1 |
/* Copyright (c) 1996 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* rpict.c - routines and variables for picture generation. |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include <sys/types.h> |
14 |
15 |
#ifndef NIX |
16 |
#ifdef BSD |
17 |
#include <sys/time.h> |
18 |
#include <sys/resource.h> |
19 |
#else |
20 |
#include <sys/times.h> |
21 |
#include <unistd.h> |
22 |
#endif |
23 |
#endif |
24 |
25 |
extern time_t time(); |
26 |
27 |
#include <signal.h> |
28 |
29 |
#include "view.h" |
30 |
31 |
#include "resolu.h" |
32 |
33 |
#include "random.h" |
34 |
35 |
#include "paths.h" |
36 |
37 |
#define RFTEMPLATE "rfXXXXXX" |
38 |
39 |
#ifndef SIGCONT |
40 |
#define SIGCONT SIGIO |
41 |
#endif |
42 |
43 |
int dimlist[MAXDIM]; /* sampling dimensions */ |
44 |
int ndims = 0; /* number of sampling dimensions */ |
45 |
int samplendx; /* sample index number */ |
46 |
47 |
VIEW ourview = STDVIEW; /* view parameters */ |
48 |
int hresolu = 512; /* horizontal resolution */ |
49 |
int vresolu = 512; /* vertical resolution */ |
50 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
51 |
52 |
int psample = 4; /* pixel sample size */ |
53 |
double maxdiff = .05; /* max. difference for interpolation */ |
54 |
double dstrpix = 0.67; /* square pixel distribution */ |
55 |
56 |
double dstrsrc = 0.0; /* square source distribution */ |
57 |
double shadthresh = .05; /* shadow threshold */ |
58 |
double shadcert = .5; /* shadow certainty */ |
59 |
int directrelay = 1; /* number of source relays */ |
60 |
int vspretest = 512; /* virtual source pretest density */ |
61 |
int directvis = 1; /* sources visible? */ |
62 |
double srcsizerat = .25; /* maximum ratio source size/dist. */ |
63 |
64 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ |
65 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */ |
66 |
double seccg = 0.; /* global scattering eccentricity */ |
67 |
double ssampdist = 0.; /* scatter sampling distance */ |
68 |
69 |
double specthresh = .15; /* specular sampling threshold */ |
70 |
double specjitter = 1.; /* specular sampling jitter */ |
71 |
72 |
int backvis = 1; /* back face visibility */ |
73 |
74 |
int maxdepth = 6; /* maximum recursion depth */ |
75 |
double minweight = 5e-3; /* minimum ray weight */ |
76 |
77 |
COLOR ambval = BLKCOLOR; /* ambient value */ |
78 |
int ambvwt = 0; /* initial weight for ambient value */ |
79 |
double ambacc = 0.2; /* ambient accuracy */ |
80 |
int ambres = 32; /* ambient resolution */ |
81 |
int ambdiv = 128; /* ambient divisions */ |
82 |
int ambssamp = 0; /* ambient super-samples */ |
83 |
int ambounce = 0; /* ambient bounces */ |
84 |
char *amblist[128]; /* ambient include/exclude list */ |
85 |
int ambincl = -1; /* include == 1, exclude == 0 */ |
86 |
87 |
#ifdef MSDOS |
88 |
int ralrm = 60; /* seconds between reports */ |
89 |
#else |
90 |
int ralrm = 0; /* seconds between reports */ |
91 |
#endif |
92 |
93 |
double pctdone = 0.0; /* percentage done */ |
94 |
95 |
time_t tlastrept = 0L; /* time at last report */ |
96 |
97 |
extern time_t tstart; /* starting time */ |
98 |
99 |
extern unsigned long nrays; /* number of rays traced */ |
100 |
101 |
#define MAXDIV 16 /* maximum sample size */ |
102 |
103 |
#define pixjitter() (.5+dstrpix*(.5-frandom())) |
104 |
105 |
int hres, vres; /* resolution for this frame */ |
106 |
107 |
extern char *mktemp(); |
108 |
109 |
double pixvalue(); |
110 |
111 |
#ifdef NIX |
112 |
#define file_exists(f) (access(f,F_OK)==0) |
113 |
#else |
114 |
115 |
#include <sys/stat.h> |
116 |
int |
117 |
file_exists(fname) /* ordinary file exists? */ |
118 |
char *fname; |
119 |
120 |
struct stat sbuf; |
121 |
if (stat(fname, &sbuf) < 0) return(0); |
122 |
return((sbuf.st_mode & S_IFREG) != 0); |
123 |
124 |
#endif |
125 |
126 |
127 |
quit(code) /* quit program */ |
128 |
int code; |
129 |
130 |
if (code) /* report status */ |
131 |
report(); |
132 |
headclean(); /* delete header file */ |
133 |
pfclean(); /* clean up persist files */ |
134 |
exit(code); |
135 |
136 |
137 |
138 |
#ifndef NIX |
139 |
report() /* report progress */ |
140 |
141 |
extern char *myhostname(); |
142 |
double u, s; |
143 |
#ifdef BSD |
144 |
struct rusage rubuf; |
145 |
#else |
146 |
struct tms tbuf; |
147 |
double period; |
148 |
#endif |
149 |
150 |
tlastrept = time((time_t *)NULL); |
151 |
#ifdef BSD |
152 |
getrusage(RUSAGE_SELF, &rubuf); |
153 |
u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; |
154 |
s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; |
155 |
getrusage(RUSAGE_CHILDREN, &rubuf); |
156 |
u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; |
157 |
s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; |
158 |
#else |
159 |
times(&tbuf); |
160 |
#ifdef _SC_CLK_TCK |
161 |
period = 1.0 / sysconf(_SC_CLK_TCK); |
162 |
#else |
163 |
period = 1.0 / 60.0; |
164 |
#endif |
165 |
u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period; |
166 |
s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period; |
167 |
#endif |
168 |
169 |
sprintf(errmsg, |
170 |
"%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n", |
171 |
nrays, pctdone, u/3600., s/3600., |
172 |
(tlastrept-tstart)/3600., myhostname()); |
173 |
eputs(errmsg); |
174 |
#ifndef BSD |
175 |
signal(SIGCONT, report); |
176 |
#endif |
177 |
178 |
#else |
179 |
180 |
181 |
182 |
sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n", |
183 |
nrays, pctdone, (tlastrept-tstart)/3600.0); |
184 |
eputs(errmsg); |
185 |
186 |
#endif |
187 |
188 |
189 |
rpict(seq, pout, zout, prvr) /* generate image(s) */ |
190 |
int seq; |
191 |
char *pout, *zout, *prvr; |
192 |
193 |
* If seq is greater than zero, then we will render a sequence of |
194 |
* images based on view parameter strings read from the standard input. |
195 |
* If pout is NULL, then all images will be sent to the standard ouput. |
196 |
* If seq is greater than zero and prvr is an integer, then it is the |
197 |
* frame number at which rendering should begin. Preceeding view parameter |
198 |
* strings will be skipped in the input. |
199 |
* If pout and prvr are the same, prvr is renamed to avoid overwriting. |
200 |
* Note that pout and zout should contain %d format specifications for |
201 |
* sequenced file naming. |
202 |
203 |
204 |
extern char *rindex(), *strncpy(), *strcat(), *strcpy(); |
205 |
char fbuf[128], fbuf2[128]; |
206 |
int npicts; |
207 |
register char *cp; |
208 |
RESOLU rs; |
209 |
double pa; |
210 |
/* check sampling */ |
211 |
if (psample < 1) |
212 |
psample = 1; |
213 |
else if (psample > MAXDIV) { |
214 |
sprintf(errmsg, "pixel sampling reduced from %d to %d", |
215 |
psample, MAXDIV); |
216 |
error(WARNING, errmsg); |
217 |
psample = MAXDIV; |
218 |
219 |
/* get starting frame */ |
220 |
if (seq <= 0) |
221 |
seq = 0; |
222 |
else if (prvr != NULL && isint(prvr)) { |
223 |
register int rn; /* skip to specified view */ |
224 |
if ((rn = atoi(prvr)) < seq) |
225 |
error(USER, "recover frame less than start frame"); |
226 |
if (pout == NULL) |
227 |
error(USER, "missing output file specification"); |
228 |
for ( ; seq < rn; seq++) |
229 |
if (nextview(stdin) == EOF) |
230 |
error(USER, "unexpected EOF on view input"); |
231 |
prvr = fbuf; /* mark for renaming */ |
232 |
233 |
if (pout != NULL & prvr != NULL) { |
234 |
sprintf(fbuf, pout, seq); |
235 |
if (!strcmp(prvr, fbuf)) { /* rename */ |
236 |
strcpy(fbuf2, fbuf); |
237 |
for (cp = fbuf2; *cp; cp++) |
238 |
239 |
while (cp > fbuf2 && !ISDIRSEP(cp[-1])) |
240 |
cp--; |
241 |
strcpy(cp, RFTEMPLATE); |
242 |
prvr = mktemp(fbuf2); |
243 |
if (rename(fbuf, prvr) < 0) |
244 |
if (errno == ENOENT) { /* ghost file */ |
245 |
sprintf(errmsg, |
246 |
"new output file \"%s\"", |
247 |
fbuf); |
248 |
249 |
prvr = NULL; |
250 |
} else { /* serious error */ |
251 |
sprintf(errmsg, |
252 |
"cannot rename \"%s\" to \"%s\"", |
253 |
fbuf, prvr); |
254 |
error(SYSTEM, errmsg); |
255 |
256 |
257 |
258 |
npicts = 0; /* render sequence */ |
259 |
do { |
260 |
if (seq && nextview(stdin) == EOF) |
261 |
break; |
262 |
pctdone = 0.0; |
263 |
if (pout != NULL) { |
264 |
265 |
if (file_exists(fbuf)) { |
266 |
if (prvr != NULL || !strcmp(fbuf, pout)) { |
267 |
sprintf(errmsg, |
268 |
"output file \"%s\" exists", |
269 |
fbuf); |
270 |
error(USER, errmsg); |
271 |
272 |
continue; /* don't clobber */ |
273 |
274 |
if (freopen(fbuf, "w", stdout) == NULL) { |
275 |
sprintf(errmsg, |
276 |
"cannot open output file \"%s\"", fbuf); |
277 |
278 |
279 |
#ifdef MSDOS |
280 |
setmode(fileno(stdout), O_BINARY); |
281 |
#endif |
282 |
dupheader(); |
283 |
284 |
hres = hresolu; vres = vresolu; pa = pixaspect; |
285 |
if (prvr != NULL) |
286 |
if (viewfile(prvr, &ourview, &rs) <= 0 |
287 |
|| rs.or != PIXSTANDARD) { |
288 |
sprintf(errmsg, |
289 |
"cannot recover view parameters from \"%s\"", prvr); |
290 |
291 |
} else { |
292 |
pa = 0.0; |
293 |
hres = scanlen(&rs); |
294 |
vres = numscans(&rs); |
295 |
296 |
if ((cp = setview(&ourview)) != NULL) |
297 |
error(USER, cp); |
298 |
normaspect(viewaspect(&ourview), &pa, &hres, &vres); |
299 |
if (seq) { |
300 |
if (ralrm > 0) { |
301 |
fprintf(stderr, "FRAME %d:", seq); |
302 |
fprintview(&ourview, stderr); |
303 |
putc('\n', stderr); |
304 |
fflush(stderr); |
305 |
306 |
printf("FRAME=%d\n", seq); |
307 |
308 |
fputs(VIEWSTR, stdout); |
309 |
fprintview(&ourview, stdout); |
310 |
putchar('\n'); |
311 |
if (pa < .99 || pa > 1.01) |
312 |
fputaspect(pa, stdout); |
313 |
fputformat(COLRFMT, stdout); |
314 |
putchar('\n'); |
315 |
if (zout != NULL) |
316 |
sprintf(cp=fbuf, zout, seq); |
317 |
else |
318 |
cp = NULL; |
319 |
render(cp, prvr); |
320 |
prvr = NULL; |
321 |
npicts++; |
322 |
} while (seq++); |
323 |
/* check that we did something */ |
324 |
if (npicts == 0) |
325 |
error(WARNING, "no output produced"); |
326 |
327 |
328 |
329 |
nextview(fp) /* get next view from fp */ |
330 |
FILE *fp; |
331 |
332 |
char linebuf[256]; |
333 |
334 |
while (fgets(linebuf, sizeof(linebuf), fp) != NULL) |
335 |
if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) |
336 |
return(0); |
337 |
return(EOF); |
338 |
339 |
340 |
341 |
render(zfile, oldfile) /* render the scene */ |
342 |
char *zfile, *oldfile; |
343 |
344 |
extern long lseek(); |
345 |
COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ |
346 |
float *zbar[MAXDIV+1]; /* z values */ |
347 |
char *sampdens; /* previous sample density */ |
348 |
int ypos; /* current scanline */ |
349 |
int ystep; /* current y step size */ |
350 |
int hstep; /* h step size */ |
351 |
int zfd; |
352 |
COLOR *colptr; |
353 |
float *zptr; |
354 |
register int i; |
355 |
/* allocate scanlines */ |
356 |
for (i = 0; i <= psample; i++) { |
357 |
scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); |
358 |
if (scanbar[i] == NULL) |
359 |
goto memerr; |
360 |
361 |
hstep = (psample*140+49)/99; /* quincunx sampling */ |
362 |
ystep = (psample*99+70)/140; |
363 |
if (hstep > 2) { |
364 |
i = hres/hstep + 2; |
365 |
if ((sampdens = malloc(i)) == NULL) |
366 |
goto memerr; |
367 |
while (i--) |
368 |
sampdens[i] = hstep; |
369 |
} else |
370 |
sampdens = NULL; |
371 |
/* open z-file */ |
372 |
if (zfile != NULL) { |
373 |
if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { |
374 |
sprintf(errmsg, "cannot open z-file \"%s\"", zfile); |
375 |
376 |
377 |
#ifdef MSDOS |
378 |
setmode(zfd, O_BINARY); |
379 |
#endif |
380 |
381 |
zbar[i] = (float *)malloc(hres*sizeof(float)); |
382 |
if (zbar[i] == NULL) |
383 |
goto memerr; |
384 |
385 |
} else { |
386 |
zfd = -1; |
387 |
for (i = 0; i <= psample; i++) |
388 |
zbar[i] = NULL; |
389 |
390 |
/* write out boundaries */ |
391 |
fprtresolu(hres, vres, stdout); |
392 |
/* recover file and compute first */ |
393 |
i = salvage(oldfile); |
394 |
if (i >= vres) |
395 |
goto alldone; |
396 |
if (zfd != -1 && i > 0 && |
397 |
lseek(zfd, (long)i*hres*sizeof(float), 0) == -1) |
398 |
error(SYSTEM, "z-file seek error in render"); |
399 |
pctdone = 100.0*i/vres; |
400 |
if (ralrm > 0) /* report init stats */ |
401 |
report(); |
402 |
#ifndef BSD |
403 |
else |
404 |
#endif |
405 |
406 |
ypos = vres-1 - i; /* initialize sampling */ |
407 |
init_drawsources(psample); |
408 |
fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); |
409 |
/* compute scanlines */ |
410 |
for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { |
411 |
/* bottom adjust? */ |
412 |
if (ypos < 0) { |
413 |
ystep += ypos; |
414 |
ypos = 0; |
415 |
416 |
colptr = scanbar[ystep]; /* move base to top */ |
417 |
scanbar[ystep] = scanbar[0]; |
418 |
scanbar[0] = colptr; |
419 |
zptr = zbar[ystep]; |
420 |
zbar[ystep] = zbar[0]; |
421 |
zbar[0] = zptr; |
422 |
/* fill base line */ |
423 |
fillscanline(scanbar[0], zbar[0], sampdens, |
424 |
425 |
/* fill bar */ |
426 |
fillscanbar(scanbar, zbar, hres, ypos, ystep); |
427 |
/* add bitty sources */ |
428 |
drawsources(scanbar, zbar, 0, hres, ypos, ystep); |
429 |
/* write it out */ |
430 |
#ifndef BSD |
431 |
signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ |
432 |
#endif |
433 |
for (i = ystep; i > 0; i--) { |
434 |
if (zfd != -1 && write(zfd, (char *)zbar[i], |
435 |
hres*sizeof(float)) |
436 |
< hres*sizeof(float)) |
437 |
goto writerr; |
438 |
if (fwritescan(scanbar[i], hres, stdout) < 0) |
439 |
goto writerr; |
440 |
441 |
if (fflush(stdout) == EOF) |
442 |
goto writerr; |
443 |
/* record progress */ |
444 |
pctdone = 100.0*(vres-1-ypos)/vres; |
445 |
if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm) |
446 |
report(); |
447 |
#ifndef BSD |
448 |
else |
449 |
450 |
#endif |
451 |
452 |
/* clean up */ |
453 |
signal(SIGCONT, SIG_IGN); |
454 |
if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float)) |
455 |
456 |
goto writerr; |
457 |
fwritescan(scanbar[0], hres, stdout); |
458 |
459 |
goto writerr; |
460 |
alldone: |
461 |
if (zfd != -1) { |
462 |
if (close(zfd) == -1) |
463 |
goto writerr; |
464 |
465 |
free((char *)zbar[i]); |
466 |
467 |
468 |
free((char *)scanbar[i]); |
469 |
if (sampdens != NULL) |
470 |
free(sampdens); |
471 |
pctdone = 100.0; |
472 |
if (ralrm > 0) |
473 |
report(); |
474 |
signal(SIGCONT, SIG_DFL); |
475 |
return; |
476 |
writerr: |
477 |
error(SYSTEM, "write error in render"); |
478 |
memerr: |
479 |
error(SYSTEM, "out of memory in render"); |
480 |
481 |
482 |
483 |
fillscanline(scanline, zline, sd, xres, y, xstep) /* fill scan at y */ |
484 |
register COLOR *scanline; |
485 |
register float *zline; |
486 |
register char *sd; |
487 |
int xres, y, xstep; |
488 |
489 |
static int nc = 0; /* number of calls */ |
490 |
int bl = xstep, b = xstep; |
491 |
double z; |
492 |
register int i; |
493 |
494 |
z = pixvalue(scanline[0], 0, y); |
495 |
if (zline) zline[0] = z; |
496 |
/* zig-zag start for quincunx pattern */ |
497 |
for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) { |
498 |
if (i >= xres) { |
499 |
xstep += xres-1-i; |
500 |
i = xres-1; |
501 |
502 |
z = pixvalue(scanline[i], i, y); |
503 |
if (zline) zline[i] = z; |
504 |
if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1]; |
505 |
if (i <= xstep) |
506 |
b = fillsample(scanline, zline, 0, y, i, 0, b/2); |
507 |
else |
508 |
b = fillsample(scanline+i-xstep, |
509 |
zline ? zline+i-xstep : (float *)NULL, |
510 |
i-xstep, y, xstep, 0, b/2); |
511 |
if (sd) *sd++ = nc & 1 ? bl : b; |
512 |
bl = b; |
513 |
514 |
if (sd && nc & 1) *sd = bl; |
515 |
516 |
517 |
518 |
fillscanbar(scanbar, zbar, xres, y, ysize) /* fill interior */ |
519 |
register COLOR *scanbar[]; |
520 |
register float *zbar[]; |
521 |
int xres, y, ysize; |
522 |
523 |
COLOR vline[MAXDIV+1]; |
524 |
float zline[MAXDIV+1]; |
525 |
int b = ysize; |
526 |
register int i, j; |
527 |
528 |
for (i = 0; i < xres; i++) { |
529 |
copycolor(vline[0], scanbar[0][i]); |
530 |
copycolor(vline[ysize], scanbar[ysize][i]); |
531 |
if (zbar[0]) { |
532 |
zline[0] = zbar[0][i]; |
533 |
zline[ysize] = zbar[ysize][i]; |
534 |
535 |
b = fillsample(vline, zbar[0] ? zline : (float *)NULL, |
536 |
i, y, 0, ysize, b/2); |
537 |
538 |
for (j = 1; j < ysize; j++) |
539 |
copycolor(scanbar[j][i], vline[j]); |
540 |
if (zbar[0]) |
541 |
542 |
zbar[j][i] = zline[j]; |
543 |
544 |
545 |
546 |
547 |
int |
548 |
fillsample(colline, zline, x, y, xlen, ylen, b) /* fill interior points */ |
549 |
register COLOR *colline; |
550 |
551 |
int x, y; |
552 |
int xlen, ylen; |
553 |
int b; |
554 |
555 |
double ratio; |
556 |
double z; |
557 |
COLOR ctmp; |
558 |
int ncut; |
559 |
register int len; |
560 |
561 |
if (xlen > 0) /* x or y length is zero */ |
562 |
len = xlen; |
563 |
else |
564 |
len = ylen; |
565 |
566 |
if (len <= 1) /* limit recursion */ |
567 |
return(0); |
568 |
569 |
if (b > 0 || |
570 |
(zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) |
571 |
|| bigdiff(colline[0], colline[len], maxdiff)) { |
572 |
573 |
z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); |
574 |
if (zline) zline[len>>1] = z; |
575 |
ncut = 1; |
576 |
} else { /* interpolate */ |
577 |
copycolor(colline[len>>1], colline[len]); |
578 |
ratio = (double)(len>>1) / len; |
579 |
scalecolor(colline[len>>1], ratio); |
580 |
if (zline) zline[len>>1] = zline[len] * ratio; |
581 |
ratio = 1.0 - ratio; |
582 |
copycolor(ctmp, colline[0]); |
583 |
scalecolor(ctmp, ratio); |
584 |
addcolor(colline[len>>1], ctmp); |
585 |
if (zline) zline[len>>1] += zline[0] * ratio; |
586 |
ncut = 0; |
587 |
588 |
/* recurse */ |
589 |
ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); |
590 |
591 |
ncut += fillsample(colline+(len>>1), |
592 |
zline ? zline+(len>>1) : (float *)NULL, |
593 |
x+(xlen>>1), y+(ylen>>1), |
594 |
xlen-(xlen>>1), ylen-(ylen>>1), b/2); |
595 |
596 |
return(ncut); |
597 |
598 |
599 |
600 |
double |
601 |
pixvalue(col, x, y) /* compute pixel value */ |
602 |
COLOR col; /* returned color */ |
603 |
int x, y; /* pixel position */ |
604 |
605 |
static RAY thisray; |
606 |
607 |
if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, &ourview, |
608 |
(x+pixjitter())/hres, (y+pixjitter())/vres)) < -FTINY) { |
609 |
setcolor(col, 0.0, 0.0, 0.0); |
610 |
return(0.0); |
611 |
612 |
613 |
rayorigin(&thisray, NULL, PRIMARY, 1.0); |
614 |
615 |
samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ |
616 |
617 |
rayvalue(&thisray); /* trace ray */ |
618 |
619 |
copycolor(col, thisray.rcol); /* return color */ |
620 |
621 |
return(thisray.rt); /* return distance */ |
622 |
623 |
624 |
625 |
int |
626 |
salvage(oldfile) /* salvage scanlines from killed program */ |
627 |
char *oldfile; |
628 |
629 |
COLR *scanline; |
630 |
FILE *fp; |
631 |
int x, y; |
632 |
633 |
if (oldfile == NULL) |
634 |
goto gotzip; |
635 |
636 |
if ((fp = fopen(oldfile, "r")) == NULL) { |
637 |
sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); |
638 |
639 |
goto gotzip; |
640 |
641 |
#ifdef MSDOS |
642 |
setmode(fileno(fp), O_BINARY); |
643 |
#endif |
644 |
/* discard header */ |
645 |
getheader(fp, NULL, NULL); |
646 |
/* get picture size */ |
647 |
if (!fscnresolu(&x, &y, fp)) { |
648 |
sprintf(errmsg, "bad recover file \"%s\" - not removed", |
649 |
oldfile); |
650 |
651 |
fclose(fp); |
652 |
goto gotzip; |
653 |
654 |
655 |
if (x != hres || y != vres) { |
656 |
sprintf(errmsg, "resolution mismatch in recover file \"%s\"", |
657 |
oldfile); |
658 |
659 |
660 |
661 |
scanline = (COLR *)malloc(hres*sizeof(COLR)); |
662 |
if (scanline == NULL) |
663 |
error(SYSTEM, "out of memory in salvage"); |
664 |
for (y = 0; y < vres; y++) { |
665 |
if (freadcolrs(scanline, hres, fp) < 0) |
666 |
break; |
667 |
if (fwritecolrs(scanline, hres, stdout) < 0) |
668 |
goto writerr; |
669 |
670 |
671 |
goto writerr; |
672 |
free((char *)scanline); |
673 |
fclose(fp); |
674 |
unlink(oldfile); |
675 |
return(y); |
676 |
gotzip: |
677 |
678 |
error(SYSTEM, "error writing picture header"); |
679 |
return(0); |
680 |
writerr: |
681 |
sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); |
682 |
683 |
684 |
685 |
686 |
int |
687 |
pixnumber(x, y, xres, yres) /* compute pixel index (brushed) */ |
688 |
register int x, y; |
689 |
int xres, yres; |
690 |
691 |
x -= y; |
692 |
while (x < 0) |
693 |
x += xres; |
694 |
return((((x>>2)*yres + y) << 2) + (x & 3)); |
695 |
