--- ray/src/rt/rpict.c 1992/11/10 21:24:34 2.18 +++ ray/src/rt/rpict.c 1993/08/11 09:46:15 2.29 @@ -27,6 +27,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include "paths.h" +#define RFTEMPLATE "rfXXXXXX" + +#ifndef SIGCONT +#define SIGCONT SIGIO +#endif + int dimlist[MAXDIM]; /* sampling dimensions */ int ndims = 0; /* number of sampling dimensions */ int samplendx; /* sample index number */ @@ -45,7 +51,7 @@ double shadthresh = .05; /* shadow threshold */ double shadcert = .5; /* shadow certainty */ int directrelay = 1; /* number of source relays */ int vspretest = 512; /* virtual source pretest density */ -int directinvis = 0; /* sources invisible? */ +int directvis = 1; /* sources visible? */ double srcsizerat = .25; /* maximum ratio source size/dist. */ double specthresh = .15; /* specular sampling threshold */ @@ -76,35 +82,41 @@ long tlastrept = 0L; /* time at last report */ extern long time(); extern long tstart; /* starting time */ -extern long nrays; /* number of rays traced */ +extern unsigned long nrays; /* number of rays traced */ #define MAXDIV 16 /* maximum sample size */ #define pixjitter() (.5+dstrpix*(.5-frandom())) -#define RFTEMPLATE "rfXXXXXX" -#define HFTEMPLATE TEMPLATE - -static char *hfname = NULL; /* header file name */ -static FILE *hfp = NULL; /* header file pointer */ - static int hres, vres; /* resolution for this frame */ extern char *mktemp(); double pixvalue(); +#ifdef NIX +#define file_exists(f) (access(f,F_OK)==0) +#else +#include +#include +int +file_exists(fname) /* ordinary file exists? */ +char *fname; +{ + struct stat sbuf; + if (stat(fname, &sbuf) < 0) return(0); + return((sbuf.st_mode & S_IFREG) != 0); +} +#endif + quit(code) /* quit program */ int code; { if (code) /* report status */ report(); - if (hfname != NULL) { /* delete header file */ - if (hfp != NULL) - fclose(hfp); - unlink(hfname); - } + headclean(); /* delete header file */ + pfclean(); /* clean up persist files */ exit(code); } @@ -122,7 +134,7 @@ report() /* report progress */ t += (rubuf.ru_utime.tv_usec + rubuf.ru_stime.tv_usec) / 1e6; t += rubuf.ru_utime.tv_sec + rubuf.ru_stime.tv_sec; - sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f CPU hours\n", + sprintf(errmsg, "%lu rays, %4.2f%% done after %5.4f CPU hours\n", nrays, pctdone, t/3600.0); eputs(errmsg); tlastrept = time((long *)0); @@ -131,41 +143,14 @@ report() /* report progress */ report() /* report progress */ { tlastrept = time((long *)0); - sprintf(errmsg, "%ld rays, %4.2f%% done after %5.4f hours\n", + sprintf(errmsg, "%lu rays, %4.2f%% done after %5.4f hours\n", nrays, pctdone, (tlastrept-tstart)/3600.0); eputs(errmsg); - signal(SIGALRM, report); + signal(SIGCONT, report); } #endif -openheader() /* save standard output to header file */ -{ - hfname = mktemp(HFTEMPLATE); - if (freopen(hfname, "w", stdout) == NULL) { - sprintf(errmsg, "cannot open header file \"%s\"", hfname); - error(SYSTEM, errmsg); - } -} - - -dupheader() /* repeat header on standard output */ -{ - register int c; - - if (hfp == NULL) { - if ((hfp = fopen(hfname, "r")) == NULL) - error(SYSTEM, "error reopening header file"); -#ifdef MSDOS - setmode(fileno(hfp), O_BINARY); -#endif - } else if (fseek(hfp, 0L, 0) < 0) - error(SYSTEM, "seek error on header file"); - while ((c = getc(hfp)) != EOF) - putchar(c); -} - - rpict(seq, pout, zout, prvr) /* generate image(s) */ int seq; char *pout, *zout, *prvr; @@ -181,8 +166,9 @@ char *pout, *zout, *prvr; * sequenced file naming. */ { - extern char *rindex(), *strncpy(), *strcat(); + extern char *rindex(), *strncpy(), *strcat(), *strcpy(); char fbuf[128], fbuf2[128]; + int npicts; register char *cp; RESOLU rs; double pa; @@ -219,20 +205,37 @@ char *pout, *zout, *prvr; cp--; strcpy(cp, RFTEMPLATE); prvr = mktemp(fbuf2); - if (rename(fbuf, prvr) < 0 && errno != ENOENT) { - sprintf(errmsg, + if (rename(fbuf, prvr) < 0) + if (errno == ENOENT) { /* ghost file */ + sprintf(errmsg, + "new output file \"%s\"", + fbuf); + error(WARNING, errmsg); + prvr = NULL; + } else { /* serious error */ + sprintf(errmsg, "cannot rename \"%s\" to \"%s\"", fbuf, prvr); - error(SYSTEM, errmsg); - } + error(SYSTEM, errmsg); + } } } - /* render sequence */ + npicts = 0; /* render sequence */ do { if (seq && nextview(stdin) == EOF) break; + pctdone = 0.0; if (pout != NULL) { sprintf(fbuf, pout, seq); + if (file_exists(fbuf)) { + if (prvr != NULL || !strcmp(fbuf, pout)) { + sprintf(errmsg, + "output file \"%s\" exists", + fbuf); + error(USER, errmsg); + } + continue; /* don't clobber */ + } if (freopen(fbuf, "w", stdout) == NULL) { sprintf(errmsg, "cannot open output file \"%s\"", fbuf); @@ -280,7 +283,11 @@ char *pout, *zout, *prvr; cp = NULL; render(cp, prvr); prvr = NULL; + npicts++; } while (seq++); + /* check that we did something */ + if (npicts == 0) + error(WARNING, "no output produced"); } @@ -326,10 +333,10 @@ char *zfile, *oldfile; sampdens[i] = hstep; } else sampdens = NULL; - /* open z file */ + /* open z-file */ if (zfile != NULL) { if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { - sprintf(errmsg, "cannot open z file \"%s\"", zfile); + sprintf(errmsg, "cannot open z-file \"%s\"", zfile); error(SYSTEM, errmsg); } #ifdef MSDOS @@ -351,14 +358,14 @@ char *zfile, *oldfile; i = salvage(oldfile); if (zfd != -1 && i > 0 && lseek(zfd, (long)i*hres*sizeof(float), 0) == -1) - error(SYSTEM, "z file seek error in render"); + error(SYSTEM, "z-file seek error in render"); pctdone = 100.0*i/vres; if (ralrm > 0) /* report init stats */ report(); #ifndef BSD else #endif - signal(SIGALRM, report); + signal(SIGCONT, report); ypos = vres-1 - i; fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); /* compute scanlines */ @@ -381,7 +388,7 @@ char *zfile, *oldfile; fillscanbar(scanbar, zbar, hres, ypos, ystep); /* write it out */ #ifndef BSD - signal(SIGALRM, SIG_IGN); /* don't interrupt writes */ + signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ #endif for (i = ystep; i > 0; i--) { if (zfd != -1 && write(zfd, (char *)zbar[i], @@ -399,11 +406,11 @@ char *zfile, *oldfile; report(); #ifndef BSD else - signal(SIGALRM, report); + signal(SIGCONT, report); #endif } /* clean up */ - signal(SIGALRM, SIG_IGN); + signal(SIGCONT, SIG_IGN); if (zfd != -1) { if (write(zfd, (char *)zbar[0], hres*sizeof(float)) < hres*sizeof(float)) @@ -423,6 +430,7 @@ char *zfile, *oldfile; pctdone = 100.0; if (ralrm > 0) report(); + signal(SIGCONT, SIG_DFL); return; writerr: error(SYSTEM, "write error in render"); @@ -596,10 +604,11 @@ char *oldfile; setmode(fileno(fp), O_BINARY); #endif /* discard header */ - getheader(fp, NULL); + getheader(fp, NULL, NULL); /* get picture size */ if (!fscnresolu(&x, &y, fp)) { - sprintf(errmsg, "bad recover file \"%s\"", oldfile); + sprintf(errmsg, "bad recover file \"%s\" - not removed", + oldfile); error(WARNING, errmsg); fclose(fp); return(0);
