--- ray/src/rt/rpaint.h 2003/06/27 06:53:23 2.5 +++ ray/src/rt/rpaint.h 2013/11/13 23:45:54 2.11 @@ -1,22 +1,30 @@ -/* RCSid $Id: rpaint.h,v 2.5 2003/06/27 06:53:23 greg Exp $ */ +/* RCSid $Id: rpaint.h,v 2.11 2013/11/13 23:45:54 greg Exp $ */ /* * rpaint.h - header file for image painting. */ #ifndef _RAD_RPAINT_H_ #define _RAD_RPAINT_H_ + +#include "driver.h" +#include "view.h" + #ifdef __cplusplus extern "C" { #endif -#include "driver.h" +#ifdef _WIN32 /* stupid Windows name collisions */ +#undef COORD +#define COORD radCOORD +#undef RECT +#define RECT radRECT +#endif -#include "view.h" - typedef short COORD; /* an image coordinate */ typedef struct pnode { struct pnode *kid; /* children */ COORD x, y; /* position */ + COORD xmin, ymin, xmax, ymax; /* rectangle */ COLOR v; /* value */ } PNODE; /* a paint node */ @@ -38,6 +46,15 @@ extern VIEW ourview; /* current view parameters */ extern VIEW oldview; /* previous view parameters */ extern int hresolu, vresolu; /* image resolution */ +extern int newparam; /* parameter setting changed */ + +extern char *dvcname; /* output device name */ + +extern char rifname[]; /* rad input file name */ + +extern int psample; /* pixel sample size */ +extern double maxdiff; /* max. sample difference */ + extern int greyscale; /* map colors to brightness? */ extern int pdepth; /* image depth in current frame */ @@ -47,16 +64,15 @@ extern double exposure; /* exposure for scene */ extern struct driver *dev; /* driver functions */ +extern int nproc; /* number of processes */ + /* defined in rview.c */ extern void devopen(char *dname); extern void devclose(void); extern void printdevices(void); -extern void fillreserves(void); -extern void freereserves(void); extern void command(char *prompt); extern void rsample(void); -extern int refine(PNODE *p, int xmin, int ymin, - int xmax, int ymax, int pd); +extern int refine(PNODE *p, int pd); /* defined in rv2.c */ extern void getframe(char *s); extern void getrepaint(char *s); @@ -64,10 +80,12 @@ extern void getview(char *s); extern void lastview(char *s); extern void saveview(char *s); extern void loadview(char *s); +extern void getfocus(char *s); extern void getaim(char *s); extern void getmove(char *s); extern void getrotate(char *s); extern void getpivot(char *s); +extern void getorigin(char *s); extern void getexposure(char *s); extern int getparam(char *str, char *dsc, int typ, void *p); extern void setparam(char *s); @@ -77,13 +95,14 @@ extern void writepict(char *s); extern int getrect(char *s, RECT *r); extern int getinterest(char *s, int direc, FVECT vec, double *mp); extern float *greyof(COLOR col); -extern void paint(PNODE *p, int xmin, int ymin, int xmax, int ymax); -extern void newimage(void); +extern int paint(PNODE *p); +extern int waitrays(void); +extern void newimage(char *s); extern void redraw(void); extern void repaint(int xmin, int ymin, int xmax, int ymax); -extern void paintrect(PNODE *p, int xmin, int ymin, - int xmax, int ymax, RECT *r); -extern PNODE *findrect(int x, int y, PNODE *p, RECT *r, int pd); +extern void paintrect(PNODE *p, RECT *r); +extern PNODE *findrect(int x, int y, PNODE *p, int pd); +extern void compavg(PNODE *p); extern void scalepict(PNODE *p, double sf); extern void getpictcolrs(int yoff, COLR *scan, PNODE *p, int xsiz, int ysiz);
