root/radiance/ray/src/rt/rpaint.h
Revision: 2.10
Committed: Wed Oct 5 17:20:55 2011 UTC (13 years, 10 months ago) by greg
Windows compatibility changes from Bill Hoffman
1 /* RCSid $Id: rpaint.h,v 2.9 2008/09/05 19:45:41 greg Exp $ */
2 /*
3 * rpaint.h - header file for image painting.
4 */
5 #ifndef _RAD_RPAINT_H_
6 #define _RAD_RPAINT_H_
7
8 #include "driver.h"
9 #include "view.h"
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 #ifdef _WIN32 /* stupid Windows name collisions */
16 #undef COORD
17 #define COORD radCOORD
18 #undef RECT
19 #define RECT radRECT
20 #endif
21
22 typedef short COORD; /* an image coordinate */
23
24 typedef struct pnode {
25 struct pnode *kid; /* children */
26 COORD x, y; /* position */
27 COORD xmin, ymin, xmax, ymax; /* rectangle */
28 COLOR v; /* value */
29 } PNODE; /* a paint node */
30
31 /* child ordering */
32 #define DL 0 /* down left */
33 #define DR 1 /* down right */
34 #define UL 2 /* up left */
35 #define UR 3 /* up right */
36
37 #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
38
39 typedef struct {
40 COORD l, d, r, u; /* left, down, right, up */
41 } RECT; /* a rectangle */
42
43 extern PNODE ptrunk; /* the base of the image tree */
44
45 extern VIEW ourview; /* current view parameters */
46 extern VIEW oldview; /* previous view parameters */
47 extern int hresolu, vresolu; /* image resolution */
48
49 extern int newparam; /* parameter setting changed */
50
51 extern char *dvcname; /* output device name */
52
53 extern char rifname[]; /* rad input file name */
54
55 extern int psample; /* pixel sample size */
56 extern double maxdiff; /* max. sample difference */
57
58 extern int greyscale; /* map colors to brightness? */
59
60 extern int pdepth; /* image depth in current frame */
61 extern RECT pframe; /* current frame rectangle */
62
63 extern double exposure; /* exposure for scene */
64
65 extern struct driver *dev; /* driver functions */
66
67 extern int nproc; /* number of processes */
68
69 /* defined in rview.c */
70 extern void devopen(char *dname);
71 extern void devclose(void);
72 extern void printdevices(void);
73 extern void command(char *prompt);
74 extern void rsample(void);
75 extern int refine(PNODE *p, int pd);
76 /* defined in rv2.c */
77 extern void getframe(char *s);
78 extern void getrepaint(char *s);
79 extern void getview(char *s);
80 extern void lastview(char *s);
81 extern void saveview(char *s);
82 extern void loadview(char *s);
83 extern void getfocus(char *s);
84 extern void getaim(char *s);
85 extern void getmove(char *s);
86 extern void getrotate(char *s);
87 extern void getpivot(char *s);
88 extern void getexposure(char *s);
89 extern int getparam(char *str, char *dsc, int typ, void *p);
90 extern void setparam(char *s);
91 extern void traceray(char *s);
92 extern void writepict(char *s);
93 /* defined in rv3.c */
94 extern int getrect(char *s, RECT *r);
95 extern int getinterest(char *s, int direc, FVECT vec, double *mp);
96 extern float *greyof(COLOR col);
97 extern int paint(PNODE *p);
98 extern int waitrays(void);
99 extern void newimage(char *s);
100 extern void redraw(void);
101 extern void repaint(int xmin, int ymin, int xmax, int ymax);
102 extern void paintrect(PNODE *p, RECT *r);
103 extern PNODE *findrect(int x, int y, PNODE *p, int pd);
104 extern void compavg(PNODE *p);
105 extern void scalepict(PNODE *p, double sf);
106 extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
107 int xsiz, int ysiz);
108 extern void freepkids(PNODE *p);
109 extern void newview(VIEW *vp);
110 extern void moveview(double angle, double elev, double mag, FVECT vc);
111 extern void pcopy(PNODE *p1, PNODE *p2);
112 extern void zoomview(VIEW *vp, double zf);
113
114
115 #ifdef __cplusplus
116 }
117 #endif
118 #endif /* _RAD_RPAINT_H_ */
119
