Decreased -lw default
Removed '//' comment lines that shouldn't be in C code
Implemented Mark Stock's fix for depth-of-field blur
Made depth-of-field aperture sampling over a disk rather than a square
Made -u+ option truly random
Robustness improvements in depth-of-field blurring
Minor code improvements
Various compatibility fixes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Fixed fputnow() call to match prototype.
Got some feature dependency backwards.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Compile fixes for Linux
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
moved lseek() and ftell() declarations to standard.h
added missing calls to setview()
added -pm option for motion blurring
added test of directvis before call to drawsources()
made bitty source drawing more efficient
slight improvement for recovering complete file
added -bv option for back face visibility (normally on)
compiler error fix for AIX
added insurance that picture header is written right away
added insurance policy against undefined CLK_TCK variable
fixed error in SIGCONT catching for System V
fixed use of uname()
improved(?) portability of usage stuff for System V
compatibility fixes
fixed time declaration and use
fixed time reporting for non-BSD machines(?)
improved error reporting on bad recover files
more sensible warning for nonexistent -ro file
improved error testing for noclobber feature of -o option
made it so -o option will not clobber files
reinitialized pctdone in rpict()
added final instruction to render() to set SIGCONT to default action
changed signals so ALRM always causes exit, CONT now used by rpict
changed -di to ! -dv
fixed call to getheader() to pass 3 arguments always (DOS bug fix)
bug fixes for MS-DOS
added setmode(fd,O_BINARY) where needed for MSDOS
Changes for 32-bit PC port
Changes for PC port
put back in final report() call
added view parameters to frame reporting
fixed bug in testing of recover file rename
improved efficiency of view skipping slightly
added -o and -S options for image sequences and slave operation
forgot to disable alarm signal before final writes
changed default values and handling of specthresh
added -sj and -st options and changed old -s options to -p
minor change to signal handling under System V
bug fix in sampling underwriting scanline buffer
improved sampling
signal.h
changed to quincunx pattern for initial image samples
improved ALRM signal handling for SYSV
increased defaults for -dp parameter
added virtual sources
reduced MAXDIV and added warning if it is exceeded
changed reporting so that alarm() is not used.
eliminated unnecessary call to lseek in render()
added fisheye view types
fixed computation of pctdone
changed include of fcntl.h
changed reading and writing of z-files and viewfiles
simplified residual calculation
added reset to report signal for SYS V
added z-file output to rpict
Fixed routines to render only desired pixels
Corrected resolution of output to correspond to request.
Added xres,yres variables so we don't mung ourview.[hv]resolu
Added calls to picture resolution get/put routines
Reduced default ambient resolution
Efficient approximation to direct component with many sources Glow type changed Spot type eliminated
Added warnings for inappropriate recover files
