--- ray/src/rt/rpict.c 1990/01/12 09:27:11 1.15 +++ ray/src/rt/rpict.c 1992/09/08 20:56:20 2.13 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,14 +15,23 @@ static char SCCSid[] = "$SunId$ LBL"; #ifdef BSD #include #include -#else -#include #endif +#include +#include + #include "view.h" +#include "resolu.h" + #include "random.h" +#include "paths.h" + +int dimlist[MAXDIM]; /* sampling dimensions */ +int ndims = 0; /* number of sampling dimensions */ +int samplendx; /* sample index number */ + VIEW ourview = STDVIEW; /* view parameters */ int hresolu = 512; /* horizontal resolution */ int vresolu = 512; /* vertical resolution */ @@ -35,7 +44,14 @@ double dstrpix = 0.67; /* square pixel distribution double dstrsrc = 0.0; /* square source distribution */ double shadthresh = .05; /* shadow threshold */ double shadcert = .5; /* shadow certainty */ +int directrelay = 1; /* number of source relays */ +int vspretest = 512; /* virtual source pretest density */ +int directinvis = 0; /* sources invisible? */ +double srcsizerat = .25; /* maximum ratio source size/dist. */ +double specthresh = .15; /* specular sampling threshold */ +double specjitter = 1.; /* specular sampling jitter */ + int maxdepth = 6; /* maximum recursion depth */ double minweight = 5e-3; /* minimum ray weight */ @@ -52,28 +68,47 @@ int ralrm = 0; /* seconds between reports */ double pctdone = 0.0; /* percentage done */ +long tlastrept = 0L; /* time at last report */ + +extern long time(); +extern long tstart; /* starting time */ + extern long nrays; /* number of rays traced */ -#define MAXDIV 32 /* maximum sample size */ +#define MAXDIV 16 /* maximum sample size */ #define pixjitter() (.5+dstrpix*(.5-frandom())) +#define RFTEMPLATE "rfXXXXXX" +#define HFTEMPLATE TEMPLATE + +static char *hfname = NULL; /* header file name */ +static FILE *hfp = NULL; /* header file pointer */ + +static int hres, vres; /* resolution for this frame */ + +extern char *mktemp(); + double pixvalue(); quit(code) /* quit program */ int code; { - if (code || ralrm > 0) /* report status */ + if (code) /* report status */ report(); - + if (hfname != NULL) { /* delete header file */ + if (hfp != NULL) + fclose(hfp); + unlink(hfname); + } exit(code); } +#ifdef BSD report() /* report progress */ { -#ifdef BSD struct rusage rubuf; double t; @@ -86,68 +121,242 @@ report() /* report progress */ sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n", nrays, pctdone, t/3600.0); + eputs(errmsg); + tlastrept = time((long *)0); +} #else +report() /* report progress */ +{ + tlastrept = time((long *)0); + sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n", + nrays, pctdone, (tlastrept-tstart)/3600.0); + eputs(errmsg); signal(SIGALRM, report); - sprintf(errmsg, "%ld rays, %4.2f%% done\n", nrays, pctdone); +} #endif - eputs(errmsg); - if (ralrm > 0) - alarm(ralrm); + +openheader() /* save standard output to header file */ +{ + hfname = mktemp(HFTEMPLATE); + if (freopen(hfname, "w", stdout) == NULL) { + sprintf(errmsg, "cannot open header file \"%s\"", hfname); + error(SYSTEM, errmsg); + } } +closeheader() /* done with header output */ +{ + if (hfname == NULL) + return; + if (fflush(stdout) == EOF || (hfp = fopen(hfname, "r")) == NULL) + error(SYSTEM, "error reopening header file"); +} + + +dupheader() /* repeat header on standard output */ +{ + register int c; + + if (fseek(hfp, 0L, 0) < 0) + error(SYSTEM, "seek error on header file"); + while ((c = getc(hfp)) != EOF) + putchar(c); +} + + +rpict(seq, pout, zout, prvr) /* generate image(s) */ +int seq; +char *pout, *zout, *prvr; +/* + * If seq is greater than zero, then we will render a sequence of + * images based on view parameter strings read from the standard input. + * If pout is NULL, then all images will be sent to the standard ouput. + * If seq is greater than zero and prvr is an integer, then it is the + * frame number at which rendering should begin. Preceeding view parameter + * strings will be skipped in the input. + * If pout and prvr are the same, prvr is renamed to avoid overwriting. + * Note that pout and zout should contain %d format specifications for + * sequenced file naming. + */ +{ + extern char *rindex(), *strncpy(), *strcat(); + char fbuf[128], fbuf2[128]; + register char *cp; + RESOLU rs; + double pa; + /* finished writing header */ + closeheader(); + /* check sampling */ + if (psample < 1) + psample = 1; + else if (psample > MAXDIV) { + sprintf(errmsg, "pixel sampling reduced from %d to %d", + psample, MAXDIV); + error(WARNING, errmsg); + psample = MAXDIV; + } + /* get starting frame */ + if (seq <= 0) + seq = 0; + else if (prvr != NULL && isint(prvr)) { + register int rn; /* skip to specified view */ + if ((rn = atoi(prvr)) < seq) + error(USER, "recover frame less than start frame"); + if (pout == NULL) + error(USER, "missing output file specification"); + for ( ; seq < rn; seq++) + if (nextview(stdin) == EOF) + error(USER, "unexpected EOF on view input"); + prvr = fbuf; /* mark for renaming */ + } + if (pout != NULL) { + sprintf(fbuf, pout, seq); + if (prvr != NULL && !strcmp(prvr, fbuf)) { /* rename */ + fbuf2[0] = '\0'; + if ((cp = rindex(fbuf, '/')) != NULL) + strncpy(fbuf2, fbuf, cp-fbuf+1); + strcat(fbuf2, RFTEMPLATE); + prvr = mktemp(fbuf2); + if (rename(fbuf, prvr) < 0 && errno != ENOENT) { + sprintf(errmsg, + "cannot rename \"%s\" to \"%s\"", + fbuf, prvr); + error(SYSTEM, errmsg); + } + } + } + /* render sequence */ + do { + if (seq && nextview(stdin) == EOF) + break; + if (pout != NULL) { + sprintf(fbuf, pout, seq); + if (freopen(fbuf, "w", stdout) == NULL) { + sprintf(errmsg, + "cannot open output file \"%s\"", fbuf); + error(SYSTEM, errmsg); + } + dupheader(); + } + hres = hresolu; vres = vresolu; pa = pixaspect; + if (prvr != NULL) + if (viewfile(prvr, &ourview, &rs) <= 0 + || rs.or != PIXSTANDARD) { + sprintf(errmsg, + "cannot recover view parameters from \"%s\"", prvr); + error(WARNING, errmsg); + } else { + pa = 0.0; + hres = scanlen(&rs); + vres = numscans(&rs); + } + if ((cp = setview(&ourview)) != NULL) + error(USER, cp); + normaspect(viewaspect(&ourview), &pa, &hres, &vres); + if (seq) { + if (ralrm > 0) { + fprintf(stderr, "FRAME %d:", seq); + fprintview(&ourview, stderr); + putc('\n', stderr); + fflush(stderr); + } + printf("FRAME=%d\n", seq); + } + fputs(VIEWSTR, stdout); + fprintview(&ourview, stdout); + putchar('\n'); + if (pa < .99 || pa > 1.01) + fputaspect(pa, stdout); + fputformat(COLRFMT, stdout); + putchar('\n'); + if (zout != NULL) + sprintf(cp=fbuf, zout, seq); + else + cp = NULL; + render(cp, prvr); + prvr = NULL; + } while (seq++); +} + + +nextview(fp) /* get next view from fp */ +FILE *fp; +{ + char linebuf[256]; + + while (fgets(linebuf, sizeof(linebuf), fp) != NULL) + if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) + return(0); + return(EOF); +} + + render(zfile, oldfile) /* render the scene */ char *zfile, *oldfile; { + extern long lseek(); COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ float *zbar[MAXDIV+1]; /* z values */ + char *sampdens; /* previous sample density */ int ypos; /* current scanline */ int ystep; /* current y step size */ - FILE *zfp; + int hstep; /* h step size */ + int zfd; COLOR *colptr; float *zptr; register int i; - /* check sampling */ - if (psample < 1) - psample = 1; - else if (psample > MAXDIV) - psample = MAXDIV; /* allocate scanlines */ for (i = 0; i <= psample; i++) { - scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR)); + scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); if (scanbar[i] == NULL) goto memerr; } + hstep = (psample*140+49)/99; /* quincunx sampling */ + ystep = (psample*99+70)/140; + if (hstep > 2) { + i = hres/hstep + 2; + if ((sampdens = malloc(i)) == NULL) + goto memerr; + while (i--) + sampdens[i] = hstep; + } else + sampdens = NULL; /* open z file */ if (zfile != NULL) { - if ((zfp = fopen(zfile, "a+")) == NULL) { + if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { sprintf(errmsg, "cannot open z file \"%s\"", zfile); error(SYSTEM, errmsg); } for (i = 0; i <= psample; i++) { - zbar[i] = (float *)malloc(hresolu*sizeof(float)); + zbar[i] = (float *)malloc(hres*sizeof(float)); if (zbar[i] == NULL) goto memerr; } } else { - zfp = NULL; + zfd = -1; for (i = 0; i <= psample; i++) zbar[i] = NULL; } /* write out boundaries */ - fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout); + fprtresolu(hres, vres, stdout); /* recover file and compute first */ i = salvage(oldfile); - if (zfp != NULL && fseek(zfp, (long)i*hresolu*sizeof(float), 0) == EOF) + if (zfd != -1 && i > 0 && + lseek(zfd, (long)i*hres*sizeof(float), 0) == -1) error(SYSTEM, "z file seek error in render"); - ypos = vresolu-1 - i; - fillscanline(scanbar[0], zbar[0], hresolu, ypos, psample); - ystep = psample; + pctdone = 100.0*i/vres; + if (ralrm > 0) /* report init stats */ + report(); +#ifndef BSD + else +#endif + signal(SIGALRM, report); + ypos = vres-1 - i; + fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); /* compute scanlines */ for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { - /* record progress */ - pctdone = 100.0*(vresolu-ypos-ystep)/vresolu; /* bottom adjust? */ if (ypos < 0) { ystep += ypos; @@ -160,35 +369,54 @@ char *zfile, *oldfile; zbar[ystep] = zbar[0]; zbar[0] = zptr; /* fill base line */ - fillscanline(scanbar[0], zbar[0], hresolu, ypos, psample); + fillscanline(scanbar[0], zbar[0], sampdens, + hres, ypos, hstep); /* fill bar */ - fillscanbar(scanbar, zbar, hresolu, ypos, ystep); + fillscanbar(scanbar, zbar, hres, ypos, ystep); /* write it out */ +#ifndef BSD + signal(SIGALRM, SIG_IGN); /* don't interrupt writes */ +#endif for (i = ystep; i > 0; i--) { - if (zfp != NULL && fwrite(zbar[i],sizeof(float),hresolu,zfp) != hresolu) + if (zfd != -1 && write(zfd, (char *)zbar[i], + hres*sizeof(float)) + < hres*sizeof(float)) goto writerr; - if (fwritescan(scanbar[i],hresolu,stdout) < 0) + if (fwritescan(scanbar[i], hres, stdout) < 0) goto writerr; } - if (zfp != NULL && fflush(zfp) == EOF) - goto writerr; if (fflush(stdout) == EOF) goto writerr; + /* record progress */ + pctdone = 100.0*(vres-1-ypos)/vres; + if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm) + report(); +#ifndef BSD + else + signal(SIGALRM, report); +#endif } /* clean up */ - if (zfp != NULL) { - fwrite(zbar[0], sizeof(float), hresolu, zfp); - if (fclose(zfp) == EOF) + signal(SIGALRM, SIG_IGN); + if (zfd != -1) { + if (write(zfd, (char *)zbar[0], hres*sizeof(float)) + < hres*sizeof(float)) goto writerr; + if (close(zfd) == -1) + goto writerr; for (i = 0; i <= psample; i++) free((char *)zbar[i]); } - fwritescan(scanbar[0], hresolu, stdout); + fwritescan(scanbar[0], hres, stdout); if (fflush(stdout) == EOF) goto writerr; for (i = 0; i <= psample; i++) free((char *)scanbar[i]); + if (sampdens != NULL) + free(sampdens); pctdone = 100.0; + if (ralrm > 0) + report(); return; writerr: error(SYSTEM, "write error in render"); @@ -197,29 +425,38 @@ memerr: } -fillscanline(scanline, zline, xres, y, xstep) /* fill scan line at y */ +fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */ register COLOR *scanline; register float *zline; +register char *sd; int xres, y, xstep; { - int b = xstep; + static int nc = 0; /* number of calls */ + int bl = xstep, b = xstep; double z; register int i; z = pixvalue(scanline[0], 0, y); if (zline) zline[0] = z; - - for (i = xstep; i < xres-1+xstep; i += xstep) { + /* zig-zag start for quincunx pattern */ + for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) { if (i >= xres) { xstep += xres-1-i; i = xres-1; } z = pixvalue(scanline[i], i, y); if (zline) zline[i] = z; - - b = fillsample(scanline+i-xstep, zline ? zline+i-xstep : NULL, - i-xstep, y, xstep, 0, b/2); + if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1]; + if (i <= xstep) + b = fillsample(scanline, zline, 0, y, i, 0, b/2); + else + b = fillsample(scanline+i-xstep, + zline ? zline+i-xstep : NULL, + i-xstep, y, xstep, 0, b/2); + if (sd) *sd++ = nc & 1 ? bl : b; + bl = b; } + if (sd && nc & 1) *sd = bl; } @@ -231,7 +468,6 @@ int xres, y, ysize; COLOR vline[MAXDIV+1]; float zline[MAXDIV+1]; int b = ysize; - double z; register int i, j; for (i = 0; i < xres; i++) { @@ -315,18 +551,23 @@ pixvalue(col, x, y) /* compute pixel value */ COLOR col; /* returned color */ int x, y; /* pixel position */ { - static RAY thisray; /* our ray for this pixel */ + static RAY thisray; - viewray(thisray.rorg, thisray.rdir, &ourview, - (x+pixjitter())/hresolu, (y+pixjitter())/vresolu); + if (viewray(thisray.rorg, thisray.rdir, &ourview, + (x+pixjitter())/hres, (y+pixjitter())/vres) < 0) { + setcolor(col, 0.0, 0.0, 0.0); + return(0.0); + } rayorigin(&thisray, NULL, PRIMARY, 1.0); - + + samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ + rayvalue(&thisray); /* trace ray */ copycolor(col, thisray.rcol); /* return color */ - return(thisray.rot); /* return distance */ + return(thisray.rt); /* return distance */ } @@ -349,26 +590,26 @@ char *oldfile; /* discard header */ getheader(fp, NULL); /* get picture size */ - if (fgetresolu(&x, &y, fp) != (YMAJOR|YDECR)) { + if (!fscnresolu(&x, &y, fp)) { sprintf(errmsg, "bad recover file \"%s\"", oldfile); error(WARNING, errmsg); fclose(fp); return(0); } - if (x != hresolu || y != vresolu) { + if (x != hres || y != vres) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); } - scanline = (COLR *)malloc(hresolu*sizeof(COLR)); + scanline = (COLR *)malloc(hres*sizeof(COLR)); if (scanline == NULL) error(SYSTEM, "out of memory in salvage"); - for (y = 0; y < vresolu; y++) { - if (freadcolrs(scanline, hresolu, fp) < 0) + for (y = 0; y < vres; y++) { + if (freadcolrs(scanline, hres, fp) < 0) break; - if (fwritecolrs(scanline, hresolu, stdout) < 0) + if (fwritecolrs(scanline, hres, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF) @@ -378,5 +619,18 @@ char *oldfile; unlink(oldfile); return(y); writerr: - error(SYSTEM, "write error in salvage"); + sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); + error(SYSTEM, errmsg); +} + + +int +pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */ +register int x, y; +int xres, yres; +{ + x -= y; + while (x < 0) + x += xres; + return((((x>>2)*yres + y) << 2) + (x & 3)); }
