--- ray/src/rt/rpict.c 1989/09/12 12:28:26 1.7 +++ ray/src/rt/rpict.c 1992/11/19 20:25:57 2.20 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -17,25 +17,45 @@ static char SCCSid[] = "$SunId$ LBL"; #include #endif +#include + #include "view.h" +#include "resolu.h" + #include "random.h" -VIEW ourview = STDVIEW(512); /* view parameters */ +#include "paths.h" +int dimlist[MAXDIM]; /* sampling dimensions */ +int ndims = 0; /* number of sampling dimensions */ +int samplendx; /* sample index number */ + +VIEW ourview = STDVIEW; /* view parameters */ +int hresolu = 512; /* horizontal resolution */ +int vresolu = 512; /* vertical resolution */ +double pixaspect = 1.0; /* pixel aspect ratio */ + int psample = 4; /* pixel sample size */ -double maxdiff = .05; /* max. difference for interpolation */ -double dstrpix = 0.67; /* square pixel distribution */ +double maxdiff = .05; /* max. difference for interpolation */ +double dstrpix = 0.67; /* square pixel distribution */ -double dstrsrc = 0.0; /* square source distribution */ -double shadthresh = .05; /* shadow threshold */ -double shadcert = .5; /* shadow certainty */ +double dstrsrc = 0.0; /* square source distribution */ +double shadthresh = .05; /* shadow threshold */ +double shadcert = .5; /* shadow certainty */ +int directrelay = 1; /* number of source relays */ +int vspretest = 512; /* virtual source pretest density */ +int directvis = 1; /* sources visible? */ +double srcsizerat = .25; /* maximum ratio source size/dist. */ +double specthresh = .15; /* specular sampling threshold */ +double specjitter = 1.; /* specular sampling jitter */ + int maxdepth = 6; /* maximum recursion depth */ -double minweight = 5e-3; /* minimum ray weight */ +double minweight = 5e-3; /* minimum ray weight */ COLOR ambval = BLKCOLOR; /* ambient value */ -double ambacc = 0.2; /* ambient accuracy */ +double ambacc = 0.2; /* ambient accuracy */ int ambres = 32; /* ambient resolution */ int ambdiv = 128; /* ambient divisions */ int ambssamp = 0; /* ambient super-samples */ @@ -43,32 +63,57 @@ int ambounce = 0; /* ambient bounces */ char *amblist[128]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ +#ifdef MSDOS +int ralrm = 60; /* seconds between reports */ +#else int ralrm = 0; /* seconds between reports */ +#endif -double pctdone = 0.0; /* percentage done */ +double pctdone = 0.0; /* percentage done */ +long tlastrept = 0L; /* time at last report */ + +extern long time(); +extern long tstart; /* starting time */ + extern long nrays; /* number of rays traced */ -#define MAXDIV 32 /* maximum sample size */ +#define MAXDIV 16 /* maximum sample size */ -#define pixjitter() (.5+dstrpix*(.5-frandom())) +#define pixjitter() (.5+dstrpix*(.5-frandom())) +#define RFTEMPLATE "rfXXXXXX" +#define HFTEMPLATE TEMPLATE +static char *hfname = NULL; /* header file name */ +static FILE *hfp = NULL; /* header file pointer */ + +static int hres, vres; /* resolution for this frame */ + +extern char *mktemp(); + +double pixvalue(); + + quit(code) /* quit program */ int code; { - if (code || ralrm > 0) /* report status */ + if (code) /* report status */ report(); - + if (hfname != NULL) { /* delete header file */ + if (hfp != NULL) + fclose(hfp); + unlink(hfname); + } exit(code); } +#ifdef BSD report() /* report progress */ { -#ifdef BSD struct rusage rubuf; - double t; + double t; getrusage(RUSAGE_SELF, &rubuf); t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; @@ -79,117 +124,389 @@ report() /* report progress */ sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n", nrays, pctdone, t/3600.0); + eputs(errmsg); + tlastrept = time((long *)0); +} #else - sprintf(errmsg, "%ld rays, %4.2f%% done\n", nrays, pctdone); -#endif +report() /* report progress */ +{ + tlastrept = time((long *)0); + sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n", + nrays, pctdone, (tlastrept-tstart)/3600.0); eputs(errmsg); + signal(SIGALRM, report); +} +#endif - if (ralrm > 0) - alarm(ralrm); + +openheader() /* save standard output to header file */ +{ + hfname = mktemp(HFTEMPLATE); + if (freopen(hfname, "w", stdout) == NULL) { + sprintf(errmsg, "cannot open header file \"%s\"", hfname); + error(SYSTEM, errmsg); + } } -render(oldfile) /* render the scene */ -char *oldfile; +dupheader() /* repeat header on standard output */ { - COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ - int ypos; /* current scanline */ - COLOR *colptr; - register int i; + register int c; + if (hfp == NULL) { + if ((hfp = fopen(hfname, "r")) == NULL) + error(SYSTEM, "error reopening header file"); +#ifdef MSDOS + setmode(fileno(hfp), O_BINARY); +#endif + } else if (fseek(hfp, 0L, 0) < 0) + error(SYSTEM, "seek error on header file"); + while ((c = getc(hfp)) != EOF) + putchar(c); +} + + +rpict(seq, pout, zout, prvr) /* generate image(s) */ +int seq; +char *pout, *zout, *prvr; +/* + * If seq is greater than zero, then we will render a sequence of + * images based on view parameter strings read from the standard input. + * If pout is NULL, then all images will be sent to the standard ouput. + * If seq is greater than zero and prvr is an integer, then it is the + * frame number at which rendering should begin. Preceeding view parameter + * strings will be skipped in the input. + * If pout and prvr are the same, prvr is renamed to avoid overwriting. + * Note that pout and zout should contain %d format specifications for + * sequenced file naming. + */ +{ + extern char *rindex(), *strncpy(), *strcat(); + char fbuf[128], fbuf2[128]; + register char *cp; + RESOLU rs; + double pa; + /* check sampling */ if (psample < 1) psample = 1; - else if (psample > MAXDIV) + else if (psample > MAXDIV) { + sprintf(errmsg, "pixel sampling reduced from %d to %d", + psample, MAXDIV); + error(WARNING, errmsg); psample = MAXDIV; + } + /* get starting frame */ + if (seq <= 0) + seq = 0; + else if (prvr != NULL && isint(prvr)) { + register int rn; /* skip to specified view */ + if ((rn = atoi(prvr)) < seq) + error(USER, "recover frame less than start frame"); + if (pout == NULL) + error(USER, "missing output file specification"); + for ( ; seq < rn; seq++) + if (nextview(stdin) == EOF) + error(USER, "unexpected EOF on view input"); + prvr = fbuf; /* mark for renaming */ + } + if (pout != NULL & prvr != NULL) { + sprintf(fbuf, pout, seq); + if (!strcmp(prvr, fbuf)) { /* rename */ + strcpy(fbuf2, fbuf); + for (cp = fbuf2; *cp; cp++) + ; + while (cp > fbuf2 && !ISDIRSEP(cp[-1])) + cp--; + strcpy(cp, RFTEMPLATE); + prvr = mktemp(fbuf2); + if (rename(fbuf, prvr) < 0 && errno != ENOENT) { + sprintf(errmsg, + "cannot rename \"%s\" to \"%s\"", + fbuf, prvr); + error(SYSTEM, errmsg); + } + } + } + /* render sequence */ + do { + if (seq && nextview(stdin) == EOF) + break; + if (pout != NULL) { + sprintf(fbuf, pout, seq); + if (freopen(fbuf, "w", stdout) == NULL) { + sprintf(errmsg, + "cannot open output file \"%s\"", fbuf); + error(SYSTEM, errmsg); + } +#ifdef MSDOS + setmode(fileno(stdout), O_BINARY); +#endif + dupheader(); + } + hres = hresolu; vres = vresolu; pa = pixaspect; + if (prvr != NULL) + if (viewfile(prvr, &ourview, &rs) <= 0 + || rs.or != PIXSTANDARD) { + sprintf(errmsg, + "cannot recover view parameters from \"%s\"", prvr); + error(WARNING, errmsg); + } else { + pa = 0.0; + hres = scanlen(&rs); + vres = numscans(&rs); + } + if ((cp = setview(&ourview)) != NULL) + error(USER, cp); + normaspect(viewaspect(&ourview), &pa, &hres, &vres); + if (seq) { + if (ralrm > 0) { + fprintf(stderr, "FRAME %d:", seq); + fprintview(&ourview, stderr); + putc('\n', stderr); + fflush(stderr); + } + printf("FRAME=%d\n", seq); + } + fputs(VIEWSTR, stdout); + fprintview(&ourview, stdout); + putchar('\n'); + if (pa < .99 || pa > 1.01) + fputaspect(pa, stdout); + fputformat(COLRFMT, stdout); + putchar('\n'); + if (zout != NULL) + sprintf(cp=fbuf, zout, seq); + else + cp = NULL; + render(cp, prvr); + prvr = NULL; + } while (seq++); +} - ourview.hresolu -= ourview.hresolu % psample; - ourview.vresolu -= ourview.vresolu % psample; - + +nextview(fp) /* get next view from fp */ +FILE *fp; +{ + char linebuf[256]; + + while (fgets(linebuf, sizeof(linebuf), fp) != NULL) + if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) + return(0); + return(EOF); +} + + +render(zfile, oldfile) /* render the scene */ +char *zfile, *oldfile; +{ + extern long lseek(); + COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ + float *zbar[MAXDIV+1]; /* z values */ + char *sampdens; /* previous sample density */ + int ypos; /* current scanline */ + int ystep; /* current y step size */ + int hstep; /* h step size */ + int zfd; + COLOR *colptr; + float *zptr; + register int i; + /* allocate scanlines */ for (i = 0; i <= psample; i++) { - scanbar[i] = (COLOR *)malloc((ourview.hresolu+1)*sizeof(COLOR)); + scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); if (scanbar[i] == NULL) - error(SYSTEM, "out of memory in render"); + goto memerr; } - + hstep = (psample*140+49)/99; /* quincunx sampling */ + ystep = (psample*99+70)/140; + if (hstep > 2) { + i = hres/hstep + 2; + if ((sampdens = malloc(i)) == NULL) + goto memerr; + while (i--) + sampdens[i] = hstep; + } else + sampdens = NULL; + /* open z file */ + if (zfile != NULL) { + if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { + sprintf(errmsg, "cannot open z file \"%s\"", zfile); + error(SYSTEM, errmsg); + } +#ifdef MSDOS + setmode(zfd, O_BINARY); +#endif + for (i = 0; i <= psample; i++) { + zbar[i] = (float *)malloc(hres*sizeof(float)); + if (zbar[i] == NULL) + goto memerr; + } + } else { + zfd = -1; + for (i = 0; i <= psample; i++) + zbar[i] = NULL; + } /* write out boundaries */ - fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, stdout); - - ypos = ourview.vresolu - salvage(oldfile); /* find top line */ - fillscanline(scanbar[0], ypos, psample); /* top scan */ - - for (ypos -= psample; ypos > -psample; ypos -= psample) { - - colptr = scanbar[psample]; /* get last scanline */ - scanbar[psample] = scanbar[0]; + fprtresolu(hres, vres, stdout); + /* recover file and compute first */ + i = salvage(oldfile); + if (zfd != -1 && i > 0 && + lseek(zfd, (long)i*hres*sizeof(float), 0) == -1) + error(SYSTEM, "z file seek error in render"); + pctdone = 100.0*i/vres; + if (ralrm > 0) /* report init stats */ + report(); +#ifndef BSD + else +#endif + signal(SIGALRM, report); + ypos = vres-1 - i; + fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); + /* compute scanlines */ + for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { + /* bottom adjust? */ + if (ypos < 0) { + ystep += ypos; + ypos = 0; + } + colptr = scanbar[ystep]; /* move base to top */ + scanbar[ystep] = scanbar[0]; scanbar[0] = colptr; - - fillscanline(scanbar[0], ypos, psample); /* base scan */ - - fillscanbar(scanbar, ypos, psample); - - for (i = psample-1; i >= 0; i--) - if (fwritescan(scanbar[i], ourview.hresolu, stdout) < 0) + zptr = zbar[ystep]; + zbar[ystep] = zbar[0]; + zbar[0] = zptr; + /* fill base line */ + fillscanline(scanbar[0], zbar[0], sampdens, + hres, ypos, hstep); + /* fill bar */ + fillscanbar(scanbar, zbar, hres, ypos, ystep); + /* write it out */ +#ifndef BSD + signal(SIGALRM, SIG_IGN); /* don't interrupt writes */ +#endif + for (i = ystep; i > 0; i--) { + if (zfd != -1 && write(zfd, (char *)zbar[i], + hres*sizeof(float)) + < hres*sizeof(float)) goto writerr; + if (fwritescan(scanbar[i], hres, stdout) < 0) + goto writerr; + } if (fflush(stdout) == EOF) goto writerr; - pctdone = 100.0*(ourview.vresolu-ypos)/ourview.vresolu; + /* record progress */ + pctdone = 100.0*(vres-1-ypos)/vres; + if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm) + report(); +#ifndef BSD + else + signal(SIGALRM, report); +#endif } - + /* clean up */ + signal(SIGALRM, SIG_IGN); + if (zfd != -1) { + if (write(zfd, (char *)zbar[0], hres*sizeof(float)) + < hres*sizeof(float)) + goto writerr; + if (close(zfd) == -1) + goto writerr; + for (i = 0; i <= psample; i++) + free((char *)zbar[i]); + } + fwritescan(scanbar[0], hres, stdout); + if (fflush(stdout) == EOF) + goto writerr; for (i = 0; i <= psample; i++) free((char *)scanbar[i]); + if (sampdens != NULL) + free(sampdens); + pctdone = 100.0; + if (ralrm > 0) + report(); return; writerr: error(SYSTEM, "write error in render"); +memerr: + error(SYSTEM, "out of memory in render"); } -fillscanline(scanline, y, xstep) /* fill scan line at y */ -register COLOR *scanline; -int y, xstep; +fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */ +register COLOR *scanline; +register float *zline; +register char *sd; +int xres, y, xstep; { - int b = xstep; + static int nc = 0; /* number of calls */ + int bl = xstep, b = xstep; + double z; register int i; - pixvalue(scanline[0], 0, y); - - for (i = xstep; i <= ourview.hresolu; i += xstep) { - - pixvalue(scanline[i], i, y); - - b = fillsample(scanline+i-xstep, i-xstep, y, xstep, 0, b/2); + z = pixvalue(scanline[0], 0, y); + if (zline) zline[0] = z; + /* zig-zag start for quincunx pattern */ + for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) { + if (i >= xres) { + xstep += xres-1-i; + i = xres-1; + } + z = pixvalue(scanline[i], i, y); + if (zline) zline[i] = z; + if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1]; + if (i <= xstep) + b = fillsample(scanline, zline, 0, y, i, 0, b/2); + else + b = fillsample(scanline+i-xstep, + zline ? zline+i-xstep : NULL, + i-xstep, y, xstep, 0, b/2); + if (sd) *sd++ = nc & 1 ? bl : b; + bl = b; } + if (sd && nc & 1) *sd = bl; } -fillscanbar(scanbar, y, ysize) /* fill interior */ -register COLOR *scanbar[]; -int y, ysize; +fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */ +register COLOR *scanbar[]; +register float *zbar[]; +int xres, y, ysize; { COLOR vline[MAXDIV+1]; + float zline[MAXDIV+1]; int b = ysize; register int i, j; - for (i = 0; i < ourview.hresolu; i++) { + for (i = 0; i < xres; i++) { copycolor(vline[0], scanbar[0][i]); copycolor(vline[ysize], scanbar[ysize][i]); + if (zbar[0]) { + zline[0] = zbar[0][i]; + zline[ysize] = zbar[ysize][i]; + } - b = fillsample(vline, i, y, 0, ysize, b/2); + b = fillsample(vline, zbar[0] ? zline : NULL, + i, y, 0, ysize, b/2); for (j = 1; j < ysize; j++) copycolor(scanbar[j][i], vline[j]); + if (zbar[0]) + for (j = 1; j < ysize; j++) + zbar[j][i] = zline[j]; } } int -fillsample(colline, x, y, xlen, ylen, b) /* fill interior points */ -register COLOR *colline; +fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ +register COLOR *colline; +register float *zline; int x, y; int xlen, ylen; int b; { - double ratio; + double ratio; + double z; COLOR ctmp; int ncut; register int len; @@ -202,9 +519,12 @@ int b; if (len <= 1) /* limit recursion */ return(0); - if (b > 0 || bigdiff(colline[0], colline[len], maxdiff)) { + if (b > 0 + || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) + || bigdiff(colline[0], colline[len], maxdiff)) { - pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); + z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); + if (zline) zline[len>>1] = z; ncut = 1; } else { /* interpolate */ @@ -212,36 +532,47 @@ int b; copycolor(colline[len>>1], colline[len]); ratio = (double)(len>>1) / len; scalecolor(colline[len>>1], ratio); - copycolor(ctmp, colline[0]); + if (zline) zline[len>>1] = zline[len] * ratio; ratio = 1.0 - ratio; + copycolor(ctmp, colline[0]); scalecolor(ctmp, ratio); addcolor(colline[len>>1], ctmp); + if (zline) zline[len>>1] += zline[0] * ratio; ncut = 0; } /* recurse */ - ncut += fillsample(colline, x, y, xlen>>1, ylen>>1, (b-1)/2); + ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); - ncut += fillsample(colline + (len>>1), x + (xlen>>1), y + (ylen>>1), - xlen - (xlen>>1), ylen - (ylen>>1), b/2); + ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL, + x+(xlen>>1), y+(ylen>>1), + xlen-(xlen>>1), ylen-(ylen>>1), b/2); return(ncut); } +double pixvalue(col, x, y) /* compute pixel value */ COLOR col; /* returned color */ int x, y; /* pixel position */ { - static RAY thisray; /* our ray for this pixel */ + static RAY thisray; - rayview(thisray.rorg, thisray.rdir, &ourview, - x + pixjitter(), y + pixjitter()); + if (viewray(thisray.rorg, thisray.rdir, &ourview, + (x+pixjitter())/hres, (y+pixjitter())/vres) < 0) { + setcolor(col, 0.0, 0.0, 0.0); + return(0.0); + } rayorigin(&thisray, NULL, PRIMARY, 1.0); - + + samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ + rayvalue(&thisray); /* trace ray */ copycolor(col, thisray.rcol); /* return color */ + + return(thisray.rt); /* return distance */ } @@ -255,35 +586,38 @@ char *oldfile; if (oldfile == NULL) return(0); - else if ((fp = fopen(oldfile, "r")) == NULL) { + + if ((fp = fopen(oldfile, "r")) == NULL) { sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); error(WARNING, errmsg); return(0); } +#ifdef MSDOS + setmode(fileno(fp), O_BINARY); +#endif /* discard header */ - getheader(fp, NULL); + getheader(fp, NULL, NULL); /* get picture size */ - if (fgetresolu(&x, &y, fp) != (YMAJOR|YDECR)) { + if (!fscnresolu(&x, &y, fp)) { sprintf(errmsg, "bad recover file \"%s\"", oldfile); error(WARNING, errmsg); fclose(fp); return(0); } - if (x != ourview.hresolu || y != ourview.vresolu) { + if (x != hres || y != vres) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); - return(0); } - scanline = (COLR *)malloc(ourview.hresolu*sizeof(COLR)); + scanline = (COLR *)malloc(hres*sizeof(COLR)); if (scanline == NULL) error(SYSTEM, "out of memory in salvage"); - for (y = 0; y < ourview.vresolu; y++) { - if (freadcolrs(scanline, ourview.hresolu, fp) < 0) + for (y = 0; y < vres; y++) { + if (freadcolrs(scanline, hres, fp) < 0) break; - if (fwritecolrs(scanline, ourview.hresolu, stdout) < 0) + if (fwritecolrs(scanline, hres, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF) @@ -293,5 +627,18 @@ char *oldfile; unlink(oldfile); return(y); writerr: - error(SYSTEM, "write error in salvage"); + sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); + error(SYSTEM, errmsg); +} + + +int +pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */ +register int x, y; +int xres, yres; +{ + x -= y; + while (x < 0) + x += xres; + return((((x>>2)*yres + y) << 2) + (x & 3)); }
