--- ray/src/rt/rpict.c 1992/07/10 19:29:50 2.9 +++ ray/src/rt/rpict.c 1998/06/17 13:29:55 2.51 @@ -1,4 +1,4 @@ -/* Copyright (c) 1992 Regents of the University of California */ +/* Copyright (c) 1996 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -6,19 +6,25 @@ static char SCCSid[] = "$SunId$ LBL"; /* * rpict.c - routines and variables for picture generation. - * - * 8/14/85 */ #include "ray.h" +#include + +#ifndef NIX #ifdef BSD #include #include +#else +#include +#include #endif +#endif +extern time_t time(); + #include -#include #include "view.h" @@ -26,6 +32,14 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" +#include "paths.h" + +#define RFTEMPLATE "rfXXXXXX" + +#ifndef SIGCONT +#define SIGCONT SIGIO +#endif + int dimlist[MAXDIM]; /* sampling dimensions */ int ndims = 0; /* number of sampling dimensions */ int samplendx; /* sample index number */ @@ -33,28 +47,38 @@ int samplendx; /* sample index number */ VIEW ourview = STDVIEW; /* view parameters */ int hresolu = 512; /* horizontal resolution */ int vresolu = 512; /* vertical resolution */ -double pixaspect = 1.0; /* pixel aspect ratio */ +double pixaspect = 1.0; /* pixel aspect ratio */ int psample = 4; /* pixel sample size */ -double maxdiff = .05; /* max. difference for interpolation */ -double dstrpix = 0.67; /* square pixel distribution */ +double maxdiff = .05; /* max. difference for interpolation */ +double dstrpix = 0.67; /* square pixel distribution */ -double dstrsrc = 0.0; /* square source distribution */ -double shadthresh = .05; /* shadow threshold */ -double shadcert = .5; /* shadow certainty */ +double mblur = 0.; /* motion blur parameter */ + +double dstrsrc = 0.0; /* square source distribution */ +double shadthresh = .05; /* shadow threshold */ +double shadcert = .5; /* shadow certainty */ int directrelay = 1; /* number of source relays */ int vspretest = 512; /* virtual source pretest density */ -int directinvis = 0; /* sources invisible? */ -double srcsizerat = .25; /* maximum ratio source size/dist. */ +int directvis = 1; /* sources visible? */ +double srcsizerat = .25; /* maximum ratio source size/dist. */ -double specthresh = .15; /* specular sampling threshold */ -double specjitter = 1.; /* specular sampling jitter */ +COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ +COLOR salbedo = BLKCOLOR; /* global scattering albedo */ +double seccg = 0.; /* global scattering eccentricity */ +double ssampdist = 0.; /* scatter sampling distance */ +double specthresh = .15; /* specular sampling threshold */ +double specjitter = 1.; /* specular sampling jitter */ + +int backvis = 1; /* back face visibility */ + int maxdepth = 6; /* maximum recursion depth */ -double minweight = 5e-3; /* minimum ray weight */ +double minweight = 5e-3; /* minimum ray weight */ COLOR ambval = BLKCOLOR; /* ambient value */ -double ambacc = 0.2; /* ambient accuracy */ +int ambvwt = 0; /* initial weight for ambient value */ +double ambacc = 0.2; /* ambient accuracy */ int ambres = 32; /* ambient resolution */ int ambdiv = 128; /* ambient divisions */ int ambssamp = 0; /* ambient super-samples */ @@ -62,108 +86,110 @@ int ambounce = 0; /* ambient bounces */ char *amblist[128]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ +#ifdef MSDOS +int ralrm = 60; /* seconds between reports */ +#else int ralrm = 0; /* seconds between reports */ +#endif -double pctdone = 0.0; /* percentage done */ +double pctdone = 0.0; /* percentage done */ -long tlastrept = 0L; /* time at last report */ +time_t tlastrept = 0L; /* time at last report */ -extern long time(); -extern long tstart; /* starting time */ +extern time_t tstart; /* starting time */ -extern long nrays; /* number of rays traced */ +extern unsigned long nrays; /* number of rays traced */ -#define MAXDIV 16 /* maximum sample size */ +#define MAXDIV 16 /* maximum sample size */ -#define pixjitter() (.5+dstrpix*(.5-frandom())) +#define pixjitter() (.5+dstrpix*(.5-frandom())) -#define RFTEMPLATE "rfXXXXXX" -#define HFTEMPLATE "/tmp/hfXXXXXX" +int hres, vres; /* resolution for this frame */ -static char *hfname = NULL; /* header file name */ -static FILE *hfp = NULL; /* header file pointer */ +static VIEW lastview; /* the previous view input */ -static int hres, vres; /* resolution for this frame */ - extern char *mktemp(); -double pixvalue(); +double pixvalue(); +#ifdef NIX +#define file_exists(f) (access(f,F_OK)==0) +#else +#include +#include +int +file_exists(fname) /* ordinary file exists? */ +char *fname; +{ + struct stat sbuf; + if (stat(fname, &sbuf) < 0) return(0); + return((sbuf.st_mode & S_IFREG) != 0); +} +#endif + quit(code) /* quit program */ int code; { if (code) /* report status */ report(); - if (hfname != NULL) { /* delete header file */ - if (hfp != NULL) - fclose(hfp); - unlink(hfname); - } + headclean(); /* delete header file */ + pfclean(); /* clean up persist files */ exit(code); } -#ifdef BSD +#ifndef NIX report() /* report progress */ { + extern char *myhostname(); + double u, s; +#ifdef BSD struct rusage rubuf; - double t; +#else + struct tms tbuf; + double period; +#endif + tlastrept = time((time_t *)NULL); +#ifdef BSD getrusage(RUSAGE_SELF, &rubuf); - t = (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; - t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec; + u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; + s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; getrusage(RUSAGE_CHILDREN, &rubuf); - t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; - t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec; + u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; + s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; +#else + times(&tbuf); +#ifdef _SC_CLK_TCK + period = 1.0 / sysconf(_SC_CLK_TCK); +#else + period = 1.0 / 60.0; +#endif + u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period; + s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period; +#endif - sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n", - nrays, pctdone, t/3600.0); + sprintf(errmsg, + "%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n", + nrays, pctdone, u/3600., s/3600., + (tlastrept-tstart)/3600., myhostname()); eputs(errmsg); - tlastrept = time((long *)0); +#ifndef BSD + signal(SIGCONT, report); +#endif } #else report() /* report progress */ { - tlastrept = time((long *)0); - sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n", + tlastrept = time((time_t *)NULL); + sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n", nrays, pctdone, (tlastrept-tstart)/3600.0); eputs(errmsg); - signal(SIGALRM, report); } #endif -openheader() /* save standard output to header file */ -{ - hfname = mktemp(HFTEMPLATE); - if (freopen(hfname, "w", stdout) == NULL) { - sprintf(errmsg, "cannot open header file \"%s\"", hfname); - error(SYSTEM, errmsg); - } -} - - -closeheader() /* done with header output */ -{ - if (hfname == NULL) - return; - if (fflush(stdout) == EOF || (hfp = fopen(hfname, "r")) == NULL) - error(SYSTEM, "error reopening header file"); -} - - -dupheader() /* repeat header on standard output */ -{ - register int c; - - if (fseek(hfp, 0L, 0) < 0) - error(SYSTEM, "seek error on header file"); - while ((c = getc(hfp)) != EOF) - putchar(c); -} - - rpict(seq, pout, zout, prvr) /* generate image(s) */ int seq; char *pout, *zout, *prvr; @@ -179,13 +205,12 @@ char *pout, *zout, *prvr; * sequenced file naming. */ { - extern char *rindex(), *strncpy(), *strcat(); + extern char *rindex(), *strncpy(), *strcat(), *strcpy(); char fbuf[128], fbuf2[128]; + int npicts; register char *cp; - RESOLU rs; - double pa; - /* finished writing header */ - closeheader(); + RESOLU rs; + double pa; /* check sampling */ if (psample < 1) psample = 1; @@ -207,35 +232,59 @@ char *pout, *zout, *prvr; for ( ; seq < rn; seq++) if (nextview(stdin) == EOF) error(USER, "unexpected EOF on view input"); + setview(&ourview); prvr = fbuf; /* mark for renaming */ } - if (pout != NULL) { + if (pout != NULL & prvr != NULL) { sprintf(fbuf, pout, seq); - if (!strcmp(prvr, fbuf)) { /* rename recover file */ - fbuf2[0] = '\0'; - if ((cp = rindex(fbuf, '/')) != NULL) - strncpy(fbuf2, fbuf, cp-fbuf+1); - strcat(fbuf2, RFTEMPLATE); + if (!strcmp(prvr, fbuf)) { /* rename */ + strcpy(fbuf2, fbuf); + for (cp = fbuf2; *cp; cp++) + ; + while (cp > fbuf2 && !ISDIRSEP(cp[-1])) + cp--; + strcpy(cp, RFTEMPLATE); prvr = mktemp(fbuf2); - if (rename(fbuf, prvr) < 0 && errno != ENOENT) { - sprintf(errmsg, + if (rename(fbuf, prvr) < 0) + if (errno == ENOENT) { /* ghost file */ + sprintf(errmsg, + "new output file \"%s\"", + fbuf); + error(WARNING, errmsg); + prvr = NULL; + } else { /* serious error */ + sprintf(errmsg, "cannot rename \"%s\" to \"%s\"", fbuf, prvr); - error(SYSTEM, errmsg); - } + error(SYSTEM, errmsg); + } } } - /* render sequence */ + npicts = 0; /* render sequence */ do { if (seq && nextview(stdin) == EOF) break; + pctdone = 0.0; if (pout != NULL) { sprintf(fbuf, pout, seq); + if (file_exists(fbuf)) { + if (prvr != NULL || !strcmp(fbuf, pout)) { + sprintf(errmsg, + "output file \"%s\" exists", + fbuf); + error(USER, errmsg); + } + setview(&ourview); + continue; /* don't clobber */ + } if (freopen(fbuf, "w", stdout) == NULL) { sprintf(errmsg, "cannot open output file \"%s\"", fbuf); error(SYSTEM, errmsg); } +#ifdef MSDOS + setmode(fileno(stdout), O_BINARY); +#endif dupheader(); } hres = hresolu; vres = vresolu; pa = pixaspect; @@ -255,8 +304,10 @@ char *pout, *zout, *prvr; normaspect(viewaspect(&ourview), &pa, &hres, &vres); if (seq) { if (ralrm > 0) { - sprintf(errmsg, "starting frame %d\n", seq); - eputs(errmsg); + fprintf(stderr, "FRAME %d:", seq); + fprintview(&ourview, stderr); + putc('\n', stderr); + fflush(stderr); } printf("FRAME=%d\n", seq); } @@ -273,7 +324,11 @@ char *pout, *zout, *prvr; cp = NULL; render(cp, prvr); prvr = NULL; + npicts++; } while (seq++); + /* check that we did something */ + if (npicts == 0) + error(WARNING, "no output produced"); } @@ -282,6 +337,7 @@ FILE *fp; { char linebuf[256]; + copystruct(&lastview, &ourview); while (fgets(linebuf, sizeof(linebuf), fp) != NULL) if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) return(0); @@ -292,7 +348,6 @@ FILE *fp; render(zfile, oldfile) /* render the scene */ char *zfile, *oldfile; { - extern long lseek(); COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ float *zbar[MAXDIV+1]; /* z values */ char *sampdens; /* previous sample density */ @@ -319,12 +374,15 @@ char *zfile, *oldfile; sampdens[i] = hstep; } else sampdens = NULL; - /* open z file */ + /* open z-file */ if (zfile != NULL) { if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { - sprintf(errmsg, "cannot open z file \"%s\"", zfile); + sprintf(errmsg, "cannot open z-file \"%s\"", zfile); error(SYSTEM, errmsg); } +#ifdef MSDOS + setmode(zfd, O_BINARY); +#endif for (i = 0; i <= psample; i++) { zbar[i] = (float *)malloc(hres*sizeof(float)); if (zbar[i] == NULL) @@ -339,17 +397,21 @@ char *zfile, *oldfile; fprtresolu(hres, vres, stdout); /* recover file and compute first */ i = salvage(oldfile); + if (i >= vres) + goto alldone; if (zfd != -1 && i > 0 && - lseek(zfd, (long)i*hres*sizeof(float), 0) == -1) - error(SYSTEM, "z file seek error in render"); + lseek(zfd, (long)i*hres*sizeof(float), 0) < 0) + error(SYSTEM, "z-file seek error in render"); pctdone = 100.0*i/vres; if (ralrm > 0) /* report init stats */ report(); -#ifndef BSD +#ifndef BSD else #endif - signal(SIGALRM, report); - ypos = vres-1 - i; + signal(SIGCONT, report); + ypos = vres-1 - i; /* initialize sampling */ + if (directvis) + init_drawsources(psample); fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); /* compute scanlines */ for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { @@ -369,9 +431,11 @@ char *zfile, *oldfile; hres, ypos, hstep); /* fill bar */ fillscanbar(scanbar, zbar, hres, ypos, ystep); + if (directvis) /* add bitty sources */ + drawsources(scanbar, zbar, 0, hres, ypos, ystep); /* write it out */ -#ifndef BSD - signal(SIGALRM, SIG_IGN); /* don't interrupt writes */ +#ifndef BSD + signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ #endif for (i = ystep; i > 0; i--) { if (zfd != -1 && write(zfd, (char *)zbar[i], @@ -385,32 +449,36 @@ char *zfile, *oldfile; goto writerr; /* record progress */ pctdone = 100.0*(vres-1-ypos)/vres; - if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm) + if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm) report(); -#ifndef BSD +#ifndef BSD else - signal(SIGALRM, report); + signal(SIGCONT, report); #endif } /* clean up */ - signal(SIGALRM, SIG_IGN); - if (zfd != -1) { - if (write(zfd, (char *)zbar[0], hres*sizeof(float)) + signal(SIGCONT, SIG_IGN); + if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float)) < hres*sizeof(float)) - goto writerr; + goto writerr; + fwritescan(scanbar[0], hres, stdout); + if (fflush(stdout) == EOF) + goto writerr; +alldone: + if (zfd != -1) { if (close(zfd) == -1) goto writerr; for (i = 0; i <= psample; i++) free((char *)zbar[i]); } - fwritescan(scanbar[0], hres, stdout); - if (fflush(stdout) == EOF) - goto writerr; for (i = 0; i <= psample; i++) free((char *)scanbar[i]); if (sampdens != NULL) free(sampdens); pctdone = 100.0; + if (ralrm > 0) + report(); + signal(SIGCONT, SIG_DFL); return; writerr: error(SYSTEM, "write error in render"); @@ -420,16 +488,16 @@ memerr: fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */ -register COLOR *scanline; -register float *zline; +register COLOR *scanline; +register float *zline; register char *sd; int xres, y, xstep; { static int nc = 0; /* number of calls */ int bl = xstep, b = xstep; - double z; + double z; register int i; - + z = pixvalue(scanline[0], 0, y); if (zline) zline[0] = z; /* zig-zag start for quincunx pattern */ @@ -445,7 +513,7 @@ int xres, y, xstep; b = fillsample(scanline, zline, 0, y, i, 0, b/2); else b = fillsample(scanline+i-xstep, - zline ? zline+i-xstep : NULL, + zline ? zline+i-xstep : (float *)NULL, i-xstep, y, xstep, 0, b/2); if (sd) *sd++ = nc & 1 ? bl : b; bl = b; @@ -455,27 +523,25 @@ int xres, y, xstep; fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */ -register COLOR *scanbar[]; -register float *zbar[]; +register COLOR *scanbar[]; +register float *zbar[]; int xres, y, ysize; { COLOR vline[MAXDIV+1]; float zline[MAXDIV+1]; int b = ysize; register int i, j; - + for (i = 0; i < xres; i++) { - copycolor(vline[0], scanbar[0][i]); copycolor(vline[ysize], scanbar[ysize][i]); if (zbar[0]) { zline[0] = zbar[0][i]; zline[ysize] = zbar[ysize][i]; } - - b = fillsample(vline, zbar[0] ? zline : NULL, + b = fillsample(vline, zbar[0] ? zline : (float *)NULL, i, y, 0, ysize, b/2); - + for (j = 1; j < ysize; j++) copycolor(scanbar[j][i], vline[j]); if (zbar[0]) @@ -486,38 +552,35 @@ int xres, y, ysize; int -fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ -register COLOR *colline; -register float *zline; +fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ +register COLOR *colline; +register float *zline; int x, y; int xlen, ylen; int b; { - extern double fabs(); - double ratio; - double z; + double ratio; + double z; COLOR ctmp; int ncut; register int len; - + if (xlen > 0) /* x or y length is zero */ len = xlen; else len = ylen; - + if (len <= 1) /* limit recursion */ return(0); - - if (b > 0 - || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) + + if (b > 0 || + (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) || bigdiff(colline[0], colline[len], maxdiff)) { - + z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); if (zline) zline[len>>1] = z; ncut = 1; - } else { /* interpolate */ - copycolor(colline[len>>1], colline[len]); ratio = (double)(len>>1) / len; scalecolor(colline[len>>1], ratio); @@ -531,8 +594,9 @@ int b; } /* recurse */ ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); - - ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL, + + ncut += fillsample(colline+(len>>1), + zline ? zline+(len>>1) : (float *)NULL, x+(xlen>>1), y+(ylen>>1), xlen-(xlen>>1), ylen-(ylen>>1), b/2); @@ -545,22 +609,41 @@ pixvalue(col, x, y) /* compute pixel value */ COLOR col; /* returned color */ int x, y; /* pixel position */ { - static RAY thisray; - - if (viewray(thisray.rorg, thisray.rdir, &ourview, - (x+pixjitter())/hres, (y+pixjitter())/vres) < 0) { + RAY thisray; + FVECT lorg, ldir; + double hpos, vpos, lmax, d; + /* compute view ray */ + hpos = (x+pixjitter())/hres; + vpos = (y+pixjitter())/vres; + if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, + &ourview, hpos, vpos)) < -FTINY) { setcolor(col, 0.0, 0.0, 0.0); return(0.0); } - rayorigin(&thisray, NULL, PRIMARY, 1.0); - samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ + /* optional motion blur */ + if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir, + &lastview, hpos, vpos)) >= -FTINY) { + register int i; + register double d = mblur*(.5-urand(281+samplendx)); + + thisray.rmax = (1.-d)*thisray.rmax + d*lmax; + for (i = 3; i--; ) { + thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i]; + thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i]; + } + if (normalize(thisray.rdir) == 0.0) + return(0.0); + } + + rayorigin(&thisray, NULL, PRIMARY, 1.0); + rayvalue(&thisray); /* trace ray */ copycolor(col, thisray.rcol); /* return color */ - + return(thisray.rt); /* return distance */ } @@ -574,21 +657,25 @@ char *oldfile; int x, y; if (oldfile == NULL) - return(0); - + goto gotzip; + if ((fp = fopen(oldfile, "r")) == NULL) { sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); error(WARNING, errmsg); - return(0); + goto gotzip; } +#ifdef MSDOS + setmode(fileno(fp), O_BINARY); +#endif /* discard header */ - getheader(fp, NULL); + getheader(fp, NULL, NULL); /* get picture size */ if (!fscnresolu(&x, &y, fp)) { - sprintf(errmsg, "bad recover file \"%s\"", oldfile); + sprintf(errmsg, "bad recover file \"%s\" - not removed", + oldfile); error(WARNING, errmsg); fclose(fp); - return(0); + goto gotzip; } if (x != hres || y != vres) { @@ -612,6 +699,10 @@ char *oldfile; fclose(fp); unlink(oldfile); return(y); +gotzip: + if (fflush(stdout) == EOF) + error(SYSTEM, "error writing picture header"); + return(0); writerr: sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); error(SYSTEM, errmsg);
