root/radiance/ray/src/rt/rpict.c
Revision: 2.17
Committed: Thu Oct 15 21:13:17 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.16: +12 -0 lines
added setmode(fd,O_BINARY) where needed for MSDOS
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rpict.c - routines and variables for picture generation.
9 *
10 * 8/14/85
11 */
12
13 #include "ray.h"
14
15 #ifdef BSD
16 #include <sys/time.h>
17 #include <sys/resource.h>
18 #endif
19
20 #include <signal.h>
21
22 #include "view.h"
23
24 #include "resolu.h"
25
26 #include "random.h"
27
28 #include "paths.h"
29
30 int dimlist[MAXDIM]; /* sampling dimensions */
31 int ndims = 0; /* number of sampling dimensions */
32 int samplendx; /* sample index number */
33
34 VIEW ourview = STDVIEW; /* view parameters */
35 int hresolu = 512; /* horizontal resolution */
36 int vresolu = 512; /* vertical resolution */
37 double pixaspect = 1.0; /* pixel aspect ratio */
38
39 int psample = 4; /* pixel sample size */
40 double maxdiff = .05; /* max. difference for interpolation */
41 double dstrpix = 0.67; /* square pixel distribution */
42
43 double dstrsrc = 0.0; /* square source distribution */
44 double shadthresh = .05; /* shadow threshold */
45 double shadcert = .5; /* shadow certainty */
46 int directrelay = 1; /* number of source relays */
47 int vspretest = 512; /* virtual source pretest density */
48 int directinvis = 0; /* sources invisible? */
49 double srcsizerat = .25; /* maximum ratio source size/dist. */
50
51 double specthresh = .15; /* specular sampling threshold */
52 double specjitter = 1.; /* specular sampling jitter */
53
54 int maxdepth = 6; /* maximum recursion depth */
55 double minweight = 5e-3; /* minimum ray weight */
56
57 COLOR ambval = BLKCOLOR; /* ambient value */
58 double ambacc = 0.2; /* ambient accuracy */
59 int ambres = 32; /* ambient resolution */
60 int ambdiv = 128; /* ambient divisions */
61 int ambssamp = 0; /* ambient super-samples */
62 int ambounce = 0; /* ambient bounces */
63 char *amblist[128]; /* ambient include/exclude list */
64 int ambincl = -1; /* include == 1, exclude == 0 */
65
66 #ifdef MSDOS
67 int ralrm = 60; /* seconds between reports */
68 #else
69 int ralrm = 0; /* seconds between reports */
70 #endif
71
72 double pctdone = 0.0; /* percentage done */
73
74 long tlastrept = 0L; /* time at last report */
75
76 extern long time();
77 extern long tstart; /* starting time */
78
79 extern long nrays; /* number of rays traced */
80
81 #define MAXDIV 16 /* maximum sample size */
82
83 #define pixjitter() (.5+dstrpix*(.5-frandom()))
84
85 #define RFTEMPLATE "rfXXXXXX"
86 #define HFTEMPLATE TEMPLATE
87
88 static char *hfname = NULL; /* header file name */
89 static FILE *hfp = NULL; /* header file pointer */
90
91 static int hres, vres; /* resolution for this frame */
92
93 extern char *mktemp();
94
95 double pixvalue();
96
97
98 quit(code) /* quit program */
99 int code;
100 {
101 if (code) /* report status */
102 report();
103 if (hfname != NULL) { /* delete header file */
104 if (hfp != NULL)
105 fclose(hfp);
106 unlink(hfname);
107 }
108 exit(code);
109 }
110
111
112 #ifdef BSD
113 report() /* report progress */
114 {
115 struct rusage rubuf;
116 double t;
117
118 getrusage(RUSAGE_SELF, &rubuf);
119 t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
120 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
121 getrusage(RUSAGE_CHILDREN, &rubuf);
122 t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
123 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
124
125 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n",
126 nrays, pctdone, t/3600.0);
127 eputs(errmsg);
128 tlastrept = time((long *)0);
129 }
130 #else
131 report() /* report progress */
132 {
133 tlastrept = time((long *)0);
134 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n",
135 nrays, pctdone, (tlastrept-tstart)/3600.0);
136 eputs(errmsg);
137 signal(SIGALRM, report);
138 }
139 #endif
140
141
142 openheader() /* save standard output to header file */
143 {
144 hfname = mktemp(HFTEMPLATE);
145 if (freopen(hfname, "w", stdout) == NULL) {
146 sprintf(errmsg, "cannot open header file \"%s\"", hfname);
147 error(SYSTEM, errmsg);
148 }
149 }
150
151
152 closeheader() /* done with header output */
153 {
154 if (hfname == NULL)
155 return;
156 if (fflush(stdout) == EOF || (hfp = fopen(hfname, "r")) == NULL)
157 error(SYSTEM, "error reopening header file");
158 #ifdef MSDOS
159 setmode(fileno(hfp), O_BINARY);
160 #endif
161 }
162
163
164 dupheader() /* repeat header on standard output */
165 {
166 register int c;
167
168 if (fseek(hfp, 0L, 0) < 0)
169 error(SYSTEM, "seek error on header file");
170 while ((c = getc(hfp)) != EOF)
171 putchar(c);
172 }
173
174
175 rpict(seq, pout, zout, prvr) /* generate image(s) */
176 int seq;
177 char *pout, *zout, *prvr;
178 /*
179 * If seq is greater than zero, then we will render a sequence of
180 * images based on view parameter strings read from the standard input.
181 * If pout is NULL, then all images will be sent to the standard ouput.
182 * If seq is greater than zero and prvr is an integer, then it is the
183 * frame number at which rendering should begin. Preceeding view parameter
184 * strings will be skipped in the input.
185 * If pout and prvr are the same, prvr is renamed to avoid overwriting.
186 * Note that pout and zout should contain %d format specifications for
187 * sequenced file naming.
188 */
189 {
190 extern char *rindex(), *strncpy(), *strcat();
191 char fbuf[128], fbuf2[128];
192 register char *cp;
193 RESOLU rs;
194 double pa;
195 /* finished writing header */
196 closeheader();
197 /* check sampling */
198 if (psample < 1)
199 psample = 1;
200 else if (psample > MAXDIV) {
201 sprintf(errmsg, "pixel sampling reduced from %d to %d",
202 psample, MAXDIV);
203 error(WARNING, errmsg);
204 psample = MAXDIV;
205 }
206 /* get starting frame */
207 if (seq <= 0)
208 seq = 0;
209 else if (prvr != NULL && isint(prvr)) {
210 register int rn; /* skip to specified view */
211 if ((rn = atoi(prvr)) < seq)
212 error(USER, "recover frame less than start frame");
213 if (pout == NULL)
214 error(USER, "missing output file specification");
215 for ( ; seq < rn; seq++)
216 if (nextview(stdin) == EOF)
217 error(USER, "unexpected EOF on view input");
218 prvr = fbuf; /* mark for renaming */
219 }
220 if (pout != NULL) {
221 sprintf(fbuf, pout, seq);
222 if (prvr != NULL && !strcmp(prvr, fbuf)) { /* rename */
223 fbuf2[0] = '\0';
224 if ((cp = rindex(fbuf, '/')) != NULL)
225 strncpy(fbuf2, fbuf, cp-fbuf+1);
226 strcat(fbuf2, RFTEMPLATE);
227 prvr = mktemp(fbuf2);
228 if (rename(fbuf, prvr) < 0 && errno != ENOENT) {
229 sprintf(errmsg,
230 "cannot rename \"%s\" to \"%s\"",
231 fbuf, prvr);
232 error(SYSTEM, errmsg);
233 }
234 }
235 }
236 /* render sequence */
237 do {
238 if (seq && nextview(stdin) == EOF)
239 break;
240 if (pout != NULL) {
241 sprintf(fbuf, pout, seq);
242 if (freopen(fbuf, "w", stdout) == NULL) {
243 sprintf(errmsg,
244 "cannot open output file \"%s\"", fbuf);
245 error(SYSTEM, errmsg);
246 }
247 #ifdef MSDOS
248 setmode(fileno(stdout), O_BINARY);
249 #endif
250 dupheader();
251 }
252 hres = hresolu; vres = vresolu; pa = pixaspect;
253 if (prvr != NULL)
254 if (viewfile(prvr, &ourview, &rs) <= 0
255 || rs.or != PIXSTANDARD) {
256 sprintf(errmsg,
257 "cannot recover view parameters from \"%s\"", prvr);
258 error(WARNING, errmsg);
259 } else {
260 pa = 0.0;
261 hres = scanlen(&rs);
262 vres = numscans(&rs);
263 }
264 if ((cp = setview(&ourview)) != NULL)
265 error(USER, cp);
266 normaspect(viewaspect(&ourview), &pa, &hres, &vres);
267 if (seq) {
268 if (ralrm > 0) {
269 fprintf(stderr, "FRAME %d:", seq);
270 fprintview(&ourview, stderr);
271 putc('\n', stderr);
272 fflush(stderr);
273 }
274 printf("FRAME=%d\n", seq);
275 }
276 fputs(VIEWSTR, stdout);
277 fprintview(&ourview, stdout);
278 putchar('\n');
279 if (pa < .99 || pa > 1.01)
280 fputaspect(pa, stdout);
281 fputformat(COLRFMT, stdout);
282 putchar('\n');
283 if (zout != NULL)
284 sprintf(cp=fbuf, zout, seq);
285 else
286 cp = NULL;
287 render(cp, prvr);
288 prvr = NULL;
289 } while (seq++);
290 }
291
292
293 nextview(fp) /* get next view from fp */
294 FILE *fp;
295 {
296 char linebuf[256];
297
298 while (fgets(linebuf, sizeof(linebuf), fp) != NULL)
299 if (isview(linebuf) && sscanview(&ourview, linebuf) > 0)
300 return(0);
301 return(EOF);
302 }
303
304
305 render(zfile, oldfile) /* render the scene */
306 char *zfile, *oldfile;
307 {
308 extern long lseek();
309 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
310 float *zbar[MAXDIV+1]; /* z values */
311 char *sampdens; /* previous sample density */
312 int ypos; /* current scanline */
313 int ystep; /* current y step size */
314 int hstep; /* h step size */
315 int zfd;
316 COLOR *colptr;
317 float *zptr;
318 register int i;
319 /* allocate scanlines */
320 for (i = 0; i <= psample; i++) {
321 scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR));
322 if (scanbar[i] == NULL)
323 goto memerr;
324 }
325 hstep = (psample*140+49)/99; /* quincunx sampling */
326 ystep = (psample*99+70)/140;
327 if (hstep > 2) {
328 i = hres/hstep + 2;
329 if ((sampdens = malloc(i)) == NULL)
330 goto memerr;
331 while (i--)
332 sampdens[i] = hstep;
333 } else
334 sampdens = NULL;
335 /* open z file */
336 if (zfile != NULL) {
337 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
338 sprintf(errmsg, "cannot open z file \"%s\"", zfile);
339 error(SYSTEM, errmsg);
340 }
341 #ifdef MSDOS
342 setmode(zfd, O_BINARY);
343 #endif
344 for (i = 0; i <= psample; i++) {
345 zbar[i] = (float *)malloc(hres*sizeof(float));
346 if (zbar[i] == NULL)
347 goto memerr;
348 }
349 } else {
350 zfd = -1;
351 for (i = 0; i <= psample; i++)
352 zbar[i] = NULL;
353 }
354 /* write out boundaries */
355 fprtresolu(hres, vres, stdout);
356 /* recover file and compute first */
357 i = salvage(oldfile);
358 if (zfd != -1 && i > 0 &&
359 lseek(zfd, (long)i*hres*sizeof(float), 0) == -1)
360 error(SYSTEM, "z file seek error in render");
361 pctdone = 100.0*i/vres;
362 if (ralrm > 0) /* report init stats */
363 report();
364 #ifndef BSD
365 else
366 #endif
367 signal(SIGALRM, report);
368 ypos = vres-1 - i;
369 fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep);
370 /* compute scanlines */
371 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
372 /* bottom adjust? */
373 if (ypos < 0) {
374 ystep += ypos;
375 ypos = 0;
376 }
377 colptr = scanbar[ystep]; /* move base to top */
378 scanbar[ystep] = scanbar[0];
379 scanbar[0] = colptr;
380 zptr = zbar[ystep];
381 zbar[ystep] = zbar[0];
382 zbar[0] = zptr;
383 /* fill base line */
384 fillscanline(scanbar[0], zbar[0], sampdens,
385 hres, ypos, hstep);
386 /* fill bar */
387 fillscanbar(scanbar, zbar, hres, ypos, ystep);
388 /* write it out */
389 #ifndef BSD
390 signal(SIGALRM, SIG_IGN); /* don't interrupt writes */
391 #endif
392 for (i = ystep; i > 0; i--) {
393 if (zfd != -1 && write(zfd, (char *)zbar[i],
394 hres*sizeof(float))
395 < hres*sizeof(float))
396 goto writerr;
397 if (fwritescan(scanbar[i], hres, stdout) < 0)
398 goto writerr;
399 }
400 if (fflush(stdout) == EOF)
401 goto writerr;
402 /* record progress */
403 pctdone = 100.0*(vres-1-ypos)/vres;
404 if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm)
405 report();
406 #ifndef BSD
407 else
408 signal(SIGALRM, report);
409 #endif
410 }
411 /* clean up */
412 signal(SIGALRM, SIG_IGN);
413 if (zfd != -1) {
414 if (write(zfd, (char *)zbar[0], hres*sizeof(float))
415 < hres*sizeof(float))
416 goto writerr;
417 if (close(zfd) == -1)
418 goto writerr;
419 for (i = 0; i <= psample; i++)
420 free((char *)zbar[i]);
421 }
422 fwritescan(scanbar[0], hres, stdout);
423 if (fflush(stdout) == EOF)
424 goto writerr;
425 for (i = 0; i <= psample; i++)
426 free((char *)scanbar[i]);
427 if (sampdens != NULL)
428 free(sampdens);
429 pctdone = 100.0;
430 if (ralrm > 0)
431 report();
432 return;
433 writerr:
434 error(SYSTEM, "write error in render");
435 memerr:
436 error(SYSTEM, "out of memory in render");
437 }
438
439
440 fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */
441 register COLOR *scanline;
442 register float *zline;
443 register char *sd;
444 int xres, y, xstep;
445 {
446 static int nc = 0; /* number of calls */
447 int bl = xstep, b = xstep;
448 double z;
449 register int i;
450
451 z = pixvalue(scanline[0], 0, y);
452 if (zline) zline[0] = z;
453 /* zig-zag start for quincunx pattern */
454 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
455 if (i >= xres) {
456 xstep += xres-1-i;
457 i = xres-1;
458 }
459 z = pixvalue(scanline[i], i, y);
460 if (zline) zline[i] = z;
461 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
462 if (i <= xstep)
463 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
464 else
465 b = fillsample(scanline+i-xstep,
466 zline ? zline+i-xstep : NULL,
467 i-xstep, y, xstep, 0, b/2);
468 if (sd) *sd++ = nc & 1 ? bl : b;
469 bl = b;
470 }
471 if (sd && nc & 1) *sd = bl;
472 }
473
474
475 fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
476 register COLOR *scanbar[];
477 register float *zbar[];
478 int xres, y, ysize;
479 {
480 COLOR vline[MAXDIV+1];
481 float zline[MAXDIV+1];
482 int b = ysize;
483 register int i, j;
484
485 for (i = 0; i < xres; i++) {
486
487 copycolor(vline[0], scanbar[0][i]);
488 copycolor(vline[ysize], scanbar[ysize][i]);
489 if (zbar[0]) {
490 zline[0] = zbar[0][i];
491 zline[ysize] = zbar[ysize][i];
492 }
493
494 b = fillsample(vline, zbar[0] ? zline : NULL,
495 i, y, 0, ysize, b/2);
496
497 for (j = 1; j < ysize; j++)
498 copycolor(scanbar[j][i], vline[j]);
499 if (zbar[0])
500 for (j = 1; j < ysize; j++)
501 zbar[j][i] = zline[j];
502 }
503 }
504
505
506 int
507 fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
508 register COLOR *colline;
509 register float *zline;
510 int x, y;
511 int xlen, ylen;
512 int b;
513 {
514 double ratio;
515 double z;
516 COLOR ctmp;
517 int ncut;
518 register int len;
519
520 if (xlen > 0) /* x or y length is zero */
521 len = xlen;
522 else
523 len = ylen;
524
525 if (len <= 1) /* limit recursion */
526 return(0);
527
528 if (b > 0
529 || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
530 || bigdiff(colline[0], colline[len], maxdiff)) {
531
532 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
533 if (zline) zline[len>>1] = z;
534 ncut = 1;
535
536 } else { /* interpolate */
537
538 copycolor(colline[len>>1], colline[len]);
539 ratio = (double)(len>>1) / len;
540 scalecolor(colline[len>>1], ratio);
541 if (zline) zline[len>>1] = zline[len] * ratio;
542 ratio = 1.0 - ratio;
543 copycolor(ctmp, colline[0]);
544 scalecolor(ctmp, ratio);
545 addcolor(colline[len>>1], ctmp);
546 if (zline) zline[len>>1] += zline[0] * ratio;
547 ncut = 0;
548 }
549 /* recurse */
550 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
551
552 ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL,
553 x+(xlen>>1), y+(ylen>>1),
554 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
555
556 return(ncut);
557 }
558
559
560 double
561 pixvalue(col, x, y) /* compute pixel value */
562 COLOR col; /* returned color */
563 int x, y; /* pixel position */
564 {
565 static RAY thisray;
566
567 if (viewray(thisray.rorg, thisray.rdir, &ourview,
568 (x+pixjitter())/hres, (y+pixjitter())/vres) < 0) {
569 setcolor(col, 0.0, 0.0, 0.0);
570 return(0.0);
571 }
572
573 rayorigin(&thisray, NULL, PRIMARY, 1.0);
574
575 samplendx = pixnumber(x,y,hres,vres); /* set pixel index */
576
577 rayvalue(&thisray); /* trace ray */
578
579 copycolor(col, thisray.rcol); /* return color */
580
581 return(thisray.rt); /* return distance */
582 }
583
584
585 int
586 salvage(oldfile) /* salvage scanlines from killed program */
587 char *oldfile;
588 {
589 COLR *scanline;
590 FILE *fp;
591 int x, y;
592
593 if (oldfile == NULL)
594 return(0);
595
596 if ((fp = fopen(oldfile, "r")) == NULL) {
597 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
598 error(WARNING, errmsg);
599 return(0);
600 }
601 #ifdef MSDOS
602 setmode(fileno(fp), O_BINARY);
603 #endif
604 /* discard header */
605 getheader(fp, NULL);
606 /* get picture size */
607 if (!fscnresolu(&x, &y, fp)) {
608 sprintf(errmsg, "bad recover file \"%s\"", oldfile);
609 error(WARNING, errmsg);
610 fclose(fp);
611 return(0);
612 }
613
614 if (x != hres || y != vres) {
615 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
616 oldfile);
617 error(USER, errmsg);
618 }
619
620 scanline = (COLR *)malloc(hres*sizeof(COLR));
621 if (scanline == NULL)
622 error(SYSTEM, "out of memory in salvage");
623 for (y = 0; y < vres; y++) {
624 if (freadcolrs(scanline, hres, fp) < 0)
625 break;
626 if (fwritecolrs(scanline, hres, stdout) < 0)
627 goto writerr;
628 }
629 if (fflush(stdout) == EOF)
630 goto writerr;
631 free((char *)scanline);
632 fclose(fp);
633 unlink(oldfile);
634 return(y);
635 writerr:
636 sprintf(errmsg, "write error during recovery of \"%s\"", oldfile);
637 error(SYSTEM, errmsg);
638 }
639
640
641 int
642 pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
643 register int x, y;
644 int xres, yres;
645 {
646 x -= y;
647 while (x < 0)
648 x += xres;
649 return((((x>>2)*yres + y) << 2) + (x & 3));
650 }
