root/radiance/ray/src/rt/rpict.c
Revision: 2.18
Committed: Tue Nov 10 21:24:34 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.17: +15 -21 lines
bug fixes for MS-DOS
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rpict.c - routines and variables for picture generation.
9 *
10 * 8/14/85
11 */
12
13 #include "ray.h"
14
15 #ifdef BSD
16 #include <sys/time.h>
17 #include <sys/resource.h>
18 #endif
19
20 #include <signal.h>
21
22 #include "view.h"
23
24 #include "resolu.h"
25
26 #include "random.h"
27
28 #include "paths.h"
29
30 int dimlist[MAXDIM]; /* sampling dimensions */
31 int ndims = 0; /* number of sampling dimensions */
32 int samplendx; /* sample index number */
33
34 VIEW ourview = STDVIEW; /* view parameters */
35 int hresolu = 512; /* horizontal resolution */
36 int vresolu = 512; /* vertical resolution */
37 double pixaspect = 1.0; /* pixel aspect ratio */
38
39 int psample = 4; /* pixel sample size */
40 double maxdiff = .05; /* max. difference for interpolation */
41 double dstrpix = 0.67; /* square pixel distribution */
42
43 double dstrsrc = 0.0; /* square source distribution */
44 double shadthresh = .05; /* shadow threshold */
45 double shadcert = .5; /* shadow certainty */
46 int directrelay = 1; /* number of source relays */
47 int vspretest = 512; /* virtual source pretest density */
48 int directinvis = 0; /* sources invisible? */
49 double srcsizerat = .25; /* maximum ratio source size/dist. */
50
51 double specthresh = .15; /* specular sampling threshold */
52 double specjitter = 1.; /* specular sampling jitter */
53
54 int maxdepth = 6; /* maximum recursion depth */
55 double minweight = 5e-3; /* minimum ray weight */
56
57 COLOR ambval = BLKCOLOR; /* ambient value */
58 double ambacc = 0.2; /* ambient accuracy */
59 int ambres = 32; /* ambient resolution */
60 int ambdiv = 128; /* ambient divisions */
61 int ambssamp = 0; /* ambient super-samples */
62 int ambounce = 0; /* ambient bounces */
63 char *amblist[128]; /* ambient include/exclude list */
64 int ambincl = -1; /* include == 1, exclude == 0 */
65
66 #ifdef MSDOS
67 int ralrm = 60; /* seconds between reports */
68 #else
69 int ralrm = 0; /* seconds between reports */
70 #endif
71
72 double pctdone = 0.0; /* percentage done */
73
74 long tlastrept = 0L; /* time at last report */
75
76 extern long time();
77 extern long tstart; /* starting time */
78
79 extern long nrays; /* number of rays traced */
80
81 #define MAXDIV 16 /* maximum sample size */
82
83 #define pixjitter() (.5+dstrpix*(.5-frandom()))
84
85 #define RFTEMPLATE "rfXXXXXX"
86 #define HFTEMPLATE TEMPLATE
87
88 static char *hfname = NULL; /* header file name */
89 static FILE *hfp = NULL; /* header file pointer */
90
91 static int hres, vres; /* resolution for this frame */
92
93 extern char *mktemp();
94
95 double pixvalue();
96
97
98 quit(code) /* quit program */
99 int code;
100 {
101 if (code) /* report status */
102 report();
103 if (hfname != NULL) { /* delete header file */
104 if (hfp != NULL)
105 fclose(hfp);
106 unlink(hfname);
107 }
108 exit(code);
109 }
110
111
112 #ifdef BSD
113 report() /* report progress */
114 {
115 struct rusage rubuf;
116 double t;
117
118 getrusage(RUSAGE_SELF, &rubuf);
119 t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
120 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
121 getrusage(RUSAGE_CHILDREN, &rubuf);
122 t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
123 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
124
125 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n",
126 nrays, pctdone, t/3600.0);
127 eputs(errmsg);
128 tlastrept = time((long *)0);
129 }
130 #else
131 report() /* report progress */
132 {
133 tlastrept = time((long *)0);
134 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n",
135 nrays, pctdone, (tlastrept-tstart)/3600.0);
136 eputs(errmsg);
137 signal(SIGALRM, report);
138 }
139 #endif
140
141
142 openheader() /* save standard output to header file */
143 {
144 hfname = mktemp(HFTEMPLATE);
145 if (freopen(hfname, "w", stdout) == NULL) {
146 sprintf(errmsg, "cannot open header file \"%s\"", hfname);
147 error(SYSTEM, errmsg);
148 }
149 }
150
151
152 dupheader() /* repeat header on standard output */
153 {
154 register int c;
155
156 if (hfp == NULL) {
157 if ((hfp = fopen(hfname, "r")) == NULL)
158 error(SYSTEM, "error reopening header file");
159 #ifdef MSDOS
160 setmode(fileno(hfp), O_BINARY);
161 #endif
162 } else if (fseek(hfp, 0L, 0) < 0)
163 error(SYSTEM, "seek error on header file");
164 while ((c = getc(hfp)) != EOF)
165 putchar(c);
166 }
167
168
169 rpict(seq, pout, zout, prvr) /* generate image(s) */
170 int seq;
171 char *pout, *zout, *prvr;
172 /*
173 * If seq is greater than zero, then we will render a sequence of
174 * images based on view parameter strings read from the standard input.
175 * If pout is NULL, then all images will be sent to the standard ouput.
176 * If seq is greater than zero and prvr is an integer, then it is the
177 * frame number at which rendering should begin. Preceeding view parameter
178 * strings will be skipped in the input.
179 * If pout and prvr are the same, prvr is renamed to avoid overwriting.
180 * Note that pout and zout should contain %d format specifications for
181 * sequenced file naming.
182 */
183 {
184 extern char *rindex(), *strncpy(), *strcat();
185 char fbuf[128], fbuf2[128];
186 register char *cp;
187 RESOLU rs;
188 double pa;
189 /* check sampling */
190 if (psample < 1)
191 psample = 1;
192 else if (psample > MAXDIV) {
193 sprintf(errmsg, "pixel sampling reduced from %d to %d",
194 psample, MAXDIV);
195 error(WARNING, errmsg);
196 psample = MAXDIV;
197 }
198 /* get starting frame */
199 if (seq <= 0)
200 seq = 0;
201 else if (prvr != NULL && isint(prvr)) {
202 register int rn; /* skip to specified view */
203 if ((rn = atoi(prvr)) < seq)
204 error(USER, "recover frame less than start frame");
205 if (pout == NULL)
206 error(USER, "missing output file specification");
207 for ( ; seq < rn; seq++)
208 if (nextview(stdin) == EOF)
209 error(USER, "unexpected EOF on view input");
210 prvr = fbuf; /* mark for renaming */
211 }
212 if (pout != NULL & prvr != NULL) {
213 sprintf(fbuf, pout, seq);
214 if (!strcmp(prvr, fbuf)) { /* rename */
215 strcpy(fbuf2, fbuf);
216 for (cp = fbuf2; *cp; cp++)
217 ;
218 while (cp > fbuf2 && !ISDIRSEP(cp[-1]))
219 cp--;
220 strcpy(cp, RFTEMPLATE);
221 prvr = mktemp(fbuf2);
222 if (rename(fbuf, prvr) < 0 && errno != ENOENT) {
223 sprintf(errmsg,
224 "cannot rename \"%s\" to \"%s\"",
225 fbuf, prvr);
226 error(SYSTEM, errmsg);
227 }
228 }
229 }
230 /* render sequence */
231 do {
232 if (seq && nextview(stdin) == EOF)
233 break;
234 if (pout != NULL) {
235 sprintf(fbuf, pout, seq);
236 if (freopen(fbuf, "w", stdout) == NULL) {
237 sprintf(errmsg,
238 "cannot open output file \"%s\"", fbuf);
239 error(SYSTEM, errmsg);
240 }
241 #ifdef MSDOS
242 setmode(fileno(stdout), O_BINARY);
243 #endif
244 dupheader();
245 }
246 hres = hresolu; vres = vresolu; pa = pixaspect;
247 if (prvr != NULL)
248 if (viewfile(prvr, &ourview, &rs) <= 0
249 || rs.or != PIXSTANDARD) {
250 sprintf(errmsg,
251 "cannot recover view parameters from \"%s\"", prvr);
252 error(WARNING, errmsg);
253 } else {
254 pa = 0.0;
255 hres = scanlen(&rs);
256 vres = numscans(&rs);
257 }
258 if ((cp = setview(&ourview)) != NULL)
259 error(USER, cp);
260 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
261 if (seq) {
262 if (ralrm > 0) {
263 fprintf(stderr, "FRAME %d:", seq);
264 fprintview(&ourview, stderr);
265 putc('\n', stderr);
266 fflush(stderr);
267 }
268 printf("FRAME=%d\n", seq);
269 }
270 fputs(VIEWSTR, stdout);
271 fprintview(&ourview, stdout);
272 putchar('\n');
273 if (pa < .99 || pa > 1.01)
274 fputaspect(pa, stdout);
275 fputformat(COLRFMT, stdout);
276 putchar('\n');
277 if (zout != NULL)
278 sprintf(cp=fbuf, zout, seq);
279 else
280 cp = NULL;
281 render(cp, prvr);
282 prvr = NULL;
283 } while (seq++);
284 }
285
286
287 nextview(fp) /* get next view from fp */
288 FILE *fp;
289 {
290 char linebuf[256];
291
292 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
293 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
294 return(0);
295 return(EOF);
296 }
297
298
299 render(zfile, oldfile) /* render the scene */
300 char *zfile, *oldfile;
301 {
302 extern long lseek();
303 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
304 float *zbar[MAXDIV+1]; /* z values */
305 char *sampdens; /* previous sample density */
306 int ypos; /* current scanline */
307 int ystep; /* current y step size */
308 int hstep; /* h step size */
309 int zfd;
310 COLOR *colptr;
311 float *zptr;
312 register int i;
313 /* allocate scanlines */
314 for (i = 0; i <= psample; i++) {
315 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
316 if (scanbar[i] == NULL)
317 goto memerr;
318 }
319 hstep = (psample*140+49)/99; /* quincunx sampling */
320 ystep = (psample*99+70)/140;
321 if (hstep > 2) {
322 i = hres/hstep + 2;
323 if ((sampdens = malloc(i)) == NULL)
324 goto memerr;
325 while (i--)
326 sampdens[i] = hstep;
327 } else
328 sampdens = NULL;
329 /* open z file */
330 if (zfile != NULL) {
331 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
332 sprintf(errmsg, "cannot open z file \"%s\"", zfile);
333 error(SYSTEM, errmsg);
334 }
335 #ifdef MSDOS
336 setmode(zfd, O_BINARY);
337 #endif
338 for (i = 0; i <= psample; i++) {
339 zbar[i] = (float *)malloc(hres*sizeof(float));
340 if (zbar[i] == NULL)
341 goto memerr;
342 }
343 } else {
344 zfd = -1;
345 for (i = 0; i <= psample; i++)
346 zbar[i] = NULL;
347 }
348 /* write out boundaries */
349 fprtresolu(hres, vres, stdout);
350 /* recover file and compute first */
351 i = salvage(oldfile);
352 if (zfd != -1 && i > 0 &&
353 lseek(zfd, (long)i*hres*sizeof(float), 0) == -1)
354 error(SYSTEM, "z file seek error in render");
355 pctdone = 100.0*i/vres;
356 if (ralrm > 0) /* report init stats */
357 report();
358 #ifndef BSD
359 else
360 #endif
361 signal(SIGALRM, report);
362 ypos = vres-1 - i;
363 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
364 /* compute scanlines */
365 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
366 /* bottom adjust? */
367 if (ypos < 0) {
368 ystep += ypos;
369 ypos = 0;
370 }
371 colptr = scanbar[ystep]; /* move base to top */
372 scanbar[ystep] = scanbar[0];
373 scanbar[0] = colptr;
374 zptr = zbar[ystep];
375 zbar[ystep] = zbar[0];
376 zbar[0] = zptr;
377 /* fill base line */
378 fillscanline(scanbar[0], zbar[0], sampdens,
379 hres, ypos, hstep);
380 /* fill bar */
381 fillscanbar(scanbar, zbar, hres, ypos, ystep);
382 /* write it out */
383 #ifndef BSD
384 signal(SIGALRM, SIG_IGN); /* don't interrupt writes */
385 #endif
386 for (i = ystep; i > 0; i--) {
387 if (zfd != -1 && write(zfd, (char *)zbar[i],
388 hres*sizeof(float))
389 < hres*sizeof(float))
390 goto writerr;
391 if (fwritescan(scanbar[i], hres, stdout) < 0)
392 goto writerr;
393 }
394 if (fflush(stdout) == EOF)
395 goto writerr;
396 /* record progress */
397 pctdone = 100.0*(vres-1-ypos)/vres;
398 if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm)
399 report();
400 #ifndef BSD
401 else
402 signal(SIGALRM, report);
403 #endif
404 }
405 /* clean up */
406 signal(SIGALRM, SIG_IGN);
407 if (zfd != -1) {
408 if (write(zfd, (char *)zbar[0], hres*sizeof(float))
409 < hres*sizeof(float))
410 goto writerr;
411 if (close(zfd) == -1)
412 goto writerr;
413 for (i = 0; i <= psample; i++)
414 free((char *)zbar[i]);
415 }
416 fwritescan(scanbar[0], hres, stdout);
417 if (fflush(stdout) == EOF)
418 goto writerr;
419 for (i = 0; i <= psample; i++)
420 free((char *)scanbar[i]);
421 if (sampdens != NULL)
422 free(sampdens);
423 pctdone = 100.0;
424 if (ralrm > 0)
425 report();
426 return;
427 writerr:
428 error(SYSTEM, "write error in render");
429 memerr:
430 error(SYSTEM, "out of memory in render");
431 }
432
433
434 fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */
435 register COLOR *scanline;
436 register float *zline;
437 register char *sd;
438 int xres, y, xstep;
439 {
440 static int nc = 0; /* number of calls */
441 int bl = xstep, b = xstep;
442 double z;
443 register int i;
444
445 z = pixvalue(scanline[0], 0, y);
446 if (zline) zline[0] = z;
447 /* zig-zag start for quincunx pattern */
448 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
449 if (i >= xres) {
450 xstep += xres-1-i;
451 i = xres-1;
452 }
453 z = pixvalue(scanline[i], i, y);
454 if (zline) zline[i] = z;
455 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
456 if (i <= xstep)
457 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
458 else
459 b = fillsample(scanline+i-xstep,
460 zline ? zline+i-xstep : NULL,
461 i-xstep, y, xstep, 0, b/2);
462 if (sd) *sd++ = nc & 1 ? bl : b;
463 bl = b;
464 }
465 if (sd && nc & 1) *sd = bl;
466 }
467
468
469 fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
470 register COLOR *scanbar[];
471 register float *zbar[];
472 int xres, y, ysize;
473 {
474 COLOR vline[MAXDIV+1];
475 float zline[MAXDIV+1];
476 int b = ysize;
477 register int i, j;
478
479 for (i = 0; i < xres; i++) {
480
481 copycolor(vline[0], scanbar[0][i]);
482 copycolor(vline[ysize], scanbar[ysize][i]);
483 if (zbar[0]) {
484 zline[0] = zbar[0][i];
485 zline[ysize] = zbar[ysize][i];
486 }
487
488 b = fillsample(vline, zbar[0] ? zline : NULL,
489 i, y, 0, ysize, b/2);
490
491 for (j = 1; j < ysize; j++)
492 copycolor(scanbar[j][i], vline[j]);
493 if (zbar[0])
494 for (j = 1; j < ysize; j++)
495 zbar[j][i] = zline[j];
496 }
497 }
498
499
500 int
501 fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
502 register COLOR *colline;
503 register float *zline;
504 int x, y;
505 int xlen, ylen;
506 int b;
507 {
508 double ratio;
509 double z;
510 COLOR ctmp;
511 int ncut;
512 register int len;
513
514 if (xlen > 0) /* x or y length is zero */
515 len = xlen;
516 else
517 len = ylen;
518
519 if (len <= 1) /* limit recursion */
520 return(0);
521
522 if (b > 0
523 || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
524 || bigdiff(colline[0], colline[len], maxdiff)) {
525
526 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
527 if (zline) zline[len>>1] = z;
528 ncut = 1;
529
530 } else { /* interpolate */
531
532 copycolor(colline[len>>1], colline[len]);
533 ratio = (double)(len>>1) / len;
534 scalecolor(colline[len>>1], ratio);
535 if (zline) zline[len>>1] = zline[len] * ratio;
536 ratio = 1.0 - ratio;
537 copycolor(ctmp, colline[0]);
538 scalecolor(ctmp, ratio);
539 addcolor(colline[len>>1], ctmp);
540 if (zline) zline[len>>1] += zline[0] * ratio;
541 ncut = 0;
542 }
543 /* recurse */
544 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
545
546 ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL,
547 x+(xlen>>1), y+(ylen>>1),
548 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
549
550 return(ncut);
551 }
552
553
554 double
555 pixvalue(col, x, y) /* compute pixel value */
556 COLOR col; /* returned color */
557 int x, y; /* pixel position */
558 {
559 static RAY thisray;
560
561 if (viewray(thisray.rorg, thisray.rdir, &ourview,
562 (x+pixjitter())/hres, (y+pixjitter())/vres) < 0) {
563 setcolor(col, 0.0, 0.0, 0.0);
564 return(0.0);
565 }
566
567 rayorigin(&thisray, NULL, PRIMARY, 1.0);
568
569 samplendx = pixnumber(x,y,hres,vres); /* set pixel index */
570
571 rayvalue(&thisray); /* trace ray */
572
573 copycolor(col, thisray.rcol); /* return color */
574
575 return(thisray.rt); /* return distance */
576 }
577
578
579 int
580 salvage(oldfile) /* salvage scanlines from killed program */
581 char *oldfile;
582 {
583 COLR *scanline;
584 FILE *fp;
585 int x, y;
586
587 if (oldfile == NULL)
588 return(0);
589
590 if ((fp = fopen(oldfile, "r")) == NULL) {
591 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
592 error(WARNING, errmsg);
593 return(0);
594 }
595 #ifdef MSDOS
596 setmode(fileno(fp), O_BINARY);
597 #endif
598 /* discard header */
599 getheader(fp, NULL);
600 /* get picture size */
601 if (!fscnresolu(&x, &y, fp)) {
602 sprintf(errmsg, "bad recover file \"%s\"", oldfile);
603 error(WARNING, errmsg);
604 fclose(fp);
605 return(0);
606 }
607
608 if (x != hres || y != vres) {
609 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
610 oldfile);
611 error(USER, errmsg);
612 }
613
614 scanline = (COLR *)malloc(hres*sizeof(COLR));
615 if (scanline == NULL)
616 error(SYSTEM, "out of memory in salvage");
617 for (y = 0; y < vres; y++) {
618 if (freadcolrs(scanline, hres, fp) < 0)
619 break;
620 if (fwritecolrs(scanline, hres, stdout) < 0)
621 goto writerr;
622 }
623 if (fflush(stdout) == EOF)
624 goto writerr;
625 free((char *)scanline);
626 fclose(fp);
627 unlink(oldfile);
628 return(y);
629 writerr:
630 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
631 error(SYSTEM, errmsg);
632 }
633
634
635 int
636 pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
637 register int x, y;
638 int xres, yres;
639 {
640 x -= y;
641 while (x < 0)
642 x += xres;
643 return((((x>>2)*yres + y) << 2) + (x & 3));
644 }
