0] = zptr;
471 /* fill base line */
472 fillscanline(scanbar[0], zbar[0], sampdens,
473 hres, ypos, hstep);
474 /* fill bar */
475 fillscanbar(scanbar, zbar, hres, ypos, ystep);
476 if (directvis) /* add bitty sources */
477 drawsources(scanbar, zbar, 0, hres, ypos, ystep);
478 /* write it out */
479 #ifdef SIGCONT
480 signal(SIGCONT, SIG_IGN); /* don't interrupt writes */
481 #endif
482 for (i = ystep; i > 0; i--) {
483 if (zfd != -1 && write(zfd, (char *)zbar[i],
484 hres*sizeof(float))
485 < hres*sizeof(float))
486 goto writerr;
487 if (fwritescan(scanbar[i], hres, stdout) < 0)
488 goto writerr;
489 }
490 if (fflush(stdout) == EOF)
491 goto writerr;
492 /* record progress */
493 pctdone = 100.0*(vres-1-ypos)/vres;
494 if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm)
495 report(0);
496 #ifdef SIGCONT
497 else
498 signal(SIGCONT, report);
499 #endif
500 }
501 /* clean up */
502 #ifdef SIGCONT
503 signal(SIGCONT, SIG_IGN);
504 #endif
505 if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float))
506 < hres*sizeof(float))
507 goto writerr;
508 fwritescan(scanbar[0], hres, stdout);
509 if (fflush(stdout) == EOF)
510 goto writerr;
511 alldone:
512 if (zfd != -1) {
513 if (close(zfd) == -1)
514 goto writerr;
515 for (i = 0; i <= psample; i++)
516 free((void *)zbar[i]);
517 }
518 for (i = 0; i <= psample; i++)
519 free((void *)scanbar[i]);
520 if (sampdens != NULL)
521 free(sampdens);
522 pctdone = 100.0;
523 if (ralrm > 0)
524 report(0);
525 #ifdef SIGCONT
526 signal(SIGCONT, SIG_DFL);
527 #endif
528 return;
529 writerr:
530 error(SYSTEM, "write error in render");
531 memerr:
532 error(SYSTEM, "out of memory in render");
533 }
534
535
536 static void
537 fillscanline( /* fill scan at y */
538 register COLOR *scanline,
539 register float *zline,
540 register char *sd,
541 int xres,
542 int y,
543 int xstep
544 )
545 {
546 static int nc = 0; /* number of calls */
547 int bl = xstep, b = xstep;
548 double z;
549 register int i;
550
551 z = pixvalue(scanline[0], 0, y);
552 if (zline) zline[0] = z;
553 /* zig-zag start for quincunx pattern */
554 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
555 if (i >= xres) {
556 xstep += xres-1-i;
557 i = xres-1;
558 }
559 z = pixvalue(scanline[i], i, y);
560 if (zline) zline[i] = z;
561 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
562 if (i <= xstep)
563 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
564 else
565 b = fillsample(scanline+i-xstep,
566 zline ? zline+i-xstep : (float *)NULL,
567 i-xstep, y, xstep, 0, b/2);
568 if (sd) *sd++ = nc & 1 ? bl : b;
569 bl = b;
570 }
571 if (sd && nc & 1) *sd = bl;
572 }
573
574
575 static void
576 fillscanbar( /* fill interior */
577 register COLOR *scanbar[],
578 register float *zbar[],
579 int xres,
580 int y,
581 int ysize
582 )
583 {
584 COLOR vline[MAXDIV+1];
585 float zline[MAXDIV+1];
586 int b = ysize;
587 register int i, j;
588
589 for (i = 0; i < xres; i++) {
590 copycolor(vline[0], scanbar[0][i]);
591 copycolor(vline[ysize], scanbar[ysize][i]);
592 if (zbar[0]) {
593 zline[0] = zbar[0][i];
594 zline[ysize] = zbar[ysize][i];
595 }
596 b = fillsample(vline, zbar[0] ? zline : (float *)NULL,
597 i, y, 0, ysize, b/2);
598
599 for (j = 1; j < ysize; j++)
600 copycolor(scanbar[j][i], vline[j]);
601 if (zbar[0])
602 for (j = 1; j < ysize; j++)
603 zbar[j][i] = zline[j];
604 }
605 }
606
607
608 static int
609 fillsample( /* fill interior points */
610 register COLOR *colline,
611 register float *zline,
612 int x,
613 int y,
614 int xlen,
615 int ylen,
616 int b
617 )
618 {
619 double ratio;
620 double z;
621 COLOR ctmp;
622 int ncut;
623 register int len;
624
625 if (xlen > 0) /* x or y length is zero */
626 len = xlen;
627 else
628 len = ylen;
629
630 if (len <= 1) /* limit recursion */
631 return(0);
632
633 if (b > 0 ||
634 (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
635 || bigdiff(colline[0], colline[len], maxdiff)) {
636
637 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
638 if (zline) zline[len>>1] = z;
639 ncut = 1;
640 } else { /* interpolate */
641 copycolor(colline[len>>1], colline[len]);
642 ratio = (double)(len>>1) / len;
643 scalecolor(colline[len>>1], ratio);
644 if (zline) zline[len>>1] = zline[len] * ratio;
645 ratio = 1.0 - ratio;
646 copycolor(ctmp, colline[0]);
647 scalecolor(ctmp, ratio);
648 addcolor(colline[len>>1], ctmp);
649 if (zline) zline[len>>1] += zline[0] * ratio;
650 ncut = 0;
651 }
652 /* recurse */
653 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
654
655 ncut += fillsample(colline+(len>>1),
656 zline ? zline+(len>>1) : (float *)NULL,
657 x+(xlen>>1), y+(ylen>>1),
658 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
659
660 return(ncut);
661 }
662
663
664 static double
665 pixvalue( /* compute pixel value */
666 COLOR col, /* returned color */
667 int x, /* pixel position */
668 int y
669 )
670 {
671 RAY thisray;
672 FVECT lorg, ldir;
673 double hpos, vpos, vdist, lmax;
674 register int i;
675 /* compute view ray */
676 hpos = (x+pixjitter())/hres;
677 vpos = (y+pixjitter())/vres;
678 if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir,
679 &ourview, hpos, vpos)) < -FTINY) {
680 setcolor(col, 0.0, 0.0, 0.0);
681 return(0.0);
682 }
683 vdist = ourview.vdist;
684 /* set pixel index */
685 samplendx = pixnumber(x,y,hres,vres);
686 /* optional motion blur */
687 if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir,
688 &lastview, hpos, vpos)) >= -FTINY) {
689 register double d = mblur*(.5-urand(281+samplendx));
690
691 thisray.rmax = (1.-d)*thisray.rmax + d*lmax;
692 for (i = 3; i--; ) {
693 thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i];
694 thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i];
695 }
696 if (normalize(thisray.rdir) == 0.0)
697 return(0.0);
698 vdist = (1.-d)*vdist + d*lastview.vdist;
699 }
700 /* optional depth-of-field */
701 if (dblur > FTINY && vdist > FTINY) {
702 double vc, dfh, dfv;
703 /* square/circle conv. */
704 dfh = vc = 1. - 2.*frandom();
705 dfv = 1. - 2.*frandom();
706 dfh *= .5*dblur*sqrt(1. - .5*dfv*dfv);
707 dfv *= .5*dblur*sqrt(1. - .5*vc*vc);
708 if (ourview.type == VT_PER || ourview.type == VT_PAR) {
709 dfh /= sqrt(ourview.hn2);
710 dfv /= sqrt(ourview.vn2);
711 for (i = 3; i--; ) {
712 vc = thisray.rorg[i] + vdist*thisray.rdir[i];
713 thisray.rorg[i] += dfh*ourview.hvec[i] +
714 dfv*ourview.vvec[i] ;
715 thisray.rdir[i] = vc - thisray.rorg[i];
716 }
717 } else { /* non-standard view case */
718 double dfd = PI/4.*dblur*(.5 - frandom());
719 if (ourview.type != VT_ANG && ourview.type != VT_PLS) {
720 if (ourview.type != VT_CYL)
721 dfh /= sqrt(ourview.hn2);
722 dfv /= sqrt(ourview.vn2);
723 }
724 for (i = 3; i--; ) {
725 vc = thisray.rorg[i] + vdist*thisray.rdir[i];
726 thisray.rorg[i] += dfh*ourview.hvec[i] +
727 dfv*ourview.vvec[i] +
728 dfd*ourview.vdir[i] ;
729 thisray.rdir[i] = vc - thisray.rorg[i];
730 }
731 }
732 if (normalize(thisray.rdir) == 0.0)
733 return(0.0);
734 }
735
736 rayorigin(&thisray, PRIMARY, NULL, NULL);
737
738 rayvalue(&thisray); /* trace ray */
739
740 copycolor(col, thisray.rcol); /* return color */
741
742 return(thisray.rt); /* return distance */
743 }
744
745
746 static int
747 salvage( /* salvage scanlines from killed program */
748 char *oldfile
749 )
750 {
751 COLR *scanline;
752 FILE *fp;
753 int x, y;
754
755 if (oldfile == NULL)
756 goto gotzip;
757
758 if ((fp = fopen(oldfile, "r")) == NULL) {
759 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
760 error(WARNING, errmsg);
761 goto gotzip;
762 }
763 SET_FILE_BINARY(fp);
764 /* discard header */
765 getheader(fp, NULL, NULL);
766 /* get picture size */
767 if (!fscnresolu(&x, &y, fp)) {
768 sprintf(errmsg, "bad recover file \"%s\" - not removed",
769 oldfile);
770 error(WARNING, errmsg);
771 fclose(fp);
772 goto gotzip;
773 }
774
775 if (x != hres || y != vres) {
776 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
777 oldfile);
778 error(USER, errmsg);
779 }
780
781 scanline = (COLR *)malloc(hres*sizeof(COLR));
782 if (scanline == NULL)
783 error(SYSTEM, "out of memory in salvage");
784 for (y = 0; y < vres; y++) {
785 if (freadcolrs(scanline, hres, fp) < 0)
786 break;
787 if (fwritecolrs(scanline, hres, stdout) < 0)
788 goto writerr;
789 }
790 if (fflush(stdout) == EOF)
791 goto writerr;
792 free((void *)scanline);
793 fclose(fp);
794 unlink(oldfile);
795 return(y);
796 gotzip:
797 if (fflush(stdout) == EOF)
798 error(SYSTEM, "error writing picture header");
799 return(0);
800 writerr:
801 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
802 error(SYSTEM, errmsg);
803 return -1; /* pro forma return */
804 }
805
806 static int
807 pixnumber( /* compute pixel index (brushed) */
808 register int x,
809 register int y,
810 int xres,
811 int yres
812 )
813 {
814 x -= y;
815 while (x < 0)
816 x += xres;
817 return((((x>>2)*yres + y) << 2) + (x & 3));
818 }
