--- ray/src/rt/rpict.c 1989/09/13 15:21:41 1.8 +++ ray/src/rt/rpict.c 2005/04/19 01:15:06 2.75 @@ -1,298 +1,811 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rpict.c,v 2.75 2005/04/19 01:15:06 greg Exp $"; #endif - /* * rpict.c - routines and variables for picture generation. - * - * 8/14/85 */ -#include "ray.h" +#include "copyright.h" +#include + +#ifndef NON_POSIX #ifdef BSD #include #include +#else +#include +#include #endif +#endif -#include "view.h" +#include +#include +#include "platform.h" +#include "ray.h" +#include "paths.h" +#include "ambient.h" +#include "view.h" #include "random.h" +#include "paths.h" +#include "rtmisc.h" /* myhostname() */ -VIEW ourview = STDVIEW(512); /* view parameters */ +#define RFTEMPLATE "rfXXXXXX" + +#ifndef SIGCONT +#ifdef SIGIO /* XXX can we live without this? */ +#define SIGCONT SIGIO +#endif +#endif + +CUBE thescene; /* our scene */ +OBJECT nsceneobjs; /* number of objects in our scene */ + +int dimlist[MAXDIM]; /* sampling dimensions */ +int ndims = 0; /* number of sampling dimensions */ +int samplendx; /* sample index number */ + +//extern void ambnotify(); +void (*addobjnotify[])() = {ambnotify, NULL}; + +VIEW ourview = STDVIEW; /* view parameters */ +int hresolu = 512; /* horizontal resolution */ +int vresolu = 512; /* vertical resolution */ +double pixaspect = 1.0; /* pixel aspect ratio */ + int psample = 4; /* pixel sample size */ -double maxdiff = .05; /* max. difference for interpolation */ -double dstrpix = 0.67; /* square pixel distribution */ +double maxdiff = .05; /* max. difference for interpolation */ +double dstrpix = 0.67; /* square pixel distribution */ -double dstrsrc = 0.0; /* square source distribution */ -double shadthresh = .05; /* shadow threshold */ -double shadcert = .5; /* shadow certainty */ +double mblur = 0.; /* motion blur parameter */ -int maxdepth = 6; /* maximum recursion depth */ -double minweight = 5e-3; /* minimum ray weight */ +double dblur = 0.; /* depth-of-field blur parameter */ +void (*trace)() = NULL; /* trace call */ + +int do_irrad = 0; /* compute irradiance? */ + +double dstrsrc = 0.0; /* square source distribution */ +double shadthresh = .05; /* shadow threshold */ +double shadcert = .5; /* shadow certainty */ +int directrelay = 1; /* number of source relays */ +int vspretest = 512; /* virtual source pretest density */ +int directvis = 1; /* sources visible? */ +double srcsizerat = .25; /* maximum ratio source size/dist. */ + +COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ +COLOR salbedo = BLKCOLOR; /* global scattering albedo */ +double seccg = 0.; /* global scattering eccentricity */ +double ssampdist = 0.; /* scatter sampling distance */ + +double specthresh = .15; /* specular sampling threshold */ +double specjitter = 1.; /* specular sampling jitter */ + +int backvis = 1; /* back face visibility */ + +int maxdepth = 7; /* maximum recursion depth */ +double minweight = 4e-3; /* minimum ray weight */ + +char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ -double ambacc = 0.2; /* ambient accuracy */ -int ambres = 32; /* ambient resolution */ -int ambdiv = 128; /* ambient divisions */ -int ambssamp = 0; /* ambient super-samples */ +int ambvwt = 0; /* initial weight for ambient value */ +double ambacc = 0.2; /* ambient accuracy */ +int ambres = 64; /* ambient resolution */ +int ambdiv = 512; /* ambient divisions */ +int ambssamp = 128; /* ambient super-samples */ int ambounce = 0; /* ambient bounces */ -char *amblist[128]; /* ambient include/exclude list */ +char *amblist[AMBLLEN]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ int ralrm = 0; /* seconds between reports */ -double pctdone = 0.0; /* percentage done */ +double pctdone = 0.0; /* percentage done */ +time_t tlastrept = 0L; /* time at last report */ +time_t tstart; /* starting time */ -extern long nrays; /* number of rays traced */ +#define MAXDIV 16 /* maximum sample size */ -static int xres, yres; /* output x and y resolution */ +#define pixjitter() (.5+dstrpix*(.5-frandom())) -#define MAXDIV 32 /* maximum sample size */ +int hres, vres; /* resolution for this frame */ -#define pixjitter() (.5+dstrpix*(.5-frandom())) +static VIEW lastview; /* the previous view input */ +//extern char *mktemp(); /* XXX should be in stdlib.h or unistd.h */ +//double pixvalue(); + +static void report(int); +static int nextview(FILE *fp); +static void render(char *zfile, char *oldfile); +static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres, + int y, int xstep); +static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres, + int y, int ysize); +static int fillsample(COLOR *colline, float *zline, int x, int y, + int xlen, int ylen, int b); +static double pixvalue(COLOR col, int x, int y); +static int salvage(char *oldfile); +static int pixnumber(int x, int y, int xres, int yres); + + + +#ifdef RHAS_STAT +#include +#include +int +file_exists(fname) /* ordinary file exists? */ +char *fname; +{ + struct stat sbuf; + if (stat(fname, &sbuf) < 0) return(0); + return((sbuf.st_mode & S_IFREG) != 0); +} +#else +#define file_exists(f) (access(f,F_OK)==0) +#endif + + +void quit(code) /* quit program */ int code; { - if (code || ralrm > 0) /* report status */ - report(); - + if (code) /* report status */ + report(0); +#ifndef NON_POSIX + headclean(); /* delete header file */ + pfclean(); /* clean up persist files */ +#endif exit(code); } -report() /* report progress */ +#ifndef NON_POSIX +static void +report(int dummy) /* report progress */ { + double u, s; #ifdef BSD struct rusage rubuf; - double t; +#else + struct tms tbuf; + double period; +#endif + tlastrept = time((time_t *)NULL); +#ifdef BSD getrusage(RUSAGE_SELF, &rubuf); - t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; - t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec; + u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; + s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; getrusage(RUSAGE_CHILDREN, &rubuf); - t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; - t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec; - - sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n", - nrays, pctdone, t/3600.0); + u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; + s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; #else - sprintf(errmsg, "%ld rays, %4.2f%% done\n", nrays, pctdone); + times(&tbuf); +#ifdef _SC_CLK_TCK + period = 1.0 / sysconf(_SC_CLK_TCK); +#else + period = 1.0 / 60.0; #endif + u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period; + s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period; +#endif + + sprintf(errmsg, + "%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n", + nrays, pctdone, u/3600., s/3600., + (tlastrept-tstart)/3600., myhostname()); eputs(errmsg); +#ifdef SIGCONT + signal(SIGCONT, report); +#endif +} +#else +static void +report(int dummy) /* report progress */ +{ + tlastrept = time((time_t *)NULL); + sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n", + nrays, pctdone, (tlastrept-tstart)/3600.0); + eputs(errmsg); +} +#endif - if (ralrm > 0) - alarm(ralrm); + +extern void +rpict( /* generate image(s) */ + int seq, + char *pout, + char *zout, + char *prvr +) +/* + * If seq is greater than zero, then we will render a sequence of + * images based on view parameter strings read from the standard input. + * If pout is NULL, then all images will be sent to the standard ouput. + * If seq is greater than zero and prvr is an integer, then it is the + * frame number at which rendering should begin. Preceeding view parameter + * strings will be skipped in the input. + * If pout and prvr are the same, prvr is renamed to avoid overwriting. + * Note that pout and zout should contain %d format specifications for + * sequenced file naming. + */ +{ + char fbuf[128], fbuf2[128]; + int npicts; + register char *cp; + RESOLU rs; + double pa; + /* check sampling */ + if (psample < 1) + psample = 1; + else if (psample > MAXDIV) { + sprintf(errmsg, "pixel sampling reduced from %d to %d", + psample, MAXDIV); + error(WARNING, errmsg); + psample = MAXDIV; + } + /* get starting frame */ + if (seq <= 0) + seq = 0; + else if (prvr != NULL && isint(prvr)) { + register int rn; /* skip to specified view */ + if ((rn = atoi(prvr)) < seq) + error(USER, "recover frame less than start frame"); + if (pout == NULL) + error(USER, "missing output file specification"); + for ( ; seq < rn; seq++) + if (nextview(stdin) == EOF) + error(USER, "unexpected EOF on view input"); + setview(&ourview); + prvr = fbuf; /* mark for renaming */ + } + if ((pout != NULL) & (prvr != NULL)) { + sprintf(fbuf, pout, seq); + if (!strcmp(prvr, fbuf)) { /* rename */ + strcpy(fbuf2, fbuf); + for (cp = fbuf2; *cp; cp++) + ; + while (cp > fbuf2 && !ISDIRSEP(cp[-1])) + cp--; + strcpy(cp, RFTEMPLATE); + prvr = mktemp(fbuf2); + if (rename(fbuf, prvr) < 0) { + if (errno == ENOENT) { /* ghost file */ + sprintf(errmsg, + "new output file \"%s\"", + fbuf); + error(WARNING, errmsg); + prvr = NULL; + } else { /* serious error */ + sprintf(errmsg, + "cannot rename \"%s\" to \"%s\"", + fbuf, prvr); + error(SYSTEM, errmsg); + } + } + } + } + npicts = 0; /* render sequence */ + do { + if (seq && nextview(stdin) == EOF) + break; + pctdone = 0.0; + if (pout != NULL) { + sprintf(fbuf, pout, seq); + if (file_exists(fbuf)) { + if (prvr != NULL || !strcmp(fbuf, pout)) { + sprintf(errmsg, + "output file \"%s\" exists", + fbuf); + error(USER, errmsg); + } + setview(&ourview); + continue; /* don't clobber */ + } + if (freopen(fbuf, "w", stdout) == NULL) { + sprintf(errmsg, + "cannot open output file \"%s\"", fbuf); + error(SYSTEM, errmsg); + } + SET_FILE_BINARY(stdout); + dupheader(); + } + hres = hresolu; vres = vresolu; pa = pixaspect; + if (prvr != NULL) { + if (viewfile(prvr, &ourview, &rs) <= 0) { + sprintf(errmsg, + "cannot recover view parameters from \"%s\"", prvr); + error(WARNING, errmsg); + } else { + pa = 0.0; + hres = scanlen(&rs); + vres = numscans(&rs); + } + } + if ((cp = setview(&ourview)) != NULL) + error(USER, cp); + normaspect(viewaspect(&ourview), &pa, &hres, &vres); + if (seq) { + if (ralrm > 0) { + fprintf(stderr, "FRAME %d:", seq); + fprintview(&ourview, stderr); + putc('\n', stderr); + fflush(stderr); + } + printf("FRAME=%d\n", seq); + } + fputs(VIEWSTR, stdout); + fprintview(&ourview, stdout); + putchar('\n'); + if (pa < .99 || pa > 1.01) + fputaspect(pa, stdout); + fputnow(stdout); + fputformat(COLRFMT, stdout); + putchar('\n'); + if (zout != NULL) + sprintf(cp=fbuf, zout, seq); + else + cp = NULL; + render(cp, prvr); + prvr = NULL; + npicts++; + } while (seq++); + /* check that we did something */ + if (npicts == 0) + error(WARNING, "no output produced"); } -render(oldfile) /* render the scene */ -char *oldfile; +static int +nextview( /* get next view from fp */ + FILE *fp +) { + char linebuf[256]; + + lastview = ourview; + while (fgets(linebuf, sizeof(linebuf), fp) != NULL) + if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) + return(0); + return(EOF); +} + + +static void +render( /* render the scene */ + char *zfile, + char *oldfile +) +{ COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ + float *zbar[MAXDIV+1]; /* z values */ + char *sampdens; /* previous sample density */ int ypos; /* current scanline */ + int ystep; /* current y step size */ + int hstep; /* h step size */ + int zfd; COLOR *colptr; + float *zptr; register int i; - - if (psample < 1) - psample = 1; - else if (psample > MAXDIV) - psample = MAXDIV; - /* output resolution may be smaller */ - xres = ourview.hresolu - (ourview.hresolu % psample); - yres = ourview.vresolu - (ourview.vresolu % psample); - + /* check for empty image */ + if (hres <= 0 || vres <= 0) { + error(WARNING, "empty output picture"); + fprtresolu(0, 0, stdout); + return; + } + /* allocate scanlines */ for (i = 0; i <= psample; i++) { - scanbar[i] = (COLOR *)malloc((xres+1)*sizeof(COLOR)); + scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); if (scanbar[i] == NULL) - error(SYSTEM, "out of memory in render"); + goto memerr; } + hstep = (psample*140+49)/99; /* quincunx sampling */ + ystep = (psample*99+70)/140; + if (hstep > 2) { + i = hres/hstep + 2; + if ((sampdens = (char *)malloc(i)) == NULL) + goto memerr; + while (i--) + sampdens[i] = hstep; + } else + sampdens = NULL; + /* open z-file */ + if (zfile != NULL) { + if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { + sprintf(errmsg, "cannot open z-file \"%s\"", zfile); + error(SYSTEM, errmsg); + } + SET_FD_BINARY(zfd); + for (i = 0; i <= psample; i++) { + zbar[i] = (float *)malloc(hres*sizeof(float)); + if (zbar[i] == NULL) + goto memerr; + } + } else { + zfd = -1; + for (i = 0; i <= psample; i++) + zbar[i] = NULL; + } /* write out boundaries */ - fputresolu(YMAJOR|YDECR, xres, yres, stdout); - - ypos = yres - salvage(oldfile); /* find top line */ - fillscanline(scanbar[0], ypos, psample); /* top scan */ - - for (ypos -= psample; ypos > -psample; ypos -= psample) { - - colptr = scanbar[psample]; /* get last scanline */ - scanbar[psample] = scanbar[0]; + fprtresolu(hres, vres, stdout); + /* recover file and compute first */ + i = salvage(oldfile); + if (i >= vres) + goto alldone; + if (zfd != -1 && i > 0 && + lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0) + error(SYSTEM, "z-file seek error in render"); + pctdone = 100.0*i/vres; + if (ralrm > 0) /* report init stats */ + report(0); +#ifdef SIGCONT + else + signal(SIGCONT, report); +#endif + ypos = vres-1 - i; /* initialize sampling */ + if (directvis) + init_drawsources(psample); + fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); + /* compute scanlines */ + for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { + /* bottom adjust? */ + if (ypos < 0) { + ystep += ypos; + ypos = 0; + } + colptr = scanbar[ystep]; /* move base to top */ + scanbar[ystep] = scanbar[0]; scanbar[0] = colptr; - - fillscanline(scanbar[0], ypos, psample); /* base scan */ - - fillscanbar(scanbar, ypos, psample); - - for (i = psample-1; i >= 0; i--) - if (fwritescan(scanbar[i], xres, stdout) < 0) + zptr = zbar[ystep]; + zbar[ystep] = zbar[0]; + zbar[0] = zptr; + /* fill base line */ + fillscanline(scanbar[0], zbar[0], sampdens, + hres, ypos, hstep); + /* fill bar */ + fillscanbar(scanbar, zbar, hres, ypos, ystep); + if (directvis) /* add bitty sources */ + drawsources(scanbar, zbar, 0, hres, ypos, ystep); + /* write it out */ +#ifdef SIGCONT + signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ +#endif + for (i = ystep; i > 0; i--) { + if (zfd != -1 && write(zfd, (char *)zbar[i], + hres*sizeof(float)) + < hres*sizeof(float)) goto writerr; + if (fwritescan(scanbar[i], hres, stdout) < 0) + goto writerr; + } if (fflush(stdout) == EOF) goto writerr; - pctdone = 100.0*(yres-ypos)/yres; + /* record progress */ + pctdone = 100.0*(vres-1-ypos)/vres; + if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm) + report(0); +#ifdef SIGCONT + else + signal(SIGCONT, report); +#endif } - + /* clean up */ +#ifdef SIGCONT + signal(SIGCONT, SIG_IGN); +#endif + if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float)) + < hres*sizeof(float)) + goto writerr; + fwritescan(scanbar[0], hres, stdout); + if (fflush(stdout) == EOF) + goto writerr; +alldone: + if (zfd != -1) { + if (close(zfd) == -1) + goto writerr; + for (i = 0; i <= psample; i++) + free((void *)zbar[i]); + } for (i = 0; i <= psample; i++) - free((char *)scanbar[i]); + free((void *)scanbar[i]); + if (sampdens != NULL) + free(sampdens); + pctdone = 100.0; + if (ralrm > 0) + report(0); +#ifdef SIGCONT + signal(SIGCONT, SIG_DFL); +#endif return; writerr: error(SYSTEM, "write error in render"); +memerr: + error(SYSTEM, "out of memory in render"); } -fillscanline(scanline, y, xstep) /* fill scan line at y */ -register COLOR *scanline; -int y, xstep; +static void +fillscanline( /* fill scan at y */ + register COLOR *scanline, + register float *zline, + register char *sd, + int xres, + int y, + int xstep +) { - int b = xstep; + static int nc = 0; /* number of calls */ + int bl = xstep, b = xstep; + double z; register int i; - - pixvalue(scanline[0], 0, y); - for (i = xstep; i <= xres; i += xstep) { - - pixvalue(scanline[i], i, y); - - b = fillsample(scanline+i-xstep, i-xstep, y, xstep, 0, b/2); + z = pixvalue(scanline[0], 0, y); + if (zline) zline[0] = z; + /* zig-zag start for quincunx pattern */ + for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) { + if (i >= xres) { + xstep += xres-1-i; + i = xres-1; + } + z = pixvalue(scanline[i], i, y); + if (zline) zline[i] = z; + if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1]; + if (i <= xstep) + b = fillsample(scanline, zline, 0, y, i, 0, b/2); + else + b = fillsample(scanline+i-xstep, + zline ? zline+i-xstep : (float *)NULL, + i-xstep, y, xstep, 0, b/2); + if (sd) *sd++ = nc & 1 ? bl : b; + bl = b; } + if (sd && nc & 1) *sd = bl; } -fillscanbar(scanbar, y, ysize) /* fill interior */ -register COLOR *scanbar[]; -int y, ysize; +static void +fillscanbar( /* fill interior */ + register COLOR *scanbar[], + register float *zbar[], + int xres, + int y, + int ysize +) { COLOR vline[MAXDIV+1]; + float zline[MAXDIV+1]; int b = ysize; register int i, j; - + for (i = 0; i < xres; i++) { - copycolor(vline[0], scanbar[0][i]); copycolor(vline[ysize], scanbar[ysize][i]); - - b = fillsample(vline, i, y, 0, ysize, b/2); - + if (zbar[0]) { + zline[0] = zbar[0][i]; + zline[ysize] = zbar[ysize][i]; + } + b = fillsample(vline, zbar[0] ? zline : (float *)NULL, + i, y, 0, ysize, b/2); + for (j = 1; j < ysize; j++) copycolor(scanbar[j][i], vline[j]); + if (zbar[0]) + for (j = 1; j < ysize; j++) + zbar[j][i] = zline[j]; } } -int -fillsample(colline, x, y, xlen, ylen, b) /* fill interior points */ -register COLOR *colline; -int x, y; -int xlen, ylen; -int b; +static int +fillsample( /* fill interior points */ + register COLOR *colline, + register float *zline, + int x, + int y, + int xlen, + int ylen, + int b +) { - double ratio; + double ratio; + double z; COLOR ctmp; int ncut; register int len; - + if (xlen > 0) /* x or y length is zero */ len = xlen; else len = ylen; - + if (len <= 1) /* limit recursion */ return(0); - - if (b > 0 || bigdiff(colline[0], colline[len], maxdiff)) { - - pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); + + if (b > 0 || + (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) + || bigdiff(colline[0], colline[len], maxdiff)) { + + z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); + if (zline) zline[len>>1] = z; ncut = 1; - } else { /* interpolate */ - copycolor(colline[len>>1], colline[len]); ratio = (double)(len>>1) / len; scalecolor(colline[len>>1], ratio); - copycolor(ctmp, colline[0]); + if (zline) zline[len>>1] = zline[len] * ratio; ratio = 1.0 - ratio; + copycolor(ctmp, colline[0]); scalecolor(ctmp, ratio); addcolor(colline[len>>1], ctmp); + if (zline) zline[len>>1] += zline[0] * ratio; ncut = 0; } /* recurse */ - ncut += fillsample(colline, x, y, xlen>>1, ylen>>1, (b-1)/2); - - ncut += fillsample(colline + (len>>1), x + (xlen>>1), y + (ylen>>1), - xlen - (xlen>>1), ylen - (ylen>>1), b/2); + ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); + ncut += fillsample(colline+(len>>1), + zline ? zline+(len>>1) : (float *)NULL, + x+(xlen>>1), y+(ylen>>1), + xlen-(xlen>>1), ylen-(ylen>>1), b/2); + return(ncut); } -pixvalue(col, x, y) /* compute pixel value */ -COLOR col; /* returned color */ -int x, y; /* pixel position */ +static double +pixvalue( /* compute pixel value */ + COLOR col, /* returned color */ + int x, /* pixel position */ + int y +) { - static RAY thisray; /* our ray for this pixel */ + RAY thisray; + FVECT lorg, ldir; + double hpos, vpos, vdist, lmax; + register int i; + /* compute view ray */ + hpos = (x+pixjitter())/hres; + vpos = (y+pixjitter())/vres; + if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, + &ourview, hpos, vpos)) < -FTINY) { + setcolor(col, 0.0, 0.0, 0.0); + return(0.0); + } + vdist = ourview.vdist; - rayview(thisray.rorg, thisray.rdir, &ourview, - x + pixjitter(), y + pixjitter()); + samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ - rayorigin(&thisray, NULL, PRIMARY, 1.0); - + /* optional motion blur */ + if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir, + &lastview, hpos, vpos)) >= -FTINY) { + register double d = mblur*(.5-urand(281+samplendx)); + + thisray.rmax = (1.-d)*thisray.rmax + d*lmax; + for (i = 3; i--; ) { + thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i]; + thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i]; + } + if (normalize(thisray.rdir) == 0.0) + return(0.0); + vdist = (1.-d)*vdist + d*lastview.vdist; + } + /* optional depth-of-field */ + if (dblur > FTINY && vdist > FTINY) { + double vc, dfh, dfv; + /* PI/4. square/circle conv. */ + dfh = PI/4.*dblur*(.5 - frandom()); + dfv = PI/4.*dblur*(.5 - frandom()); + if (ourview.type == VT_PER || ourview.type == VT_PAR) { + dfh /= sqrt(ourview.hn2); + dfv /= sqrt(ourview.vn2); + for (i = 3; i--; ) { + vc = thisray.rorg[i] + vdist*thisray.rdir[i]; + thisray.rorg[i] += dfh*ourview.hvec[i] + + dfv*ourview.vvec[i] ; + thisray.rdir[i] = vc - thisray.rorg[i]; + } + } else { /* non-standard view case */ + double dfd = PI/4.*dblur*(.5 - frandom()); + if (ourview.type != VT_ANG) { + if (ourview.type != VT_CYL) + dfh /= sqrt(ourview.hn2); + dfv /= sqrt(ourview.vn2); + } + for (i = 3; i--; ) { + vc = thisray.rorg[i] + vdist*thisray.rdir[i]; + thisray.rorg[i] += dfh*ourview.hvec[i] + + dfv*ourview.vvec[i] + + dfd*ourview.vdir[i] ; + thisray.rdir[i] = vc - thisray.rorg[i]; + } + } + if (normalize(thisray.rdir) == 0.0) + return(0.0); + } + + rayorigin(&thisray, PRIMARY, NULL, NULL); + rayvalue(&thisray); /* trace ray */ copycolor(col, thisray.rcol); /* return color */ + + return(thisray.rt); /* return distance */ } -int -salvage(oldfile) /* salvage scanlines from killed program */ -char *oldfile; +static int +salvage( /* salvage scanlines from killed program */ + char *oldfile +) { COLR *scanline; FILE *fp; int x, y; if (oldfile == NULL) - return(0); - else if ((fp = fopen(oldfile, "r")) == NULL) { + goto gotzip; + + if ((fp = fopen(oldfile, "r")) == NULL) { sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); error(WARNING, errmsg); - return(0); + goto gotzip; } + SET_FILE_BINARY(fp); /* discard header */ - getheader(fp, NULL); + getheader(fp, NULL, NULL); /* get picture size */ - if (fgetresolu(&x, &y, fp) != (YMAJOR|YDECR)) { - sprintf(errmsg, "bad recover file \"%s\"", oldfile); + if (!fscnresolu(&x, &y, fp)) { + sprintf(errmsg, "bad recover file \"%s\" - not removed", + oldfile); error(WARNING, errmsg); fclose(fp); - return(0); + goto gotzip; } - if (x != xres || y != yres) { + if (x != hres || y != vres) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); - return(0); } - scanline = (COLR *)malloc(xres*sizeof(COLR)); + scanline = (COLR *)malloc(hres*sizeof(COLR)); if (scanline == NULL) error(SYSTEM, "out of memory in salvage"); - for (y = 0; y < yres; y++) { - if (freadcolrs(scanline, xres, fp) < 0) + for (y = 0; y < vres; y++) { + if (freadcolrs(scanline, hres, fp) < 0) break; - if (fwritecolrs(scanline, xres, stdout) < 0) + if (fwritecolrs(scanline, hres, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF) goto writerr; - free((char *)scanline); + free((void *)scanline); fclose(fp); unlink(oldfile); return(y); +gotzip: + if (fflush(stdout) == EOF) + error(SYSTEM, "error writing picture header"); + return(0); writerr: - error(SYSTEM, "write error in salvage"); + sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); + error(SYSTEM, errmsg); + return -1; /* pro forma return */ +} + +static int +pixnumber( /* compute pixel index (brushed) */ + register int x, + register int y, + int xres, + int yres +) +{ + x -= y; + while (x < 0) + x += xres; + return((((x>>2)*yres + y) << 2) + (x & 3)); }
