| 1 |
/* RCSid $Id: rpaint.h,v 2.11 2013/11/13 23:45:54 greg Exp $ */
| 2 |
| 3 |
* rpaint.h - header file for image painting.
| 4 |
| 5 |
#ifndef _RAD_RPAINT_H_
| 6 |
#define _RAD_RPAINT_H_
| 7 |
| 8 |
#include "driver.h"
| 9 |
#include "view.h"
| 10 |
| 11 |
#ifdef __cplusplus
| 12 |
extern "C" {
| 13 |
#endif
| 14 |
| 15 |
#if defined(_WIN32) || defined(_WIN64)
| 16 |
/* stupid Windows name collisions */
| 17 |
#undef COORD
| 18 |
#define COORD radCOORD
| 19 |
#undef RECT
| 20 |
#define RECT radRECT
| 21 |
#endif
| 22 |
| 23 |
typedef short COORD; /* an image coordinate */
| 24 |
| 25 |
typedef struct pnode {
| 26 |
struct pnode *kid; /* children */
| 27 |
COORD x, y; /* position */
| 28 |
COORD xmin, ymin, xmax, ymax; /* rectangle */
| 29 |
COLOR v; /* value */
| 30 |
} PNODE; /* a paint node */
| 31 |
| 32 |
/* child ordering */
| 33 |
#define DL 0 /* down left */
| 34 |
#define DR 1 /* down right */
| 35 |
#define UL 2 /* up left */
| 36 |
#define UR 3 /* up right */
| 37 |
| 38 |
#define newptree() (PNODE *)calloc(4, sizeof(PNODE))
| 39 |
| 40 |
typedef struct {
| 41 |
COORD l, d, r, u; /* left, down, right, up */
| 42 |
} RECT; /* a rectangle */
| 43 |
| 44 |
extern PNODE ptrunk; /* the base of the image tree */
| 45 |
| 46 |
extern VIEW ourview; /* current view parameters */
| 47 |
extern VIEW oldview; /* previous view parameters */
| 48 |
extern int hresolu, vresolu; /* image resolution */
| 49 |
| 50 |
extern int newparam; /* parameter setting changed */
| 51 |
| 52 |
extern char *dvcname; /* output device name */
| 53 |
| 54 |
extern char rifname[]; /* rad input file name */
| 55 |
| 56 |
extern int psample; /* pixel sample size */
| 57 |
extern double maxdiff; /* max. sample difference */
| 58 |
| 59 |
extern int greyscale; /* map colors to brightness? */
| 60 |
| 61 |
extern int pdepth; /* image depth in current frame */
| 62 |
extern RECT pframe; /* current frame rectangle */
| 63 |
| 64 |
extern double exposure; /* exposure for scene */
| 65 |
| 66 |
extern struct driver *dev; /* driver functions */
| 67 |
| 68 |
extern int nproc; /* number of processes */
| 69 |
| 70 |
/* defined in rview.c */
| 71 |
extern void devopen(char *dname);
| 72 |
extern void devclose(void);
| 73 |
extern void printdevices(void);
| 74 |
extern void command(char *prompt);
| 75 |
extern void rsample(void);
| 76 |
extern int refine(PNODE *p, int pd);
| 77 |
/* defined in rv2.c */
| 78 |
extern void getframe(char *s);
| 79 |
extern void getrepaint(char *s);
| 80 |
extern void getview(char *s);
| 81 |
extern void lastview(char *s);
| 82 |
extern void saveview(char *s);
| 83 |
extern void loadview(char *s);
| 84 |
extern void getfocus(char *s);
| 85 |
extern void getaim(char *s);
| 86 |
extern void getmove(char *s);
| 87 |
extern void getrotate(char *s);
| 88 |
extern void getpivot(char *s);
| 89 |
extern void getorigin(char *s);
| 90 |
extern void getexposure(char *s);
| 91 |
extern int getparam(char *str, char *dsc, int typ, void *p);
| 92 |
extern void setparam(char *s);
| 93 |
extern void traceray(char *s);
| 94 |
extern void writepict(char *s);
| 95 |
/* defined in rv3.c */
| 96 |
extern int getrect(char *s, RECT *r);
| 97 |
extern int getinterest(char *s, int direc, FVECT vec, double *mp);
| 98 |
extern float *greyof(COLOR col);
| 99 |
extern int paint(PNODE *p);
| 100 |
extern int waitrays(void);
| 101 |
extern void newimage(char *s);
| 102 |
extern void redraw(void);
| 103 |
extern void repaint(int xmin, int ymin, int xmax, int ymax);
| 104 |
extern void paintrect(PNODE *p, RECT *r);
| 105 |
extern PNODE *findrect(int x, int y, PNODE *p, int pd);
| 106 |
extern void compavg(PNODE *p);
| 107 |
extern void scalepict(PNODE *p, double sf);
| 108 |
extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
| 109 |
int xsiz, int ysiz);
| 110 |
extern void freepkids(PNODE *p);
| 111 |
extern void newview(VIEW *vp);
| 112 |
extern void moveview(double angle, double elev, double mag, FVECT vc);
| 113 |
extern void pcopy(PNODE *p1, PNODE *p2);
| 114 |
extern void zoomview(VIEW *vp, double zf);
| 115 |
| 116 |
| 117 |
#ifdef __cplusplus
| 118 |
| 119 |
#endif
| 120 |
#endif /* _RAD_RPAINT_H_ */
| 121 |
