1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rpict.c,v 2.70 2004/09/28 17:54:19 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rpict.c - routines and variables for picture generation. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <sys/types.h> |
11 |
12 |
#ifndef NON_POSIX |
13 |
#ifdef BSD |
14 |
#include <sys/time.h> |
15 |
#include <sys/resource.h> |
16 |
#else |
17 |
#include <sys/times.h> |
18 |
#include <unistd.h> |
19 |
#endif |
20 |
#endif |
21 |
22 |
#include <time.h> |
23 |
#include <signal.h> |
24 |
25 |
#include "platform.h" |
26 |
#include "ray.h" |
27 |
#include "paths.h" |
28 |
#include "ambient.h" |
29 |
#include "view.h" |
30 |
#include "random.h" |
31 |
32 |
#include "rtmisc.h" /* myhostname() */ |
33 |
34 |
35 |
#define RFTEMPLATE "rfXXXXXX" |
36 |
37 |
#ifndef SIGCONT |
38 |
#ifdef SIGIO /* XXX can we live without this? */ |
39 |
#define SIGCONT SIGIO |
40 |
#endif |
41 |
#endif |
42 |
43 |
CUBE thescene; /* our scene */ |
44 |
OBJECT nsceneobjs; /* number of objects in our scene */ |
45 |
46 |
int dimlist[MAXDIM]; /* sampling dimensions */ |
47 |
int ndims = 0; /* number of sampling dimensions */ |
48 |
int samplendx; /* sample index number */ |
49 |
50 |
//extern void ambnotify(); |
51 |
void (*addobjnotify[])() = {ambnotify, NULL}; |
52 |
53 |
VIEW ourview = STDVIEW; /* view parameters */ |
54 |
int hresolu = 512; /* horizontal resolution */ |
55 |
int vresolu = 512; /* vertical resolution */ |
56 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
57 |
58 |
int psample = 4; /* pixel sample size */ |
59 |
double maxdiff = .05; /* max. difference for interpolation */ |
60 |
double dstrpix = 0.67; /* square pixel distribution */ |
61 |
62 |
double mblur = 0.; /* motion blur parameter */ |
63 |
64 |
void (*trace)() = NULL; /* trace call */ |
65 |
66 |
int do_irrad = 0; /* compute irradiance? */ |
67 |
68 |
double dstrsrc = 0.0; /* square source distribution */ |
69 |
double shadthresh = .05; /* shadow threshold */ |
70 |
double shadcert = .5; /* shadow certainty */ |
71 |
int directrelay = 1; /* number of source relays */ |
72 |
int vspretest = 512; /* virtual source pretest density */ |
73 |
int directvis = 1; /* sources visible? */ |
74 |
double srcsizerat = .25; /* maximum ratio source size/dist. */ |
75 |
76 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ |
77 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */ |
78 |
double seccg = 0.; /* global scattering eccentricity */ |
79 |
double ssampdist = 0.; /* scatter sampling distance */ |
80 |
81 |
double specthresh = .15; /* specular sampling threshold */ |
82 |
double specjitter = 1.; /* specular sampling jitter */ |
83 |
84 |
int backvis = 1; /* back face visibility */ |
85 |
86 |
int maxdepth = 7; /* maximum recursion depth */ |
87 |
double minweight = 4e-3; /* minimum ray weight */ |
88 |
89 |
char *ambfile = NULL; /* ambient file name */ |
90 |
COLOR ambval = BLKCOLOR; /* ambient value */ |
91 |
int ambvwt = 0; /* initial weight for ambient value */ |
92 |
double ambacc = 0.2; /* ambient accuracy */ |
93 |
int ambres = 64; /* ambient resolution */ |
94 |
int ambdiv = 512; /* ambient divisions */ |
95 |
int ambssamp = 128; /* ambient super-samples */ |
96 |
int ambounce = 0; /* ambient bounces */ |
97 |
char *amblist[128]; /* ambient include/exclude list */ |
98 |
int ambincl = -1; /* include == 1, exclude == 0 */ |
99 |
100 |
int ralrm = 0; /* seconds between reports */ |
101 |
102 |
double pctdone = 0.0; /* percentage done */ |
103 |
time_t tlastrept = 0L; /* time at last report */ |
104 |
time_t tstart; /* starting time */ |
105 |
106 |
#define MAXDIV 16 /* maximum sample size */ |
107 |
108 |
#define pixjitter() (.5+dstrpix*(.5-frandom())) |
109 |
110 |
int hres, vres; /* resolution for this frame */ |
111 |
112 |
static VIEW lastview; /* the previous view input */ |
113 |
114 |
//extern char *mktemp(); /* XXX should be in stdlib.h or unistd.h */ |
115 |
116 |
//double pixvalue(); |
117 |
118 |
static void report(int); |
119 |
static int nextview(FILE *fp); |
120 |
static void render(char *zfile, char *oldfile); |
121 |
static void fillscanline(COLOR *scanline, float *zline, char *sd, int xres, |
122 |
int y, int xstep); |
123 |
static void fillscanbar(COLOR *scanbar[], float *zbar[], int xres, |
124 |
int y, int ysize); |
125 |
static int fillsample(COLOR *colline, float *zline, int x, int y, |
126 |
int xlen, int ylen, int b); |
127 |
static double pixvalue(COLOR col, int x, int y); |
128 |
static int salvage(char *oldfile); |
129 |
static int pixnumber(int x, int y, int xres, int yres); |
130 |
131 |
132 |
133 |
#ifdef RHAS_STAT |
134 |
135 |
#include <sys/stat.h> |
136 |
int |
137 |
file_exists(fname) /* ordinary file exists? */ |
138 |
char *fname; |
139 |
140 |
struct stat sbuf; |
141 |
if (stat(fname, &sbuf) < 0) return(0); |
142 |
return((sbuf.st_mode & S_IFREG) != 0); |
143 |
144 |
#else |
145 |
#define file_exists(f) (access(f,F_OK)==0) |
146 |
#endif |
147 |
148 |
149 |
void |
150 |
quit(code) /* quit program */ |
151 |
int code; |
152 |
153 |
if (code) /* report status */ |
154 |
report(0); |
155 |
#ifndef NON_POSIX |
156 |
headclean(); /* delete header file */ |
157 |
pfclean(); /* clean up persist files */ |
158 |
#endif |
159 |
exit(code); |
160 |
161 |
162 |
163 |
#ifndef NON_POSIX |
164 |
static void |
165 |
report(int dummy) /* report progress */ |
166 |
167 |
double u, s; |
168 |
#ifdef BSD |
169 |
struct rusage rubuf; |
170 |
#else |
171 |
struct tms tbuf; |
172 |
double period; |
173 |
#endif |
174 |
175 |
tlastrept = time((time_t *)NULL); |
176 |
#ifdef BSD |
177 |
getrusage(RUSAGE_SELF, &rubuf); |
178 |
u = rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; |
179 |
s = rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; |
180 |
getrusage(RUSAGE_CHILDREN, &rubuf); |
181 |
u += rubuf.ru_utime.tv_sec + rubuf.ru_utime.tv_usec/1e6; |
182 |
s += rubuf.ru_stime.tv_sec + rubuf.ru_stime.tv_usec/1e6; |
183 |
#else |
184 |
times(&tbuf); |
185 |
#ifdef _SC_CLK_TCK |
186 |
period = 1.0 / sysconf(_SC_CLK_TCK); |
187 |
#else |
188 |
period = 1.0 / 60.0; |
189 |
#endif |
190 |
u = ( tbuf.tms_utime + tbuf.tms_cutime ) * period; |
191 |
s = ( tbuf.tms_stime + tbuf.tms_cstime ) * period; |
192 |
#endif |
193 |
194 |
sprintf(errmsg, |
195 |
"%lu rays, %4.2f%% after %.3fu %.3fs %.3fr hours on %s\n", |
196 |
nrays, pctdone, u/3600., s/3600., |
197 |
(tlastrept-tstart)/3600., myhostname()); |
198 |
eputs(errmsg); |
199 |
#ifdef SIGCONT |
200 |
signal(SIGCONT, report); |
201 |
#endif |
202 |
203 |
#else |
204 |
static void |
205 |
206 |
207 |
208 |
sprintf(errmsg, "%lu rays, %4.2f%% after %5.4f hours\n", |
209 |
nrays, pctdone, (tlastrept-tstart)/3600.0); |
210 |
eputs(errmsg); |
211 |
212 |
#endif |
213 |
214 |
215 |
extern void |
216 |
rpict( /* generate image(s) */ |
217 |
int seq, |
218 |
char *pout, |
219 |
char *zout, |
220 |
char *prvr |
221 |
222 |
223 |
* If seq is greater than zero, then we will render a sequence of |
224 |
* images based on view parameter strings read from the standard input. |
225 |
* If pout is NULL, then all images will be sent to the standard ouput. |
226 |
* If seq is greater than zero and prvr is an integer, then it is the |
227 |
* frame number at which rendering should begin. Preceeding view parameter |
228 |
* strings will be skipped in the input. |
229 |
* If pout and prvr are the same, prvr is renamed to avoid overwriting. |
230 |
* Note that pout and zout should contain %d format specifications for |
231 |
* sequenced file naming. |
232 |
233 |
234 |
char fbuf[128], fbuf2[128]; |
235 |
int npicts; |
236 |
register char *cp; |
237 |
RESOLU rs; |
238 |
double pa; |
239 |
/* check sampling */ |
240 |
if (psample < 1) |
241 |
psample = 1; |
242 |
else if (psample > MAXDIV) { |
243 |
sprintf(errmsg, "pixel sampling reduced from %d to %d", |
244 |
psample, MAXDIV); |
245 |
error(WARNING, errmsg); |
246 |
psample = MAXDIV; |
247 |
248 |
/* get starting frame */ |
249 |
if (seq <= 0) |
250 |
seq = 0; |
251 |
else if (prvr != NULL && isint(prvr)) { |
252 |
register int rn; /* skip to specified view */ |
253 |
if ((rn = atoi(prvr)) < seq) |
254 |
error(USER, "recover frame less than start frame"); |
255 |
if (pout == NULL) |
256 |
error(USER, "missing output file specification"); |
257 |
for ( ; seq < rn; seq++) |
258 |
if (nextview(stdin) == EOF) |
259 |
error(USER, "unexpected EOF on view input"); |
260 |
setview(&ourview); |
261 |
prvr = fbuf; /* mark for renaming */ |
262 |
263 |
if ((pout != NULL) & (prvr != NULL)) { |
264 |
sprintf(fbuf, pout, seq); |
265 |
if (!strcmp(prvr, fbuf)) { /* rename */ |
266 |
strcpy(fbuf2, fbuf); |
267 |
for (cp = fbuf2; *cp; cp++) |
268 |
269 |
while (cp > fbuf2 && !ISDIRSEP(cp[-1])) |
270 |
cp--; |
271 |
strcpy(cp, RFTEMPLATE); |
272 |
prvr = mktemp(fbuf2); |
273 |
if (rename(fbuf, prvr) < 0) { |
274 |
if (errno == ENOENT) { /* ghost file */ |
275 |
sprintf(errmsg, |
276 |
"new output file \"%s\"", |
277 |
fbuf); |
278 |
279 |
prvr = NULL; |
280 |
} else { /* serious error */ |
281 |
sprintf(errmsg, |
282 |
"cannot rename \"%s\" to \"%s\"", |
283 |
fbuf, prvr); |
284 |
error(SYSTEM, errmsg); |
285 |
286 |
287 |
288 |
289 |
npicts = 0; /* render sequence */ |
290 |
do { |
291 |
if (seq && nextview(stdin) == EOF) |
292 |
break; |
293 |
pctdone = 0.0; |
294 |
if (pout != NULL) { |
295 |
296 |
if (file_exists(fbuf)) { |
297 |
if (prvr != NULL || !strcmp(fbuf, pout)) { |
298 |
sprintf(errmsg, |
299 |
"output file \"%s\" exists", |
300 |
fbuf); |
301 |
error(USER, errmsg); |
302 |
303 |
304 |
continue; /* don't clobber */ |
305 |
306 |
if (freopen(fbuf, "w", stdout) == NULL) { |
307 |
sprintf(errmsg, |
308 |
"cannot open output file \"%s\"", fbuf); |
309 |
310 |
311 |
SET_FILE_BINARY(stdout); |
312 |
dupheader(); |
313 |
314 |
hres = hresolu; vres = vresolu; pa = pixaspect; |
315 |
if (prvr != NULL) { |
316 |
if (viewfile(prvr, &ourview, &rs) <= 0) { |
317 |
sprintf(errmsg, |
318 |
"cannot recover view parameters from \"%s\"", prvr); |
319 |
320 |
} else { |
321 |
pa = 0.0; |
322 |
hres = scanlen(&rs); |
323 |
vres = numscans(&rs); |
324 |
325 |
326 |
if ((cp = setview(&ourview)) != NULL) |
327 |
error(USER, cp); |
328 |
normaspect(viewaspect(&ourview), &pa, &hres, &vres); |
329 |
if (seq) { |
330 |
if (ralrm > 0) { |
331 |
fprintf(stderr, "FRAME %d:", seq); |
332 |
fprintview(&ourview, stderr); |
333 |
putc('\n', stderr); |
334 |
fflush(stderr); |
335 |
336 |
printf("FRAME=%d\n", seq); |
337 |
338 |
fputs(VIEWSTR, stdout); |
339 |
fprintview(&ourview, stdout); |
340 |
putchar('\n'); |
341 |
if (pa < .99 || pa > 1.01) |
342 |
fputaspect(pa, stdout); |
343 |
fputnow(stdout); |
344 |
fputformat(COLRFMT, stdout); |
345 |
putchar('\n'); |
346 |
if (zout != NULL) |
347 |
sprintf(cp=fbuf, zout, seq); |
348 |
else |
349 |
cp = NULL; |
350 |
render(cp, prvr); |
351 |
prvr = NULL; |
352 |
npicts++; |
353 |
} while (seq++); |
354 |
/* check that we did something */ |
355 |
if (npicts == 0) |
356 |
error(WARNING, "no output produced"); |
357 |
358 |
359 |
360 |
static int |
361 |
nextview( /* get next view from fp */ |
362 |
FILE *fp |
363 |
364 |
365 |
char linebuf[256]; |
366 |
367 |
lastview = ourview; |
368 |
while (fgets(linebuf, sizeof(linebuf), fp) != NULL) |
369 |
if (isview(linebuf) && sscanview(&ourview, linebuf) > 0) |
370 |
return(0); |
371 |
return(EOF); |
372 |
373 |
374 |
375 |
static void |
376 |
render( /* render the scene */ |
377 |
char *zfile, |
378 |
char *oldfile |
379 |
380 |
381 |
COLOR *scanbar[MAXDIV+1]; /* scanline arrays of pixel values */ |
382 |
float *zbar[MAXDIV+1]; /* z values */ |
383 |
char *sampdens; /* previous sample density */ |
384 |
int ypos; /* current scanline */ |
385 |
int ystep; /* current y step size */ |
386 |
int hstep; /* h step size */ |
387 |
int zfd; |
388 |
COLOR *colptr; |
389 |
float *zptr; |
390 |
register int i; |
391 |
/* check for empty image */ |
392 |
if (hres <= 0 || vres <= 0) { |
393 |
error(WARNING, "empty output picture"); |
394 |
fprtresolu(0, 0, stdout); |
395 |
return; |
396 |
397 |
/* allocate scanlines */ |
398 |
for (i = 0; i <= psample; i++) { |
399 |
scanbar[i] = (COLOR *)malloc(hres*sizeof(COLOR)); |
400 |
if (scanbar[i] == NULL) |
401 |
goto memerr; |
402 |
403 |
hstep = (psample*140+49)/99; /* quincunx sampling */ |
404 |
ystep = (psample*99+70)/140; |
405 |
if (hstep > 2) { |
406 |
i = hres/hstep + 2; |
407 |
if ((sampdens = (char *)malloc(i)) == NULL) |
408 |
goto memerr; |
409 |
while (i--) |
410 |
sampdens[i] = hstep; |
411 |
} else |
412 |
sampdens = NULL; |
413 |
/* open z-file */ |
414 |
if (zfile != NULL) { |
415 |
if ((zfd = open(zfile, O_WRONLY|O_CREAT, 0666)) == -1) { |
416 |
sprintf(errmsg, "cannot open z-file \"%s\"", zfile); |
417 |
418 |
419 |
SET_FD_BINARY(zfd); |
420 |
421 |
zbar[i] = (float *)malloc(hres*sizeof(float)); |
422 |
if (zbar[i] == NULL) |
423 |
goto memerr; |
424 |
425 |
} else { |
426 |
zfd = -1; |
427 |
for (i = 0; i <= psample; i++) |
428 |
zbar[i] = NULL; |
429 |
430 |
/* write out boundaries */ |
431 |
fprtresolu(hres, vres, stdout); |
432 |
/* recover file and compute first */ |
433 |
i = salvage(oldfile); |
434 |
if (i >= vres) |
435 |
goto alldone; |
436 |
if (zfd != -1 && i > 0 && |
437 |
lseek(zfd, (off_t)i*hres*sizeof(float), SEEK_SET) < 0) |
438 |
error(SYSTEM, "z-file seek error in render"); |
439 |
pctdone = 100.0*i/vres; |
440 |
if (ralrm > 0) /* report init stats */ |
441 |
report(0); |
442 |
#ifdef SIGCONT |
443 |
else |
444 |
445 |
#endif |
446 |
ypos = vres-1 - i; /* initialize sampling */ |
447 |
if (directvis) |
448 |
init_drawsources(psample); |
449 |
fillscanline(scanbar[0], zbar[0], sampdens, hres, ypos, hstep); |
450 |
/* compute scanlines */ |
451 |
for (ypos -= ystep; ypos > -ystep; ypos -= ystep) { |
452 |
/* bottom adjust? */ |
453 |
if (ypos < 0) { |
454 |
ystep += ypos; |
455 |
ypos = 0; |
456 |
457 |
colptr = scanbar[ystep]; /* move base to top */ |
458 |
scanbar[ystep] = scanbar[0]; |
459 |
scanbar[0] = colptr; |
460 |
zptr = zbar[ystep]; |
461 |
zbar[ystep] = zbar[0]; |
462 |
zbar[0] = zptr; |
463 |
/* fill base line */ |
464 |
fillscanline(scanbar[0], zbar[0], sampdens, |
465 |
466 |
/* fill bar */ |
467 |
fillscanbar(scanbar, zbar, hres, ypos, ystep); |
468 |
if (directvis) /* add bitty sources */ |
469 |
drawsources(scanbar, zbar, 0, hres, ypos, ystep); |
470 |
/* write it out */ |
471 |
#ifdef SIGCONT |
472 |
signal(SIGCONT, SIG_IGN); /* don't interrupt writes */ |
473 |
#endif |
474 |
for (i = ystep; i > 0; i--) { |
475 |
if (zfd != -1 && write(zfd, (char *)zbar[i], |
476 |
hres*sizeof(float)) |
477 |
< hres*sizeof(float)) |
478 |
goto writerr; |
479 |
if (fwritescan(scanbar[i], hres, stdout) < 0) |
480 |
goto writerr; |
481 |
482 |
if (fflush(stdout) == EOF) |
483 |
goto writerr; |
484 |
/* record progress */ |
485 |
pctdone = 100.0*(vres-1-ypos)/vres; |
486 |
if (ralrm > 0 && time((time_t *)NULL) >= tlastrept+ralrm) |
487 |
report(0); |
488 |
#ifdef SIGCONT |
489 |
else |
490 |
491 |
#endif |
492 |
493 |
/* clean up */ |
494 |
#ifdef SIGCONT |
495 |
signal(SIGCONT, SIG_IGN); |
496 |
#endif |
497 |
if (zfd != -1 && write(zfd, (char *)zbar[0], hres*sizeof(float)) |
498 |
499 |
goto writerr; |
500 |
fwritescan(scanbar[0], hres, stdout); |
501 |
502 |
goto writerr; |
503 |
alldone: |
504 |
if (zfd != -1) { |
505 |
if (close(zfd) == -1) |
506 |
goto writerr; |
507 |
508 |
free((void *)zbar[i]); |
509 |
510 |
511 |
free((void *)scanbar[i]); |
512 |
if (sampdens != NULL) |
513 |
free(sampdens); |
514 |
pctdone = 100.0; |
515 |
if (ralrm > 0) |
516 |
report(0); |
517 |
#ifdef SIGCONT |
518 |
signal(SIGCONT, SIG_DFL); |
519 |
#endif |
520 |
return; |
521 |
writerr: |
522 |
error(SYSTEM, "write error in render"); |
523 |
memerr: |
524 |
error(SYSTEM, "out of memory in render"); |
525 |
526 |
527 |
528 |
static void |
529 |
fillscanline( /* fill scan at y */ |
530 |
register COLOR *scanline, |
531 |
register float *zline, |
532 |
register char *sd, |
533 |
int xres, |
534 |
int y, |
535 |
int xstep |
536 |
537 |
538 |
static int nc = 0; /* number of calls */ |
539 |
int bl = xstep, b = xstep; |
540 |
double z; |
541 |
register int i; |
542 |
543 |
z = pixvalue(scanline[0], 0, y); |
544 |
if (zline) zline[0] = z; |
545 |
/* zig-zag start for quincunx pattern */ |
546 |
for (i = ++nc & 1 ? xstep : xstep/2; i < xres-1+xstep; i += xstep) { |
547 |
if (i >= xres) { |
548 |
xstep += xres-1-i; |
549 |
i = xres-1; |
550 |
551 |
z = pixvalue(scanline[i], i, y); |
552 |
if (zline) zline[i] = z; |
553 |
if (sd) b = sd[0] > sd[1] ? sd[0] : sd[1]; |
554 |
if (i <= xstep) |
555 |
b = fillsample(scanline, zline, 0, y, i, 0, b/2); |
556 |
else |
557 |
b = fillsample(scanline+i-xstep, |
558 |
zline ? zline+i-xstep : (float *)NULL, |
559 |
i-xstep, y, xstep, 0, b/2); |
560 |
if (sd) *sd++ = nc & 1 ? bl : b; |
561 |
bl = b; |
562 |
563 |
if (sd && nc & 1) *sd = bl; |
564 |
565 |
566 |
567 |
static void |
568 |
fillscanbar( /* fill interior */ |
569 |
register COLOR *scanbar[], |
570 |
register float *zbar[], |
571 |
int xres, |
572 |
int y, |
573 |
int ysize |
574 |
575 |
576 |
COLOR vline[MAXDIV+1]; |
577 |
float zline[MAXDIV+1]; |
578 |
int b = ysize; |
579 |
register int i, j; |
580 |
581 |
for (i = 0; i < xres; i++) { |
582 |
copycolor(vline[0], scanbar[0][i]); |
583 |
copycolor(vline[ysize], scanbar[ysize][i]); |
584 |
if (zbar[0]) { |
585 |
zline[0] = zbar[0][i]; |
586 |
zline[ysize] = zbar[ysize][i]; |
587 |
588 |
b = fillsample(vline, zbar[0] ? zline : (float *)NULL, |
589 |
i, y, 0, ysize, b/2); |
590 |
591 |
for (j = 1; j < ysize; j++) |
592 |
copycolor(scanbar[j][i], vline[j]); |
593 |
if (zbar[0]) |
594 |
595 |
zbar[j][i] = zline[j]; |
596 |
597 |
598 |
599 |
600 |
static int |
601 |
fillsample( /* fill interior points */ |
602 |
register COLOR *colline, |
603 |
604 |
int x, |
605 |
int y, |
606 |
int xlen, |
607 |
int ylen, |
608 |
int b |
609 |
610 |
611 |
double ratio; |
612 |
double z; |
613 |
COLOR ctmp; |
614 |
int ncut; |
615 |
register int len; |
616 |
617 |
if (xlen > 0) /* x or y length is zero */ |
618 |
len = xlen; |
619 |
else |
620 |
len = ylen; |
621 |
622 |
if (len <= 1) /* limit recursion */ |
623 |
return(0); |
624 |
625 |
if (b > 0 || |
626 |
(zline && 2.*fabs(zline[0]-zline[len]) > maxdiff*(zline[0]+zline[len])) |
627 |
|| bigdiff(colline[0], colline[len], maxdiff)) { |
628 |
629 |
z = pixvalue(colline[len>>1], x + (xlen>>1), y + (ylen>>1)); |
630 |
if (zline) zline[len>>1] = z; |
631 |
ncut = 1; |
632 |
} else { /* interpolate */ |
633 |
copycolor(colline[len>>1], colline[len]); |
634 |
ratio = (double)(len>>1) / len; |
635 |
scalecolor(colline[len>>1], ratio); |
636 |
if (zline) zline[len>>1] = zline[len] * ratio; |
637 |
ratio = 1.0 - ratio; |
638 |
copycolor(ctmp, colline[0]); |
639 |
scalecolor(ctmp, ratio); |
640 |
addcolor(colline[len>>1], ctmp); |
641 |
if (zline) zline[len>>1] += zline[0] * ratio; |
642 |
ncut = 0; |
643 |
644 |
/* recurse */ |
645 |
ncut += fillsample(colline, zline, x, y, xlen>>1, ylen>>1, (b-1)/2); |
646 |
647 |
ncut += fillsample(colline+(len>>1), |
648 |
zline ? zline+(len>>1) : (float *)NULL, |
649 |
x+(xlen>>1), y+(ylen>>1), |
650 |
xlen-(xlen>>1), ylen-(ylen>>1), b/2); |
651 |
652 |
return(ncut); |
653 |
654 |
655 |
656 |
static double |
657 |
pixvalue( /* compute pixel value */ |
658 |
COLOR col, /* returned color */ |
659 |
int x, /* pixel position */ |
660 |
int y |
661 |
662 |
663 |
RAY thisray; |
664 |
FVECT lorg, ldir; |
665 |
double hpos, vpos, lmax; |
666 |
/* compute view ray */ |
667 |
hpos = (x+pixjitter())/hres; |
668 |
vpos = (y+pixjitter())/vres; |
669 |
if ((thisray.rmax = viewray(thisray.rorg, thisray.rdir, |
670 |
&ourview, hpos, vpos)) < -FTINY) { |
671 |
setcolor(col, 0.0, 0.0, 0.0); |
672 |
return(0.0); |
673 |
674 |
675 |
samplendx = pixnumber(x,y,hres,vres); /* set pixel index */ |
676 |
677 |
/* optional motion blur */ |
678 |
if (lastview.type && mblur > FTINY && (lmax = viewray(lorg, ldir, |
679 |
&lastview, hpos, vpos)) >= -FTINY) { |
680 |
register int i; |
681 |
register double d = mblur*(.5-urand(281+samplendx)); |
682 |
683 |
thisray.rmax = (1.-d)*thisray.rmax + d*lmax; |
684 |
for (i = 3; i--; ) { |
685 |
thisray.rorg[i] = (1.-d)*thisray.rorg[i] + d*lorg[i]; |
686 |
thisray.rdir[i] = (1.-d)*thisray.rdir[i] + d*ldir[i]; |
687 |
688 |
if (normalize(thisray.rdir) == 0.0) |
689 |
return(0.0); |
690 |
691 |
692 |
rayorigin(&thisray, NULL, PRIMARY, 1.0); |
693 |
694 |
rayvalue(&thisray); /* trace ray */ |
695 |
696 |
copycolor(col, thisray.rcol); /* return color */ |
697 |
698 |
return(thisray.rt); /* return distance */ |
699 |
700 |
701 |
702 |
static int |
703 |
salvage( /* salvage scanlines from killed program */ |
704 |
char *oldfile |
705 |
706 |
707 |
COLR *scanline; |
708 |
FILE *fp; |
709 |
int x, y; |
710 |
711 |
if (oldfile == NULL) |
712 |
goto gotzip; |
713 |
714 |
if ((fp = fopen(oldfile, "r")) == NULL) { |
715 |
sprintf(errmsg, "cannot open recover file \"%s\"", oldfile); |
716 |
717 |
goto gotzip; |
718 |
719 |
SET_FILE_BINARY(fp); |
720 |
/* discard header */ |
721 |
getheader(fp, NULL, NULL); |
722 |
/* get picture size */ |
723 |
if (!fscnresolu(&x, &y, fp)) { |
724 |
sprintf(errmsg, "bad recover file \"%s\" - not removed", |
725 |
oldfile); |
726 |
727 |
fclose(fp); |
728 |
goto gotzip; |
729 |
730 |
731 |
if (x != hres || y != vres) { |
732 |
sprintf(errmsg, "resolution mismatch in recover file \"%s\"", |
733 |
oldfile); |
734 |
735 |
736 |
737 |
scanline = (COLR *)malloc(hres*sizeof(COLR)); |
738 |
if (scanline == NULL) |
739 |
error(SYSTEM, "out of memory in salvage"); |
740 |
for (y = 0; y < vres; y++) { |
741 |
if (freadcolrs(scanline, hres, fp) < 0) |
742 |
break; |
743 |
if (fwritecolrs(scanline, hres, stdout) < 0) |
744 |
goto writerr; |
745 |
746 |
747 |
goto writerr; |
748 |
free((void *)scanline); |
749 |
fclose(fp); |
750 |
unlink(oldfile); |
751 |
return(y); |
752 |
gotzip: |
753 |
754 |
error(SYSTEM, "error writing picture header"); |
755 |
return(0); |
756 |
writerr: |
757 |
sprintf(errmsg, "write error during recovery of \"%s\"", oldfile); |
758 |
759 |
return -1; /* pro forma return */ |
760 |
761 |
762 |
763 |
static int |
764 |
pixnumber( /* compute pixel index (brushed) */ |
765 |
register int x, |
766 |
register int y, |
767 |
int xres, |
768 |
int yres |
769 |
770 |
771 |
x -= y; |
772 |
while (x < 0) |
773 |
x += xres; |
774 |
return((((x>>2)*yres + y) << 2) + (x & 3)); |
775 |
