--- ray/src/rt/rpict.c 2011/02/25 06:51:50 2.84 +++ ray/src/rt/rpict.c 2013/03/21 00:03:09 2.86 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rpict.c,v 2.84 2011/02/25 06:51:50 greg Exp $"; +static const char RCSid[] = "$Id: rpict.c,v 2.86 2013/03/21 00:03:09 greg Exp $"; #endif /* * rpict.c - routines and variables for picture generation. @@ -236,7 +236,7 @@ rpict( /* generate image(s) */ { char fbuf[128], fbuf2[128]; int npicts; - register char *cp; + char *cp; RESOLU rs; double pa; /* check sampling */ @@ -252,7 +252,7 @@ rpict( /* generate image(s) */ if (seq <= 0) seq = 0; else if (prvr != NULL && isint(prvr)) { - register int rn; /* skip to specified view */ + int rn; /* skip to specified view */ if ((rn = atoi(prvr)) < seq) error(USER, "recover frame less than start frame"); if (pout == NULL) @@ -341,7 +341,7 @@ rpict( /* generate image(s) */ fputs(VIEWSTR, stdout); fprintview(&ourview, stdout); putchar('\n'); - if (pa < .99 || pa > 1.01) + if ((pa < .99) | (pa > 1.01)) fputaspect(pa, stdout); fputnow(stdout); fputformat(COLRFMT, stdout); @@ -390,9 +390,9 @@ render( /* render the scene */ int zfd; COLOR *colptr; float *zptr; - register int i; + int i; /* check for empty image */ - if (hres <= 0 || vres <= 0) { + if ((hres <= 0) | (vres <= 0)) { error(WARNING, "empty output picture"); fprtresolu(0, 0, stdout); return; @@ -436,7 +436,7 @@ render( /* render the scene */ i = salvage(oldfile); if (i >= vres) goto alldone; - if (zfd != -1 && i > 0 && + if ((zfd != -1) & (i > 0) && lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0) error(SYSTEM, "z-file seek error in render"); pctdone = 100.0*i/vres; @@ -530,9 +530,9 @@ memerr: static void fillscanline( /* fill scan at y */ - register COLOR *scanline, - register float *zline, - register char *sd, + COLOR *scanline, + float *zline, + char *sd, int xres, int y, int xstep @@ -541,7 +541,7 @@ fillscanline( /* fill scan at y */ static int nc = 0; /* number of calls */ int bl = xstep, b = xstep; double z; - register int i; + int i; z = pixvalue(scanline[0], 0, y); if (zline) zline[0] = z; @@ -569,8 +569,8 @@ fillscanline( /* fill scan at y */ static void fillscanbar( /* fill interior */ - register COLOR *scanbar[], - register float *zbar[], + COLOR *scanbar[], + float *zbar[], int xres, int y, int ysize @@ -579,7 +579,7 @@ fillscanbar( /* fill interior */ COLOR vline[MAXDIV+1]; float zline[MAXDIV+1]; int b = ysize; - register int i, j; + int i, j; for (i = 0; i < xres; i++) { copycolor(vline[0], scanbar[0][i]); @@ -602,8 +602,8 @@ fillscanbar( /* fill interior */ static int fillsample( /* fill interior points */ - register COLOR *colline, - register float *zline, + COLOR *colline, + float *zline, int x, int y, int xlen, @@ -615,7 +615,7 @@ fillsample( /* fill interior points */ double z; COLOR ctmp; int ncut; - register int len; + int len; if (xlen > 0) /* x or y length is zero */ len = xlen; @@ -663,25 +663,26 @@ pixvalue( /* compute pixel value */ int y ) { + extern void SDsquare2disk(double ds[2], double seedx, double seedy); RAY thisray; FVECT lorg, ldir; double hpos, vpos, vdist, lmax; - register int i; + int i; /* compute view ray */ + setcolor(col, 0.0, 0.0, 0.0); hpos = (x+pixjitter())/hres; vpos = (y+pixjitter())/vres; if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, - &ourview, hpos, vpos)) < -FTINY) { - setcolor(col, 0.0, 0.0, 0.0); + &ourview, hpos, vpos)) < -FTINY) return(0.0); - } + vdist = ourview.vdist; /* set pixel index */ samplendx = pixnumber(x,y,hres,vres); /* optional motion blur */ if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir, &lastview, hpos, vpos)) >= -FTINY) { - register double d = mblur*(.5-urand(281+samplendx)); + double d = mblur*(.5-urand(281+samplendx)); thisray.rmax = (1.-d)*thisray.rmax + d*lmax; for (i = 3; i--; ) { @@ -693,33 +694,35 @@ pixvalue( /* compute pixel value */ vdist = (1.-d)*vdist + d*lastview.vdist; } /* optional depth-of-field */ - if (dblur > FTINY && vdist > FTINY) { - double vc, dfh, dfv; - /* square/circle conv. */ - dfh = vc = 1. - 2.*frandom(); - dfv = 1. - 2.*frandom(); - dfh *= .5*dblur*sqrt(1. - .5*dfv*dfv); - dfv *= .5*dblur*sqrt(1. - .5*vc*vc); - if (ourview.type == VT_PER || ourview.type == VT_PAR) { - dfh /= sqrt(ourview.hn2); - dfv /= sqrt(ourview.vn2); + if (dblur > FTINY) { + double vc, df[2]; + /* random point on disk */ + SDsquare2disk(df, frandom(), frandom()); + df[0] *= .5*dblur; + df[1] *= .5*dblur; + if ((ourview.type == VT_PER) | (ourview.type == VT_PAR)) { + double adj = 1.0; + if (ourview.type == VT_PER) + adj /= DOT(thisray.rdir, ourview.vdir); + df[0] /= sqrt(ourview.hn2); + df[1] /= sqrt(ourview.vn2); for (i = 3; i--; ) { - vc = thisray.rorg[i] + vdist*thisray.rdir[i]; - thisray.rorg[i] += dfh*ourview.hvec[i] + - dfv*ourview.vvec[i] ; + vc = ourview.vp[i] + adj*vdist*thisray.rdir[i]; + thisray.rorg[i] += df[0]*ourview.hvec[i] + + df[1]*ourview.vvec[i] ; thisray.rdir[i] = vc - thisray.rorg[i]; } } else { /* non-standard view case */ double dfd = PI/4.*dblur*(.5 - frandom()); - if (ourview.type != VT_ANG && ourview.type != VT_PLS) { + if ((ourview.type != VT_ANG) & (ourview.type != VT_PLS)) { if (ourview.type != VT_CYL) - dfh /= sqrt(ourview.hn2); - dfv /= sqrt(ourview.vn2); + df[0] /= sqrt(ourview.hn2); + df[1] /= sqrt(ourview.vn2); } for (i = 3; i--; ) { - vc = thisray.rorg[i] + vdist*thisray.rdir[i]; - thisray.rorg[i] += dfh*ourview.hvec[i] + - dfv*ourview.vvec[i] + + vc = ourview.vp[i] + vdist*thisray.rdir[i]; + thisray.rorg[i] += df[0]*ourview.hvec[i] + + df[1]*ourview.vvec[i] + dfd*ourview.vdir[i] ; thisray.rdir[i] = vc - thisray.rorg[i]; } @@ -767,7 +770,7 @@ salvage( /* salvage scanlines from killed program */ goto gotzip; } - if (x != hres || y != vres) { + if ((x != hres) | (y != vres)) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); @@ -800,8 +803,8 @@ writerr: static int pixnumber( /* compute pixel index (brushed) */ - register int x, - register int y, + int x, + int y, int xres, int yres )
