root/radiance/ray/src/rt/rpaint.h
Revision: 2.8
Committed: Thu Aug 21 07:05:59 2008 UTC (16 years, 10 months ago) by greg
Changes since 2.7: +19 -10 lines
1 /* RCSid $Id: rpaint.h,v 2.7 2005/01/21 00:52:59 greg Exp $ */
2 /*
3 * rpaint.h - header file for image painting.
4 */
5 #ifndef _RAD_RPAINT_H_
6 #define _RAD_RPAINT_H_
7
8 #include "driver.h"
9 #include "view.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 typedef short COORD; /* an image coordinate */
16
17 typedef struct pnode {
18 struct pnode *kid; /* children */
19 COORD x, y; /* position */
20 COORD xmin, ymin, xmax, ymax; /* rectangle */
21 COLOR v; /* value */
22 } PNODE; /* a paint node */
23
24 /* child ordering */
25 #define DL 0 /* down left */
26 #define DR 1 /* down right */
27 #define UL 2 /* up left */
28 #define UR 3 /* up right */
29
30 #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
31
32 typedef struct {
33 COORD l, d, r, u; /* left, down, right, up */
34 } RECT; /* a rectangle */
35
36 extern PNODE ptrunk; /* the base of the image tree */
37
38 extern VIEW ourview; /* current view parameters */
39 extern VIEW oldview; /* previous view parameters */
40 extern int hresolu, vresolu; /* image resolution */
41
42 extern int newparam; /* parameter setting changed */
43
44 extern char *dvcname; /* output device name */
45
46 extern char rifname[]; /* rad input file name */
47
48 extern int psample; /* pixel sample size */
49 extern double maxdiff; /* max. sample difference */
50
51 extern int greyscale; /* map colors to brightness? */
52
53 extern int pdepth; /* image depth in current frame */
54 extern RECT pframe; /* current frame rectangle */
55
56 extern double exposure; /* exposure for scene */
57
58 extern struct driver *dev; /* driver functions */
59
60 extern int nproc; /* number of processes */
61
62 /* defined in rview.c */
63 extern void devopen(char *dname);
64 extern void devclose(void);
65 extern void printdevices(void);
66 extern void command(char *prompt);
67 extern void rsample(void);
68 extern int refine(PNODE *p, int pd);
69 /* defined in rv2.c */
70 extern void getframe(char *s);
71 extern void getrepaint(char *s);
72 extern void getview(char *s);
73 extern void lastview(char *s);
74 extern void saveview(char *s);
75 extern void loadview(char *s);
76 extern void getfocus(char *s);
77 extern void getaim(char *s);
78 extern void getmove(char *s);
79 extern void getrotate(char *s);
80 extern void getpivot(char *s);
81 extern void getexposure(char *s);
82 extern int getparam(char *str, char *dsc, int typ, void *p);
83 extern void setparam(char *s);
84 extern void traceray(char *s);
85 extern void writepict(char *s);
86 /* defined in rv3.c */
87 extern int getrect(char *s, RECT *r);
88 extern int getinterest(char *s, int direc, FVECT vec, double *mp);
89 extern float *greyof(COLOR col);
90 extern int paint(PNODE *p);
91 extern int waitrays(void);
92 extern void newimage(char *s);
93 extern void redraw(void);
94 extern void repaint(int xmin, int ymin, int xmax, int ymax);
95 extern void paintrect(PNODE *p, RECT *r);
96 extern PNODE *findrect(int x, int y, PNODE *p, int pd);
97 extern void scalepict(PNODE *p, double sf);
98 extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
99 int xsiz, int ysiz);
100 extern void freepkids(PNODE *p);
101 extern void newview(VIEW *vp);
102 extern void moveview(double angle, double elev, double mag, FVECT vc);
103 extern void pcopy(PNODE *p1, PNODE *p2);
104 extern void zoomview(VIEW *vp, double zf);
105
106
107 #ifdef __cplusplus
108 }
109 #endif
110 #endif /* _RAD_RPAINT_H_ */
111
