--- ray/src/rt/rpict.c 1989/02/02 10:41:36 1.1 +++ ray/src/rt/rpict.c 1991/10/10 09:18:58 1.33 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,27 +15,41 @@ static char SCCSid[] = "$SunId$ LBL"; #ifdef BSD #include #include +#else +#include #endif +#include #include "view.h" #include "random.h" -VIEW ourview = STDVIEW(512); /* view parameters */ +int dimlist[MAXDIM]; /* sampling dimensions */ +int ndims = 0; /* number of sampling dimensions */ +int samplendx; /* sample index number */ -int psample = 4; /* pixel sample size */ +VIEW ourview = STDVIEW; /* view parameters */ +int hresolu = 512; /* horizontal resolution */ +int vresolu = 512; /* vertical resolution */ +double pixaspect = 1.0; /* pixel aspect ratio */ +int psample = 4; /* pixel sample size */ double maxdiff = .05; /* max. difference for interpolation */ - double dstrpix = 0.67; /* square pixel distribution */ + double dstrsrc = 0.0; /* square source distribution */ +double shadthresh = .05; /* shadow threshold */ +double shadcert = .5; /* shadow certainty */ +int directrelay = 0; /* number of source relays */ +int vspretest = 512; /* virtual source pretest density */ +int directinvis = 0; /* sources invisible? */ int maxdepth = 6; /* maximum recursion depth */ double minweight = 5e-3; /* minimum ray weight */ COLOR ambval = BLKCOLOR; /* ambient value */ double ambacc = 0.2; /* ambient accuracy */ -int ambres = 128; /* ambient resolution */ +int ambres = 32; /* ambient resolution */ int ambdiv = 128; /* ambient divisions */ int ambssamp = 0; /* ambient super-samples */ int ambounce = 0; /* ambient bounces */ @@ -46,13 +60,20 @@ int ralrm = 0; /* seconds between reports */ double pctdone = 0.0; /* percentage done */ +long tlastrept = 0L; /* time at last report */ + +extern long time(); +extern long tstart; /* starting time */ + extern long nrays; /* number of rays traced */ -#define MAXDIV 32 /* maximum sample size */ +#define MAXDIV 15 /* maximum sample size */ #define pixjitter() (.5+dstrpix*(.5-frandom())) +double pixvalue(); + quit(code) /* quit program */ int code; { @@ -63,9 +84,9 @@ int code; } +#ifdef BSD report() /* report progress */ { -#ifdef BSD struct rusage rubuf; double t; @@ -78,117 +99,216 @@ report() /* report progress */ sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n", nrays, pctdone, t/3600.0); + eputs(errmsg); + tlastrept = time((long *)0); +} #else - sprintf(errmsg, "%ld rays, %4.2f%% done\n", nrays, pctdone); -#endif +report() /* report progress */ +{ + signal(SIGALRM, report); + tlastrept = time((long *)0); + sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n", + nrays, pctdone, (tlastrept-tstart)/3600.0); eputs(errmsg); - - if (ralrm > 0) - alarm(ralrm); } +#endif -render(oldfile) /* render the scene */ -char *oldfile; +render(zfile, oldfile) /* render the scene */ +char *zfile, *oldfile; { + extern long lseek(); COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ + float *zbar[MAXDIV+1]; /* z values */ int ypos; /* current scanline */ + int ystep; /* current y step size */ + int hstep; /* h step size */ + int zfd; COLOR *colptr; + float *zptr; register int i; - + /* check sampling */ if (psample < 1) psample = 1; - else if (psample > MAXDIV) + else if (psample > MAXDIV) { + sprintf(errmsg, "pixel sampling reduced from %d to %d", + psample, MAXDIV); + error(WARNING, errmsg); psample = MAXDIV; - - ourview.hresolu -= ourview.hresolu % psample; - ourview.vresolu -= ourview.vresolu % psample; - + } + /* allocate scanlines */ for (i = 0; i <= psample; i++) { - scanbar[i] = (COLOR *)malloc((ourview.hresolu+1)*sizeof(COLOR)); + scanbar[i] = (COLOR *)malloc(hresolu*sizeof(COLOR)); if (scanbar[i] == NULL) - error(SYSTEM, "out of memory in render"); + goto memerr; } - + /* open z file */ + if (zfile != NULL) { + if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { + sprintf(errmsg, "cannot open z file \"%s\"", zfile); + error(SYSTEM, errmsg); + } + for (i = 0; i <= psample; i++) { + zbar[i] = (float *)malloc(hresolu*sizeof(float)); + if (zbar[i] == NULL) + goto memerr; + } + } else { + zfd = -1; + for (i = 0; i <= psample; i++) + zbar[i] = NULL; + } /* write out boundaries */ - printf("-Y %d +X %d\n", ourview.vresolu, ourview.hresolu); - - ypos = ourview.vresolu - salvage(oldfile); /* find top line */ - fillscanline(scanbar[0], ypos, psample); /* top scan */ - - for (ypos -= psample; ypos > -psample; ypos -= psample) { - - colptr = scanbar[psample]; /* get last scanline */ - scanbar[psample] = scanbar[0]; + fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout); + /* recover file and compute first */ + i = salvage(oldfile); + if (zfd != -1 && i > 0 && + lseek(zfd, (long)i*hresolu*sizeof(float), 0) == -1) + error(SYSTEM, "z file seek error in render"); + pctdone = 100.0*i/vresolu; + if (ralrm > 0) /* report init stats */ + report(); +#ifndef BSD + else +#endif + signal(SIGALRM, report); + ypos = vresolu-1 - i; + hstep = (psample*140+49)/99; /* quincunx sampling */ + ystep = (psample*99+70)/140; + fillscanline(scanbar[0], zbar[0], hresolu, ypos, hstep); + /* compute scanlines */ + for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { + /* bottom adjust? */ + if (ypos < 0) { + ystep += ypos; + ypos = 0; + } + colptr = scanbar[ystep]; /* move base to top */ + scanbar[ystep] = scanbar[0]; scanbar[0] = colptr; - - fillscanline(scanbar[0], ypos, psample); /* base scan */ - - fillscanbar(scanbar, ypos, psample); - - for (i = psample-1; i >= 0; i--) - if (fwritescan(scanbar[i], ourview.hresolu, stdout) < 0) + zptr = zbar[ystep]; + zbar[ystep] = zbar[0]; + zbar[0] = zptr; + /* fill base line */ + fillscanline(scanbar[0], zbar[0], hresolu, ypos, hstep); + /* fill bar */ + fillscanbar(scanbar, zbar, hresolu, ypos, ystep); + /* write it out */ +#ifndef BSD + signal(SIGALRM, SIG_IGN); /* don't interrupt writes */ +#endif + for (i = ystep; i > 0; i--) { + if (zfd != -1 && write(zfd, (char *)zbar[i], + hresolu*sizeof(float)) + < hresolu*sizeof(float)) goto writerr; + if (fwritescan(scanbar[i], hresolu, stdout) < 0) + goto writerr; + } if (fflush(stdout) == EOF) goto writerr; - pctdone = 100.0*(ourview.vresolu-ypos)/ourview.vresolu; + /* record progress */ + pctdone = 100.0*(vresolu-1-ypos)/vresolu; + if (ralrm > 0 && time((long *)0) >= tlastrept+ralrm) + report(); +#ifndef BSD + else + signal(SIGALRM, report); +#endif } - + /* clean up */ + if (zfd != -1) { + if (write(zfd, (char *)zbar[0], hresolu*sizeof(float)) + < hresolu*sizeof(float)) + goto writerr; + if (close(zfd) == -1) + goto writerr; + for (i = 0; i <= psample; i++) + free((char *)zbar[i]); + } + fwritescan(scanbar[0], hresolu, stdout); + if (fflush(stdout) == EOF) + goto writerr; for (i = 0; i <= psample; i++) free((char *)scanbar[i]); + pctdone = 100.0; return; writerr: error(SYSTEM, "write error in render"); +memerr: + error(SYSTEM, "out of memory in render"); } -fillscanline(scanline, y, xstep) /* fill scan line at y */ +fillscanline(scanline, zline, xres, y, xstep) /* fill scan line at y */ register COLOR *scanline; -int y, xstep; +register float *zline; +int xres, y, xstep; { + static int nc = 0; /* number of calls */ int b = xstep; + double z; register int i; - pixvalue(scanline[0], 0, y); - - for (i = xstep; i <= ourview.hresolu; i += xstep) { - - pixvalue(scanline[i], i, y); + z = pixvalue(scanline[0], 0, y); + if (zline) zline[0] = z; + /* zig-zag start for quincunx pattern */ + for (i = nc++ & 1 ? xstep/2 : xstep; i < xres-1+xstep; i += xstep) { + if (i >= xres) { + xstep += xres-1-i; + i = xres-1; + } + z = pixvalue(scanline[i], i, y); + if (zline) zline[i] = z; - b = fillsample(scanline+i-xstep, i-xstep, y, xstep, 0, b/2); + b = fillsample(scanline+i-xstep, zline ? zline+i-xstep : NULL, + i-xstep, y, xstep, 0, b/2); } } -fillscanbar(scanbar, y, ysize) /* fill interior */ +fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */ register COLOR *scanbar[]; -int y, ysize; +register float *zbar[]; +int xres, y, ysize; { COLOR vline[MAXDIV+1]; + float zline[MAXDIV+1]; int b = ysize; register int i, j; - for (i = 0; i < ourview.hresolu; i++) { + for (i = 0; i < xres; i++) { copycolor(vline[0], scanbar[0][i]); copycolor(vline[ysize], scanbar[ysize][i]); + if (zbar[0]) { + zline[0] = zbar[0][i]; + zline[ysize] = zbar[ysize][i]; + } - b = fillsample(vline, i, y, 0, ysize, b/2); + b = fillsample(vline, zbar[0] ? zline : NULL, + i, y, 0, ysize, b/2); for (j = 1; j < ysize; j++) copycolor(scanbar[j][i], vline[j]); + if (zbar[0]) + for (j = 1; j < ysize; j++) + zbar[j][i] = zline[j]; } } int -fillsample(colline, x, y, xlen, ylen, b) /* fill interior points */ +fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ register COLOR *colline; +register float *zline; int x, y; int xlen, ylen; int b; { + extern double fabs(); double ratio; + double z; COLOR ctmp; int ncut; register int len; @@ -201,9 +321,12 @@ int b; if (len <= 1) /* limit recursion */ return(0); - if (b > 0 || bigdiff(colline[0], colline[len], maxdiff)) { + if (b > 0 + || (zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) + || bigdiff(colline[0], colline[len], maxdiff)) { - pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); + z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); + if (zline) zline[len>>1] = z; ncut = 1; } else { /* interpolate */ @@ -211,36 +334,47 @@ int b; copycolor(colline[len>>1], colline[len]); ratio = (double)(len>>1) / len; scalecolor(colline[len>>1], ratio); - copycolor(ctmp, colline[0]); + if (zline) zline[len>>1] = zline[len] * ratio; ratio = 1.0 - ratio; + copycolor(ctmp, colline[0]); scalecolor(ctmp, ratio); addcolor(colline[len>>1], ctmp); + if (zline) zline[len>>1] += zline[0] * ratio; ncut = 0; } /* recurse */ - ncut += fillsample(colline, x, y, xlen>>1, ylen>>1, (b-1)/2); + ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); - ncut += fillsample(colline + (len>>1), x + (xlen>>1), y + (ylen>>1), - xlen - (xlen>>1), ylen - (ylen>>1), b/2); + ncut += fillsample(colline+(len>>1), zline ? zline+(len>>1) : NULL, + x+(xlen>>1), y+(ylen>>1), + xlen-(xlen>>1), ylen-(ylen>>1), b/2); return(ncut); } +double pixvalue(col, x, y) /* compute pixel value */ COLOR col; /* returned color */ int x, y; /* pixel position */ { - static RAY thisray; /* our ray for this pixel */ + static RAY thisray; - rayview(thisray.rorg, thisray.rdir, &ourview, - x + pixjitter(), y + pixjitter()); + if (viewray(thisray.rorg, thisray.rdir, &ourview, + (x+pixjitter())/hresolu, (y+pixjitter())/vresolu) < 0) { + setcolor(col, 0.0, 0.0, 0.0); + return(0.0); + } rayorigin(&thisray, NULL, PRIMARY, 1.0); - + + samplendx = pixnumber(x,y,hresolu,vresolu); /* set pixel index */ + rayvalue(&thisray); /* trace ray */ copycolor(col, thisray.rcol); /* return color */ + + return(thisray.rt); /* return distance */ } @@ -254,7 +388,8 @@ char *oldfile; if (oldfile == NULL) return(0); - else if ((fp = fopen(oldfile, "r")) == NULL) { + + if ((fp = fopen(oldfile, "r")) == NULL) { sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); error(WARNING, errmsg); return(0); @@ -262,25 +397,26 @@ char *oldfile; /* discard header */ getheader(fp, NULL); /* get picture size */ - if (fscanf(fp, "-Y %d +X %d\n", &y, &x) != 2) { + if (fgetresolu(&x, &y, fp) != (YMAJOR|YDECR)) { + sprintf(errmsg, "bad recover file \"%s\"", oldfile); + error(WARNING, errmsg); fclose(fp); return(0); } - if (x != ourview.hresolu || y != ourview.vresolu) { + if (x != hresolu || y != vresolu) { sprintf(errmsg, "resolution mismatch in recover file \"%s\"", oldfile); error(USER, errmsg); - return(0); } - scanline = (COLR *)malloc(ourview.hresolu*sizeof(COLR)); + scanline = (COLR *)malloc(hresolu*sizeof(COLR)); if (scanline == NULL) error(SYSTEM, "out of memory in salvage"); - for (y = 0; y < ourview.vresolu; y++) { - if (freadcolrs(scanline, ourview.hresolu, fp) < 0) + for (y = 0; y < vresolu; y++) { + if (freadcolrs(scanline, hresolu, fp) < 0) break; - if (fwritecolrs(scanline, ourview.hresolu, stdout) < 0) + if (fwritecolrs(scanline, hresolu, stdout) < 0) goto writerr; } if (fflush(stdout) == EOF) @@ -291,4 +427,16 @@ char *oldfile; return(y); writerr: error(SYSTEM, "write error in salvage"); +} + + +int +pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */ +register int x, y; +int xres, yres; +{ + x -= y; + while (x < 0) + x += xres; + return((((x>>2)*yres + y) << 2) + (x & 3)); }
