root/radiance/ray/src/rt/rpict.c
Revision: 2.7
Committed: Wed Mar 11 09:32:40 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.6: +1 -0 lines
forgot to disable alarm signal before final writes
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rpict.c - routines and variables for picture generation.
9 *
10 * 8/14/85
11 */
12
13 #include "ray.h"
14
15 #ifdef BSD
16 #include <sys/time.h>
17 #include <sys/resource.h>
18 #endif
19
20 #include <signal.h>
21 #include <fcntl.h>
22
23 #include "view.h"
24
25 #include "resolu.h"
26
27 #include "random.h"
28
29 int dimlist[MAXDIM]; /* sampling dimensions */
30 int ndims = 0; /* number of sampling dimensions */
31 int samplendx; /* sample index number */
32
33 VIEW ourview = STDVIEW; /* view parameters */
34 int hresolu = 512; /* horizontal resolution */
35 int vresolu = 512; /* vertical resolution */
36 double pixaspect = 1.0; /* pixel aspect ratio */
37
38 int psample = 4; /* pixel sample size */
39 double maxdiff = .05; /* max. difference for interpolation */
40 double dstrpix = 0.67; /* square pixel distribution */
41
42 double dstrsrc = 0.0; /* square source distribution */
43 double shadthresh = .05; /* shadow threshold */
44 double shadcert = .5; /* shadow certainty */
45 int directrelay = 1; /* number of source relays */
46 int vspretest = 512; /* virtual source pretest density */
47 int directinvis = 0; /* sources invisible? */
48 double srcsizerat = .25; /* maximum ratio source size/dist. */
49
50 double specthresh = .15; /* specular sampling threshold */
51 double specjitter = 1.; /* specular sampling jitter */
52
53 int maxdepth = 6; /* maximum recursion depth */
54 double minweight = 5e-3; /* minimum ray weight */
55
56 COLOR ambval = BLKCOLOR; /* ambient value */
57 double ambacc = 0.2; /* ambient accuracy */
58 int ambres = 32; /* ambient resolution */
59 int ambdiv = 128; /* ambient divisions */
60 int ambssamp = 0; /* ambient super-samples */
61 int ambounce = 0; /* ambient bounces */
62 char *amblist[128]; /* ambient include/exclude list */
63 int ambincl = -1; /* include == 1, exclude == 0 */
64
65 int ralrm = 0; /* seconds between reports */
66
67 double pctdone = 0.0; /* percentage done */
68
69 long tlastrept = 0L; /* time at last report */
70
71 extern long time();
72 extern long tstart; /* starting time */
73
74 extern long nrays; /* number of rays traced */
75
76 #define MAXDIV 16 /* maximum sample size */
77
78 #define pixjitter() (.5+dstrpix*(.5-frandom()))
79
80 double pixvalue();
81
82
83 quit(code) /* quit program */
84 int code;
85 {
86 if (code || ralrm > 0) /* report status */
87 report();
88
89 exit(code);
90 }
91
92
93 #ifdef BSD
94 report() /* report progress */
95 {
96 struct rusage rubuf;
97 double t;
98
99 getrusage(RUSAGE_SELF, &rubuf);
100 t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
101 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
102 getrusage(RUSAGE_CHILDREN, &rubuf);
103 t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
104 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
105
106 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n",
107 nrays, pctdone, t/3600.0);
108 eputs(errmsg);
109 tlastrept = time((long *)0);
110 }
111 #else
112 report() /* report progress */
113 {
114 tlastrept = time((long *)0);
115 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n",
116 nrays, pctdone, (tlastrept-tstart)/3600.0);
117 eputs(errmsg);
118 signal(SIGALRM, report);
119 }
120 #endif
121
122
123 render(zfile, oldfile) /* render the scene */
124 char *zfile, *oldfile;
125 {
126 extern long lseek();
127 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
128 float *zbar[MAXDIV+1]; /* z values */
129 char *sampdens; /* previous sample density */
130 int ypos; /* current scanline */
131 int ystep; /* current y step size */
132 int hstep; /* h step size */
133 int zfd;
134 COLOR *colptr;
135 float *zptr;
136 register int i;
137 /* check sampling */
138 if (psample < 1)
139 psample = 1;
140 else if (psample > MAXDIV) {
141 sprintf(errmsg, "pixel sampling reduced from %d to %d",
142 psample, MAXDIV);
143 error(WARNING, errmsg);
144 psample = MAXDIV;
145 }
146 /* allocate scanlines */
147 for (i = 0; i <= psample; i++) {
148 scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR));
149 if (scanbar[i] == NULL)
150 goto memerr;
151 }
152 hstep = (psample*140+49)/99; /* quincunx sampling */
153 ystep = (psample*99+70)/140;
154 if (hstep > 2) {
155 i = hresolu/hstep + 2;
156 if ((sampdens = malloc(i)) == NULL)
157 goto memerr;
158 while (i--)
159 sampdens[i] = hstep;
160 } else
161 sampdens = NULL;
162 /* open z file */
163 if (zfile != NULL) {
164 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
165 sprintf(errmsg, "cannot open z file \"%s\"", zfile);
166 error(SYSTEM, errmsg);
167 }
168 for (i = 0; i <= psample; i++) {
169 zbar[i] = (float *)malloc(hresolu*sizeof(float));
170 if (zbar[i] == NULL)
171 goto memerr;
172 }
173 } else {
174 zfd = -1;
175 for (i = 0; i <= psample; i++)
176 zbar[i] = NULL;
177 }
178 /* write out boundaries */
179 fprtresolu(hresolu, vresolu, stdout);
180 /* recover file and compute first */
181 i = salvage(oldfile);
182 if (zfd != -1 && i > 0 &&
183 lseek(zfd, (long)i*hresolu*sizeof(float), 0) == -1)
184 error(SYSTEM, "z file seek error in render");
185 pctdone = 100.0*i/vresolu;
186 if (ralrm > 0) /* report init stats */
187 report();
188 #ifndef BSD
189 else
190 #endif
191 signal(SIGALRM, report);
192 ypos = vresolu-1 - i;
193 fillscanline(scanbar[0], zbar[0], sampdens, hresolu, ypos, hstep);
194 /* compute scanlines */
195 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
196 /* bottom adjust? */
197 if (ypos < 0) {
198 ystep += ypos;
199 ypos = 0;
200 }
201 colptr = scanbar[ystep]; /* move base to top */
202 scanbar[ystep] = scanbar[0];
203 scanbar[0] = colptr;
204 zptr = zbar[ystep];
205 zbar[ystep] = zbar[0];
206 zbar[0] = zptr;
207 /* fill base line */
208 fillscanline(scanbar[0], zbar[0], sampdens,
209 hresolu, ypos, hstep);
210 /* fill bar */
211 fillscanbar(scanbar, zbar, hresolu, ypos, ystep);
212 /* write it out */
213 #ifndef BSD
214 signal(SIGALRM, SIG_IGN); /* don't interrupt writes */
215 #endif
216 for (i = ystep; i > 0; i--) {
217 if (zfd != -1 && write(zfd, (char *)zbar[i],
218 hresolu*sizeof(float))
219 < hresolu*sizeof(float))
220 goto writerr;
221 if (fwritescan(scanbar[i], hresolu, stdout) < 0)
222 goto writerr;
223 }
224 if (fflush(stdout) == EOF)
225 goto writerr;
226 /* record progress */
227 pctdone = 100.0*(vresolu-1-ypos)/vresolu;
228 if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm)
229 report();
230 #ifndef BSD
231 else
232 signal(SIGALRM, report);
233 #endif
234 }
235 /* clean up */
236 signal(SIGALRM, SIG_IGN);
237 if (zfd != -1) {
238 if (write(zfd, (char *)zbar[0], hresolu*sizeof(float))
239 < hresolu*sizeof(float))
240 goto writerr;
241 if (close(zfd) == -1)
242 goto writerr;
243 for (i = 0; i <= psample; i++)
244 free((char *)zbar[i]);
245 }
246 fwritescan(scanbar[0], hresolu, stdout);
247 if (fflush(stdout) == EOF)
248 goto writerr;
249 for (i = 0; i <= psample; i++)
250 free((char *)scanbar[i]);
251 if (sampdens != NULL)
252 free(sampdens);
253 pctdone = 100.0;
254 return;
255 writerr:
256 error(SYSTEM, "write error in render");
257 memerr:
258 error(SYSTEM, "out of memory in render");
259 }
260
261
262 fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */
263 register COLOR *scanline;
264 register float *zline;
265 register char *sd;
266 int xres, y, xstep;
267 {
268 static int nc = 0; /* number of calls */
269 int bl = xstep, b = xstep;
270 double z;
271 register int i;
272
273 z = pixvalue(scanline[0], 0, y);
274 if (zline) zline[0] = z;
275 /* zig-zag start for quincunx pattern */
276 for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) {
277 if (i >= xres) {
278 xstep += xres-1-i;
279 i = xres-1;
280 }
281 z = pixvalue(scanline[i], i, y);
282 if (zline) zline[i] = z;
283 if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1];
284 if (i <= xstep)
285 b = fillsample(scanline, zline, 0, y, i, 0, b/2);
286 else
287 b = fillsample(scanline+i-xstep,
288 zline ? zline+i-xstep : NULL,
289 i-xstep, y, xstep, 0, b/2);
290 if (sd) *sd++ = nc & 1 ? bl : b;
291 bl = b;
292 }
293 if (sd && nc & 1) *sd = bl;
294 }
295
296
297 fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
298 register COLOR *scanbar[];
299 register float *zbar[];
300 int xres, y, ysize;
301 {
302 COLOR vline[MAXDIV+1];
303 float zline[MAXDIV+1];
304 int b = ysize;
305 register int i, j;
306
307 for (i = 0; i < xres; i++) {
308
309 copycolor(vline[0], scanbar[0][i]);
310 copycolor(vline[ysize], scanbar[ysize][i]);
311 if (zbar[0]) {
312 zline[0] = zbar[0][i];
313 zline[ysize] = zbar[ysize][i];
314 }
315
316 b = fillsample(vline, zbar[0] ? zline : NULL,
317 i, y, 0, ysize, b/2);
318
319 for (j = 1; j < ysize; j++)
320 copycolor(scanbar[j][i], vline[j]);
321 if (zbar[0])
322 for (j = 1; j < ysize; j++)
323 zbar[j][i] = zline[j];
324 }
325 }
326
327
328 int
329 fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
330 register COLOR *colline;
331 register float *zline;
332 int x, y;
333 int xlen, ylen;
334 int b;
335 {
336 extern double fabs();
337 double ratio;
338 double z;
339 COLOR ctmp;
340 int ncut;
341 register int len;
342
343 if (xlen > 0) /* x or y length is zero */
344 len = xlen;
345 else
346 len = ylen;
347
348 if (len <= 1) /* limit recursion */
349 return(0);
350
351 if (b > 0
352 || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
353 || bigdiff(colline[0], colline[len], maxdiff)) {
354
355 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
356 if (zline) zline[len>>1] = z;
357 ncut = 1;
358
359 } else { /* interpolate */
360
361 copycolor(colline[len>>1], colline[len]);
362 ratio = (double)(len>>1) / len;
363 scalecolor(colline[len>>1], ratio);
364 if (zline) zline[len>>1] = zline[len] * ratio;
365 ratio = 1.0 - ratio;
366 copycolor(ctmp, colline[0]);
367 scalecolor(ctmp, ratio);
368 addcolor(colline[len>>1], ctmp);
369 if (zline) zline[len>>1] += zline[0] * ratio;
370 ncut = 0;
371 }
372 /* recurse */
373 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
374
375 ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL,
376 x+(xlen>>1), y+(ylen>>1),
377 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
378
379 return(ncut);
380 }
381
382
383 double
384 pixvalue(col, x, y) /* compute pixel value */
385 COLOR col; /* returned color */
386 int x, y; /* pixel position */
387 {
388 static RAY thisray;
389
390 if (viewray(thisray.rorg, thisray.rdir, &ourview,
391 (x+pixjitter())/hresolu, (y+pixjitter())/vresolu) < 0) {
392 setcolor(col, 0.0, 0.0, 0.0);
393 return(0.0);
394 }
395
396 rayorigin(&thisray, NULL, PRIMARY, 1.0);
397
398 samplendx = pixnumber(x,y,hresolu,vresolu); /* set pixel index */
399
400 rayvalue(&thisray); /* trace ray */
401
402 copycolor(col, thisray.rcol); /* return color */
403
404 return(thisray.rt); /* return distance */
405 }
406
407
408 int
409 salvage(oldfile) /* salvage scanlines from killed program */
410 char *oldfile;
411 {
412 COLR *scanline;
413 FILE *fp;
414 int x, y;
415
416 if (oldfile == NULL)
417 return(0);
418
419 if ((fp = fopen(oldfile, "r")) == NULL) {
420 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
421 error(WARNING, errmsg);
422 return(0);
423 }
424 /* discard header */
425 getheader(fp, NULL);
426 /* get picture size */
427 if (!fscnresolu(&x, &y, fp)) {
428 sprintf(errmsg, "bad recover file \"%s\"", oldfile);
429 error(WARNING, errmsg);
430 fclose(fp);
431 return(0);
432 }
433
434 if (x != hresolu || y != vresolu) {
435 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
436 oldfile);
437 error(USER, errmsg);
438 }
439
440 scanline = (COLR *)malloc(hresolu*sizeof(COLR));
441 if (scanline == NULL)
442 error(SYSTEM, "out of memory in salvage");
443 for (y = 0; y < vresolu; y++) {
444 if (freadcolrs(scanline, hresolu, fp) < 0)
445 break;
446 if (fwritecolrs(scanline, hresolu, stdout) < 0)
447 goto writerr;
448 }
449 if (fflush(stdout) == EOF)
450 goto writerr;
451 free((char *)scanline);
452 fclose(fp);
453 unlink(oldfile);
454 return(y);
455 writerr:
456 error(SYSTEM, "write error in salvage");
457 }
458
459
460 int
461 pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
462 register int x, y;
463 int xres, yres;
464 {
465 x -= y;
466 while (x < 0)
467 x += xres;
468 return((((x>>2)*yres + y) << 2) + (x & 3));
469 }
