--- ray/src/rt/rpict.c 1991/12/10 17:42:01 2.3 +++ ray/src/rt/rpict.c 1993/01/29 12:15:40 2.23 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -18,7 +18,6 @@ static char SCCSid[] = "$SunId$ LBL"; #endif #include -#include #include "view.h" @@ -26,6 +25,14 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" +#include "paths.h" + +#define RFTEMPLATE "rfXXXXXX" + +#ifndef SIGCONT +#define SIGCONT SIGIO +#endif + int dimlist[MAXDIM]; /* sampling dimensions */ int ndims = 0; /* number of sampling dimensions */ int samplendx; /* sample index number */ @@ -33,25 +40,28 @@ int samplendx; /* sample index number */ VIEW ourview = STDVIEW; /* view parameters */ int hresolu = 512; /* horizontal resolution */ int vresolu = 512; /* vertical resolution */ -double pixaspect = 1.0; /* pixel aspect ratio */ +double pixaspect = 1.0; /* pixel aspect ratio */ int psample = 4; /* pixel sample size */ -double maxdiff = .05; /* max. difference for interpolation */ -double dstrpix = 0.67; /* square pixel distribution */ +double maxdiff = .05; /* max. difference for interpolation */ +double dstrpix = 0.67; /* square pixel distribution */ -double dstrsrc = 0.0; /* square source distribution */ -double shadthresh = .05; /* shadow threshold */ -double shadcert = .5; /* shadow certainty */ +double dstrsrc = 0.0; /* square source distribution */ +double shadthresh = .05; /* shadow threshold */ +double shadcert = .5; /* shadow certainty */ int directrelay = 1; /* number of source relays */ int vspretest = 512; /* virtual source pretest density */ -int directinvis = 0; /* sources invisible? */ -double srcsizerat = .25; /* maximum ratio source size/dist. */ +int directvis = 1; /* sources visible? */ +double srcsizerat = .25; /* maximum ratio source size/dist. */ +double specthresh = .15; /* specular sampling threshold */ +double specjitter = 1.; /* specular sampling jitter */ + int maxdepth = 6; /* maximum recursion depth */ -double minweight = 5e-3; /* minimum ray weight */ +double minweight = 5e-3; /* minimum ray weight */ COLOR ambval = BLKCOLOR; /* ambient value */ -double ambacc = 0.2; /* ambient accuracy */ +double ambacc = 0.2; /* ambient accuracy */ int ambres = 32; /* ambient resolution */ int ambdiv = 128; /* ambient divisions */ int ambssamp = 0; /* ambient super-samples */ @@ -59,9 +69,13 @@ int ambounce = 0; /* ambient bounces */ char *amblist[128]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ +#ifdef MSDOS +int ralrm = 60; /* seconds between reports */ +#else int ralrm = 0; /* seconds between reports */ +#endif -double pctdone = 0.0; /* percentage done */ +double pctdone = 0.0; /* percentage done */ long tlastrept = 0L; /* time at last report */ @@ -70,19 +84,24 @@ extern long tstart; /* starting time */ extern long nrays; /* number of rays traced */ -#define MAXDIV 16 /* maximum sample size */ +#define MAXDIV 16 /* maximum sample size */ -#define pixjitter() (.5+dstrpix*(.5-frandom())) +#define pixjitter() (.5+dstrpix*(.5-frandom())) -double pixvalue(); +static int hres, vres; /* resolution for this frame */ +extern char *mktemp(); +double pixvalue(); + + quit(code) /* quit program */ int code; { - if (code || ralrm > 0) /* report status */ + if (code) /* report status */ report(); - + headclean(); /* delete header file */ + pfclean(); /* clean up persist files */ exit(code); } @@ -91,7 +110,7 @@ int code; report() /* report progress */ { struct rusage rubuf; - double t; + double t; getrusage(RUSAGE_SELF, &rubuf); t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; @@ -108,15 +127,145 @@ report() /* report progress */ #else report() /* report progress */ { - signal(SIGALRM, report); tlastrept = time((long *)0); sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n", nrays, pctdone, (tlastrept-tstart)/3600.0); eputs(errmsg); + signal(SIGCONT, report); } #endif +rpict(seq, pout, zout, prvr) /* generate image(s) */ +int seq; +char *pout, *zout, *prvr; +/* + * If seq is greater than zero, then we will render a sequence of + * images based on view parameter strings read from the standard input. + * If pout is NULL, then all images will be sent to the standard ouput. + * If seq is greater than zero and prvr is an integer, then it is the + * frame number at which rendering should begin. Preceeding view parameter + * strings will be skipped in the input. + * If pout and prvr are the same, prvr is renamed to avoid overwriting. + * Note that pout and zout should contain %d format specifications for + * sequenced file naming. + */ +{ + extern char *rindex(), *strncpy(), *strcat(), *strcpy(); + char fbuf[128], fbuf2[128]; + register char *cp; + RESOLU rs; + double pa; + /* check sampling */ + if (psample < 1) + psample = 1; + else if (psample > MAXDIV) { + sprintf(errmsg, "pixel sampling reduced from %d to %d", + psample, MAXDIV); + error(WARNING, errmsg); + psample = MAXDIV; + } + /* get starting frame */ + if (seq <= 0) + seq = 0; + else if (prvr != NULL && isint(prvr)) { + register int rn; /* skip to specified view */ + if ((rn = atoi(prvr)) < seq) + error(USER, "recover frame less than start frame"); + if (pout == NULL) + error(USER, "missing output file specification"); + for ( ; seq < rn; seq++) + if (nextview(stdin) == EOF) + error(USER, "unexpected EOF on view input"); + prvr = fbuf; /* mark for renaming */ + } + if (pout != NULL & prvr != NULL) { + sprintf(fbuf, pout, seq); + if (!strcmp(prvr, fbuf)) { /* rename */ + strcpy(fbuf2, fbuf); + for (cp = fbuf2; *cp; cp++) + ; + while (cp > fbuf2 && !ISDIRSEP(cp[-1])) + cp--; + strcpy(cp, RFTEMPLATE); + prvr = mktemp(fbuf2); + if (rename(fbuf, prvr) < 0 && errno != ENOENT) { + sprintf(errmsg, + "cannot rename \"%s\" to \"%s\"", + fbuf, prvr); + error(SYSTEM, errmsg); + } + } + } + /* render sequence */ + do { + if (seq && nextview(stdin) == EOF) + break; + if (pout != NULL) { + sprintf(fbuf, pout, seq); + if (freopen(fbuf, "w", stdout) == NULL) { + sprintf(errmsg, + "cannot open output file \"%s\"", fbuf); + error(SYSTEM, errmsg); + } +#ifdef MSDOS + setmode(fileno(stdout), O_BINARY); +#endif + dupheader(); + } + hres = hresolu; vres = vresolu; pa = pixaspect; + if (prvr != NULL) + if (viewfile(prvr, &ourview, &rs) <= 0 + || rs.or != PIXSTANDARD) { + sprintf(errmsg, + "cannot recover view parameters from \"%s\"", prvr); + error(WARNING, errmsg); + } else { + pa = 0.0; + hres = scanlen(&rs); + vres = numscans(&rs); + } + if ((cp = setview(&ourview)) != NULL) + error(USER, cp); + normaspect(viewaspect(&ourview), &pa, &hres, &vres); + if (seq) { + if (ralrm > 0) { + fprintf(stderr, "FRAME %d:", seq); + fprintview(&ourview, stderr); + putc('\n', stderr); + fflush(stderr); + } + printf("FRAME=%d\n", seq); + } + fputs(VIEWSTR, stdout); + fprintview(&ourview, stdout); + putchar('\n'); + if (pa < .99 || pa > 1.01) + fputaspect(pa, stdout); + fputformat(COLRFMT, stdout); + putchar('\n'); + if (zout != NULL) + sprintf(cp=fbuf, zout, seq); + else + cp = NULL; + render(cp, prvr); + prvr = NULL; + } while (seq++); +} + + +nextview(fp) /* get next view from fp */ +FILE *fp; +{ + char linebuf[256]; + + while (fgets(linebuf, sizeof(linebuf), fp) != NULL) + if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) + return(0); + return(EOF); +} + + render(zfile, oldfile) /* render the scene */ char *zfile, *oldfile; { @@ -131,25 +280,16 @@ char *zfile, *oldfile; COLOR *colptr; float *zptr; register int i; - /* check sampling */ - if (psample < 1) - psample = 1; - else if (psample > MAXDIV) { - sprintf(errmsg, "pixel sampling reduced from %d to %d", - psample, MAXDIV); - error(WARNING, errmsg); - psample = MAXDIV; - } /* allocate scanlines */ for (i = 0; i <= psample; i++) { - scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR)); + scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); if (scanbar[i] == NULL) goto memerr; } hstep = (psample*140+49)/99; /* quincunx sampling */ ystep = (psample*99+70)/140; if (hstep > 2) { - i = hresolu/hstep + 2; + i = hres/hstep + 2; if ((sampdens = malloc(i)) == NULL) goto memerr; while (i--) @@ -162,8 +302,11 @@ char *zfile, *oldfile; sprintf(errmsg, "cannot open z file \"%s\"", zfile); error(SYSTEM, errmsg); } +#ifdef MSDOS + setmode(zfd, O_BINARY); +#endif for (i = 0; i <= psample; i++) { - zbar[i] = (float *)malloc(hresolu*sizeof(float)); + zbar[i] = (float *)malloc(hres*sizeof(float)); if (zbar[i] == NULL) goto memerr; } @@ -173,21 +316,21 @@ char *zfile, *oldfile; zbar[i] = NULL; } /* write out boundaries */ - fprtresolu(hresolu, vresolu, stdout); + fprtresolu(hres, vres, stdout); /* recover file and compute first */ i = salvage(oldfile); if (zfd != -1 && i > 0 && - lseek(zfd, (long)i*hresolu*sizeof(float), 0) == -1) + lseek(zfd, (long)i*hres*sizeof(float), 0) == -1) error(SYSTEM, "z file seek error in render"); - pctdone = 100.0*i/vresolu; + pctdone = 100.0*i/vres; if (ralrm > 0) /* report init stats */ report(); -#ifndef BSD +#ifndef BSD else #endif - signal(SIGALRM, report); - ypos = vresolu-1 - i; - fillscanline(scanbar[0], zbar[0], sampdens, hresolu, ypos, hstep); + signal(SIGCONT, report); + ypos = vres-1 - i; + fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); /* compute scanlines */ for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { /* bottom adjust? */ @@ -203,43 +346,44 @@ char *zfile, *oldfile; zbar[0] = zptr; /* fill base line */ fillscanline(scanbar[0], zbar[0], sampdens, - hresolu, ypos, hstep); + hres, ypos, hstep); /* fill bar */ - fillscanbar(scanbar, zbar, hresolu, ypos, ystep); + fillscanbar(scanbar, zbar, hres, ypos, ystep); /* write it out */ -#ifndef BSD - signal(SIGALRM, SIG_IGN); /* don't interrupt writes */ +#ifndef BSD + signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ #endif for (i = ystep; i > 0; i--) { if (zfd != -1 && write(zfd, (char *)zbar[i], - hresolu*sizeof(float)) - < hresolu*sizeof(float)) + hres*sizeof(float)) + < hres*sizeof(float)) goto writerr; - if (fwritescan(scanbar[i], hresolu, stdout) < 0) + if (fwritescan(scanbar[i], hres, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF) goto writerr; /* record progress */ - pctdone = 100.0*(vresolu-1-ypos)/vresolu; + pctdone = 100.0*(vres-1-ypos)/vres; if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm) report(); -#ifndef BSD +#ifndef BSD else - signal(SIGALRM, report); + signal(SIGCONT, report); #endif } /* clean up */ + signal(SIGCONT, SIG_IGN); if (zfd != -1) { - if (write(zfd, (char *)zbar[0], hresolu*sizeof(float)) - < hresolu*sizeof(float)) + if (write(zfd, (char *)zbar[0], hres*sizeof(float)) + < hres*sizeof(float)) goto writerr; if (close(zfd) == -1) goto writerr; for (i = 0; i <= psample; i++) free((char *)zbar[i]); } - fwritescan(scanbar[0], hresolu, stdout); + fwritescan(scanbar[0], hres, stdout); if (fflush(stdout) == EOF) goto writerr; for (i = 0; i <= psample; i++) @@ -247,6 +391,9 @@ char *zfile, *oldfile; if (sampdens != NULL) free(sampdens); pctdone = 100.0; + if (ralrm > 0) + report(); + signal(SIGCONT, SIG_DFL); return; writerr: error(SYSTEM, "write error in render"); @@ -256,14 +403,14 @@ memerr: fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */ -register COLOR *scanline; -register float *zline; +register COLOR *scanline; +register float *zline; register char *sd; int xres, y, xstep; { static int nc = 0; /* number of calls */ int bl = xstep, b = xstep; - double z; + double z; register int i; z = pixvalue(scanline[0], 0, y); @@ -291,8 +438,8 @@ int xres, y, xstep; fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */ -register COLOR *scanbar[]; -register float *zbar[]; +register COLOR *scanbar[]; +register float *zbar[]; int xres, y, ysize; { COLOR vline[MAXDIV+1]; @@ -322,16 +469,15 @@ int xres, y, ysize; int -fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ -register COLOR *colline; -register float *zline; +fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ +register COLOR *colline; +register float *zline; int x, y; int xlen, ylen; int b; { - extern double fabs(); - double ratio; - double z; + double ratio; + double z; COLOR ctmp; int ncut; register int len; @@ -384,14 +530,14 @@ int x, y; /* pixel position */ static RAY thisray; if (viewray(thisray.rorg, thisray.rdir, &ourview, - (x+pixjitter())/hresolu, (y+pixjitter())/vresolu) < 0) { + (x+pixjitter())/hres, (y+pixjitter())/vres) < 0) { setcolor(col, 0.0, 0.0, 0.0); return(0.0); } rayorigin(&thisray, NULL, PRIMARY, 1.0); - samplendx = pixnumber(x,y,hresolu,vresolu); /* set pixel index */ + samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ rayvalue(&thisray); /* trace ray */ @@ -417,8 +563,11 @@ char *oldfile; error(WARNING, errmsg); return(0); } +#ifdef MSDOS + setmode(fileno(fp), O_BINARY); +#endif /* discard header */ - getheader(fp, NULL); + getheader(fp, NULL, NULL); /* get picture size */ if (!fscnresolu(&x, &y, fp)) { sprintf(errmsg, "bad recover file \"%s\"", oldfile); @@ -427,19 +576,19 @@ char *oldfile; return(0); } - if (x != hresolu || y != vresolu) { + if (x != hres || y != vres) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); } - scanline = (COLR *)malloc(hresolu*sizeof(COLR)); + scanline = (COLR *)malloc(hres*sizeof(COLR)); if (scanline == NULL) error(SYSTEM, "out of memory in salvage"); - for (y = 0; y < vresolu; y++) { - if (freadcolrs(scanline, hresolu, fp) < 0) + for (y = 0; y < vres; y++) { + if (freadcolrs(scanline, hres, fp) < 0) break; - if (fwritecolrs(scanline, hresolu, stdout) < 0) + if (fwritecolrs(scanline, hres, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF) @@ -449,7 +598,8 @@ char *oldfile; unlink(oldfile); return(y); writerr: - error(SYSTEM, "write error in salvage"); + sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); + error(SYSTEM, errmsg); }
