root/radiance/ray/src/rt/rpict.c
Revision: 1.31
Committed: Tue Aug 13 12:16:34 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.30: +13 -1 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rpict.c - routines and variables for picture generation.
9 *
10 * 8/14/85
11 */
12
13 #include "ray.h"
14
15 #ifdef BSD
16 #include <sys/time.h>
17 #include <sys/resource.h>
18 #else
19 #include <signal.h>
20 #endif
21 #include <fcntl.h>
22
23 #include "view.h"
24
25 #include "random.h"
26
27 int dimlist[MAXDIM]; /* sampling dimensions */
28 int ndims = 0; /* number of sampling dimensions */
29 int samplendx; /* sample index number */
30
31 VIEW ourview = STDVIEW; /* view parameters */
32 int hresolu = 512; /* horizontal resolution */
33 int vresolu = 512; /* vertical resolution */
34 double pixaspect = 1.0; /* pixel aspect ratio */
35
36 int psample = 4; /* pixel sample size */
37 double maxdiff = .05; /* max. difference for interpolation */
38 double dstrpix = 0.67; /* square pixel distribution */
39
40 double dstrsrc = 0.0; /* square source distribution */
41 double shadthresh = .05; /* shadow threshold */
42 double shadcert = .5; /* shadow certainty */
43 int directrelay = 0; /* number of source relays */
44 int vspretest = 512; /* virtual source pretest density */
45 int directinvis = 0; /* sources invisible? */
46
47 int maxdepth = 6; /* maximum recursion depth */
48 double minweight = 5e-3; /* minimum ray weight */
49
50 COLOR ambval = BLKCOLOR; /* ambient value */
51 double ambacc = 0.2; /* ambient accuracy */
52 int ambres = 32; /* ambient resolution */
53 int ambdiv = 128; /* ambient divisions */
54 int ambssamp = 0; /* ambient super-samples */
55 int ambounce = 0; /* ambient bounces */
56 char *amblist[128]; /* ambient include/exclude list */
57 int ambincl = -1; /* include == 1, exclude == 0 */
58
59 int ralrm = 0; /* seconds between reports */
60
61 double pctdone = 0.0; /* percentage done */
62
63 long tlastrept = 0L; /* time at last report */
64
65 extern long time();
66 extern long tstart; /* starting time */
67
68 extern long nrays; /* number of rays traced */
69
70 #define MAXDIV 15 /* maximum sample size */
71
72 #define pixjitter() (.5+dstrpix*(.5-frandom()))
73
74 double pixvalue();
75
76
77 quit(code) /* quit program */
78 int code;
79 {
80 if (code || ralrm > 0) /* report status */
81 report();
82
83 exit(code);
84 }
85
86
87 #ifdef BSD
88 report() /* report progress */
89 {
90 struct rusage rubuf;
91 double t;
92
93 getrusage(RUSAGE_SELF, &rubuf);
94 t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
95 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
96 getrusage(RUSAGE_CHILDREN, &rubuf);
97 t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6;
98 t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec;
99
100 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n",
101 nrays, pctdone, t/3600.0);
102 eputs(errmsg);
103 tlastrept = time((long *)0);
104 }
105 #else
106 report() /* report progress */
107 {
108 signal(SIGALRM, report);
109 tlastrept = time((long *)0);
110 sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n",
111 nrays, pctdone, (tlastrept-tstart)/3600.0);
112 eputs(errmsg);
113 }
114 #endif
115
116
117 render(zfile, oldfile) /* render the scene */
118 char *zfile, *oldfile;
119 {
120 extern long lseek();
121 COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */
122 float *zbar[MAXDIV+1]; /* z values */
123 int ypos; /* current scanline */
124 int ystep; /* current y step size */
125 int zfd;
126 COLOR *colptr;
127 float *zptr;
128 register int i;
129 /* check sampling */
130 if (psample < 1)
131 psample = 1;
132 else if (psample > MAXDIV) {
133 sprintf(errmsg, "pixel sampling reduced from %d to %d",
134 psample, MAXDIV);
135 error(WARNING, errmsg);
136 psample = MAXDIV;
137 }
138 /* allocate scanlines */
139 for (i = 0; i <= psample; i++) {
140 scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR));
141 if (scanbar[i] == NULL)
142 goto memerr;
143 }
144 /* open z file */
145 if (zfile != NULL) {
146 if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) {
147 sprintf(errmsg, "cannot open z file \"%s\"", zfile);
148 error(SYSTEM, errmsg);
149 }
150 for (i = 0; i <= psample; i++) {
151 zbar[i] = (float *)malloc(hresolu*sizeof(float));
152 if (zbar[i] == NULL)
153 goto memerr;
154 }
155 } else {
156 zfd = -1;
157 for (i = 0; i <= psample; i++)
158 zbar[i] = NULL;
159 }
160 /* write out boundaries */
161 fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout);
162 /* recover file and compute first */
163 i = salvage(oldfile);
164 if (zfd != -1 && i > 0 &&
165 lseek(zfd, (long)i*hresolu*sizeof(float), 0) == -1)
166 error(SYSTEM, "z file seek error in render");
167 pctdone = 100.0*i/vresolu;
168 if (ralrm > 0) /* report init stats */
169 report();
170 ypos = vresolu-1 - i;
171 fillscanline(scanbar[0], zbar[0], hresolu, ypos, psample);
172 ystep = psample;
173 /* compute scanlines */
174 for (ypos -= ystep; ypos > -ystep; ypos -= ystep) {
175 /* bottom adjust? */
176 if (ypos < 0) {
177 ystep += ypos;
178 ypos = 0;
179 }
180 colptr = scanbar[ystep]; /* move base to top */
181 scanbar[ystep] = scanbar[0];
182 scanbar[0] = colptr;
183 zptr = zbar[ystep];
184 zbar[ystep] = zbar[0];
185 zbar[0] = zptr;
186 /* fill base line */
187 fillscanline(scanbar[0], zbar[0], hresolu, ypos, psample);
188 /* fill bar */
189 fillscanbar(scanbar, zbar, hresolu, ypos, ystep);
190 /* write it out */
191 for (i = ystep; i > 0; i--) {
192 if (zfd != -1 && write(zfd, (char *)zbar[i],
193 hresolu*sizeof(float))
194 < hresolu*sizeof(float))
195 goto writerr;
196 if (fwritescan(scanbar[i], hresolu, stdout) < 0)
197 goto writerr;
198 }
199 if (fflush(stdout) == EOF)
200 goto writerr;
201 /* record progress */
202 pctdone = 100.0*(vresolu-1-ypos)/vresolu;
203 if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm)
204 report();
205 }
206 /* clean up */
207 if (zfd != -1) {
208 if (write(zfd, (char *)zbar[0], hresolu*sizeof(float))
209 < hresolu*sizeof(float))
210 goto writerr;
211 if (close(zfd) == -1)
212 goto writerr;
213 for (i = 0; i <= psample; i++)
214 free((char *)zbar[i]);
215 }
216 fwritescan(scanbar[0], hresolu, stdout);
217 if (fflush(stdout) == EOF)
218 goto writerr;
219 for (i = 0; i <= psample; i++)
220 free((char *)scanbar[i]);
221 pctdone = 100.0;
222 return;
223 writerr:
224 error(SYSTEM, "write error in render");
225 memerr:
226 error(SYSTEM, "out of memory in render");
227 }
228
229
230 fillscanline(scanline, zline, xres, y, xstep) /* fill scan line at y */
231 register COLOR *scanline;
232 register float *zline;
233 int xres, y, xstep;
234 {
235 int b = xstep;
236 double z;
237 register int i;
238
239 z = pixvalue(scanline[0], 0, y);
240 if (zline) zline[0] = z;
241
242 for (i = xstep; i < xres-1+xstep; i += xstep) {
243 if (i >= xres) {
244 xstep += xres-1-i;
245 i = xres-1;
246 }
247 z = pixvalue(scanline[i], i, y);
248 if (zline) zline[i] = z;
249
250 b = fillsample(scanline+i-xstep, zline ? zline+i-xstep : NULL,
251 i-xstep, y, xstep, 0, b/2);
252 }
253 }
254
255
256 fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */
257 register COLOR *scanbar[];
258 register float *zbar[];
259 int xres, y, ysize;
260 {
261 COLOR vline[MAXDIV+1];
262 float zline[MAXDIV+1];
263 int b = ysize;
264 register int i, j;
265
266 for (i = 0; i < xres; i++) {
267
268 copycolor(vline[0], scanbar[0][i]);
269 copycolor(vline[ysize], scanbar[ysize][i]);
270 if (zbar[0]) {
271 zline[0] = zbar[0][i];
272 zline[ysize] = zbar[ysize][i];
273 }
274
275 b = fillsample(vline, zbar[0] ? zline : NULL,
276 i, y, 0, ysize, b/2);
277
278 for (j = 1; j < ysize; j++)
279 copycolor(scanbar[j][i], vline[j]);
280 if (zbar[0])
281 for (j = 1; j < ysize; j++)
282 zbar[j][i] = zline[j];
283 }
284 }
285
286
287 int
288 fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */
289 register COLOR *colline;
290 register float *zline;
291 int x, y;
292 int xlen, ylen;
293 int b;
294 {
295 extern double fabs();
296 double ratio;
297 double z;
298 COLOR ctmp;
299 int ncut;
300 register int len;
301
302 if (xlen > 0) /* x or y length is zero */
303 len = xlen;
304 else
305 len = ylen;
306
307 if (len <= 1) /* limit recursion */
308 return(0);
309
310 if (b > 0
311 || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len]))
312 || bigdiff(colline[0], colline[len], maxdiff)) {
313
314 z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1));
315 if (zline) zline[len>>1] = z;
316 ncut = 1;
317
318 } else { /* interpolate */
319
320 copycolor(colline[len>>1], colline[len]);
321 ratio = (double)(len>>1) / len;
322 scalecolor(colline[len>>1], ratio);
323 if (zline) zline[len>>1] = zline[len] * ratio;
324 ratio = 1.0 - ratio;
325 copycolor(ctmp, colline[0]);
326 scalecolor(ctmp, ratio);
327 addcolor(colline[len>>1], ctmp);
328 if (zline) zline[len>>1] += zline[0] * ratio;
329 ncut = 0;
330 }
331 /* recurse */
332 ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2);
333
334 ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL,
335 x+(xlen>>1), y+(ylen>>1),
336 xlen-(xlen>>1), ylen-(ylen>>1), b/2);
337
338 return(ncut);
339 }
340
341
342 double
343 pixvalue(col, x, y) /* compute pixel value */
344 COLOR col; /* returned color */
345 int x, y; /* pixel position */
346 {
347 static RAY thisray;
348
349 if (viewray(thisray.rorg, thisray.rdir, &ourview,
350 (x+pixjitter())/hresolu, (y+pixjitter())/vresolu) < 0) {
351 setcolor(col, 0.0, 0.0, 0.0);
352 return(0.0);
353 }
354
355 rayorigin(&thisray, NULL, PRIMARY, 1.0);
356
357 samplendx = pixnumber(x,y,hresolu,vresolu); /* set pixel index */
358
359 rayvalue(&thisray); /* trace ray */
360
361 copycolor(col, thisray.rcol); /* return color */
362
363 return(thisray.rt); /* return distance */
364 }
365
366
367 int
368 salvage(oldfile) /* salvage scanlines from killed program */
369 char *oldfile;
370 {
371 COLR *scanline;
372 FILE *fp;
373 int x, y;
374
375 if (oldfile == NULL)
376 return(0);
377
378 if ((fp = fopen(oldfile, "r")) == NULL) {
379 sprintf(errmsg, "cannot open recover file \"%s\"", oldfile);
380 error(WARNING, errmsg);
381 return(0);
382 }
383 /* discard header */
384 getheader(fp, NULL);
385 /* get picture size */
386 if (fgetresolu(&x, &y, fp) != (YMAJOR|YDECR)) {
387 sprintf(errmsg, "bad recover file \"%s\"", oldfile);
388 error(WARNING, errmsg);
389 fclose(fp);
390 return(0);
391 }
392
393 if (x != hresolu || y != vresolu) {
394 sprintf(errmsg, "resolution mismatch in recover file \"%s\"",
395 oldfile);
396 error(USER, errmsg);
397 }
398
399 scanline = (COLR *)malloc(hresolu*sizeof(COLR));
400 if (scanline == NULL)
401 error(SYSTEM, "out of memory in salvage");
402 for (y = 0; y < vresolu; y++) {
403 if (freadcolrs(scanline, hresolu, fp) < 0)
404 break;
405 if (fwritecolrs(scanline, hresolu, stdout) < 0)
406 goto writerr;
407 }
408 if (fflush(stdout) == EOF)
409 goto writerr;
410 free((char *)scanline);
411 fclose(fp);
412 unlink(oldfile);
413 return(y);
414 writerr:
415 error(SYSTEM, "write error in salvage");
416 }
417
418
419 int
420 pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */
421 register int x, y;
422 int xres, yres;
423 {
424 x -= y;
425 while (x < 0)
426 x += xres;
427 return((((x>>2)*yres + y) << 2) + (x & 3));
428 }
