root/radiance/ray/src/rt/rpict.c
Fri May 9 23:28:57 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.87: +13 -15 lines
Diff to previous 2.87 , to selected 2.76
Added process ID to reports
Tue Feb 18 12:13:42 2014 UTC (10 years, 3 months ago) by greg
Changes since 2.86: +13 -7 lines
Diff to previous 2.86 , to selected 2.76
Thu Mar 21 00:03:09 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.85: +15 -15 lines
Diff to previous 2.85 , to selected 2.76
Switched to more accurate disk sampling for depth-of-field blur
Mon Nov 26 07:04:07 2012 UTC (11 years, 6 months ago) by greg
Changes since 2.84: +33 -30 lines
Diff to previous 2.84 , to selected 2.76
Fixed bug in depth-of-field with non-zero fore clipping plane
Fri Feb 25 06:51:50 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.83: +2 -2 lines
Diff to previous 2.83 , to selected 2.76
Decreased -lw default
Fri Sep 3 21:16:50 2010 UTC (13 years, 9 months ago) by greg
Changes since 2.82: +1 -6 lines
Diff to previous 2.82 , to selected 2.76
Removed '//' comment lines that shouldn't be in C code
Sat May 15 15:31:30 2010 UTC (14 years, 1 month ago) by greg
Changes since 2.81: +3 -3 lines
Diff to previous 2.81 , to selected 2.76
Implemented Mark Stock's fix for depth-of-field blur
Mon May 11 21:46:31 2009 UTC (15 years, 1 month ago) by greg
Changes since 2.80: +6 -4 lines
Diff to previous 2.80 , to selected 2.76
Made depth-of-field aperture sampling over a disk rather than a square
Sun Apr 27 17:22:49 2008 UTC (16 years, 1 month ago) by schorsch
Changes since 2.79: +13 -13 lines
Diff to previous 2.79 , to selected 2.76
Thu Apr 24 10:28:25 2008 UTC (16 years, 1 month ago) by schorsch
Changes since 2.78: +5 -1 lines
Diff to previous 2.78 , to selected 2.76
Tue Mar 11 02:21:47 2008 UTC (16 years, 3 months ago) by greg
Diff to previous 2.77 , to selected 2.76
Wed Apr 5 06:22:56 2006 UTC (18 years, 2 months ago) by greg
Changes since 2.76: +3 -7 lines
Diff to previous 2.76
Made -u+ option truly random
Revision 2.76 - (view) (download) (annotate) - [selected]
Mon Jun 13 20:07:56 2005 UTC (19 years ago) by greg
Changes since 2.75: +7 -2 lines
Diff to previous 2.75
Changes since 2.74: +2 -2 lines
Diff to previous 2.74 , to selected 2.76
Mon Feb 7 20:13:55 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.73: +28 -9 lines
Diff to previous 2.73 , to selected 2.76
Robustness improvements in depth-of-field blurring
Tue Jan 18 00:33:16 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.72: +21 -4 lines
Diff to previous 2.72 , to selected 2.76
Fri Nov 5 17:36:55 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 2.71 , to selected 2.76
Sat Oct 23 18:55:53 2004 UTC (19 years, 7 months ago) by schorsch
CVS Tags: rad3R6P1
Changes since 2.70: +2 -2 lines
Diff to previous 2.70 , to selected 2.76
Tue Sep 28 17:54:19 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.69: +1 -1 lines
Diff to previous 2.69 , to selected 2.76
Changes since 2.68: +91 -52 lines
Diff to previous 2.68 , to selected 2.76
Sun Mar 28 16:31:14 2004 UTC (20 years, 2 months ago) by greg
Changes since 2.67: +1 -1 lines
Diff to previous 2.67 , to selected 2.76
Thu Feb 12 18:55:50 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.66: +1 -0 lines
Diff to previous 2.66 , to selected 2.76
Wed Nov 26 19:16:24 2003 UTC (20 years, 6 months ago) by greg
Changes since 2.65: +1 -2 lines
Diff to previous 2.65 , to selected 2.76
Minor code improvements
Mon Oct 27 10:30:18 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.64: +1 -1 lines
Diff to previous 2.64 , to selected 2.76
Various compatibility fixes.
Changes since 2.63: +1 -1 lines
Diff to previous 2.63 , to selected 2.76
Wed Sep 24 14:55:54 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.62: +6 -6 lines
Diff to previous 2.62 , to selected 2.76
Changes since 2.61: +1 -1 lines
Diff to previous 2.61 , to selected 2.76
Changes since 2.60: +5 -3 lines
Diff to previous 2.60 , to selected 2.76
Thu Jul 3 21:44:41 2003 UTC (20 years, 11 months ago) by schorsch
Diff to previous 2.59 , to selected 2.76
Fixed fputnow() call to match prototype.
Thu Jul 3 18:03:58 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.58: +1 -0 lines
Diff to previous 2.58 , to selected 2.76
Mon Jun 30 19:58:37 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.57: +3 -3 lines
Diff to previous 2.57 , to selected 2.76
Got some feature dependency backwards.
Changes since 2.56: +4 -4 lines
Diff to previous 2.56 , to selected 2.76
Changes since 2.55: +11 -5 lines
Diff to previous 2.55 , to selected 2.76
Changes since 2.54: +7 -14 lines
Diff to previous 2.54 , to selected 2.76
Mon Mar 10 17:26:26 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.53: +1 -2 lines
Diff to previous 2.53 , to selected 2.76
Compile fixes for Linux
Changes since 2.52: +1 -56 lines
Diff to previous 2.52 , to selected 2.76
Changes since 2.51: +90 -21 lines
Diff to previous 2.51 , to selected 2.76
Wed Jun 17 13:29:55 1998 UTC (26 years ago) by gwlarson
Changes since 2.50: +1 -2 lines
Diff to previous 2.50 , to selected 2.76
moved lseek() and ftell() declarations to standard.h
Mon Apr 13 14:01:08 1998 UTC (26 years, 2 months ago) by gwlarson
Changes since 2.49: +2 -0 lines
Diff to previous 2.49 , to selected 2.76
added missing calls to setview()
Tue Mar 3 19:14:28 1998 UTC (26 years, 3 months ago) by gwlarson
Changes since 2.48: +30 -6 lines
Diff to previous 2.48 , to selected 2.76
added -pm option for motion blurring
Mon Oct 20 16:46:37 1997 UTC (26 years, 7 months ago) by gregl
Changes since 2.47: +4 -3 lines
Diff to previous 2.47 , to selected 2.76
added test of directvis before call to drawsources()
Sat Jun 8 21:16:06 1996 UTC (28 years ago) by greg
Changes since 2.46: +5 -5 lines
Diff to previous 2.46 , to selected 2.76
made bitty source drawing more efficient
Wed Apr 17 14:02:05 1996 UTC (28 years, 2 months ago) by greg
Diff to previous 2.45 , to selected 2.76
Fri Mar 15 21:02:09 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.44: +14 -17 lines
Diff to previous 2.44 , to selected 2.76
Wed Feb 14 15:18:05 1996 UTC (28 years, 4 months ago) by greg
Changes since 2.43: +1 -0 lines
Diff to previous 2.43 , to selected 2.76
Wed Feb 7 16:35:18 1996 UTC (28 years, 4 months ago) by greg
Changes since 2.42: +2 -8 lines
Diff to previous 2.42 , to selected 2.76
Tue Jan 23 16:27:31 1996 UTC (28 years, 4 months ago) by greg
Changes since 2.41: +9 -6 lines
Diff to previous 2.41 , to selected 2.76
slight improvement for recovering complete file
Fri Dec 8 18:49:20 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.40: +6 -1 lines
Diff to previous 2.40 , to selected 2.76
Wed Dec 21 09:51:56 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.39: +2 -0 lines
Diff to previous 2.39 , to selected 2.76
added -bv option for back face visibility (normally on)
Tue Dec 20 20:18:30 1994 UTC (29 years, 6 months ago) by greg
Changes since 2.38: +3 -3 lines
Diff to previous 2.38 , to selected 2.76
Mon Aug 29 15:42:34 1994 UTC (29 years, 9 months ago) by greg
Changes since 2.37: +4 -3 lines
Diff to previous 2.37 , to selected 2.76
compiler error fix for AIX
Wed Dec 22 21:03:54 1993 UTC (30 years, 5 months ago) by greg
Changes since 2.36: +8 -4 lines
Diff to previous 2.36 , to selected 2.76
added insurance that picture header is written right away
Sun Dec 12 13:56:08 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.35: +5 -1 lines
Diff to previous 2.35 , to selected 2.76
added insurance policy against undefined CLK_TCK variable
Wed Nov 24 14:28:08 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.34: +3 -1 lines
Diff to previous 2.34 , to selected 2.76
fixed error in SIGCONT catching for System V
Wed Nov 24 10:05:53 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.33 , to selected 2.76
fixed use of uname()
Tue Nov 23 09:56:31 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.32: +5 -3 lines
Diff to previous 2.32 , to selected 2.76
improved(?) portability of usage stuff for System V
Mon Nov 22 09:34:15 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.31: +16 -11 lines
Diff to previous 2.31 , to selected 2.76
compatibility fixes
Thu Nov 18 09:22:55 1993 UTC (30 years, 7 months ago) by greg
Changes since 2.30: +8 -6 lines
Diff to previous 2.30 , to selected 2.76
fixed time declaration and use
Thu Oct 28 15:24:19 1993 UTC (30 years, 7 months ago) by greg
Changes since 2.29: +30 -10 lines
Diff to previous 2.29 , to selected 2.76
fixed time reporting for non-BSD machines(?)
Wed Aug 11 09:46:15 1993 UTC (30 years, 10 months ago) by greg
Diff to previous 2.28 , to selected 2.76
improved error reporting on bad recover files
Fri Aug 6 17:12:19 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.27: +11 -4 lines
Diff to previous 2.27 , to selected 2.76
more sensible warning for nonexistent -ro file
Mon Aug 2 21:48:37 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.26: +23 -1 lines
Diff to previous 2.26 , to selected 2.76
improved error testing for noclobber feature of -o option
Fri Jul 30 10:31:09 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.25: +11 -4 lines
Diff to previous 2.25 , to selected 2.76
made it so -o option will not clobber files
Fri May 28 18:59:50 1993 UTC (31 years ago) by greg
Changes since 2.24: +1 -0 lines
Diff to previous 2.24 , to selected 2.76
reinitialized pctdone in rpict()
Tue May 25 10:30:08 1993 UTC (31 years ago) by greg
Diff to previous 2.23 , to selected 2.76
Fri Jan 29 12:15:40 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.22: +1 -0 lines
Diff to previous 2.22 , to selected 2.76
added final instruction to render() to set SIGCONT to default action
Thu Jan 21 10:08:59 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.21: +9 -5 lines
Diff to previous 2.21 , to selected 2.76
changed signals so ALRM always causes exit, CONT now used by rpict
Wed Jan 20 15:19:47 1993 UTC (31 years, 5 months ago) by greg
Changes since 2.20: +5 -39 lines
Diff to previous 2.20 , to selected 2.76
Thu Nov 19 20:25:57 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.19 , to selected 2.76
changed -di to ! -dv
Thu Nov 12 10:11:53 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.18 , to selected 2.76
fixed call to getheader() to pass 3 arguments always (DOS bug fix)
Tue Nov 10 21:24:34 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.17: +15 -21 lines
Diff to previous 2.17 , to selected 2.76
bug fixes for MS-DOS
Thu Oct 15 21:13:17 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.16: +12 -0 lines
Diff to previous 2.16 , to selected 2.76
added setmode(fd,O_BINARY) where needed for MSDOS
Tue Oct 6 12:30:07 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.15: +4 -0 lines
Diff to previous 2.15 , to selected 2.76
Changes for 32-bit PC port
Fri Oct 2 16:19:10 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.14: +0 -1 lines
Diff to previous 2.14 , to selected 2.76
Mon Sep 21 12:07:52 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.13: +33 -34 lines
Diff to previous 2.13 , to selected 2.76
Changes for PC port
Tue Sep 8 20:56:20 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.12: +2 -0 lines
Diff to previous 2.12 , to selected 2.76
put back in final report() call
Tue Sep 8 15:35:16 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.11: +3 -1 lines
Diff to previous 2.11 , to selected 2.76
Sun Aug 9 20:28:41 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.10 , to selected 2.76
added view parameters to frame reporting
Sat Aug 8 18:45:02 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.9 , to selected 2.76
fixed bug in testing of recover file rename
Fri Jul 10 19:29:50 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.8: +16 -17 lines
Diff to previous 2.8 , to selected 2.76
improved efficiency of view skipping slightly
Fri Jul 10 14:58:19 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.7: +198 -36 lines
Diff to previous 2.7 , to selected 2.76
added -o and -S options for image sequences and slave operation
Wed Mar 11 09:32:40 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.6: +1 -0 lines
Diff to previous 2.6 , to selected 2.76
forgot to disable alarm signal before final writes
Thu Jan 16 12:05:23 1992 UTC (32 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 2.76
changed default values and handling of specthresh
Tue Jan 14 16:15:57 1992 UTC (32 years, 5 months ago) by greg
Diff to previous 2.4 , to selected 2.76
added -sj and -st options and changed old -s options to -p
Sat Dec 28 18:43:15 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 2.76
minor change to signal handling under System V
Tue Dec 10 17:42:01 1991 UTC (32 years, 6 months ago) by greg
Changes since 2.2: +6 -2 lines
Diff to previous 2.2 , to selected 2.76
bug fix in sampling underwriting scanline buffer
Thu Nov 21 10:10:46 1991 UTC (32 years, 7 months ago) by greg
Changes since 2.1: +25 -9 lines
Diff to previous 2.1 , to selected 2.76
improved sampling
Tue Nov 12 17:08:26 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.36: +0 -0 lines
Diff to previous 1.36 , to selected 2.76
Mon Nov 11 14:02:45 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.35: +4 -2 lines
Diff to previous 1.35 , to selected 2.76
Mon Oct 21 12:57:57 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.34: +2 -1 lines
Diff to previous 1.34 , to selected 2.76
Thu Oct 10 12:58:13 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.33: +2 -2 lines
Diff to previous 1.33 , to selected 2.76
signal.h
Thu Oct 10 09:18:58 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.32: +8 -5 lines
Diff to previous 1.32 , to selected 2.76
changed to quincunx pattern for initial image samples
Thu Sep 19 13:55:53 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.31: +11 -0 lines
Diff to previous 1.31 , to selected 2.76
improved ALRM signal handling for SYSV
Tue Aug 13 12:16:34 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.30: +13 -1 lines
Diff to previous 1.30 , to selected 2.76
Thu Jul 18 14:42:54 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.29: +1 -0 lines
Diff to previous 1.29 , to selected 2.76
Tue Jun 25 14:06:12 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.28: +1 -1 lines
Diff to previous 1.28 , to selected 2.76
increased defaults for -dp parameter
Mon Jun 24 16:10:46 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.27: +1 -0 lines
Diff to previous 1.27 , to selected 2.76
Wed Jun 19 16:36:34 1991 UTC (33 years ago) by greg
Changes since 1.26: +1 -0 lines
Diff to previous 1.26 , to selected 2.76
added virtual sources
Tue Jun 18 10:27:16 1991 UTC (33 years ago) by greg
Changes since 1.25: +6 -3 lines
Diff to previous 1.25 , to selected 2.76
reduced MAXDIV and added warning if it is exceeded
Tue May 21 17:41:35 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.24: +9 -2 lines
Diff to previous 1.24 , to selected 2.76
Tue Apr 9 09:31:01 1991 UTC (33 years, 2 months ago) by greg
Changes since 1.23: +23 -9 lines
Diff to previous 1.23 , to selected 2.76
changed reporting so that alarm() is not used.
Thu Nov 1 12:06:01 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.22: +2 -1 lines
Diff to previous 1.22 , to selected 2.76
eliminated unnecessary call to lseek in render()
Sat Oct 13 21:32:25 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.21: +5 -2 lines
Diff to previous 1.21 , to selected 2.76
added fisheye view types
Tue Jun 26 09:00:12 1990 UTC (33 years, 11 months ago) by greg
Changes since 1.20: +0 -1 lines
Diff to previous 1.20 , to selected 2.76
Tue Mar 27 11:40:07 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.19: +3 -2 lines
Diff to previous 1.19 , to selected 2.76
Thu Mar 1 08:19:01 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.18: +1 -1 lines
Diff to previous 1.18 , to selected 2.76
fixed computation of pctdone
Wed Feb 21 12:39:37 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.17 , to selected 2.76
changed include of fcntl.h
Fri Jan 19 00:00:19 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.16: +4 -3 lines
Diff to previous 1.16 , to selected 2.76
Tue Jan 16 11:30:09 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.15: +12 -10 lines
Diff to previous 1.15 , to selected 2.76
changed reading and writing of z-files and viewfiles
Fri Jan 12 09:27:11 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.14: +23 -35 lines
Diff to previous 1.14 , to selected 2.76
simplified residual calculation
Thu Jan 11 08:30:42 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.13: +3 -0 lines
Diff to previous 1.13 , to selected 2.76
added reset to report signal for SYS V
Tue Jan 9 09:07:29 1990 UTC (34 years, 5 months ago) by greg
Diff to previous 1.12 , to selected 2.76
Mon Jan 8 13:38:01 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.11: +25 -25 lines
Diff to previous 1.11 , to selected 2.76
Sun Dec 10 13:42:45 1989 UTC (34 years, 6 months ago) by greg
Changes since 1.10: +105 -30 lines
Diff to previous 1.10 , to selected 2.76
added z-file output to rpict
Tue Oct 3 12:17:09 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.9: +38 -27 lines
Diff to previous 1.9 , to selected 2.76
Fixed routines to render only desired pixels
Fri Sep 29 08:16:41 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.8: +38 -32 lines
Diff to previous 1.8 , to selected 2.76
Corrected resolution of output to correspond to request.
Wed Sep 13 15:21:41 1989 UTC (34 years, 9 months ago) by greg
Changes since 1.7: +17 -16 lines
Diff to previous 1.7 , to selected 2.76
Added xres,yres variables so we don't mung ourview.[hv]resolu
Tue Sep 12 12:28:26 1989 UTC (34 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 2.76
Added calls to picture resolution get/put routines
Mon Jul 10 15:21:30 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.5 , to selected 2.76
Reduced default ambient resolution
Tue Jun 13 10:57:40 1989 UTC (35 years ago) by greg
Diff to previous 1.4 , to selected 2.76
Wed Jun 7 21:00:57 1989 UTC (35 years ago) by greg
Diff to previous 1.3 , to selected 2.76
Wed Jun 7 08:35:21 1989 UTC (35 years ago) by greg
Diff to previous 1.2 , to selected 2.76
Glow type changed
Spot type eliminated
Mon Apr 10 09:32:55 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 2.76
Added warnings for inappropriate recover files
Thu Feb 2 10:41:36 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.76
