--- ray/src/rt/rpict.c 1990/01/12 09:27:11 1.15 +++ ray/src/rt/rpict.c 2003/06/05 19:29:34 2.55 @@ -1,46 +1,91 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id"; #endif - /* * rpict.c - routines and variables for picture generation. - * - * 8/14/85 */ +#include "copyright.h" + #include "ray.h" +#include + +#ifndef NIX #ifdef BSD #include #include #else -#include +#include +#include #endif +#endif -#include "view.h" +#include +#include +#include "platform.h" +#include "view.h" #include "random.h" +#include "paths.h" + +#define RFTEMPLATE "rfXXXXXX" + +#ifndef SIGCONT +#define SIGCONT SIGIO +#endif + +CUBE thescene; /* our scene */ +OBJECT nsceneobjs; /* number of objects in our scene */ + +int dimlist[MAXDIM]; /* sampling dimensions */ +int ndims = 0; /* number of sampling dimensions */ +int samplendx; /* sample index number */ + +extern void ambnotify(); +void (*addobjnotify[])() = {ambnotify, NULL}; + VIEW ourview = STDVIEW; /* view parameters */ int hresolu = 512; /* horizontal resolution */ int vresolu = 512; /* vertical resolution */ -double pixaspect = 1.0; /* pixel aspect ratio */ +double pixaspect = 1.0; /* pixel aspect ratio */ int psample = 4; /* pixel sample size */ -double maxdiff = .05; /* max. difference for interpolation */ -double dstrpix = 0.67; /* square pixel distribution */ +double maxdiff = .05; /* max. difference for interpolation */ +double dstrpix = 0.67; /* square pixel distribution */ -double dstrsrc = 0.0; /* square source distribution */ -double shadthresh = .05; /* shadow threshold */ -double shadcert = .5; /* shadow certainty */ +double mblur = 0.; /* motion blur parameter */ +void (*trace)() = NULL; /* trace call */ + +int do_irrad = 0; /* compute irradiance? */ + +double dstrsrc = 0.0; /* square source distribution */ +double shadthresh = .05; /* shadow threshold */ +double shadcert = .5; /* shadow certainty */ +int directrelay = 1; /* number of source relays */ +int vspretest = 512; /* virtual source pretest density */ +int directvis = 1; /* sources visible? */ +double srcsizerat = .25; /* maximum ratio source size/dist. */ + +COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ +COLOR salbedo = BLKCOLOR; /* global scattering albedo */ +double seccg = 0.; /* global scattering eccentricity */ +double ssampdist = 0.; /* scatter sampling distance */ + +double specthresh = .15; /* specular sampling threshold */ +double specjitter = 1.; /* specular sampling jitter */ + +int backvis = 1; /* back face visibility */ + int maxdepth = 6; /* maximum recursion depth */ -double minweight = 5e-3; /* minimum ray weight */ +double minweight = 5e-3; /* minimum ray weight */ +char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ -double ambacc = 0.2; /* ambient accuracy */ +int ambvwt = 0; /* initial weight for ambient value */ +double ambacc = 0.2; /* ambient accuracy */ int ambres = 32; /* ambient resolution */ int ambdiv = 128; /* ambient divisions */ int ambssamp = 0; /* ambient super-samples */ @@ -50,104 +95,334 @@ int ambincl = -1; /* include == 1, exclude == 0 */ int ralrm = 0; /* seconds between reports */ -double pctdone = 0.0; /* percentage done */ +double pctdone = 0.0; /* percentage done */ +time_t tlastrept = 0L; /* time at last report */ +time_t tstart; /* starting time */ -extern long nrays; /* number of rays traced */ +#define MAXDIV 16 /* maximum sample size */ -#define MAXDIV 32 /* maximum sample size */ +#define pixjitter() (.5+dstrpix*(.5-frandom())) -#define pixjitter() (.5+dstrpix*(.5-frandom())) +int hres, vres; /* resolution for this frame */ -double pixvalue(); +static VIEW lastview; /* the previous view input */ +extern char *mktemp(); /* XXX should be in stdlib.h or unistd.h */ +void report(); + +double pixvalue(); + +#ifdef NIX +#define file_exists(f) (access(f,F_OK)==0) +#else +#include +#include +int +file_exists(fname) /* ordinary file exists? */ +char *fname; +{ + struct stat sbuf; + if (stat(fname, &sbuf) < 0) return(0); + return((sbuf.st_mode & S_IFREG) != 0); +} +#endif + + +void quit(code) /* quit program */ int code; { - if (code || ralrm > 0) /* report status */ + if (code) /* report status */ report(); - +#ifndef NIX + headclean(); /* delete header file */ + pfclean(); /* clean up persist files */ +#endif exit(code); } +#ifndef NIX +void report() /* report progress */ { + extern char *myhostname(); + double u, s; #ifdef BSD struct rusage rubuf; - double t; +#else + struct tms tbuf; + double period; +#endif + tlastrept = time((time_t *)NULL); +#ifdef BSD getrusage(RUSAGE_SELF, &rubuf); - t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; - t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec; + u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; + s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; getrusage(RUSAGE_CHILDREN, &rubuf); - t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; - t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec; - - sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n", - nrays, pctdone, t/3600.0); + u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; + s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; #else - signal(SIGALRM, report); - sprintf(errmsg, "%ld rays, %4.2f%% done\n", nrays, pctdone); + times(&tbuf); +#ifdef _SC_CLK_TCK + period = 1.0 / sysconf(_SC_CLK_TCK); +#else + period = 1.0 / 60.0; #endif + u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period; + s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period; +#endif + + sprintf(errmsg, + "%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n", + nrays, pctdone, u/3600., s/3600., + (tlastrept-tstart)/3600., myhostname()); eputs(errmsg); +#ifndef BSD + signal(SIGCONT, report); +#endif +} +#else +void +report() /* report progress */ +{ + tlastrept = time((time_t *)NULL); + sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n", + nrays, pctdone, (tlastrept-tstart)/3600.0); + eputs(errmsg); +} +#endif - if (ralrm > 0) - alarm(ralrm); + +void +rpict(seq, pout, zout, prvr) /* generate image(s) */ +int seq; +char *pout, *zout, *prvr; +/* + * If seq is greater than zero, then we will render a sequence of + * images based on view parameter strings read from the standard input. + * If pout is NULL, then all images will be sent to the standard ouput. + * If seq is greater than zero and prvr is an integer, then it is the + * frame number at which rendering should begin. Preceeding view parameter + * strings will be skipped in the input. + * If pout and prvr are the same, prvr is renamed to avoid overwriting. + * Note that pout and zout should contain %d format specifications for + * sequenced file naming. + */ +{ + char fbuf[128], fbuf2[128]; + int npicts; + register char *cp; + RESOLU rs; + double pa; + /* check sampling */ + if (psample < 1) + psample = 1; + else if (psample > MAXDIV) { + sprintf(errmsg, "pixel sampling reduced from %d to %d", + psample, MAXDIV); + error(WARNING, errmsg); + psample = MAXDIV; + } + /* get starting frame */ + if (seq <= 0) + seq = 0; + else if (prvr != NULL && isint(prvr)) { + register int rn; /* skip to specified view */ + if ((rn = atoi(prvr)) < seq) + error(USER, "recover frame less than start frame"); + if (pout == NULL) + error(USER, "missing output file specification"); + for ( ; seq < rn; seq++) + if (nextview(stdin) == EOF) + error(USER, "unexpected EOF on view input"); + setview(&ourview); + prvr = fbuf; /* mark for renaming */ + } + if (pout != NULL & prvr != NULL) { + sprintf(fbuf, pout, seq); + if (!strcmp(prvr, fbuf)) { /* rename */ + strcpy(fbuf2, fbuf); + for (cp = fbuf2; *cp; cp++) + ; + while (cp > fbuf2 && !ISDIRSEP(cp[-1])) + cp--; + strcpy(cp, RFTEMPLATE); + prvr = mktemp(fbuf2); + if (rename(fbuf, prvr) < 0) + if (errno == ENOENT) { /* ghost file */ + sprintf(errmsg, + "new output file \"%s\"", + fbuf); + error(WARNING, errmsg); + prvr = NULL; + } else { /* serious error */ + sprintf(errmsg, + "cannot rename \"%s\" to \"%s\"", + fbuf, prvr); + error(SYSTEM, errmsg); + } + } + } + npicts = 0; /* render sequence */ + do { + if (seq && nextview(stdin) == EOF) + break; + pctdone = 0.0; + if (pout != NULL) { + sprintf(fbuf, pout, seq); + if (file_exists(fbuf)) { + if (prvr != NULL || !strcmp(fbuf, pout)) { + sprintf(errmsg, + "output file \"%s\" exists", + fbuf); + error(USER, errmsg); + } + setview(&ourview); + continue; /* don't clobber */ + } + if (freopen(fbuf, "w", stdout) == NULL) { + sprintf(errmsg, + "cannot open output file \"%s\"", fbuf); + error(SYSTEM, errmsg); + } + SET_FILE_BINARY(stdout); + dupheader(); + } + hres = hresolu; vres = vresolu; pa = pixaspect; + if (prvr != NULL) + if (viewfile(prvr, &ourview, &rs) <= 0 + || rs.rt != PIXSTANDARD) { + sprintf(errmsg, + "cannot recover view parameters from \"%s\"", prvr); + error(WARNING, errmsg); + } else { + pa = 0.0; + hres = scanlen(&rs); + vres = numscans(&rs); + } + if ((cp = setview(&ourview)) != NULL) + error(USER, cp); + normaspect(viewaspect(&ourview), &pa, &hres, &vres); + if (seq) { + if (ralrm > 0) { + fprintf(stderr, "FRAME %d:", seq); + fprintview(&ourview, stderr); + putc('\n', stderr); + fflush(stderr); + } + printf("FRAME=%d\n", seq); + } + fputs(VIEWSTR, stdout); + fprintview(&ourview, stdout); + putchar('\n'); + if (pa < .99 || pa > 1.01) + fputaspect(pa, stdout); + fputformat(COLRFMT, stdout); + putchar('\n'); + if (zout != NULL) + sprintf(cp=fbuf, zout, seq); + else + cp = NULL; + render(cp, prvr); + prvr = NULL; + npicts++; + } while (seq++); + /* check that we did something */ + if (npicts == 0) + error(WARNING, "no output produced"); } +nextview(fp) /* get next view from fp */ +FILE *fp; +{ + char linebuf[256]; + + copystruct(&lastview, &ourview); + while (fgets(linebuf, sizeof(linebuf), fp) != NULL) + if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) + return(0); + return(EOF); +} + + render(zfile, oldfile) /* render the scene */ char *zfile, *oldfile; { COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ float *zbar[MAXDIV+1]; /* z values */ + char *sampdens; /* previous sample density */ int ypos; /* current scanline */ int ystep; /* current y step size */ - FILE *zfp; + int hstep; /* h step size */ + int zfd; COLOR *colptr; float *zptr; register int i; - /* check sampling */ - if (psample < 1) - psample = 1; - else if (psample > MAXDIV) - psample = MAXDIV; + /* check for empty image */ + if (hres <= 0 || vres <= 0) { + error(WARNING, "empty output picture"); + fprtresolu(0, 0, stdout); + return; + } /* allocate scanlines */ for (i = 0; i <= psample; i++) { - scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR)); + scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); if (scanbar[i] == NULL) goto memerr; } - /* open z file */ + hstep = (psample*140+49)/99; /* quincunx sampling */ + ystep = (psample*99+70)/140; + if (hstep > 2) { + i = hres/hstep + 2; + if ((sampdens = (char *)malloc(i)) == NULL) + goto memerr; + while (i--) + sampdens[i] = hstep; + } else + sampdens = NULL; + /* open z-file */ if (zfile != NULL) { - if ((zfp = fopen(zfile, "a+")) == NULL) { - sprintf(errmsg, "cannot open z file \"%s\"", zfile); + if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { + sprintf(errmsg, "cannot open z-file \"%s\"", zfile); error(SYSTEM, errmsg); } + SET_FD_BINARY(zfd); for (i = 0; i <= psample; i++) { - zbar[i] = (float *)malloc(hresolu*sizeof(float)); + zbar[i] = (float *)malloc(hres*sizeof(float)); if (zbar[i] == NULL) goto memerr; } } else { - zfp = NULL; + zfd = -1; for (i = 0; i <= psample; i++) zbar[i] = NULL; } /* write out boundaries */ - fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout); + fprtresolu(hres, vres, stdout); /* recover file and compute first */ i = salvage(oldfile); - if (zfp != NULL && fseek(zfp, (long)i*hresolu*sizeof(float), 0) == EOF) - error(SYSTEM, "z file seek error in render"); - ypos = vresolu-1 - i; - fillscanline(scanbar[0], zbar[0], hresolu, ypos, psample); - ystep = psample; + if (i >= vres) + goto alldone; + if (zfd != -1 && i > 0 && + lseek(zfd, (off_t)i*hres*sizeof(float), 0) < 0) + error(SYSTEM, "z-file seek error in render"); + pctdone = 100.0*i/vres; + if (ralrm > 0) /* report init stats */ + report(); +#ifndef BSD + else +#endif + signal(SIGCONT, report); + ypos = vres-1 - i; /* initialize sampling */ + if (directvis) + init_drawsources(psample); + fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); /* compute scanlines */ for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { - /* record progress */ - pctdone = 100.0*(vresolu-ypos-ystep)/vresolu; /* bottom adjust? */ if (ypos < 0) { ystep += ypos; @@ -160,35 +435,58 @@ char *zfile, *oldfile; zbar[ystep] = zbar[0]; zbar[0] = zptr; /* fill base line */ - fillscanline(scanbar[0], zbar[0], hresolu, ypos, psample); + fillscanline(scanbar[0], zbar[0], sampdens, + hres, ypos, hstep); /* fill bar */ - fillscanbar(scanbar, zbar, hresolu, ypos, ystep); + fillscanbar(scanbar, zbar, hres, ypos, ystep); + if (directvis) /* add bitty sources */ + drawsources(scanbar, zbar, 0, hres, ypos, ystep); /* write it out */ +#ifndef BSD + signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ +#endif for (i = ystep; i > 0; i--) { - if (zfp != NULL && fwrite(zbar[i],sizeof(float),hresolu,zfp) != hresolu) + if (zfd != -1 && write(zfd, (char *)zbar[i], + hres*sizeof(float)) + < hres*sizeof(float)) goto writerr; - if (fwritescan(scanbar[i],hresolu,stdout) < 0) + if (fwritescan(scanbar[i], hres, stdout) < 0) goto writerr; } - if (zfp != NULL && fflush(zfp) == EOF) - goto writerr; if (fflush(stdout) == EOF) goto writerr; + /* record progress */ + pctdone = 100.0*(vres-1-ypos)/vres; + if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm) + report(); +#ifndef BSD + else + signal(SIGCONT, report); +#endif } /* clean up */ - if (zfp != NULL) { - fwrite(zbar[0], sizeof(float), hresolu, zfp); - if (fclose(zfp) == EOF) + signal(SIGCONT, SIG_IGN); + if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float)) + < hres*sizeof(float)) + goto writerr; + fwritescan(scanbar[0], hres, stdout); + if (fflush(stdout) == EOF) + goto writerr; +alldone: + if (zfd != -1) { + if (close(zfd) == -1) goto writerr; for (i = 0; i <= psample; i++) - free((char *)zbar[i]); + free((void *)zbar[i]); } - fwritescan(scanbar[0], hresolu, stdout); - if (fflush(stdout) == EOF) - goto writerr; for (i = 0; i <= psample; i++) - free((char *)scanbar[i]); + free((void *)scanbar[i]); + if (sampdens != NULL) + free(sampdens); pctdone = 100.0; + if (ralrm > 0) + report(); + signal(SIGCONT, SIG_DFL); return; writerr: error(SYSTEM, "write error in render"); @@ -197,55 +495,61 @@ memerr: } -fillscanline(scanline, zline, xres, y, xstep) /* fill scan line at y */ -register COLOR *scanline; -register float *zline; +fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */ +register COLOR *scanline; +register float *zline; +register char *sd; int xres, y, xstep; { - int b = xstep; - double z; + static int nc = 0; /* number of calls */ + int bl = xstep, b = xstep; + double z; register int i; - + z = pixvalue(scanline[0], 0, y); if (zline) zline[0] = z; - - for (i = xstep; i < xres-1+xstep; i += xstep) { + /* zig-zag start for quincunx pattern */ + for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) { if (i >= xres) { xstep += xres-1-i; i = xres-1; } z = pixvalue(scanline[i], i, y); if (zline) zline[i] = z; - - b = fillsample(scanline+i-xstep, zline ? zline+i-xstep : NULL, - i-xstep, y, xstep, 0, b/2); + if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1]; + if (i <= xstep) + b = fillsample(scanline, zline, 0, y, i, 0, b/2); + else + b = fillsample(scanline+i-xstep, + zline ? zline+i-xstep : (float *)NULL, + i-xstep, y, xstep, 0, b/2); + if (sd) *sd++ = nc & 1 ? bl : b; + bl = b; } + if (sd && nc & 1) *sd = bl; } fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */ -register COLOR *scanbar[]; -register float *zbar[]; +register COLOR *scanbar[]; +register float *zbar[]; int xres, y, ysize; { COLOR vline[MAXDIV+1]; float zline[MAXDIV+1]; int b = ysize; - double z; register int i, j; - + for (i = 0; i < xres; i++) { - copycolor(vline[0], scanbar[0][i]); copycolor(vline[ysize], scanbar[ysize][i]); if (zbar[0]) { zline[0] = zbar[0][i]; zline[ysize] = zbar[ysize][i]; } - - b = fillsample(vline, zbar[0] ? zline : NULL, + b = fillsample(vline, zbar[0] ? zline : (float *)NULL, i, y, 0, ysize, b/2); - + for (j = 1; j < ysize; j++) copycolor(scanbar[j][i], vline[j]); if (zbar[0]) @@ -256,38 +560,35 @@ int xres, y, ysize; int -fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ -register COLOR *colline; -register float *zline; +fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ +register COLOR *colline; +register float *zline; int x, y; int xlen, ylen; int b; { - extern double fabs(); - double ratio; - double z; + double ratio; + double z; COLOR ctmp; int ncut; register int len; - + if (xlen > 0) /* x or y length is zero */ len = xlen; else len = ylen; - + if (len <= 1) /* limit recursion */ return(0); - - if (b > 0 - || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) + + if (b > 0 || + (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) || bigdiff(colline[0], colline[len], maxdiff)) { - + z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); if (zline) zline[len>>1] = z; ncut = 1; - } else { /* interpolate */ - copycolor(colline[len>>1], colline[len]); ratio = (double)(len>>1) / len; scalecolor(colline[len>>1], ratio); @@ -301,8 +602,9 @@ int b; } /* recurse */ ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); - - ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL, + + ncut += fillsample(colline+(len>>1), + zline ? zline+(len>>1) : (float *)NULL, x+(xlen>>1), y+(ylen>>1), xlen-(xlen>>1), ylen-(ylen>>1), b/2); @@ -315,18 +617,42 @@ pixvalue(col, x, y) /* compute pixel value */ COLOR col; /* returned color */ int x, y; /* pixel position */ { - static RAY thisray; /* our ray for this pixel */ + RAY thisray; + FVECT lorg, ldir; + double hpos, vpos, lmax, d; + /* compute view ray */ + hpos = (x+pixjitter())/hres; + vpos = (y+pixjitter())/vres; + if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, + &ourview, hpos, vpos)) < -FTINY) { + setcolor(col, 0.0, 0.0, 0.0); + return(0.0); + } - viewray(thisray.rorg, thisray.rdir, &ourview, - (x+pixjitter())/hresolu, (y+pixjitter())/vresolu); + samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ + /* optional motion blur */ + if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir, + &lastview, hpos, vpos)) >= -FTINY) { + register int i; + register double d = mblur*(.5-urand(281+samplendx)); + + thisray.rmax = (1.-d)*thisray.rmax + d*lmax; + for (i = 3; i--; ) { + thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i]; + thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i]; + } + if (normalize(thisray.rdir) == 0.0) + return(0.0); + } + rayorigin(&thisray, NULL, PRIMARY, 1.0); - + rayvalue(&thisray); /* trace ray */ copycolor(col, thisray.rcol); /* return color */ - - return(thisray.rot); /* return distance */ + + return(thisray.rt); /* return distance */ } @@ -339,44 +665,63 @@ char *oldfile; int x, y; if (oldfile == NULL) - return(0); - + goto gotzip; + if ((fp = fopen(oldfile, "r")) == NULL) { sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); error(WARNING, errmsg); - return(0); + goto gotzip; } + SET_FILE_BINARY(fp); /* discard header */ - getheader(fp, NULL); + getheader(fp, NULL, NULL); /* get picture size */ - if (fgetresolu(&x, &y, fp) != (YMAJOR|YDECR)) { - sprintf(errmsg, "bad recover file \"%s\"", oldfile); + if (!fscnresolu(&x, &y, fp)) { + sprintf(errmsg, "bad recover file \"%s\" - not removed", + oldfile); error(WARNING, errmsg); fclose(fp); - return(0); + goto gotzip; } - if (x != hresolu || y != vresolu) { + if (x != hres || y != vres) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); } - scanline = (COLR *)malloc(hresolu*sizeof(COLR)); + scanline = (COLR *)malloc(hres*sizeof(COLR)); if (scanline == NULL) error(SYSTEM, "out of memory in salvage"); - for (y = 0; y < vresolu; y++) { - if (freadcolrs(scanline, hresolu, fp) < 0) + for (y = 0; y < vres; y++) { + if (freadcolrs(scanline, hres, fp) < 0) break; - if (fwritecolrs(scanline, hresolu, stdout) < 0) + if (fwritecolrs(scanline, hres, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF) goto writerr; - free((char *)scanline); + free((void *)scanline); fclose(fp); unlink(oldfile); return(y); +gotzip: + if (fflush(stdout) == EOF) + error(SYSTEM, "error writing picture header"); + return(0); writerr: - error(SYSTEM, "write error in salvage"); + sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); + error(SYSTEM, errmsg); +} + + +int +pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */ +register int x, y; +int xres, yres; +{ + x -= y; + while (x < 0) + x += xres; + return((((x>>2)*yres + y) << 2) + (x & 3)); }
