root/Development/ray/src/rt/rpaint.h
Revision: 2.12
Committed: Sun Mar 6 01:13:18 2016 UTC (9 years, 10 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
Changes since 2.11: +7 -6 lines
# User Rev Content
1 schorsch 2.12 /* RCSid $Id: rpaint.h,v 2.11 2013/11/13 23:45:54 greg Exp $ */
2 greg 1.1 /*
3     * rpaint.h - header file for image painting.
4 greg 2.2 */
5 schorsch 2.4 #ifndef _RAD_RPAINT_H_
6     #define _RAD_RPAINT_H_
7 schorsch 2.6
8     #include "driver.h"
9     #include "view.h"
10
11 schorsch 2.4 #ifdef __cplusplus
12     extern "C" {
13     #endif
14 greg 1.1
15 schorsch 2.12 #if defined(_WIN32) || defined(_WIN64)
16     /* stupid Windows name collisions */
17     #undef COORD
18     #define COORD radCOORD
19     #undef RECT
20     #define RECT radRECT
21 greg 2.10 #endif
22
23 greg 1.1 typedef short COORD; /* an image coordinate */
24
25     typedef struct pnode {
26     struct pnode *kid; /* children */
27     COORD x, y; /* position */
28 greg 2.8 COORD xmin, ymin, xmax, ymax; /* rectangle */
29 greg 1.1 COLOR v; /* value */
30     } PNODE; /* a paint node */
31
32     /* child ordering */
33     #define DL 0 /* down left */
34     #define DR 1 /* down right */
35     #define UL 2 /* up left */
36     #define UR 3 /* up right */
37
38     #define newptree() (PNODE *)calloc(4, sizeof(PNODE))
39
40     typedef struct {
41     COORD l, d, r, u; /* left, down, right, up */
42     } RECT; /* a rectangle */
43
44     extern PNODE ptrunk; /* the base of the image tree */
45
46     extern VIEW ourview; /* current view parameters */
47     extern VIEW oldview; /* previous view parameters */
48 greg 1.2 extern int hresolu, vresolu; /* image resolution */
49 greg 1.1
50 greg 2.8 extern int newparam; /* parameter setting changed */
51
52     extern char *dvcname; /* output device name */
53
54     extern char rifname[]; /* rad input file name */
55
56     extern int psample; /* pixel sample size */
57     extern double maxdiff; /* max. sample difference */
58
59 greg 1.1 extern int greyscale; /* map colors to brightness? */
60
61     extern int pdepth; /* image depth in current frame */
62     extern RECT pframe; /* current frame rectangle */
63
64     extern double exposure; /* exposure for scene */
65
66     extern struct driver *dev; /* driver functions */
67
68 greg 2.8 extern int nproc; /* number of processes */
69
70 greg 2.2 /* defined in rview.c */
71     extern void devopen(char *dname);
72     extern void devclose(void);
73     extern void printdevices(void);
74     extern void command(char *prompt);
75     extern void rsample(void);
76 greg 2.8 extern int refine(PNODE *p, int pd);
77 greg 2.2 /* defined in rv2.c */
78     extern void getframe(char *s);
79     extern void getrepaint(char *s);
80     extern void getview(char *s);
81     extern void lastview(char *s);
82     extern void saveview(char *s);
83     extern void loadview(char *s);
84 greg 2.7 extern void getfocus(char *s);
85 greg 2.2 extern void getaim(char *s);
86     extern void getmove(char *s);
87     extern void getrotate(char *s);
88     extern void getpivot(char *s);
89 greg 2.11 extern void getorigin(char *s);
90 greg 2.2 extern void getexposure(char *s);
91     extern int getparam(char *str, char *dsc, int typ, void *p);
92     extern void setparam(char *s);
93     extern void traceray(char *s);
94     extern void writepict(char *s);
95     /* defined in rv3.c */
96     extern int getrect(char *s, RECT *r);
97     extern int getinterest(char *s, int direc, FVECT vec, double *mp);
98     extern float *greyof(COLOR col);
99 greg 2.8 extern int paint(PNODE *p);
100     extern int waitrays(void);
101     extern void newimage(char *s);
102 greg 2.2 extern void redraw(void);
103     extern void repaint(int xmin, int ymin, int xmax, int ymax);
104 greg 2.8 extern void paintrect(PNODE *p, RECT *r);
105     extern PNODE *findrect(int x, int y, PNODE *p, int pd);
106 greg 2.9 extern void compavg(PNODE *p);
107 greg 2.2 extern void scalepict(PNODE *p, double sf);
108     extern void getpictcolrs(int yoff, COLR *scan, PNODE *p,
109     int xsiz, int ysiz);
110     extern void freepkids(PNODE *p);
111     extern void newview(VIEW *vp);
112     extern void moveview(double angle, double elev, double mag, FVECT vc);
113     extern void pcopy(PNODE *p1, PNODE *p2);
114     extern void zoomview(VIEW *vp, double zf);
115
116 schorsch 2.4
117     #ifdef __cplusplus
118     }
119 greg 2.2 #endif
120 schorsch 2.4 #endif /* _RAD_RPAINT_H_ */
121
